1213C2
1213C2
    APEM(埃斐)
    SWITCH PUSH SPST-NO 3A 125V
1213C2 数据手册
PANEL SWITCHES 2 -1 SW 08 18 00 1200 series Momentary pushbutton switches • round plunger DISTINCTIVE FEATURES Butt action contacts Double break NF (EN 61058-1), UL and CSA approved ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A) : 4 A 250 VAC - 8 A 125 VAC - 4 A 24 VDC - 8 A 12 VDC - silver plated copper contacts (C) : 2 A 250 VAC - 3 A 125 VAC - 2 A 24 VDC - 3 A 12 VDC • Initial contact resistance : 10 mΩ • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 2,000 Vrms 50 Hz min. between terminals 3,000 Vrms 50 Hz min. between terminals and frame • Electrical life : 10,000 cycles at full load GENERAL SPECIFICATIONS • Torque : 1.50 Nm (1.10 Ft.lb) max. applied to nut • Panel thickness : 5 mm (.196) max. • Total travel : NO : 4.5 mm (.177) ± 0.3 (.011) NC : 3.5 mm (.137) ± 0.3 (.011) • Operating temperature : -20 °C to +55 °C (-4 °F to +131 °F) MATERIALS • Case : polyamide • Plunger : polyamide • Bushing : brass, nickel plated • Contacts : A : silver C : copper, silver plated APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 Momentary pushbutton switches • round plunger MOUNTING TERMINALS • Panel cut-out : Ø 12.2 (.480) 4 A 250 VAC - 8 A 125 VAC All models function 3 (NO) Models 1233X209 and 1233X209L are standard marked NF. To order switches marked NF, UL or CSA, complete appropriate box of ordering format. 4.50 (.177) 0.80 (.031) 6.35 (.25) Solderlug / quick-connect. Screw Ø.50 (.059DIA) Ø3.00x0.50 (.118DIAx0.50) 9.20 (.362) EN 61058-1 2 A 250 VAC or 4 A 250 VAC, T55/125 °C All models 6.35x0.80 (.25x.031) 9.20 (.362) AGENCY APPROVALS Ø3.00x0.50 (.118DIAx0.50) 7.20 (.283) 9.20 (.362) Ø3.10 (.122DIA) 6.35x0.80 (.25x.031) 4.50 (.177) PANEL SWITCHES 1200 series Normalized quick-connect 6.35 (.25) 0.80 (.031) Screw + clamp ELECTRICAL FUNCTIONS KEYWAY NO (function 3) 2 NC (function 2) Momentary pushbutton switches • round plunger BUILD YOUR PART NUMBER BASIC PART NUMBER 12 SERIES TERMINALS ELECTRICAL FUNCTIONS 1 Solder lug and quick-connect 2 Normally closed 2 Screw 3 Normally open 3 Normalized quick-connect 0 Screw terminal + clamp 0.-7 Right angle screw terminals + clamp OPTIONS CONTACT MATERIALS APPROVALS PLUNGER COLORS A Silver 2 Black C Copper, silver plated 3 Green 6 Red 7/1 NF UL/CSA White SPECIAL MODELS FINISH LUXE Chrome plated cap nut U117 instead of knurled cap nut U411 Consult factory for details of approved models. X209 NF standard marked, silver contacts X209L NF standard marked, silver contacts, long plunger ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to following pages for further information. Sealing boots are available to protect the switches against dust and water. See "Sealing Boots" section of website. Mounting accessories : standard hardware supplied : - silver contact models : 1 hex nut U166 and 1 knurled nut U411 - copper contact models : 1 hex nut U42 and 1 knurled nut U411 Standard and special hardware is presented in the “Hardware“ section of website. 3 PANEL SWITCHES 1200 series Momentary pushbutton switches • round plunger KEYWAY Ø8.00 (.315DIA) Ø12.00x0.75 SI (.472DIAx0.75 IS) Normally Open 12.00 (.472) 1213 9.20 (.362) Normally Closed 1.00 (.039) 1212 10.50 (.413) 7.50 (.295) SOLDER LUG/QUICK-CONNECT TERMINALS 17.00 (.669) 13.20 (.519) 6.35x0.80 (.25x0.031) 14.00 (.551) Plunger height : NO model : 7.50 mm, NC model : 5.80 mm KEYWAY Ø8.00 (.315DIA) Normally Open 10.50 (.413) 1223 8.00 (.315) Normally Closed 1.00 (.039) 1222 7.50 (.295) Ø12.00x0.75 SI (.472DIAx0.75 IS) 12.00 (.472) SCREW TERMINALS 13.20 (.519) 17.00 (.669) 14.00 (.551) Plunger height : NO model : 7.50 mm, NC model : 5.80 mm NORMALIZED QUICK-CONNECT TERMINALS KEYWAY ø8.00 (.315DIA) ø12.00x0.75 SI (.472DIAx0.75 IS) Normally Open 12.00 (.472) 1233 17.00 (.669) 13.20 (.519) 9.20 (.362) Normally Closed 1.00 (.039) 1232 10.50 (.413) 7.50 (.295) ø1.50 (.059DIA) 6.35x0.80 (.25x0.031) 14.00 (.551) Plunger height : NO model : 7.50 mm, NC model : 5.80 mm KEYWAY Ø12.00x0.75 SI (.472DIAx0.75 IS) Ø8.00 (.315DIA) 1203 Normally Open 13.20 (.519) 17.00 (.669) Plunger height : NO model : 7.50 mm, NC model : 5.80 mm 4 12.00 (.472) Normally Closed 7.20 (.283) 1202 10.50 (.413) 7.50 (.295) STRAIGHT SCREW TERMINALS + CLAMP 1.00 (.039) PANEL SWITCHES 1200 series 6.35x0.80 (.25x.031) 14.00 (.551) Momentary pushbutton switches • round plunger KEYWAY Ø12.00x0.75 SI (.472DIAx0.75 IS) Ø8.00 (.315DIA) Normally Open 90˚ 21.00 (.826) 7.00 (.275) 1.00 (.039) 1203-7 12.00 (.472) 10.50 (.413) 7.50 (.295) RIGHT ANGLE SCREW TERMINALS + CLAMP 6.35x0.80 (.25x.031) 14.00 (.551) CONTACT MATERIALS BASIC P/N A C Silver Copper, silver plated FINISH BASIC P/N LUXE Chrome plated cap nut U117 instead of knurled nut U411 PLUNGER COLORS BASIC P/N 2 Black 3 Green 6 Red 7/1 White SPECIAL MODELS BASIC P/N X209 NF standard marked - Silver contacts - short plunger X209L NF standard marked - Silver contacts - long plunger See drawings next page. NOTE : Ground connector U187 compulsory on models X209 and X209L if the panel is not metallic or not connected to ground. Order separately : see “Hardware“ section of website. 5 PANEL SWITCHES 1200 series Momentary pushbutton switches • round plunger SPECIAL MODELS (CONTINUED) BASIC P/N OPTION X209 KEYWAY Ø12.00x0.75 SI (.472DIAx0.75 IS) 12.00 (.472) Normally Open 9.20 (.362) 1.00 (.039) 1233A•X209 10.50 (.413) 7.50 (.295) Ø8.00 (.315DIA) 13.20 (.519) 6.35x0.80 (.25x0.031) 17.00 (.669) 14.00 (.551) Replace • with the desired plunger color. KEYWAY OPTION X209L Ø12.00x0.75 SI (.472DIAx0.75 IS) 13.00 (.511) Ø8.00 (.315DIA) 10.50 (.413) Normally Open 12.00 (.472) 1233A•X209L 9.20 (.362) 1.00 (.039) PANEL SWITCHES 1200 series 13.20 (.519) 17.00 (.669) 6.35x0.80 (.25x0.031) Replace • with the desired plunger color. AGENCY APPROVALS BASIC P/N NF All models UL-CSA All models function 3 (NO), including X209 and X209L Marking : to order switches marked NF, UL or CSA, complete above box with desired approvals. 6 14.00 (.551)
1213C2 价格&库存
很抱歉,暂时无法提供与“1213C2”相匹配的价格&库存,您可以联系我们找货
1213C2
  • 1+36.08147
  • 10+32.83046
  • 25+31.18122
  • 50+30.00659
  • 100+29.47266
库存:4249
