AV5V22F102074BK
AV5V22F102074BK
    APEM(埃斐)
    APEM - AV5V22F102074BK - Vandal Resistant Switch, AV Series, 30.2 mm, SPST-NO, SPST-NC, Momentary, R...
AV5V22F102074BK 数据手册
AV series 0N V3 -A SW PANEL SWITCHES O CN 9 70 -1 Security pushbutton switches • Ø 30 mm • illuminated momentary NC/NO DISTINCTIVE FEATURES Large actuator With illuminated ring Momentary NC/NO Solder lug, flying lead or cable terminals Marking available on request ENVIRONMENTAL SPECIFICATIONS • Optional front panel sealing : IP67 according to IEC 60529 • Robustness : IK06 according to EN 62262 (1 joule) • Operating temperature : -30 °C to +85 °C (-22 °F to +185 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 1 A 30 VDC • LED voltage : 12 VDC, 24 VDC or 48 VDC (If not supplied by APEM, a resistor must be series-connected by the user)** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 10 MΩ min. at 500 VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 1,000 Vrms 50 Hz min. between terminals and frame • Electrical life : 250,000 cycles at full load **Resistor value = supply voltage - LED forward voltage LED forward current GENERAL SPECIFICATIONS • Travel : 2.5 mm ± 0.3 mm (.003) • Operating force : 5 N ± 2 N • Torque : 10 Nm max. • Panel thickness : 1 (.039) to 6 mm (.236) max. • Low level or mechanical life : 1,000,000 cycles • Hand soldering : 350 °C (662 °F), 5 seconds max. The company reserves the right to change specifications without notice. 1 PANEL SWITCHES AV series Security pushbutton switches • Ø 30 mm • illuminated momentary NC/NO MATERIALS • Case : polyamide, glass filled • Contacts : silver • Bushing : see following pages • Actuator : see following pages • Elastomeric membrane : silicone • LED ELECTRICAL FUNCTIONS CAV3-9FCT NC/NO ECHELLE 1 MOUNTING • Panel cut-out : Ø 30.2 mm (1.189) • Min. pitch for matrix mounting : 44 mm x 44 mm (1.732x1.732) 2 Security pushbutton switches • Ø 30 mm • illuminated momentary NC/NO BUILD YOUR PART NUMBER BASIC PART NUMBER AV SERIES BUSHING DIAMETER 5 30 (1.181) 0 No LED 1 Blue V Green 5 Yellow 6 Red 7 White 9 Amber CONTACTS LED RESISTORS LED COLORS 0 No resistor supplied 1 2 TERMINALS 2 Solder/ quick-connect 12 VDC resistor F Flying leads 2 24 VDC resistor C Cable 4 48 VDC resistor Silver OPTIONS RING COLORS FLYING LEAD PROTECTION 0 No protection and/or no flying leads 1 Heat-shrink sleeves 2 Tube + epoxy SEALING 1 Blue 4 Grey* 7 Opal white Blank 2 Black* 5 Yellow 8 Translucent K 3 Green 6 Red 9 Orange No sealing Sealed to IP67 *non-illuminated only FLYING LEAD/CABLE LENGTH 000 No flying leads / no cable 020 Length 20 cm (std) XXX Length in centimeters BUSHING/ACTUATOR MATERIALS 00 Nickel plated brass / Nickel plated brass 4B Stainless steel 316 / Stainless steel 316 Other : on request. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of website. 3 PANEL SWITCHES AV series Security pushbutton switches • Ø 30 mm • illuminated momentary NC/NO Plastic hex nut 36 (1.417) across flats 2.20 (.086) 36.00 (1.417) + + - Non-illuminated _ AV50022 + - 5.00 (.197) NC NO 24.00 (.945) 8.30 (.326) * Select LED color on previous page - No LED resistor supplied on this model. Illuminated* AV5••2F + - + - CAV5DT-1 ech : 0.8 Plastic hex nut 36 (1.417) across flats 2.20 (.086) 12.40 (.488) Ø30.00x1.50 SI (1.181DIAx1.50 IS) Ø25.00 (.984DIA) Ø34.00 (1.338DIA) FLAT ACTUATOR - FLYING LEAD TERMINALS Ø30.00x1.50 SI (1.181DIAx1.50 IS) Illuminated* 2.80x0.50 (.110x.019) NO NC AV5•022 12.40 (.488) Ø34.00 (1.338DIA) FLAT ACTUATOR - SOLDER LUG TERMINALS Non-illuminated AV5002F 5.00 (.197) * Select LED color & resistor on previous page. Ø20.00 (.787DIA) 200 (7.874) 24.00 (.945) Wire colors : black: NC, orange: NO, red: LED anode (+), blue : LED cathode (-) CAV5DT-2 ech : 0.8 Plastic hex nut 36 (1.417) across flats FLAT ACTUATOR - CABLE TERMINALS 2.20 (.086) 12.40 (.488) Ø30.00x1.50 SI (1.181DIAx1.50 IS) Illuminated* AV5••2C + - + - Ø34.00 (1.338DIA) PANEL SWITCHES AV series Non-illuminated AV5002C 5.00 (.197) 24.00 (.945) 200 (7.874) * Select LED color & resistor on previous page. CAV5DT-3 Echelle 0.8 4 Security pushbutton switches • Ø 30 mm • illuminated momentary NC/NO FLYING LEAD PROTECTION BASIC P/N 0 1 2 No protection and/or no flying leads Heat-shrink sleeves Tube + epoxy FLYING LEAD/ CABLE LENGTH BASIC P/N 000 020 XXX No flying leads / no cable Length 20 cm (standard) Length in centimeters RING COLORS BASIC P/N 1 2 3 4 5 6 7 8 9 Blue Black * Green Grey * Yellow Red Opal white (std) Translucent Orange * non-illuminated only BUSHING/ACTUATOR MATERIALS BASIC P/N CODE BUSHING ACTUATOR 00 (std) Nickel plated brass Nickel plated brass 4B Stainless steel 316 Stainless steel 316 Other : on request. SEALING BASIC P/N Blank No sealing K Front panel sealing to IP67 OPTION K 2 1 - internal membrane - external gasket CAV3ET ECHELLE 1 5 PANEL SWITCHES AV series
AV5V22F102074BK 价格&库存
很抱歉,暂时无法提供与“AV5V22F102074BK”相匹配的价格&库存,您可以联系我们找货
