PANEL SWITCHES
2
-1
SW
08
18
00
1200 series
Momentary pushbutton switches •
round plunger
DISTINCTIVE FEATURES
Butt action contacts
Double break
NF (EN 61058-1), UL and CSA approved
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 4 A 250 VAC - 8 A 125 VAC - 4 A 24 VDC - 8 A 12 VDC
- silver plated copper contacts (C) :
2 A 250 VAC - 3 A 125 VAC - 2 A 24 VDC - 3 A 12 VDC
• Initial contact resistance : 10 mΩ
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
2,000 Vrms 50 Hz min. between terminals
3,000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 10,000 cycles at full load
GENERAL SPECIFICATIONS
• Torque : 1.50 Nm (1.10 Ft.lb) max. applied to nut
• Panel thickness : 5 mm (.196) max.
• Total travel :
NO : 4.5 mm (.177) ± 0.3 (.011)
NC : 3.5 mm (.137) ± 0.3 (.011)
• Operating temperature : -20 °C to +55 °C (-4 °F to +131 °F)
MATERIALS
• Case : polyamide
• Plunger : polyamide
• Bushing : brass, nickel plated
• Contacts :
A : silver
C : copper, silver plated
APEM products may be recycled at end-of-life for the re-claiming of valuable metal components.
The company reserves the right to change specifications without notice.
1
round plunger
MOUNTING
TERMINALS
• Panel cut-out : Ø 12.2 (.480)
All models function 3 (NO)
Models 1233X209 and 1233X209L are standard
marked NF. To order switches marked NF, UL or CSA,
complete appropriate box of ordering format.
4.50
(.177)
0.80
(.031)
6.35
(.25)
Solderlug / quick-connect.
Screw
Ø.50
(.059DIA)
Ø3.00x0.50
(.118DIAx0.50)
9.20
(.362)
EN 61058-1
2 A 250 VAC or 4 A 250 VAC,
T55/125 °C
All models
6.35x0.80
(.25x.031)
9.20
(.362)
AGENCY APPROVALS
Ø3.00x0.50
(.118DIAx0.50)
7.20
(.283)
9.20
(.362)
Ø3.10
(.122DIA)
6.35x0.80
(.25x.031)
4.50
(.177)
PANEL SWITCHES
1200 series
Normalized quick-connect
6.35
(.25)
0.80
(.031)
Screw + clamp
ELECTRICAL FUNCTIONS
KEYWAY
NO (function 3)
2
NC (function 2)
round plunger
BUILD YOUR PART NUMBER
BASIC PART NUMBER
12
SERIES
TERMINALS
1
Solder lug and quick-connect
2
Normally closed
2
Screw
3
Normally open
3
Screw terminal + clamp
0.-7
Right angle screw terminals
+ clamp
OPTIONS
CONTACT MATERIALS
APPROVALS
PLUNGER COLORS
A
Silver
2
Black
C
Copper, silver
plated
3
Green
6
Red
7/1
NF
UL/CSA
White
SPECIAL MODELS
FINISH
LUXE
Chrome plated cap
nut U117 instead of
knurled cap nut U411
Consult factory
for details
of approved
models.
X209
NF standard marked,
silver contacts
X209L
NF standard marked,
silver contacts, long
plunger
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to following pages for further information.
Sealing boots are available to protect the switches against dust and water. See "Sealing Boots" section of website.
Mounting accessories : standard hardware supplied :
- silver contact models : 1 hex nut U166 and 1 knurled nut U411
- copper contact models : 1 hex nut U42 and 1 knurled nut U411
Standard and special hardware is presented in the “Hardware“ section of website.
3
PANEL SWITCHES
1200 series
round plunger
KEYWAY
Ø8.00
(.315DIA)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Normally Open
12.00
(.472)
1213
9.20
(.362)
Normally Closed
1.00
(.039)
1212
10.50
(.413)
7.50
(.295)
SOLDER LUG/QUICK-CONNECT TERMINALS
17.00
(.669)
13.20
(.519)
6.35x0.80
(.25x0.031)
14.00
(.551)
Plunger height : NO model : 7.50 mm, NC model : 5.80 mm
KEYWAY
Ø8.00
(.315DIA)
Normally Open
10.50
(.413)
1223
8.00
(.315)
Normally Closed
1.00
(.039)
1222
7.50
(.295)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
12.00
(.472)
SCREW TERMINALS
13.20
(.519)
17.00
(.669)
14.00
(.551)
NORMALIZED QUICK-CONNECT TERMINALS
KEYWAY
ø8.00
(.315DIA)
ø12.00x0.75 SI
(.472DIAx0.75 IS)
Normally Open
12.00
(.472)
1233
17.00
(.669)
13.20
(.519)
9.20
(.362)
Normally Closed
1.00
(.039)
1232
10.50
(.413)
7.50
(.295)
ø1.50
(.059DIA)
6.35x0.80
(.25x0.031)
14.00
(.551)
KEYWAY
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Ø8.00
(.315DIA)
1203
Normally Open
13.20
(.519)
17.00
(.669)
4
12.00
(.472)
Normally Closed
7.20
(.283)
1202
10.50
(.413)
7.50
(.295)
STRAIGHT SCREW TERMINALS + CLAMP
1.00
(.039)
PANEL SWITCHES
1200 series
6.35x0.80
(.25x.031)
14.00
(.551)
round plunger
KEYWAY
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Ø8.00
(.315DIA)
Normally Open
90˚
21.00
(.826)
7.00
(.275)
1.00
(.039)
1203-7
12.00
(.472)
10.50
(.413)
7.50
(.295)
RIGHT ANGLE SCREW TERMINALS + CLAMP
6.35x0.80
(.25x.031)
14.00
(.551)
CONTACT MATERIALS
BASIC P/N
A
C
Silver
Copper, silver plated
FINISH
BASIC P/N
LUXE
Chrome plated cap nut U117 instead of knurled nut U411
PLUNGER COLORS
BASIC P/N
2 Black
3 Green
6 Red
7/1 White
SPECIAL MODELS
BASIC P/N
X209 NF standard marked - Silver contacts - short plunger
X209L NF standard marked - Silver contacts - long plunger
See drawings next page.
NOTE : Ground connector U187 compulsory on models X209 and X209L if the panel is not metallic or not connected
to ground. Order separately : see “Hardware“ section of website.
5
PANEL SWITCHES
1200 series
round plunger
SPECIAL MODELS
(CONTINUED)
BASIC P/N
OPTION X209
KEYWAY
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
12.00
(.472)
Normally Open
9.20
(.362)
1.00
(.039)
1233A•X209
10.50
(.413)
7.50
(.295)
Ø8.00
(.315DIA)
13.20
(.519)
6.35x0.80
(.25x0.031)
17.00
(.669)
14.00
(.551)
Replace • with the desired plunger color.
KEYWAY
OPTION X209L
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
13.00
(.511)
Ø8.00
(.315DIA)
10.50
(.413)
Normally Open
12.00
(.472)
1233A•X209L
9.20
(.362)
1.00
(.039)
PANEL SWITCHES
1200 series
13.20
(.519)
17.00
(.669)
6.35x0.80
(.25x0.031)
AGENCY APPROVALS
BASIC P/N
NF
All models
UL-CSA All models function 3 (NO), including X209 and X209L
Marking : to order switches marked NF, UL or CSA, complete above box with desired approvals.
6
14.00
(.551)
很抱歉,暂时无法提供与“1223MA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 40+216.2435140+28.01110
