SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE
DPS9 SERIES PUSHWHEEL SWITCHES
FEATURES
z.315"(8mm)
wide pushwheel switches with extra large visible readout characters .
zBi-directional snap action detent pushbutton mechanism.
zBlack housing and drum with white printing.
zGangable
front mounting models with spacers and side covers.
zGold wiping action contacts.
zP.C. board options include solderable lands.
DPS9 SPECIFICATIONS
Panel mounting hole:
Height
Width
Installed depth with p.c. board:
Short
Long
Insertion from front
Insertion from rear
MATERIALS
Body:
PPO
1.300"(33mm)
.315"(8mm)
PC board:
1.535"(39mm)
1.968"(50mm)
yes
no
FR 4 DIN 40802
IEC 249-2, Contact
surface gold over
nickel on copper
Sliding contact:
Gold over nickel
on copper alloy
CODES
Code
positions marking
111 Decimal
10
0-9
131 BCD
10
0-9
137 BCD comp
10
0-9
141 BCD + comp
10
0-9
301 Hexadecimal 16 0-9, A-F(0-15)
307 Hexadec comp 16 0-9, A-F(0-15)
400 change-over
10
+,-,+,-,etc..
see truth tables
see truth tables
see truth tables
see truth tables
see truth tables
see truth tables
see truth tables
STANDARD COLORS
Housing,Drum,Printing
2 = black 3 = white
2,2,3
T
ELECTRICAL DATA
Operating voltage:
Contact load, static:
Contact load, dynamic:
Contact resistance (type AK):
40 V max.
1 A max.
100 mA max.
less than 100 mOhm
TECHNICAL DATA
Operating temperature range:
Electric life, min. switching cycles
Actuation force, approx (oz.):
Weight, approx. (grams):
Character ht: 10 digit - .268" (6.8mm)
Audible click
Vibration DIN IEC 68, parts 2-6
Shock DIN 40046, part 7
-20°C to 80°C
greater than 1,000,000
16
6.5
16 digit - .169" (4.3mm)
yes
yes
yes
Other special features are available upon
request including:
Factory or customer set stops (10 digit models)
L.E.D. illumination (transparent drum)
Red digits
Decimal point
Special codes or printing
Gray housing
See sockets at end of Pushwheel section.
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
T1
TRUTH TABLES
2
3
4
5
6
7
8
9
C
z
z
z
z
z
z
z
z
z
z
CODE 137
BCD COMP.
1 2 4 8
z
z
z z
z
z
z
z z
z z z
z
z
z
C
z
z
z
z
z
z
z
z
z
z
2
3
4
5
6
7
8
9
1 2 4
z z z
z z
z
z
z
z z
z
z
z
z
z
z
z
C
z
z
z
z
z
z
z
z
z
z
z z z
z z
A+
z
Az
z
z
z
z
z
z
z
z
C 1 2 4 8 1 2 4 8
C 0 1 2 3 4 5 6 7 8 9
z z
z
8
z
z
z
z
z
z
z
z
CODE 141
BCD + COMP.
CODE 111
DECIMAL
2
3
4
5
6
7
8
9
CODE 301
HEXADECIMAL
CODE 400
CHANGE-OVER
z
z
z
z
z
z
z
z
z
z
z
z
2
3
4
5
6
7
8
9
z
z z z z
z z
z
z z z
z
z
1 2 4 8 C
z
z
z
z
z
z z
z
z
z
z
z
z
z z
z
z
z z z
z z
z
z z
z
z z
z z
z z
z z z
z
z z z
z z z z
z z z z z
2
3
4
5
6
7
8
9
A
B
C
D
E
F
C
z
z
z
z
z
z
z
z
z
z
z
z
z
z
z
z
1 2 4 8
z z z z
z z z
z
z z
z z
z
z z
z
z
z
z
z
z z z
z z
z
z
z
z z
z
z
z z
z z z
z z
z
z
z z
z
z z
z
z
z
z
2
3
4
5
6
7
8
9
A
B
C
D
E
F
CODE 307
HEXADEC. COMP.
z z
z
z
z z z z
z
z
z z z z
z z
z
z z
MECHANICAL OUTLINE WITH PANEL CUT-OUT & MOUNTING
n = number of decades
Dimensions in brackets apply when DPS910PB2 side covers are used.
T
PIN CONNECTIONS
z 131
z The switching mode is
shorting - i.e. - even during
actuation, at least one
output is connected to
input C.
137
141
z 301
AK z 307
400
111
+ 1 2
C 8
+ 1 2
C 8
4 +
2 4 2 C 8 1 1 8 4 + 1 2
+ 1 2
C 8
C 8
4 4 -
+ C
A- A+
0 1 2 3 C 4 5 6 7 8 9
111bl + C 0 1 2 3 4 5 6 7 8 9
T2
4 -
Pitch .079"(2mm)
CODE 131
BCD
PRINTED CIRCUIT OPTIONS
P.C. boards have .039" (1mm) holes and are suitable for soldering or socket connection (with the exception of LED
illumination option).
AK short p.c. board
AL long p.c. board
LS p.c. board w/solder pins
Allows customer to add
resistors, diodes, ect.
Ordering information: Below is an order format that enables you to 'build your own switch' and specify the correct switch model
number by simply selecting from available options shown and filling in the boxes. Consult factory for fully assembled switches.
'BUILD YOUR OWN SWITCH' ORDER FORMAT
Series model
D P
S
Code
P.C. board
Terminations
9
Standard colors
2
1
1
1
1
3
3
4
1
3
3
4
1
7
1
1
7
Decimal
BCD
BCD comp.
BCD + comp.
Hexadecimal.
Hexadecimal comp.
Change-over
A K Short
A L Long
(NONE)
L S with p.c.
solder pins
Black housing.
& drum, white
lettering.
Example of complete model no.: DPS9141AKLS2
Order SP15 as a separate line item for limit stop
pin (for 10 position models only).
ACCESSORIES
Order separately
T
DPS9L2 Dummy housing
DPS910PB2 Pair of side covers
DPS910P2 Pair of side covers
DPS9L2
Dummy
switches
These are empty
plastic housings with
the same dimensions
as DPS9 model (see
outline). Use to fill
hole where switch is
not needed.
DPS910A2 Spacer
T3
很抱歉,暂时无法提供与“DPS9141AK2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 9+108.15402
- 21+106.19528
- 42+104.16399
- 83+102.20525
