1202A2
1202A2
    APEM(埃斐)
    按动开关 1万次 单刀单掷-常闭 8A,4A 24V -20℃~+55℃
1202A2 数据手册
15-Serie 1200-A_20-Serie 1200-A 04/11/14 15:01 Page107 1200 series Momentary pushbutton switches - round plunger Distinctive features and specifications UG1410A ❑ Butt action contacts, double break ❑ NF (EN 61058-1), UL and CSA approved B2 ELECTRICAL SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : - silver contacts (A) : 4A 250VAC - 8A 125VAC - 4A 24VDC - 8A 12VDC - silver plated copper contacts (C) : 2A 250VAC - 3A 125VAC - 2A 24VDC 3A 12VDC • Initial contact resistance : 10 mΩ • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals 3.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 10.000 cycles at full load GENERAL SPECIFICATIONS • Torque : 1,50 Nm (1.10 Ft.lb) max. applied to nut • Panel thickness : 5 mm (.196) max. • Total travel : NO : 4,5 (.177) +/- 0,3 (.011) NC : 3,5 (.137) +/- 0,3 (.011) • Operating temperature : -20°C to +55°C • Case : polyamide • Plunger : polyamide • Bushing : brass, nickel plated • Contacts : A : silver C : copper, silver plated AGENCY APPROVALS EN 61058-1 2A 250VAC or 4A 250VAC, T55/125°C All models 4A 250VAC - 8A 125VAC All models function 3 (NO) Models 1233X209 and 1233X209L are standard marked NF. To order switches marked NF, UL or CSA, complete appropriate box of ordering format. ABOUT THIS SERIES Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Sealing boots are available to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied : - silver contact models : 1 hex nut U166 and 1 knurled nut U411 - copper contact models : 1 hex nut U42 and 1 knurled nut U411 Standard and special hardware are presented in section I. Packaging unit : 40 pieces, except model 1200.L (50 pieces). The company reserves the right to change specifications without notice. APEM www.apem.com B2-107 15-Serie 1200-A_20-Serie 1200-A 31/10/14 09:00 Page108 1200 series Momentary pushbutton switches - round plunger Solder lug/quick-connect terminals - screw terminals • Single pole configurations • Approved models : see following pages • Panel cut-out : Ø 12,2 (.480) NC (function 2) 121. 122. 9.20 (.362) 6.35x0.80 (.25x.031) Ø3.00x0.50 (.118DIAx0.50) 0.80 (.031) 6.35 (.25) 120. 123. MODEL STRUCTURE Plunger height : NO model : 7,50 mm, NC model : 5,80 mm ➞ Keyway Solder lug/quick-connect terminals Ø8.00 (.315DIA) Normally Open 12.00 (.472) 1213 17.00 (.669) 9.20 (.362) Normally Closed 1.00 (.039) 1212 10.50 (.413) 7.50 (.295) Ø12.00x0.75 SI (.472DIAx0.75 IS) 13.20 (.519) 14.00 (.551) 6.35x0.80 (.25x0.031) ➞ Keyway Screw terminals Ø8.00 (.315DIA) Normally Closed 1223 Normally Open 14.00 (.551) 8.00 (.315) 1.00 (.039) 13.20 (.519) 17.00 (.669) ➞ Keyway ø12.00x0.75 SI (.472DIAx0.75 IS) Normally Open 10.50 (.413) 1233 17.00 (.669) www.apem.com 12.00 (.472) Normally Closed 1.00 (.039) 1232 ø8.00 (.315DIA) 13.20 (.519) 9.20 (.362) Normalized quick-connect terminals B2-108 12.00 (.472) 10.50 (.413) 1222 7.50 (.295) Ø12.00x0.75 SI (.472DIAx0.75 IS) 7.50 (.295) B2 0.80 (.031) 6.35 (.25) 9.20 (.362) 6.35x0.80 (.25x.031) 4.50 (.177) NO (function 3) Ø.50 (.059DIA) Ø3.00x0.50 (.118DIAx0.50) 7.20 (.283) 9.20 (.362) Ø3.10 (.122DIA) 4.50 (.177) ➞ Keyway ø1.50 (.059DIA) 14.00 (.551) 6.35x0.80 (.25x0.031) APEM 15-Serie 1200-A_20-Serie 1200-A 31/10/14 09:00 Page109 1200 series Momentary pushbutton switches - round plunger Plunger height : NO model : 7,50 mm, NC model : 5,80 mm 10.50 (.413) Normally Open 6.35x0.80 (.25x.031) 13.20 (.519) 17.00 (.669) ➞ Keyway Ø12.00x0.75 SI (.472DIAx0.75 IS) 14.00 (.551) B2 Ø8.00 (.315DIA) 7.50 (.295) Right angle screw terminals + clamp 12.00 (.472) 1203 7.20 (.283) Normally Closed Ø8.00 (.315DIA) 1.00 (.039) 1202 Ø12.00x0.75 SI (.472DIAx0.75 IS) 7.50 (.295) ➞ Keyway Straight screw terminals + clamp 90˚ 21.00 (.826) 6.35x0.80 (.25x.031) 14.00 (.551) 7.00 (.275) 12.00 (.472) 10.50 (.413) Normally Open 1.00 (.039) 1203-7 CONTACT MATERIALS A C Silver Copper, silver plated FINISH LUXE Chrome plated cap nut U117 instead of knurled nut U411 PLUNGER COLOURS 2 : Black - 3 : Green - 6 : Red - 7/1 : White APEM www.apem.com B2-109 15-Serie 1200-A_20-Serie 1200-A 31/10/14 09:00 Page110 1200 series Momentary pushbutton switches - round plunger SPECIAL MODELS NF standard marked - Silver contacts X209 Ø12.00x0.75 SI (.472DIAx0.75 IS) Ø8.00 (.315DIA) 9.20 (.362) 1.00 (.039) Normally open 1233A•X209 B2 12.00 (.472) 10.50 (.413) 7.50 (.295) ➞ Keyway 13.20 (.519) 17.00 (.669) Replace • with the desired plunger colour. 14.00 (.551) 6.35x0.80 (.25x0.031) NF standard marked - Silver contacts X209L Ø12.00x0.75 SI (.472DIAx0.75 IS) Ø8.00 (.315DIA) 12.00 (.472) Normally open 13.20 (.519) Replace • with the desired plunger colour. 17.00 (.669) 6.35x0.80 (.25x0.031) 9.20 (.362) 1.00 (.039) 1233A•X209L 10.50 (.413) 13.00 (.511) ➞ Keyway 14.00 (.551) NOTE : Ground connector U187 compulsory on models X209 and X209L if the panel is not metallic or not connected to ground. Order separately : see section I. AGENCY APPROVALS NF All models UL-CSA All models function 3 (NO), including X209 and X209L Marking : to order switches marked NF, UL or CSA, complete above box with desired approvals. B2-110 www.apem.com APEM 16-Serie 1200M-MR-A_21-Serie 1200M-MR-A 04/11/14 15:03 Page111 1200M/MR series Robust momentary pushbutton switches - metal plunger Distinctive features and specifications UG1410A ❑ Butt action contacts, double break ❑ UL and CSA approved B2 ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A) : 4A 250VAC - 8A 125VAC - 4A 24VDC - 8A 12VDC - silver plated copper contacts (C) : 2A 250VAC - 3A 125VAC - 2A 14VDC - 3A 12VDC • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals 3.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 10.000 cycles at full load MATERIALS GENERAL SPECIFICATIONS • Case : polyamide • Plunger : top chrome plated brass on polyamide base • Bushing : brass, nickel plated • Cap nut : brass, chrome plated • Contacts : A : silver C : copper, silver plated • Torque : 1,50 Nm (1.10 Ft.lb) max. applied to nut • Panel thickness : 4,5 mm (.177) max. • Total travel : NO : 4,5 mm (.177) +/- 0,3 (.011) NC : 3,5 mm (.137) +/- 0,3 (.011) • Operating temperature : -20°C to +55°C AGENCY APPROVALS 4A 250VAC - 8A 125VAC Availability : approved models are 1213A and 1203A (M or MR) (model 1223A is only UL approved). Marking : to order switches marked UL or CSA, complete appropriate box of ordering format. ABOUT THIS SERIES Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Mounting accessories : standard hardware supplied with all models : 1 hex nut U166 and 1 conic cap nut U1866-6. Special cap nut U1874 is presented on the following pages. Packaging unit : 40 pieces The company reserves the right to change specifications without notice. APEM www.apem.com B2-111 16-Serie 1200M-MR-A_21-Serie 1200M-MR-A 31/10/14 08:59 Page112 1200M/MR series Robust momentary pushbutton switches - metal plunger Solder lug/quick-connect terminals - screw terminals 6.35x0.80 (.25x.031) Ø3.00x0.50 (.118DIAx0.50) Ø3.00x0.50 (.118DIAx0.50) 0.80 (.031) 6.35 (.25) 9.20 (.362) 9.20 (.362) 0.80 (.031) 6.35 (.25) Keyway Solder lug/quick-connect terminals 6,35 x 0,8 (.250 x .031) ➞ Ø12.00x0.75 SI (.472DIAx0.75 IS) Ø8.00 (.315DIA) 1213MR 1213M NO 12.00 (.472) NC 17.00 (.669) 9.20 (.362) 1212M 1.00 (.039) 1212MR 7.50 (.295) Curved plunger Flat plunger 13.20 (.519) 6.35x0.80 (.25x0.031) 14.00 (.551) 1223MR 1223M NO 12.00 (.472) NC 13.20 (.519) 17.00 (.669) 14.00 (.551) 8.00 (.315) 1222M 1.00 (.039) 1222MR 7.50 (.295) Curved plunger Flat plunger Ø8.00 (.315DIA) 5.00 (.196) Ø12.00x0.75 SI (.472DIAx0.75 IS) 5.00 (.196) ➞ Keyway Screw terminals 5.00 (.196) Ø12.00x0.75 SI (.472DIAx0.75 IS) Ø8.00 (.315DIA) 1203MR 1203M NO 13.20 (.519) 17.00 (.669) www.apem.com 12.00 (.472) NC 6.35x0.80 (.25x.031) 14.00 (.551) 7.00 (.275) 1202M 1.00 (.039) 1202MR 7.50 (.295) Curved plunger Flat plunger 5.00 (.196) ➞ Keyway Screw terminals + clamp B2-112 5.00 (.196) MODEL STRUCTURE 5.00 (.196) B2 NC (function 2) 4.50 (.177) NO (function 3) 120. 122. Ø3.10 (.122DIA) 7.20 (.283) • Flat or curved plunger • Panel cut-out Ø 12,2 (.480) • Single pole 121. ➞ Keyway APEM 16-Serie 1200M-MR-A_21-Serie 1200M-MR-A 31/10/14 09:00 Page113 1200M/MR series Robust momentary pushbutton switches - metal plunger CONTACT MATERIALS Silver Copper, silver plated A C AGENCY APPROVALS B2 UL - CSA Availability : approved models are 1213A and 1203A (M or MR) - model 1223A is only UL approved. Marking : to order switches marked UL or CSA, complete above box with desired approvals. SPECIAL CAP NUT 3.50 (.137) Chrome plated cap nut Ø 16 (.629), flat and plain. Can be supplied instead of standard cap nut U1866-6. Order separately. Ø16.00 (.629DIA) U1874 APEM www.apem.com B2-113
1202A2 价格&库存
很抱歉,暂时无法提供与“1202A2”相匹配的价格&库存,您可以联系我们找货
