AV1630C940
AV1630C940
    APEM(埃斐)
    APEM - AV1630C940 - Vandal Resistant Switch, AV Series, 16.2 mm, SPST-NO, Off-(On), Round Domed, Nat...
AV1630C940 数据手册
AV series V -A SW PANEL SWITCHES M O M 16 9 70 -1 Snap action security pushbutton switches • Ø 16 mm • momentary (NO) DISTINCTIVE FEATURES Momentary (NO) Compact Long life Marking available ENVIRONMENTAL SPECIFICATIONS • Optional front panel sealing : IP65 according to IEC 60529 • Operating temperature : -30 °C to +70 °C (-22 °F to +158 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 200 mA 48 VDC - 100 mA 48 VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 2,000 Vrms 50 Hz min. between terminals and frame • Electrical life : 50,000 cycles at 200 mA 48 VDC 100,000 cycles at 100 mA 48 VDC GENERAL SPECIFICATIONS • Travel : 1.60 mm (.063) ± 0.3 mm (.011) • Torque : 5 Nm min. - 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Low level or mechanical life : 1,000,000 cycles MATERIALS • Case : PBT • Contacts : brass, silver plated (C) • Bushing and actuator : see next page The company reserves the right to change specifications without notice. 1 PANEL SWITCHES AV series Snap action security pushbutton switches • Ø 16 mm • momentary (NO) ELECTRICAL FUNCTIONS Function 3 (NO) MOUNTING • Panel cut-out : Ø 16.2 mm (.637) • Min. pitch for matrix mounting : 24 mm x 24 mm (.944 x .944) (AV6P & AV6B : 20 mm x 20 mm) 2 Snap action security pushbutton switches • Ø 16 mm • momentary (NO) BUILD YOUR PART NUMBER BASIC PART NUMBER AV SERIES BUSHING/ACTUATOR CONFIGURATIONS 06 Flat actuator 16 Curved actuator 08 Curved actuator + chamfer 07 Flat actuator + chamfer 6P Flat actuator + knurled nut 6B Curved actuator + knurled nut FUNCTION 3 NO CASE 0 Short CONTACTS Brass, silver plated C TERMINALS 9 Screw OPTIONS BUSHING/ACTUATOR MATERIALS 00 (std) Nickel plated brass / Nickel plated brass 10 Nickel plated brass / Stainless steel 40 Stainless steel / Stainless steel 70 Black chrome plated brass / Black chrome plated brass SEALING Blank K No sealing Sealed to IP65 ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of website. 3 PANEL SWITCHES AV series Snap action security pushbutton switches • Ø 16 mm • momentary (NO) FLAT OR CURVED ACTUATOR SCREW TERMINALS Hex nut 19 (.748) across flats 3.00 (.118) 3.00 (.118) Ø12.00 (.472DIA) Ø18.00 (.708DIA) AV0630C9 Ø16.00X1.00 SI (.629DIAX1.00 IS) Flat actuator Curved actuator AV1630C9 1.50 (.059) 9.50 (.374) 11.20 (.440) AV16DT1-A Hex nut 19 (.748) across flats Flat actuator 2.00 (.078) FLAT OR CURVED ACTUATOR WITH CHAMFER 1.50 (.059) AV0830C9 Curved actuator AV0730C9 WITH KNURLED NUT FOR MATRIX MOUNTING 20 X 20 (.787X.787) Flat actuator Ø18.00 (.708DIA) Ø18.00 (.708DIA) Ø12.00 (.472DIA) Ø12.00 (.472DIA) Ø18.00 (.708DIA) Ø18.00 (.708DIA) AV6P30C9 Curved actuator 20.00 (.787) PANEL SWITCHES AV series AV6B30C9 FICHIER CAV6PDT1 Wrench available under P/N U1990. Screw terminals for wires 1,5 mm2 max. 4 Snap action security pushbutton switches • Ø 16 mm • momentary (NO) BUSHING/ACTUATOR MATERIALS BASIC P/N CODE BUSHING ACTUATOR 00 (std) Nickel plated brass Nickel plated brass 10 Nickel plated brass Stainless steel 40 Stainless steel Stainless steel 70 Black chrome plated brass Black chrome plated brass FLAT OR CURVED METAL ACTUATOR SEALING BASIC P/N Blank No sealing K Front panel sealing to IP65 OPTION K 1 2 - elastomeric membrane - external gasket CAVNONFET 5 PANEL SWITCHES AV series
AV1630C940
物料型号:SW-AV16MOM-1709 器件简介:AV系列瞬时安全按钮开关,直径16mm,瞬时(NO)型。
引脚分配:3个引脚,分别为NO(常开)。
参数特性: - 最大电流/电压额定值:200mA 48VDC(电阻性负载)- 100mA 48VDC(电阻性负载) - 初始接触电阻:最大50mΩ - 绝缘电阻:最小1,000 MΩ(500VDC条件下) - 耐压:2,000 Vrms 50 Hz(端子与框架之间) - 电气寿命:50,000次循环(200mA 48VDC)- 100,000次循环(100mA 48VDC) 功能详解:瞬时(NO)型,即按下时导通,松开后断开。
应用信息:适用于需要瞬时动作的场合,如控制电路的开关。
封装信息:面板厚度1(0.039英寸)至6mm(0.236英寸),面板开孔直径16.2mm(0.637英寸),最小矩阵安装间距24mm x 24mm(0.944 x 0.944英寸)。
请注意,公司保留在不通知的情况下更改规格的权利。
AV1630C940 价格&库存
很抱歉,暂时无法提供与“AV1630C940”相匹配的价格&库存,您可以联系我们找货
AV1630C940
  • 3+320.37529
  • 7+314.42652
库存:7
