IB and IS series
Sealed momentary pushbutton switches
Distinctive features and specifications
❑ Snap-in and threaded bushing models
❑ Compact, light in weight
• Behind-panel depth of 13 mm (.512) only
• 50 % reduction in weight compared to metallic models
❑ Tactile feedback
❑ Sealed to IP 67
B
ENVIRONMENTAL SPECIFICATIONS
• Degree of protection : IP 67
• Shock resistance : 100 g according to IEC 512-4, test 6c
• Vibration resistance : 10-500 Hz - 10 g according to IEC 512-4, test 6d
• Salt spray : IEC 512-6, test 11f
• Operating temperature : -40°C to +85°C
MATERIALS
• Case : thermoplastic UL94-V0
• Plunger : polyamide 6/6
• Bushing/bezel : polyamide 6/6
• Contacts : silver, gold plated
• Terminal seal : epoxy
ELECTRICAL AND GENERAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
400mA 32VAC - 100mA 50VDC - 125mA 125VAC
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1 GΩ min. at 500VDC
• Dielectric strength : 1.000 VAC rms
• Electrical life at full load : 500.000 cycles
• Panel thickness :
- IB series : 0,8 mm (.031) min. - 1,8 mm ( .071) max.
- IS series : 1,5 mm (.059) min. - 4 mm (.157) max.
• Total travel : 1,5 mm (.059)
• Operating force : 2N to 5N
• Contact bounce : 10 ms
• Mechanical life : 1.000.000 cycles
• Torque : 1,5 Nm max. applied to nut
• Soldering : 300°C max. for 3 seconds
B-22
www.apem.com
APEM
IB and IS series
Overview
IB Snap-in
IS Threaded
bushing
Electrical
function
Bezel shape
SERIES
R
Round
3
Terminals
S Solder lug
Z1 Quick-connect
2,8 x 0,5 mm
P Straight PC
Normally open
(NO)
Contacts
AD Silver, gold
plated
B
Plunger colour
1
1/4
2
3
5
6
7/1
8
9
Blue
Dark blue
Black
Green
Yellow
Red
White
Chrome plat.
Orange
Finish
00
08
10
Option
Black (std)
Chrome plated
(IS only)
White
104
High Plunger
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches and options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketted numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
A sealing boot is available to protect the switches against frost and sand. It is presented at the end of the series and in section H.
Mounting accessories : Standard hardware supplied : 1 flat seal (IB series)
1 hex nut 14 mm (.551) across flats and 1 flat seal (IS series). The hex nut is presented in section I (part number U166).
Packaging unit : 50 pieces
APEM
www.apem.com
B-23
IB and IS series
• Nine plunger colours
• Flat plunger top allowing marking
• Antirotation bushing
Straight P
Solder lug S
3.40
(.133)
1.00
(.039)
1.50
(.059)
1.20
(.047)
8.40
(.330)
2.40
(.094)
Quick-connect Z1
1.20
(.047)
2.80
(.110)
2.80
(.110)
MODEL
STRUCTURE
B
➞ Flat
Snap-in mounting - solder lugs
Panel thickness : 0,8 mm to 1,8 mm
1.20
(.047)
5.00
(.196)
Normally open
3.20
(.125)
13.00
(.511)
IBR3SAD
Ø17.50
(.688DIA)
2.00
(.078)
Ø12.00
(.472DIA)
0.50
(.019)
2.80
(.110)
EPOXY
5.08
(.200)
Also available with straight PC : IBR3PAD or quick-connect terminals : IBR3Z1AD
Mounting by threaded bushing - solder lugs
➞ Flat
Panel thickness : 1,5 mm to 4 mm
1.20
(.047)
5.60
(.220)
5.00
(.196)
Normally open
3.20
(.125)
13.00
(.511)
ISR3SAD
Ø17.50
(.688DIA)
2.00
(.078)
Ø12.00
(.472DIA)
0.50
(.019)
5.08
(.200)
2.80
(.110)
EPOXY
Ø12.00x0.75SI
(.472DIAx0.75IS)
Also available with straight PC : ISR3PAD or quick-connect terminals : ISR3Z1AD
PLUNGER COLOUR
Plunger marking : consult factory.
1 : blue - 1/4 : dark blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7/1 : white - 8 : chrome plated - 9 : orange
BUSHING AND BEZEL FINISH
00 : Black (standard)
08 : Chrome plated (IS series only)
B-24
10 : White
www.apem.com
APEM
IB and IS series
PLUNGER OPTION
4.70
(.185)
Ø12.00
(.472DIA)
104 : High plunger
IB SERIES MOUNTING
Panel cut-out
Matrix mounting
B
Cross section
1
18.00
(.709)
1.80 MAXI.
(.071MAX.)
18.00
(.709)
2
18.00
(.709)
0.80 MINI.
(.031MIN.)
12.90
(.507)
TACTILE FEEDBACK
Ø13.60
(.535DIA)
➀ Elastomeric membrane ➁ Flat seal
Operating force/travel
IS SERIES MOUNTING
1
3
20.00
(.787)
20.00
(.787)
Switching point
20.00
(.787)
12.90
(.507)
Indicative
nominal curve
Force (N)
Matrix mounting
1.50min-4Max
(.059MIN.-.157MAX.)
Panel cut-out
Ø13.60
(.535DIA)
Ø13.50
(.531DIA)
0.6
1.2
1.5
Travel (mm)
By silicone boot, transparent (U5125) or black
(U5125-2), for protection against frost and abrasion by
sand. Order separately.
Operating temperature : -40°C to +125°C
Life expectancy : 500 000 cycles
APEM
8.80
(.346)
ADDITIONAL SEALING
Ø18.30
(.720 DIA)
www.apem.com
B-25
很抱歉,暂时无法提供与“IBR3SAD6”相匹配的价格&库存,您可以联系我们找货
