11000 and 12000 series
Professional toggle switches
Distinctive features
UG1410A-R1
❑ Applications
These switches are specially manufactured for defence, telecommunications and
other professional applications.
A
❑ Approvals
CECC 96201-005
CECC 96201-008
• Meeting the requirements of MIL standard (MIL 3950)
❑ Robust switches for high specification environments
❑ Toggle action on 2-position models giving smooth mechanical
operation
❑ Plastic material with high insulation resistance
❑ Several front panel sealing options
❑ Several locking lever options (12000 series)
❑ Bright chrome, satin chrome or black finish
The company reserves the right to change specifications without notice.
APEM
www.apem.com
A-57
11000 series
Professional toggle switches - threaded bushing Ø 6,35 (1/4)
Specifications
ELECTRICAL SPECIFICATIONS
A
• Max. current/voltage rating with resistive load :
- silver contacts (A-AD2-X780) : 4A 30VDC
- gold contacts (D) : 100mA 30VDC
• Minimum load : AD2-X780-D contacts : 10mA 50mV, 10µA 5V min.
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
1.000 Vrms 50 Hz min. between terminals
2.000 Vrms 50 Hz min. between poles and between terminals and frame
• Contact bounce : 2 ms max.
• Electrical life at full load :
Peak currents, refer to “Special options”.
Number of cycles
Contacts
2 positions
3 positions
A
4A 30VDC
50.000
50.000
AD2
X780
4A 30VDC
(Gold plating : 100mA 30VDC max.)
20.000
20.000
D
100mA 30VDC
80.000
50.000
150.000
100.000
Low level or mechanical life
MATERIALS
• Case : diallylphthalate (DAP)
• Actuator : brass, nickel plated
• Bushing : brass, nickel plated
• Housing : brass, nickel plated
• Contacts
A : silver
AD2 : gold plated silver
(2 microns gold)
X780 : solid rivet - gold plated
silver/nickel alloy
D : solid gold rivet
X910 : silver/nickel alloy (for
peak currents, see “Special
options”)
• Terminal seal : epoxy
Note : AD2 and X780 contacts
can be used for high level
applications. In this case, the
gold layer is considered only as
a protection against oxidation
during storage.
GENERAL SPECIFICATIONS
• Torque :1,25 Nm (.92 Ft.lb) max. applied between the 2 nuts
• Standard panel thickness : 2,5 mm (.098) max.
• Operating temperature : -40°C to +85°C
RELIABILITY
- RUN-IN TEST
Upon request, each individual switch can be submitted to a low level run-in
test of 50 or 250 cycles to ensure suitability for special applications requiring
a very high level of reliability (military, etc.).
AGENCY APPROVALS
CECC 96201-005
CECC 96201-008
Availability : consult factory for details of approved models.
Marking : to order switches marked CECC, complete appropriate box of
ordering format.
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
Packaging unit : 25 pieces or 50 pieces depending on models.
A-58
www.apem.com
APEM
11000 series
Overview
11
SERIES
Terminals and bushings
Solder lug or right
angle
Straight PC terminals
1
2
All models with Ø 6,35
(1/4) threaded bushing.
Number of poles
3
4
5
6
Single pole
Double pole
Three pole
Four pole
Electrical functions
6
9
7
8
Finish
A
AD2
D
Silver
Gold plated silver
(2 microns)
Solid gold rivet
See "Special options" for X780
(solid silver/nickel rivet) and
X910 (for peak currents).
OFF
OFF
OFF
ON
ON
MOM
MOM
Blank Solder lug or
straight PC
Right angle,
W
horizontal mounting
(function 6, SP only)
Levers
Blank Nickel plated
G
Black finish on
bushing, actuator
and hardware.
Contact materials
ON
ON
MOM
ON
Terminals
Approval
CECC
Blank Standard
-26 Cylindrical
Sealing
Blank Epoxy sealed terminals
standard
K
Front panel sealing by
one O-ring and sealing
washer
Availability : Consult
approved models.
Special options
Blank No special
requirement
X408 Front panel sealing
by two O-rings
Other : see following pages.
Sealing by two O-rings, see
X408, "Special options" box.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- options in the same order as in above chart
Sealing boots are available to protect the switches against dust and water. They are presented in section H.
Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 (.314) across flats, 1 locking ring and 1
lockwasher. Standard and special hardware available are presented in section I.
APEM
www.apem.com
A-59
A
11000 series
• Solder lug, straight PC or right angle terminals
• Epoxy sealed terminals standard
3
Function 6
1
2
1.20
(.047)
3
2.50
(.098)
Other functions
1.00
(.039)
9.50
(.374)
2
MODEL
STRUCTURE
Shown with standard lever
11.30 6.30
(.444) (.248)
III
III
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
0.70
(.027)
Ø3.00
(.118 DIA)
11136
11139
11137
11138
I
14.00
(.551)
II 26˚
1
Ø6.35-40UNS
(1/4-40UNS)
2.50
(.098)
3
2
8.00
(.314)
13.40
(.527)
0.50
(.019)
II
1 2 3
I
4.00
(.157)
Solder lug terminals - single pole
Keyway
5.00
(.196)
EPOXY
➞ Keyway
26˚
3
Ø .00
(.118 )AID
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
14.00
(.551)
I
0.70
(.027)
6
Ø .35-40UNS
(1/4-40U)NS
5.00
(.196)
4
5
6
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
9
I
I
I
20˚
4.30
(.169)
Ø6.35-40UNS
(1/4-40UNS)
1
Ø 2.00
(.472 )AID
11156
11159
11157
11158
7
8
A-60
www.apem.com
14.00
(.551)
III
20.00
(.787)
4.00
(.157)
II
17.00
(.669)
3 2 1
I
11.30 5.70
(.444) (.224)
OXYEP
0.50
(.019)
➞ Keyway
Solder lug terminals - three pole
6.00
(.236)
I
6
14.00
(.551)
2.50
(.098)
3
11146
11149
11147
11148
I
4
5
13.40
(.527)
5.00
(.196)
6.00
(.236)
1
2
11.30 6.30
(.444) (.248)
4.00
(.157)
III
2.50
(.098)
II
3 2 1
I
0.50
(.019)
Solder lug terminals - double pole
3
Ø .00
(.118 )AID
A
1
5.00
(.196)
1.70
(.066)
➞ Keyway
XYEPO
APEM
11000 series
4.30
(.169)
A
5.00
(.196)
1
Ø 2.00
(.472 )AID
4.00
(.157)
I
0.70
(.027)
ON
3
Ø .00
(.118 )AID
ON
26˚
I
8.00
(.314)
13.40
(.527)
14.00
(.551)
I
3
2
1
11236
11.30 6.30
(.444) (.248)
0.50
(.019)
III
Ø6.35-40UNS
(1/4-40U)NS
Ø1.60
(.062 IA)D
1.00
(.039)
II
1 2 3
II
EPOXY
9.50
(.374)
➞ Keyway
0.70
(.027)
ON
Ø6.35-40USN
(1/4-40UNS)
14.00
(.551)
9.50
(.374)
I
20˚
ON
4.30
(.169)
Ø6.35-40UNS
(1/4-40UNS)
Ø1.60
(.062 IA)D
1
Ø 2.00
(.472 )AID
6.00
(.236)
3
Ø .00
(.118 )AID
ON
I
9
14.00
(.551)
6
I
7
8
4.00
(.157)
4
5
20.00
(.787)
17.00
(.669)
0.50
(.019)
III
YEPOX
1.00
(.039)
II
APEM
www.apem.com
4.00
(.157)
3 2 1
II
11256
11.30 5.70
(.444) (.224)
➞ Keyway
Straight PC terminals - three pole ▲
Ø1.60
(.062 )IAD
6.00
(.236)
I
3
Ø .00
(.118 )AID
26˚
I
6
6.00
(.236)
3
ON
I
4
5
14.00
(.551)
13.40
(.527)
4.00
(.157)
1
2
11246
11.30 6.30
(.444) (.248)
III
0.50
(.019)
II
1.00
(.039)
II
EPOXY
3 2 1
Straight PC terminals - double pole ▲
4.00
(.157)
6.00
(.236)
➞ Keyway
Straight PC terminals - single pole ▲
14.00
(.551)
Ø6.35-40UNS
(1/4-40UNS)
6.00
(.236)
I
3
Ø .00
(.118 )AID
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
20˚
I
12
9
4.00
(.157)
I
10
11
7
8
2.50
(.098)
III
26.00
(1.023)
3 2 1
II
17.00
(.669)
0.50
(.019)
II
11166
11169
11167
11168
11.30 5.70
(.444) (.224)
➞ Keyway
Solder lug terminals - four pole
9.50
(.374)
XYEPO
4.00
(.157)
A-61
11000 series
ON
11266
20˚
ON
14.00
(.551)
I
I
4.30
(.169)
Ø6.35-40UNS
(1/4-40UNS)
1
Ø .60
(.062 IA)D
1
Ø 2.00
(.472 )AID
6.00
(.236)
3
Ø .00
(.118 )AID
12
I
6.00
(.236)
9
10
11
4.00
(.157)
7
8
0.50
(.019)
III
26.00
(1.023)
1.00
(.039)
II
17.00
(.669)
3 2 1
II
A
11.30 5.70
(.444) (.224)
➞ Keyway
Straight PC terminals - four pole ▲
III
ON
ON
▲ 3,5 mm (.138) short terminals available
for function 6, as well as for functions 9, 7
and 8. On request.
5.20
(.204)
Standard
2
Ø .20
(.086 )AID
6
Ø .50 6
Ø .50
(.255 )IAD (.255 IA)D
6
Ø .50 6
Ø .50
(.255 )IAD (.255 DIA)
6
Ø .50
(.255 A)ID
2.70 2.70
(.106)(.106)
2.70
(.106)
With K
sealing option
6
Ø .50
(.255 A)ID
2.70 2.70
(.106)(.106)
2.70
(.106)
With X408
sealing option
5.00
(.196)
II
1.10
(.043)
5.20 5.20
(.204)(.204)
2
Ø .20 2
Ø .20
(.086 IA)D (.086 IA)D
1.10
(.043)
1.10
(.043)
6
Ø .50
(.255 IA)D
XYEPO
3.50
(.137)
I
PANEL CUT-OUT
6
Ø .50 6
Ø .50
(.255 )AID (.255 )AID
4.00
(.157)
➞ Keyway
Right angle terminals - horizontal - single pole
11136W
9.50
(.374)
1.00
(.039)
C11COSpicotAC
A-62
www.apem.com
APEM
11000 series
CONTACT MATERIALS
Silver
Gold plated silver (2 micron gold)
Solid gold rivet
A
AD2
D
A
See "Special options" for contacts X780 (solid silver/nickel rivet) and contacts X910 (for peak currents).
FINISH
Nickel plated
Black finish on bushing, lever and hardware.
Blank
G
Other finish, consult factory.
Ø10.60
(.417 IA)D
Ø11.80
(.464 IA)D
2
5.80
(.228)
6
Ø .40
(.251 )AID
Not available on 11000W model.
1
1.5Mixa
(.104 )XAM
Epoxy sealed terminals are standard.
Blank
No sealing except standard
K
Front panel sealing by O-ring and sealing washer. Protects the switch
against water and dust.
Panel seal withstands 1 bar pressure and remains sealed even when
switch is operated.
2.30
(.090)
SEALING
➀ O-ring ➁ Sealing washer
Sealing by two O-rings, see X408 under "Special options".
Sealing boots : see section H.
LEVERS
Blank
Standard
APEM
9.00
(.354)
2
Ø .00
(.078 A)ID
7.00
(.275)
11.30
(.444)
7.00
(.275)
3
Ø .00
(.118 )AID
-26
Cylindrical
www.apem.com
A-63
11000 series
SPECIAL OPTIONS
5.50
(.216)
A
1
Front panel sealing by two O-rings. Flatted bushing for precise
orientation.
Protects the switch against water and dust.
switch is operated.
4.00 ixaM
(.157 )XAM
X408
X408
X780
Solid rivet, gold plated silver/nickel alloy
X910
Switches for peak currents
➞ Flat
➀ O-rings
Peak current up to 80A (1 ms) 60VDC - single/double pole
Single pole
11136 X910
ON
ON
Double pole
11146 X910
• Contacts : solid rivet - silver/nickel alloy (AgNi)
• Max. current/voltage rating :
3/80A (1 ms) 60VDC - 10.000 cycles
ON
ON
• Further specifications and dimensions : see previous pages
• General information on peak currents : see end of catalogue.
AGENCY APPROVALS
CECC
CECC 96201-005 (high level - contacts X780)
CECC 96201-008 (low level - contacts AD2 or D)
Marking : to order switches marked CECC , complete above box with ”CECC”.
Blank : no agency approval required.
A-64
www.apem.com
APEM
12000 series
Professional toggle switches - threaded bushing Ø 11,9 (15/32)
Specifications
A
Number of cycles
Contacts
2 positions
3 positions
A
4A 30VDC
50.000
50.000
AD2
X780
4A 30VDC
20.000
20.000
D
100mA 30VDC
80.000
50.000
150.000
100.000
MATERIALS
• Actuator : brass, chrome plated
• Contacts
A : silver
(2 microns gold)
silver/nickel alloy
options”)
during storage.
Tin dipped terminals available,
see "Special options".
• Torque :1,50 Nm (1.10 Ft.lb) max. applied between the 2 nuts
• Standard panel thickness : 4,5 mm (.177) max.
RELIABILITY
- RUN-IN TEST
a very high level of reliability (military, space, etc.).
AGENCY APPROVALS
CECC 96201-005
CECC 96201-008
Designed to MIL specifications
ordering format.
Packaging unit : 2 pole models : 25 pieces - 3 & 4 pole models : 20 pieces.
APEM
www.apem.com
A-65
12000 series
Overview
12
SERIES
1
2
A
All models with threaded
bushing Ø 11,9 (15/32).
Bushing Ø 15 (.590), see
X822 under "Special
options".
Number of poles
4
5
6
Momentary for
function 4
Double pole
Three pole
Four pole
6
9
7
8
5
ON
ON
MOM
ON
OFF
OFF
OFF
ON
ON
ON
MOM
MOM
MOM
4
ON
ON
ON
ON
ON MOM ▲
MOM ON MOM ▲
1R ON ON MOM
2R MOM ON MOM
Leave blank for other
functions.
Function 4
. ▲ Must not have blank
in "momentary" box.
Finish
Fluorescent tip
Blank Bright chrome finish
on actuator
G
actuator and hardware.
Blank None
-038 White fluorescent
tip to lever
A
AD2
D
Silver
Silver, gold plated
(2 micron gold))
Solid gold rivet
rivet) and X910 (for peak
currents).
Blank No special
requirement
by two O-rings
X822 Bushing Ø 15 (.590)
Available with matt black
finish (G) only.
Satin chrome finish, see "Special
options".
Contact materials
Special options
Other : see foll. pages.
Sealing
Blank Epoxy sealed
terminals standard
K
one O-ring and
sealing washer
box.
Levers
Blank Standard lever
-12
Short lever
Locking levers
Approvals
CECC
Availability :
Consult factory for details
of approved models.
-1V 1 locked position
-2V 2 locked positions
-3V 3 locked positions
ABOUT THIS SERIES
Mounting accessories : standard hardware supplied with all models : 2 hex nuts 14 (.551) across flats and 1 locking ring.
Security caps are available to prevent inadvertent lever operation. They are presented in section I.
A-66
www.apem.com
APEM
12000 series
Solder lug terminals : 12100
1
2
3
Function 6
1
2
3
Other functions
Function 6
26°
Functions 9, 7, 8, 4
20°
Function 5
12°
1.20
(.047)
9.50
(.374)
Typical angle of throw (A)
5.00
(.196)
1.70
(.066)
➞ Keyway
2.50
(.098)
1.00
(.039)
A
MODEL
STRUCTURE
III
14.00
(.551)
1.00
(.039)
Ø18.20
(.716 DIA)
5.00
(.196)
6.00
(.236)
ON
ON
MOM
MOM
ON
MOM
MOM
MOM
II A
4.00
(.157)
6
1
3
I
2
4
5
2.50
(.098)
OFF
OFF
OFF
ON
ON
ON
ON
1
2
13.70
(.539)
0.50
(.019)
ON
ON
MOM
ON
ON
ON
MOM
III
10.90
(.429)
Ø6.00
(.236 DIA)
12146
12149
12147
12148
12144*
12144 1R*
12144 2R*
12145
II
Ø11.90-32UNS
(15/32-32UNS)
I
17.30
(.681)
3
Keyway
EPOXY
* Function 4 : SP in DP case - connections, see end of catalogue.
➞ Keyway
13.70
(.539)
III
14.00
(.551)
II A
12
II A
III
OFF
OFF
OFF
ON
ON
ON
ON
ON
MOM
MOM
ON
MOM
MOM
Ø6.00
(.236 DIA)
ON
ON
MOM
ON
ON
ON
MOM
Ø11.90-32UNS
(15/32-32UNS)
1.00
(.039)
12166
12169
12167
12168
12164*
12164 1R*
12164 2R*
* Function 4 : DP in 4P case - connections, see end of catalogue.
APEM
www.apem.com
14.00
(.551)
9
I
5.00
(.196)
Ø18.20
(.716 DIA)
6.00
(.236)
10
11
26.00
(1.023)
2.50
(.098)
7
8
13.70
(.539)
1
III
10.90
(.429)
2
II
17.30
(.681)
EPOXY
3
I
5.00
(.196)
0.50
(.019)
➞ Keyway
Ø18.20
(.716 DIA)
6.00
(.236)
Ø6.00
(.236 DIA)
Ø11.90-32UNS
(15/32-32UNS)
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
2.50
(.098)
III
4.00
(.157)
9
4.00
(.157)
6
I
1
7
8
2
4
5
1.00
(.039)
12156
12159
12157
12158
20.00
(.787)
3
II
10.90
(.429)
0.50
(.019)
I
17.30
(.681)
EPOXY
A-67
12000 series
Straight PC terminals : 12200
6
II A
14.00
(.551)
3
I
III
ON
1.00
(.039)
6
9
I
II A
14.00
(.551)
7
8
20.00
(.787)
III
ON
1.00
(.039)
Ø18.20
(.716 DIA)
Ø1.60
(.062 DIA)
9
12
I
II A
III
ON
6.00
(.236)
14.00
(.551)
10
11
26.00
(1.023)
1.00
(.039)
Ø18.20
(.716 DIA)
PANEL CUT-OUT
Standard
5.10
(.200)
6.00
(.236)
6.00
(.236)
4.00
(.157)
EPOXY
1.70
(.066)
on request for function 6. Standard for
functions 9, 7, 8, 4 and 5.
5.10
(.200)
5.10 5.10
(.200) (.200)
With K
sealing option
5.10 5.10
(.200) (.200)
With X408
sealing option
5.00
(.196)
9.60 9.60
(.377) (.377)
9.50
(.374)
3.50
(.137)
9.60
(.377)
Ø1.60
(.062 DIA)
1.70
(.066)
Ø 2.00 1
Ø 2.00
1
Ø 2.00 1
(.472 IA)D (.472 A)ID (.472 A)ID
1.70
(.066)
1
Ø 2.50 1
Ø 2.50 1
Ø 2.50 3
1
Ø 2.00 1
Ø 2.00 1
Ø 2.00
Ø .50
3
Ø .50 3
Ø .50
(.492 IA)D (.492 IA)D (.492 IA)D (.137 IA)D (.137 A)ID (.137
(.472
A)DI (.472 A)ID (.472 A)DI
)AID
Ø6.00
(.236 DIA)
Ø11.90-32UNS
(15/32-32UNS)
1.00
(.039)
7
8
13.70
(.539)
4.00
(.157)
ON
12266
III
10.90
(.429)
2 1
II
17.30
(.681)
4.00
(.157)
EPOXY
3
I
9.50
(.374)
0.50
(.019)
➞ Keyway
6.00
(.236)
Ø6.00
(.236 DIA)
Ø11.90-32UNS
(15/32-32UNS)
1.00
(.039)
4
5
13.70
(.539)
4.00
(.157)
ON
III
10.90
(.429)
4.00
(.157)
EPOXY
2 1
II
17.30
(.681)
Ø1.60
(.062 DIA)
3
I
9.50
(.374)
0.50
(.019)
➞ Keyway
12256
Ø6.00
(.236 DIA)
Ø11.90-32UNS
(15/32-32UNS)
1.00
(.039)
A
Ø18.20
(.716 DIA)
6.00
(.236)
4
5
6.00
(.236)
1
2
0.50
(.019)
ON
12246
III
13.70
(.539)
2 1
II
10.90
(.429)
3
I
17.30
(.681)
4.00
(.157)
➞ Keyway
1.00
(.039)
C11COSpicotAC
A-68
www.apem.com
APEM
12000 series
CONTACT MATERIALS
A
AD2
D
Silver
Silver, gold plated (2 micron gold)
Solid gold rivet (except functions 4 and 5)
A
FINISH
Blank
G
Bright chrome finish on actuator
For satin chrome finish, see "Special options".
4 ixaM
(.157 )xam
3.00
(.118)
SEALING
Blank
No sealing except standard.
K
Front panel sealing by one O-ring and sealing washer.
when switch is operated.
2
➀ O-ring
1
2
1
➁ Sealing washer
FLUORESCENT TIP
Standard lever
Blank
None
-038
White fluorescent tip.
Becomes luminous when submitted to ultra-violet rays.
Locking lever
Available with matt black finish (option G) only.
1
C 2E-TK 1
eL 29-09-92
APEM
www.apem.com
:chE 1
A-69
12000 series
ACTUATORS
Levers
Dash compulsory before lever code.
6
Ø .00
(.236 )AID
5
Ø .00
(.196 IA)D
Security caps : see section I.
11.90
(.468)
11.90
(.468)
11.80
(.464)
17.30
(.681)
A
Blank
Standard
-12
Short lever
Locking levers
➞ Keyway
19.40
(.763)
19.40
(.763)
11.90
(.468)
11.90
(.468)
11.90
(.468)
7
Ø .00
(.275)
20.60
(.811)
7
Ø .0
(.275 0
)AID
7
Ø .0
(.275 0
)AID
-1V
-2V
-3V
1 locked position (function 6)
Typical angle of throw : 26°
2 locked positions (function 6)
3 locked positions (functions 9 and 4)
Typical angle of throw : 20°
-4V
-4V
Functions 9 & 4
-5V
-5V
Functions 7 & 442R
-12V
-12V
Functions 8 & 441R
-7V
-7V
Functions 8 & 441R
-13V
-13V
Funct. 8, 5 & 441R
-8V
-8V
-9V
-9V
Functions 8, 9, 44 &
441R
Functions 8 & 441R
-15V
-15V
Functions 8 & 441R
-16V
-16V
Functions 4 & 9
-11V
-11V
Functons 8, 9, 44 &
441R
-17V
-17V
Functions 7 & 442R
-20V
-20V
Functions 9 & 44
Note : -5V and -12V are not true locking levers : no pulling is required before actuation.
SPECIAL OPTIONS
1
Blank
No special requirement.
X408
17-02-2010
orientation. Panel thickness : 8 mm (.314) max., 3 mmLe
(.118)
min.
Le 17-02-2010
ECH:1
ECH:1
even when
switch is operated.
X545
Lever, bushing, housing, nuts and washers with satin chrome finish.
A-70
www.apem.com
10.40
(.409)
C12LV
C12LV
➞ Flat
➀ O-rings
APEM
12000 series
SPECIAL OPTIONS
1
Ø 5 X 100 SI
(.590 AID X 100 S)I
Threaded bushing Ø 15 (.590), with double flat
Not available with function 5 or locking levers.
Includes front panel sealing and X780 contact material.
1
12.70
(.500)
10.40
(.409)
X822
(continued)
Solid rivet - gold plated silver/nickel alloy contacts
Not available with function 5.
X822
➞ Flat
➀ O-rings
X910
Ø15.20
(.598 IA)D
13.00
(.511)
X780
6.5 ixaM
(.255 )xaM
A
Peak current up to 80A (1 ms) 60VDC - double pole
12146 X910
ON
ON
AGENCY APPROVAL
CECC
Marking : to order switches marked CECC, complete above box with ”CECC”.
APEM
www.apem.com
A-71
