SW
0N
60
-3
PANEL SWITCHES
1
71
1
F-
3600NF series
Sealed toggle switches
for outdoor applications
DISTINCTIVE FEATURES
Sealed to IP67
Solid silver contacts
UL approved
ENVIRONMENTAL SPECIFICATIONS
• Sealing to IP67 according to IEC 60529 obtained by
- O-ring between lever and bushing
- half-length boot and nylon washer (supplied mounted)
- elastomer gasket between cover and case
- molded-in terminal inserts
- sealing washer U60
• Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F)
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load : 12 A 28 VDC
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
2,500 Vrms 50 Hz min. between terminals
3,000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 10,000 cycles at full load
GENERAL SPECIFICATIONS
• Torque : 1.50 Nm (1.10 Ft.lb) max. applied to nut
• Panel thickness : 2 mm (.079) max. with all accessories
MATERIALS
• Case : phenolic resin
• Actuator : brass, nickel plated
• Bushing : brass, nickel plated
• Contacts : solid silver
The company reserves the right to change specifications without notice.
1
Sealed toggle switches for outdoor applications
PANEL CUT-OUT
AGENCY APPROVAL
6 A 125 VAC/250 VAC
Availability : consult factory for details or approved
models.
Marking : to order switches marked UL, complete last box
of ordering format.
TERMINALS
¯3.00x0.50 SI
(.118DIAx0.50 IS)
9.20
(.362)
¯3.10
(.122DIA)
0.80
(.031)
6.35
(.25)
Screw
4.50
(.177)
9.20
(.362)
PANEL SWITCHES
3600NF series
Solder lug / quick-connect
ELECTRICAL FUNCTIONS
KEYWAY
3
2
2
1
6.35x0.80
(.25x.031)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
36
NUMBER OF POLES
SERIES
TERMINALS
3
Single pole
1
ON
OFF
NF
4
Double pole
4
ON
ON
ON
5
NF/2
MOM
ON
6
ON
ON
7
MOM
OFF
MOM
8
ON
OFF
MOM
9
ON
OFF
ON
Screw
Solder lug /
quick-connect
OPTIONS
SPECIAL LEVER
FINISH
G
Black finish on lever
and sealing boot nut
X1052
30 mm (1.181) long lever
APPROVAL
UL
Consult factory for
detail of approved
models.
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Mounting accessories : 1 sealing boot U1151, 1 hex nut U166, 1 nylon washer U21 and 1 sealing washer U60. Standard and special
hardware available is presented in the "Accessories" section of website.
3
PANEL SWITCHES
3600NF series
SCREW TERMINALS - SINGLE POLE
KEYWAY
17.50
(.689)
90˚
MOM
ON
3636NF
ON
ON
3637NF
MOM
OFF
MOM
3638NF
ON
OFF
MOM
3639NF
ON
OFF
ON
10.50
(.413)
24.60
(.968)
9.20
(.362)
24.60
(.968)
9.20
(.362)
4
I
2
II
5
6.35x0.80
(.25x.031)
3635NF
1
30˚
I
2-3
OFF
35.00
(1.378)
II
3631NF
III
2-1
ON
III
3
6
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
21.50
(.846)
SCREW TERMINALS - DOUBLE POLE
KEYWAY
17.50
(.689)
90˚
ON
ON
ON
3645NF
MOM
ON
3646NF
ON
ON
3647NF
MOM
OFF
MOM
3648NF
ON
OFF
MOM
3649NF
ON
OFF
ON
10.50
(.413)
4
I
2
II
5
6.35x0.80
(.25x.031)
3644NF *
1
30˚
I
2-3
5-6
OFF
35.00
(1.378)
II
3641NF
III
2-1
5-4
ON
III
3
6
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
21.50
(.846)
* Function 4 : SP in DP case, see "Technical information" on website
SOLDER LUG AND QUICK-CONNECT
KEYWAY
17.50
(.689)
MOM
ON
3636NF/2
ON
ON
3637NF/2
MOM
OFF
MOM
3638NF/2
ON
OFF
MOM
OFF
2
9.20
(.362)
24.60
(.968)
9.20
(.362)
I
II
5
III
3
6
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
21.50
(.846)
ON
KEYWAY
17.50
(.689)
90˚
II
I
2-3
OFF
3644NF/2*
ON
ON
ON
3645NF/2
MOM
ON
3646NF/2
ON
ON
3647NF/2
MOM
OFF
MOM
3648NF/2
ON
OFF
MOM
3649NF/2
ON
OFF
ON
1
10.50
(.413)
4
I
2
II
5
III
3
6
21.50
(.846)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
6.35x0.80
(.25x.031)
III
2-1
ON
3641NF/2
4
30˚
ON
24.60
(.968)
6.35x0.80
(.25x.031)
3635NF/2
1
30˚
I
2-3
OFF
35.00
(1.378)
II
3631NF/2
III
2-1
ON
3639NF/2
10.50
(.413)
90˚
35.00
(1.378)
PANEL SWITCHES
3600NF series
4
FINISH
BASIC P/N
G
Black finish on lever and nut of sealing boot
SPECIAL LEVER
BASIC P/N
X1052 30 mm (1.181) long lever
X1052
AGENCY APPROVAL
BASIC P/N
00
UL
Marking : to order switches marked UL, complete above box with ”UL”.
5
PANEL SWITCHES
3600NF series
很抱歉,暂时无法提供与“3647NF/2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+246.72463
- 25+240.32012
- 50+231.90574
- 100+226.75089
- 250+221.82515
