AV1630C900
AV1630C900
    APEM(埃斐)
    APEM - AV1630C900 - Vandal Resistant Switch, AV Series, 16.2 mm, SPST-NO, Off-(On), Round Domed, Nat...
AV1630C900 数据手册
AV series Anti-vandal and security pushbutton switches Distinctive features ❑ Attractive, robust and durable • Irremovable • Anti-jamming construction : reduced travel to prevent insertion of foreign parts • Contact and mechanism protected against crushing • Fire resistant • Long life B ❑ Sealed versions ❑ Degree of protection (switches mounted on vertical panels, as shown opposite) : - standard version : IP54 - sealed version : IP65 EXAMPLES OF MOUNTING FOR SEALED VERSIONS ➞ O-ring Preferred With boot U2187 (sect. H) Packaging unit : specified on the following pages. Mounting accessories : Standard and special hardware are presented in section I. B-88 www.apem.com APEM AV series Anti-vandal and security pushbutton switches Distinctive features The AV series is a large range of security pushbutton switches including 4 product families : ANTI-VANDAL PUSHBUTTON SWITCHES (page B-90) • Increased impact resistance provided by a nut (Ø 19 mm) or mechanical stop (Ø 22 mm) • Stainless steel actuator and bushing B • Bushing dia. 19 (.748) or 22 mm (.866) SECURITY PUSHBUTTON SWITCHES WITH LARGE ACTUATOR (page B-93) • Ergonomic actuator dia. 20 (.787) or 30 mm (1.181) • Tactile feedback • Up to 5A 250VAC • Bushing dia. 22 mm (.866) or 24 mm (.944) OTHER SECURITY PUSHBUTTON SWITCHES (page B-96 ) • A large variety of actuator shapes, electrical functions, connections, finish and marking options • Bushing dia. 16 (.629), 19 (.748) or 22 mm (.866) SNAP-ACTION SECURITY PUSHBUTTON SWITCHES (page B-104) • Tactile feedback • Illuminated or non-illuminated • Bushing dia. 19 mm (.748) • Models with overmolded actuator APEM www.apem.com B-89 AV series Anti-vandal pushbutton switches Distinctive features and specifications ❑ Increased impact resistance provided by a nut or mechanical stop ❑ Stainless steel actuator and bushing ❑ UL-CSA approved (long case only) B SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load (C contacts) : 2A 48 VDC • Approved ratings of models with long case and A contacts (AV..000) : UL-CSA : 4A 250VAC - 8A 125VAC - 6.000 cycles • Initial contact resistance : 10 mΩ max. at 1A 2V • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame 2.000 Vrms 50 Hz min. between terminals • Electrical life : 10.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Mechanical life : 1.000.000 cycles • Packaging unit : 20 pieces (models Ø 22) or 40 pieces (models Ø 19) • Case : PBT • Contacts : brass, silver plated (C) or silver (A) • Bushing : stainless steel • Actuator : stainless steel ROBUSTNESS Model Ø 19 mm (.748) Impacts on actuator according to CECC 96000 Hammer radius 10 mm B-90 Hammer radius 25 mm SEALING ( OPTION T ) 1 5 Kg IK08 29.5 cm • Panel cut-out : Ø 19,2 mm (.755) or Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm (1.181) x 30 mm (1.181) Model Ø 22 mm (.866) 1.7 Kg Degree of protection according to EN 50102, June 95 (NFC 20-015) CUT-OUTS Striking energy: 5 joules (5Nm) 40 cm Hammer radius 50 mm IK10 Striking energy: 20 joules (20Nm) 2 Front panel sealing (IP65) 0.3 Kg 34 cm 10 strokes Striking energy: 1 joule (1Nm) 1.5 Kg 34 cm www.apem.com 10 strokes Striking energy: 5 joules (5Nm) ➀ internal gasket ➁ external gasket APEM AV series Anti-vandal pushbutton switches Bushing Ø 19 (.748) - momentary (NO) ORDER FORMAT Series Bush./act. config. Case style 09 19 9D 100 000 Function AV NO (function 3) Contact material Terminal type C A 9 2 Bush./act. material 3 Sealing 40 N T To order a sealed product, replace N with T at the end of P/N. B BASIC MODEL Hex nut 22 (.866) across flats Short case - flat actuator - AV09100...40N 3.00 (.118) ø19.00x1.00 SI (.748DIAx1.00 IS) 7.30 (.287) Screw terminals for wires 1,5 mm2 max. 2.00 (.078) 9.50 (.374) 6.50 (.255) 3.00 (.118) EPOXY Hex nut 22 (.866) across flats Long case - flat actuator - UL-CSA approved - AV09000...40N 3.00 (.118) ! New 6.50 (.255) 7.20 (.283) Flush model Ø22.00 (.866DIA) Ø22.00 (.866DIA) Ø22.20 Mini (.874DIA Min.) Screw terminals AV19•003C940N Solder lug / quick-connect terminals AV19•003C240N 1.30 Mini (.051 Min.) 1.20 (.047) 2.00 (.078) 3.60 (.141) 11.60 (.456) Case style : replace • with 1 for short case and 0 for long case. OTHER CONFIGURATIONS APEM Ø22.00 (.866DIA) Ø15.00 (.590DIA) Ø22.00 (.866DIA) 2.00 (.078) Screw terminals for wires 1,5 mm2 max. Ø15.00 (.590DIA) Ø19.00x1.00 SI (.748DIAx1.00 IS) 5.00 (.196) Screw terminals AV090003A940N Curved actuator 1.20 (.047) 2.80x0.5 (.110x.019) Solder lug / quick-connect term. AV091003C240N 2.80 (.110) ø22.00 (.866DIA) ø22.00 (.866DIA) Screw terminals AV091003C940N ø15.00 (.590DIA) 5.00 (.196) Ø19.20 (.755DIA) Screw terminals AV9D•003C940N Solder lug / quick-connect terminals AV9D•003C240N www.apem.com B-91 AV series Anti-vandal pushbutton switches Bushing Ø 22 (.866) - momentary (NO) ORDER FORMAT Series Bush./act. config. Case style 03 02 M3 M2 100 000 Function Contact material 3 C AV NO (function 3) Terminal type Bush./act. material Sealing 40 C A 9 2 N T To order a sealed product, replace N with T at the end of P/N. BASIC MODEL Hex nut 25 (.984) across flats Short case - flat actuator - AV03100...40N ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) 7.30 (.287) 3.00 (.118) 2.80x0.5 (.110x.019) Solder lug / quick-connect term. AV031003C240N ø15.00 (.59DIA) ø25.00 (.984DIA) Screw terminals AV031003C940N 1.20 (.047) 2.80 (.110) 12.70 (.500) Screw terminals for wires 1,5 mm max. 2 6.30 (.248) Hex nut 25 (.984) across flats Ø22.00x1.00 SI (.866DIAx1.00 IS) ! New 2.00 (.078) 15.00 (.590) Screw terminals for wires 1,5 mm2 max. 10.00 (.248) 5.00 (.196) Case style : replace • with 1 for short case and 0 for long case. OTHER CONFIGURATIONS Curved actuator Flatted bushing Ø25.00 (.984DIA) Ø25.00 (.984DIA) 2.00 (.078) Ø15.00 (.590DIA) Screw terminals AV02•003C940N Solder lug / quick-connect term. AV02•003C240N B-92 3.00 (.118) Ø15.00 (.59DIA) Ø25.00 (.984DIA) Screw terminals AV030003A940N Ø15.00 (.590DIA) EPOXY 5.00 (.196) Long case - flat actuator - UL-CSA approved - AV03000...40N 3.60 (.141) B Flat actuator Screw terminals AVM3•003C940N Curved actuator Screw terminals AVM2•003C940N www.apem.com Ø22.20 (.874DIA) 10.00 (.393 ) APEM AV series Security pushbutton switches with large actuator Bushing Ø 22 (.866) - momentary (combined NC/NO) ORDER FORMAT Series Bushing diameter Bush./act. config. AV 22 L Actuator style Bush./act. Contact/ matl terminals 40 P B C Combined NC/NO 2 4 See next page. SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 5A 250VAC • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at 1A 250VAC 50.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -20°C to +55°C • Mechanical life : 3.000.000 cycles • Front panel sealing : IP65 • Packaging unit : 20 pieces (except black chrome plated : 16 pieces) • Case : polyester, glass filled • Contacts : silver/nickel alloy • Bushing : stainless steel (std) • Actuator : stainless steel (std) CUT-OUT • Panel cut-out : Ø 22,2 (.874) or Ø 24,2 (.952) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) All model numbers below are for switches with standard bushing/actuator material. BASIC MODEL Flat actuator - solder lug terminals - AV22LP ➞ O-ring 29.00 (1.142) Hex nut 25 (.984) across flats 3.00 (.118) 4.00 (.157) 1.40 (.055) 2.40 (.094) 0.50 (.019) Ø20.00 (.787DIA) Ø26.00 (1.023DIA) AV22LP402 Ø22.00x1.00 SI (.866DIAx1.00 IS) 12.50 (.492) OTHER CONFIGURATIONS Curved actuator AV22LB402 APEM Recessed actuator AV22LC402 www.apem.com B-93 B AV series Security pushbutton switches with large actuator Bushing Ø 24 (.944) - low profile - momentary (combined NC/NO) BASIC MODEL Flat actuator - solder lug terminals - AV24LP ➞ O-ring Hex nut 27 (1.062) across flats 30.80 (1.213) 1.30 (.051) 4.00 (.157) 1.40 (.055) 2.40 (.094) 0.50 (.019) B Ø20.00 (.787DIA) Ø30.00 (1.181DIA) AV24LP402 Ø24.00x1.00 SI (.944DIAx1.00 IS) 14.20 (.559) OTHER CONFIGURATIONS Curved actuator Recessed actuator AV24LB402 AV24LC402 BUSHING/ACTUATOR MATERIAL For non-standard material, replace 40 with one of the following codes. Models with non-anodized actuator CODE BUSHING 40 (standard) Stainless steel 20 Chrome plated brass ACTUATOR Stainless steel Chrome plated brass Models with anodized actuator CODE BUSHING ACTUATOR COLOUR 1• 2• 4• Black chrome plated brass Chrome plated brass Stainless steel Replace • with one of the following codes : 1 : blue - 2 : black - 3 : pale green - 3F : dark green - 4 : natural - 5 : gold yellow CONTACT 6 : red - 6B : maroon / TERMINALS ø1.40 (.055 DIA) 2 (standard) NC/NO, solder lug terminals 4 NC/NO, quick-connect terminals 4 B-94 www.apem.com 2.80 (.110) APEM AV series Mushroom head security pushbutton switches Bushing Ø 22 (.866) - momentary (combined NC/NO) ORDER FORMAT Series Bushing diameter Bush./act. config. AV 22 PNA Actuator colour Contact/ terminals see below 2 4 Combined NC/NO SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 5A 250VAC • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1.000.000 cycles at 1A 250VAC 50.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -20°C to +55°C • Mechanical life : 1.000.000 cycles • Front panel sealing : IP65 • Packaging unit : 16 pieces • Case : polyester, glass filled • Contacts : silver/nickel alloy • Bushing : brass, nickel plated • Actuator : aluminium, anodized CUT-OUT • Panel cut-out : Ø 22,2 (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) BASIC MODEL Hex nut 25 (.984) across flats Solder lug terminals - red actuator - AV22PNA 25.00 (.984) 2.40 (.094) 0.50 (.019) 4.00 (.157) 1.40 (.055) ø30.00 (1.181DIA) AV22PNA62 8.50 (.334) ø22.00x1.00 SI (.866DIAx1.00 IS) Joint (O-ring) 10.80 (.425) ACTUATOR ANODIZATION COLOUR 1 : blue - 2 : black - 3 : pale green - 3F : dark green - 4 : natural - 5 : gold yellow - 6 : red - 6B : maroon CONTACT / TERMINALS 2 (standard) NC/NO, solder lug terminals 4 NC/NO, quick-connect terminals ø1.40 (.055 DIA) 4 APEM www.apem.com 2.80 (.110) B-95 B AV series Security pushbutton switches Bushing Ø 16 (.629) - momentary (NO) ORDER FORMAT Series Bush./act. Function config. AV 3 Case style Contact matl. Term. type Bush./act. material 0 C 9 00 06 16 08 NO (function 3) K See ”options” page. SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 200mA 48 VDC - 100mA 48VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 50.000 cycles at 200mA 48VDC 100.000 cycles at 100mA 48VDC • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Mechanical life : 1.000.000 cycles • Packaging unit : 60 pieces • Case : PBT • Contacts : brass, silver plated (C) • Bushing and actuator : nickel plated brass (std) CUT-OUT • Panel cut-out : Ø 16,2 (.637) • Min. pitch for matrix mounting : 24 mm x 24 mm (.944 x .944) All model numbers below are for switches with standard bushing/actuator material, without marking. BASIC MODEL Hex nut 19 (.748) across flats Flat actuator - screw terminals - AV06 3.00 (.118) ø12.00 (.472DIA) ø18.00 (.708DIA) AV0630C900 ø16.00X1.00 SI (.629DIAX1.00 IS) 3.00 (.118) 1.50 (.059) 9.50 (.374) 11.20 (.440) Screw terminals for wires 1,5 mm2 max. OTHER CONFIGURATIONS AV1630C900 B-96 2.00 (.078) 1.50 (.059) Curved actuator w. chamfer 3.00 (.118) Curved actuator 1.50 (.059) B Sealing AV0830C900 www.apem.com APEM AV series New! Security pushbutton switches Bushing Ø 16 (.629) - latching action ORDER FORMAT Series Bush./act. Function config. AV 1 Contact matl. 1 A Term. type Bush./act. material Sealing 00 06 16 ON OFF Case style 4 2 8 K See ”options” page. SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load :1,5A 250VAC - 1A 24VDC • Initial contact resistance : 50mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.500 Vrms 50 Hz min. between terminals 1 000 Vrms 50 Hz between terminals and frame • Electrical life : 100.000 cycles at 1,5A 250VAC 40.000 cycles at 1A 24VDC • Torque : 5 Nm min. - 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Operating temperature : -30°C to +70°C • Mechanical life : 200.000 cycles • Packaging unit : 25 pieces • Case : PA-6T, UL94-V0 • Contacts : silver (A) Gold plated silver (AD) on request. • Bushing and actuator : nickel plated brass (std) CUT-OUT • Panel cut-out : Ø 16,2 (.637) • Min. pitch for matrix mounting : 24 mm x 24 mm (.944 x .944) All model numbers below are for switches with standard bushing/actuator material, without marking. BASIC MODEL Hex nut 19 (.748) across flats Solder lug terminals - AV..11A200 3.40 (.133) OFF - ON Ø16.00X1.00 SI (.629DIAX1.00 IS) Curved actuator AV1611A200 1.40 (.055) ON 2.30 (.090) Ø12.00 (.472DIA) - Ø18.00 (.708DIA) OFF 3.00 (.118) Ø12.00 (.472DIA) Flat actuator AV0611A200 Ø18.00 (.708DIA) 3.00 (.118) EPOXY 1.50 (.059) 9.00 (.354) 15.20 (.598) OTHER CONFIGURATIONS Quick-connect terminals 5.08 (.200) EPOXY EPOXY 1.10 (.043) 0.50 (.019) 1.20 (.047) 2.40 (.094) 0.50 (.019) 8.00 (.314) 3.50 (.137) Straight PC terminals 2.80 (.047) Flat actuator AV0611A400 APEM Curved actuator AV1611A400 Flat actuator AV0611A800 Curved actuator AV1611A800 www.apem.com B-97 B AV series New! Security pushbutton switches Bushing Ø 19 (.748) - momentary (combined NC/NO) ORDER FORMAT 3 1 2 Series Bushing diameter Bush./act. config. AV 19 L Actuator style Bush./act. Contact/ matl terminals 00 4 See below Combined NC/NO SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 5A 250VAC - 5A 125VAC - 6.000 cycles 5A 15VDC - 3A 30VDC - 50.000 cycles • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between term. and frame • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 9 mm (.354) max. • Operating temperature : -20°C to +85°C • Mechanical life : 1.000.000 cycles • Front panel sealing : IP65 • Packaging unit : 20 pieces • Case : PA 6/6 • Contacts : silver • Bushing : nickel pl. brass (std) • Actuator : nickel pl. brass (std) CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) All model numbers below are for switches with standard bushing/actuator material. BASIC MODEL ➞ O-ring Solder lug terminals - AV19..007 Hex nut 22 (.866) across flats 2.00 (.078) 3 1 2 Ø15.00 (.590) Ø22.00 (.866DIA) Curved actuator AV19LB007 Ø15.00 (.590) 4 Flat actuator AV19LP007 0.50 (.019) Ø19.00X1.00 SI (.748DIAX1.00 IS) 1.50 (.059) 2.00 (.078) 3.60 (.141) Ø22.00 (.866DIA) B 7 P B 13.10 (.515) BUSHING/ACTUATOR MATERIAL 3.60 (.141) For non-standard material, replace 00 with one of the following codes. CODE BUSHING ACTUATOR 00 (std) 20 40 Nickel plated brass Chrome plated brass Stainless steel Nickel plated brass Chrome plated brass Stainless steel B-98 12.60 (.496) www.apem.com APEM AV series Security pushbutton switches Bushing Ø 19 (.748) - momentary (NO) ORDER FORMAT Series Bush./act. config. Case style AV 09 19 9P 9B NO (function 3) Function Contact matl. 3 C 100 000 Term. type Bush./act. Marking Sealing material 00 C A 9 2 K See ”options” page. SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load (C contacts): 2A 48 VDC • Approved ratings of models with long case and A contacts (AV..000) : UL-CSA : 4A 250VAC - 8A 125VAC - 6.000 cycles • Initial contact resistance : 10 mΩ max. at 1A 2V • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame 2.000 Vrms 50 Hz min. between terminals • Electrical life : 10.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Mechanical life : 1.000.000 cycles • Packaging unit : 40 pieces • Case : PBT • Contacts : brass, silver plated (C) or silver (A) • Bushing : brass, nickel plated (std) • Actuator : brass, nickel plated (std) CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm (1.181) x 30 mm (1.181) All model numbers below are for switches with standard bushing/actuator material, without marking. BASIC MODEL Hex nut 22 (.866) across flats Short case - flat actuator - AV09100...00 ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) 1.20 (.047) 2.80x0.5 (.110x.019) Solder lug / quick-connect term. AV091003C200 2.80 (.110) ø15.00 (.590DIA) ø22.00 (.866DIA) Screw terminals AV091003C900 7.30 (.287) 3.00 (.118) 5.50 (.216) 13.50 (.531) 5.00 (.196) EPOXY Screw terminals for wires 1,5 mm2 max. Hex nut 22 (.866) across flats Long case - flat actuator - UL-CSA approved - AV09000...00 3.00 (.118) ! New Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø22.00 (.866DIA) Screw terminals AV090003A900 Ø15.00 (.590DIA) 5.00 (.196) 2.00 (.078) 14.80 (.582) 10.50 (.413) Screw terminals for wires 1,5 mm max. 2 APEM www.apem.com B-99 B AV series Security pushbutton switches Bushing Ø 19 (.748) - momentary (NO) Case style : replace • with 1 for short case and 0 for long case. OTHER CONFIGURATIONS Ø22.00 (.866DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) Ø15.00 (.590DIA) Ø15.00 (.590DIA) Screw terminals AV19•003C900 Solder lug / quick-connect terminals AV19•003C200 25.00 (.984) 25.00 (.984) 4.50 (.177) Flat actuator, screw term. AV9P•003C900 Flat actuator, solder lug term. AV9P•003C200 25.00 (.984) 4.50 (.177) Ø22.00 (.866DIA) Curved actuator, screw term. AV9B•003C900 Curved act., solder lug term. AV9B•003C200 Wrench available under P/N U1929. AV series Security pushbutton switches Bushing Ø 19 (.748) - other electrical functions Hex nut 22 (.866) across flats Bushing Ø 19 (748) - combined NC/NO - AV..9035 • Single pole, solder lug terminals • Gold plated silver contacts • Current/voltage rating with resistive load : max. : 1A 30V - min : 10µA 5V Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) Flat actuator AV099035D200 0.80 (.031) Ø15.00 (.590DIA) Ø22.00 (.866DIA) • Dielectric strength : 1.000 Vrms between terminals 2.000 Vrms between terminals and frame • Electrical life : 250.000 cycles at full load • Mechanical life : 1.000.000 cycles • Packaging unit : 20 pieces • Further specifications : see previous page. 3.60 (.141) Curved actuator AV199035D200 5.08 (.200) 1.20 (.047) 2.00x0.40 (.078x.015) 3.00 (.118) Note : a current above 100mA damages the gold plating. Ø15.00 (.590DIA) B With knurled nut for matrix mounting 25 (.984) x 25 (.984) 2.00 (.078) 3.60 (.141) Curved actuator 15.00 (.590) 7.50 (.295) 5.20 (.204) Bushing/actuator materials, marking and sealing : see ”options” page. B-100 www.apem.com APEM AV series Security pushbutton switches Bushing Ø 22 (.866) - momentary (NO) ORDER FORMAT Series Bush./act. config. Case style AV 03 02 M3 M2 NO (function 3) Function Contact matl. 3 C 100 000 Term. type Bush./act. Marking Sealing material 00 C A 9 2 K See ”options” page. SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load (C contacts): 2A 48 VDC • Approved ratings of models with long case and A contacts (AV..000) : UL-CSA : 4A 250VAC - 8A 125VAC - 6.000 cycles • Initial contact resistance : 10 mΩ max. at 1A 2V • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and frame 2.000 Vrms 50 Hz min. between terminals • Electrical life : 10.000 cycles at full load • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Mechanical life : 1.000.000 cycles • Packaging unit : 20 pieces • Case : PBT • Contacts : brass, silver plated (C) or silver (A) • Bushing : brass, nickel plated (std) • Actuator : brass, nickel plated (std) CUT-OUTS • Panel cut-out : Ø 22,2 mm (.874) • Min. pitch for matrix mounting : 30 mm (1.181) x 30 mm (1.181) All model numbers below are for switches with standard bushing/actuator material, without marking. BASIC MODEL Hex nut 25 (.984) across flats Short case - flat actuator - AV03100...00 ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) 7.30 (.287) 3.00 (.118) 2.80x0.5 (.110x.019) Solder lug / quick-connect term. AV031003C200 ø15.00 (.59DIA) ø25.00 (.984DIA) Screw terminals AV031003C900 1.20 (.047) 2.80 (.110) 12.70 (.500) Screw terminals for wires 1,5 mm2 max. 6.30 (.248) Hex nut 25 (.984) across flats Long case - flat actuator - UL-CSA approved - AV03000...00 Ø22.00x1.00 SI (.866DIAx1.00 IS) ! New 2.00 (.078) 3.00 (.118) Ø15.00 (.59DIA) Ø25.00 (.984DIA) Screw terminals AV030003A900 Screw terminals for wires 1,5 mm max. 2 APEM EPOXY 5.00 (.196) www.apem.com 15.00 (.590) 10.00 (.248) 5.00 (.196) B-101 B AV series Security pushbutton switches Bushing Ø 22 (.866) - momentary (NO) Case style : replace • with 1 for short case and 0 for long case. OTHER CONFIGURATIONS Curved actuator Flatted bushing Ø15.00 (.590DIA) Ø25.00 (.984DIA) Flat actuator Screw terminals AVM3•003C900 Screw terminals AV02•003C900 Solder lug / quick-connect terminals AV02•003C200 Ø22.20 (.874DIA) 10.00 (.393 ) Curved actuator Screw terminals AVM2•003C900 AV series Security pushbutton switches Bushing Ø 22 (.866) - other electrical functions Hex nut 25 (.984) across flats Bushing Ø 22 (.866) - Normally closed (NC) - AV..1200 Curved actuator AV021202C00 ON - 15.40 (.606) (.519) 7.00 (.275) Hex nut 25 (.984) across flats 3.00 (.118) 1.60 (.063) 8.40 (.330) 5.80 (.228) Ø22.00x1.00 SI (.866DIAx1.00 IS) 3.60 (.141) ON 14.00 (.551) Ø15.00 (.59DIA) • Double pole, solder lug/quick-connect term., curved actuator • Silver contacts • Max. current/voltage rating with resistive load : 3(1,5)A 250VAC - 6A 125VAC - 3A 24VAC or DC • Dielectric strength : 3.000 Vrms min. between terminals and frame • Electrical life : 10.000 cycles at full load 50.000 cycles at 1A 24VAC or DC • Mechanical life : 100.000 cycles • Packaging unit : 10 pieces Ø3.00x0.50 (.118DIAx.0.50) 13.20 3.60 (.141) Bushing Ø 22 (.866) - alternate action - AV..4700 AV044746A200 3.00 (.118) Ø15.00 (.59DIA) Ø25.00 (.984DIA) 2.00 (.078) 0.50x2.80 (.019x.110) Flat actuator AV031202C00 Ø22.00x1.00 SI (.866DIAx1.00 IS) Ø15.00 (.59DIA) • Single pole, screw terminals, without marking • Silver plated copper contacts (C) • Max. current/voltage rating with resistive load : 2A 250VAC - 3A 125VAC - 2,5A 24VDC • Dielectric strength : 2.000 Vrms 50 Hz min. betw. term. and frame 2.000 Vrms. 50 Hz min. between terminals • Electrical life : 100.000 cycles at 0,3A 24VAC or DC 10.000 cycles at full load • Packaging unit : 20 pieces Ø25.00 (.984DIA) B Ø15.00 (.590DIA) 2.00 (.078) 3.60 (.141) Ø25.00 (.984DIA) 14.00 (.551) 20.60 (.811) 7.20 (.283) Further specifications : see previous page. Bushing/actuator materials, marking and sealing : see ”options” on next page. B-102 www.apem.com APEM AV series Security pushbutton switches Options After selecting basic model number, fill in last 3 boxes with desired options. Series Bush./act. config. Case style Function Contact matl. Term. type Bush./act. Marking Sealing material AV BUSHING/ACTUATOR MATERIAL For non-standard material, replace 00 with one of the following codes. ** Option 80 not available on models with dia. 16 mm (.629) bushing Flat or curved metal actuator CODE BUSHING ACTUATOR 00 (standard) 10 12 20 30 40 80 ** Nickel plated brass Nickel plated brass Nickel plated brass Chrome plated brass Chrome plated brass Stainless steel Varnished polished brass Nickel plated brass Stainless steel Chrome plated brass Chrome plated brass Stainless steel Stainless steel Varnished polished brass B Flat thermoplastic actuator (not available with dia. 16 mm (.629) bushing) CODE BUSHING ACTUATOR COLOUR 0• (standard) 2• 8• Nickel plated brass Chrome plated brass Varnished polished brass Replace • with one of the following codes. 1 : blue - 2 : black - 3 : green - 4 : grey 5 : yellow - 6 : red - 7/1: white - 9 : orange Select an option from each of the two tables below. MARKING For flat or curved actuator. Not available on model AV031202C00. - by engraving on brass actuator (stainless steel on request) - by hot stamping on thermoplastic actuator. Ø15.00 (0.590DIA) TYPE OF MARKING CODE TYPE 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O CODE 8.00 (0.314) Letter O : same code and same design as number 0. For special symbols, consult factory. Minimum order : 500 pieces 1.50 (0.059) COLOUR OF MARKING COLOUR Brass actuator 0 (standard) 2 Same as finish Black Note : a finished product supplied in version “0” cannot be modified to version "2". Thermoplastic actuator 2 Black 7 White SEALING Blank No sealing 1 1 2 2 K Frontal panel sealing (IP65) ➀ elastomeric membrane ➁ external gasket ➀ internal gasket ➁ external gasket For types with bushing Ø 16 APEM K Front panel sealing (IP65) For types with bushing Ø 19 or Ø 22 www.apem.com B-103 AV series Snap-action security pushbutton switches Bushing Ø 19 (.748) - illuminated or not - momentary (NO) ORDER FORMAT Series Bush./act. config. Case style AV Illum. or not Funct. Contact matl. C7 3 09 19 NO (function 3) Term. Bush./act. LED Marking Seal. type material colour D 2 00 L 0 2 9 K See ”options” on next page. SPECIFICATIONS • Max. current/voltage rating with resistive load : 50mA 24VDC • LED voltage and consumption : 2-colour LED : 2V (3V max.) 20mA Other colours : 2V (3V max.) 10mA A resistor must be series-connected by the user.** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between terminals and bushing • Electrical life : 1.000.000 cycles at full load • Operating force : 7 N +/-2N • Travel : 0,7 mm (.027) +/- 0,1 mm (.003) • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Soldering : 270°C max. during 3 sec. • Packaging unit : 40 pieces • Case : PBT UL94-V0 • Terminals : brass, gold plated • Contacts : gold plated dome • Bushing : brass, nickel plated (std) • Actuator : brass, nickel plated (std) • LED CUT-OUTS • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm (1.181) x 30 mm (1.181) All model numbers below are for switches with standard bushing/actuator material, without marking. ** Resistor value = supply voltage - LED forward voltage LED forward current Hex nut 22 (.866) across flats Flat actuator - non-illuminated Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) 2.00 (.078) 3.00 (.118) 1.90 (.074) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Screw terminals AV09C703D900 Ø15.00 (.590DIA) Ø22.00 (.866DIA) 1.10 (.043) Solder lug terminals AV09C703D200 EPOXY 4.15 (.163) 13.50 (.531) Also available with curved actuator : AV19C703D200 or AV19C703D900 3.90 (.153) 13.50 (.531) 13.20 (.519) Hex nut 22 (.866) across flats Flat actuator - illuminated Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) 2.00 (.078) 3.00 (.118) Ø10.00 (.393DIA) Ø15.00 (.590DIA) - Ø22.00 (.866DIA) + Ø15.00 (.590DIA) Screw terminals AV09C7L3D900 1.90 (.074) 1.10 (.043) Solder lug terminals AV09C7L3D200 Ø22.00 (.866DIA) B MATERIALS EPOXY 4.15 (.163) 13.50 (.531) B-104 www.apem.com 13.20 (.519) 13.50 (.531) 3.90 (.153) APEM AV series Snap-action security pushbutton switches Options After selecting basic model no., fill in last 4 boxes with desired options. Series Bush./act. config. Case style Illum. or not Funct. Contact matl. Term. Bush./act. LED Marking Seal. type material colour AV BUSHING/ACTUATOR MATERIAL For non-standard material, replace 00 with one of the following codes. Non-illuminated models Illuminated models CODE BUSHING ACTUATOR CODE BUSHING ACTUATOR 00 (std) 10 30 40 80 Nickel plated brass Nickel plated brass Chrome plated brass Stainless steel Varnished polished brass Nickel plated brass Stainless steel Stainless steel Stainless steel Varnished polished brass 00 (std) 20 40 45 80 Nickel plated brass Chrome plated brass Stainless steel Stainless steel Varnished polished brass Nickel plated brass Chrome plated brass Stainless steel Nickel plated brass Varnished polished brass LED COLOUR No LED Blank 1: Blue - 3 : Green - 5 : Yellow - 6 : Red - 7 : White - 9 : Amber - 2 : Red/green Select an option from each of the two tables below. MARKING For flat or curved actuator. TYPE OF MARKING - by engraving on non-illuminated brass actuator (stainless steel on request). - by hot stamping on thermoplastic insert ( illuminated actuators) Ø10.00 (0.393DIA) CODE TYPE 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O 8.00 (0.314) Letter O : same code and same design as number 0. 1.00 (0.039) 1.50 (0.059) For special symbols, consult factory. Minimum order : 500 pieces COLOUR OF MARKING CODE COLOUR Non-illuminated actuators 0 (standard) Same as finish 2 Black Note : a finished product supplied in version “0” cannot be modified to version "2". Illuminated actuators 2 Black (on white) SEALING No sealing Blank 1 2 K Front panel sealing (IP65) APEM ➀ internal gasket ➁ external gasket www.apem.com B-105 B AV series New! Snap-action security pushbuttons with overmolded actuator Bushing Ø 19 (.748) - illuminated or not - momentary (NO) ORDER FORMAT Series Bush./act. config. AV Illum. or not 9 Contact matl. Term. type D Overmolding 2 4 K See ”options” on next page. SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 50mA 24VDC • LED voltage and consumption : 2-colour LED : 2V (3V max.) 20mA Other colours : 2V (3V max.) 10mA A resistor must be series-connected by the user.** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between terminals and bushing • Electrical life : 1.000.000 cycles at full load • Operating force : 7 N +/-2N • Travel : 0,7 mm (.027) +/- 0,1 mm (.003) • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Operating temperature : -30°C to +70°C • Soldering : 270°C max. during 3 sec. • Packaging unit : 40 pieces • Case : PBT UL94-V0 • Terminals : brass, gold plated • Contacts : gold plated dome • Bushing : brass, nickel plated (std) • Actuator : stainless steel, with thermoplastic overmolding • LED CUT-OUTS • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm (1.181) x 30 mm (1.181) ** Resistor value = supply voltage - LED forward voltage LED forward current Hex nut 22 (.866) across flats Solder lug terminals 3.00 (.118) 2.00 (.078) 2.00 (.078) 1.90 (.074) Ø10.00 (.393DIA) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Non illuminated AV9S0D2 1.10 (.043) Illuminated AV9SLD2 EPOXY 4.15 (.163) 4.30 (.169) 9.80 (.385) Also available with bushing Ø 22 (.866) : on request. Hex nut 22 (.866) across flats Straight PC terminals 2.00 (.078) 3.00 (.118) 4.00 (.157) Ø10.00 (.393DIA) Ø15.00 (.590DIA) 2.00 (.078) Ø22.00 (.866DIA) Non illuminated AV9S0D4 Ø15.00 (.590DIA) Illuminated AV9SLD4 Ø22.00 (.866DIA) B LED Actuator Seal. colour style 0 S0 SL NO (function 3) Bush. material EPOXY 6.00 (.236) 9.80 (.385) 4.30 (.169) Also available with bushing Ø 22 (.866) : on request. B-106 www.apem.com APEM AV series New! Snap-action security pushbuttons with overmolded actuator Options Series Bush./act. config. After selecting basic model no., fill in last 5 boxes with desired options. Illum. or not Contact matl. Term. type Bush. material Overmolding LED Actuator Seal. colour style AV BUSHING MATERIALS COLOUR OF OVERMOLDING LED COLOURS CODE MATERIAL CODE COLOUR CODE COLOUR 0 (std) 2 4 5 6 7 8 9 Nickel plated brass Chrome plated brass Stainless steel Gold plated brass Chrome plated brass, satin Chrome pl. brass, matt black Varnished polished brass Polished brass 1 2 3 4 5 6 7 8 9 Blue Black Green Grey Yellow Red White Translucent Orange Blank 1 2 3 5 6 7 9 No LED Blue Red/green Green Yellow Red White Amber B ACTUATOR STYLES The ring and symbols are obtained by photochemical engraving of a stainless steel insert. The insert is then overmolded in the desired colour. The following actuator styles are available. For other types, consult factory. CODE 001 002 DESCRIPTION Illuminated ring and disc Illuminated ring 003 004 005 Arrow Loudspeaker OFF Double arrow RING/SYMBOL SEALING No sealing Blank 1 2 K Front panel sealing (IP65) APEM ➀ internal gasket ➁ external gasket www.apem.com B-107
AV1630C900 价格&库存
很抱歉,暂时无法提供与“AV1630C900”相匹配的价格&库存,您可以联系我们找货
