DPS9301AK2
DPS9301AK2
    APEM(埃斐)
DPS9301AK2 数据手册
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE DPS9 SERIES PUSHWHEEL SWITCHES FEATURES z.315"(8mm) wide pushwheel switches with extra large visible readout characters . zBi-directional snap action detent pushbutton mechanism. zBlack housing and drum with white printing. zGangable front mounting models with spacers and side covers. zGold wiping action contacts. zP.C. board options include solderable lands. DPS9 SPECIFICATIONS Panel mounting hole: Height Width Installed depth with p.c. board: Short Long Insertion from front Insertion from rear MATERIALS Body: PPO 1.300"(33mm) .315"(8mm) PC board: 1.535"(39mm) 1.968"(50mm) yes no FR 4 DIN 40802 IEC 249-2, Contact surface gold over nickel on copper Sliding contact: Gold over nickel on copper alloy CODES Code positions marking 111 Decimal 10 0-9 131 BCD 10 0-9 137 BCD comp 10 0-9 141 BCD + comp 10 0-9 301 Hexadecimal 16 0-9, A-F(0-15) 307 Hexadec comp 16 0-9, A-F(0-15) 400 change-over 10 +,-,+,-,etc.. see truth tables see truth tables see truth tables see truth tables see truth tables see truth tables see truth tables STANDARD COLORS Housing,Drum,Printing 2 = black 3 = white 2,2,3 T ELECTRICAL DATA Operating voltage: Contact load, static: Contact load, dynamic: Contact resistance (type AK): 40 V max. 1 A max. 100 mA max. less than 100 mOhm TECHNICAL DATA Operating temperature range: Electric life, min. switching cycles Actuation force, approx (oz.): Weight, approx. (grams): Character ht: 10 digit - .268" (6.8mm) Audible click Vibration DIN IEC 68, parts 2-6 Shock DIN 40046, part 7 -20°C to 80°C greater than 1,000,000 16 6.5 16 digit - .169" (4.3mm) yes yes yes Other special features are available upon request including: Factory or customer set stops (10 digit models) L.E.D. illumination (transparent drum) Red digits Decimal point Special codes or printing Gray housing See sockets at end of Pushwheel section. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com T1 DPS9 SERIES PUSHWHEEL SWITCHES TRUTH TABLES 0 1 2 3 4 5 6 7 8 9 C z z z z z z z z z z CODE 137 BCD COMP. 1 2 4 8 z z z z z z z z z z z z z z z C z z z z z z z z z z 0 1 2 3 4 5 6 7 8 9 1 2 4 z z z z z z z z z z z z z z z z z C z z z z z z z z z z + + + + + - z z z z z A+ z Az z z z z z z z z C 1 2 4 8 1 2 4 8 C 0 1 2 3 4 5 6 7 8 9 z z z 8 z z z z z z z z CODE 141 BCD + COMP. CODE 111 DECIMAL 0 1 2 3 4 5 6 7 8 9 CODE 301 HEXADECIMAL CODE 400 CHANGE-OVER z z z z z z z z z z z z 0 1 2 3 4 5 6 7 8 9 z z z z z z z z z z z z z 1 2 4 8 C z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z 0 1 2 3 4 5 6 7 8 9 A B C D E F C z z z z z z z z z z z z z z z z 1 2 4 8 z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z 0 1 2 3 4 5 6 7 8 9 A B C D E F CODE 307 HEXADEC. COMP. z z z z z z z z z z z z z z z z z z z MECHANICAL OUTLINE WITH PANEL CUT-OUT & MOUNTING n = number of decades Dimensions in brackets apply when DPS910PB2 side covers are used. T PIN CONNECTIONS z 131 z The switching mode is shorting - i.e. - even during actuation, at least one output is connected to input C. 137 141 z 301 AK z 307 400 111 + 1 2 C 8 + 1 2 C 8 4 + 2 4 2 C 8 1 1 8 4 + 1 2 + 1 2 C 8 C 8 4 4 - + C A- A+ 0 1 2 3 C 4 5 6 7 8 9 111bl + C 0 1 2 3 4 5 6 7 8 9 T2 4 - - Pitch .079"(2mm) APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE CODE 131 BCD DPS9 SERIES PUSHWHEEL SWITCHES PRINTED CIRCUIT OPTIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE P.C. boards have .039" (1mm) holes and are suitable for soldering or socket connection (with the exception of LED illumination option). AK short p.c. board AL long p.c. board LS p.c. board w/solder pins Allows customer to add resistors, diodes, ect. Ordering information: Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply selecting from available options shown and filling in the boxes. Consult factory for fully assembled switches. 'BUILD YOUR OWN SWITCH' ORDER FORMAT Series model D P S Code P.C. board Terminations 9 Standard colors 2 1 1 1 1 3 3 4 1 3 3 4 0 0 0 1 1 7 1 1 7 0 Decimal BCD BCD comp. BCD + comp. Hexadecimal. Hexadecimal comp. Change-over A K Short A L Long (NONE) L S with p.c. solder pins Black housing. & drum, white lettering. Example of complete model no.: DPS9141AKLS2 Order SP15 as a separate line item for limit stop pin (for 10 position models only). ACCESSORIES Order separately T DPS9L2 Dummy housing DPS910PB2 Pair of side covers DPS910P2 Pair of side covers DPS9L2 Dummy switches These are empty plastic housings with the same dimensions as DPS9 model (see outline). Use to fill hole where switch is not needed. DPS910A2 Spacer APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com T3
DPS9301AK2 价格&库存
很抱歉,暂时无法提供与“DPS9301AK2”相匹配的价格&库存,您可以联系我们找货
DPS9301AK2
  • 8+118.27419
  • 19+116.06153
  • 38+113.83679
库存:70
