10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page44
13000 series
Professional quick-break momentary pushbutton switches
Distinctive features and specifications
UG1410A
❑ PC and panel mount models
❑ Bushing Ø 6,35 (1/4) and 11,9 (15/32)
❑ UL and CECC approved
B2
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (A-AD2) : 4A 30VDC
- gold plated contacts (CD) : 100mA 30V
• Minimum load (AD2-CD contacts) : 10mA 50mV, 10µA 5V min.
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
1.000 Vrms 50 Hz min. between terminals
2.000 Vrms 50 Hz min. between poles and between terminals and frame
• Contact bounce : 2 ms max.
• Electrical life :
Contacts
Number of cycles
A
4A 30VDC
50.000
AD2
4A 30VDC
(gold plating : 100mA 30VDC max.)
20.000
CD
100mA 30VDC
50.000
Low level or mechanical life
MATERIALS
150.000
GENERAL SPECIFICATIONS
• Case : diallylphthalate (DAP)
• Actuator : brass, nickel plated
• Bushing : brass, nickel plated
• Housing : brass, nickel plated
• Contacts : A : silver
AD2 : silver, gold plated
(2 micron gold)
CD : brass, gold plated
• Terminal seal : epoxy
• Torque : 1,25 Nm (.922 Ft.lb)
max. applied to nut
• Standard panel thickness : 2 mm
(.078 ) max.
• Total travel : 2 mm (.078)
• Operating temperature :
-40°C to +85°C
Note : AD2 contacts can be used for high level applications.In this case, the
gold layer is considered only as a protection against oxidation during
storage.
The company reserves the right to change specifications without notice.
B2-44
www.apem.com
APEM
10-Serie 13000-A_13-Serie 13000-A 04/11/14 14:47 Page45
13000 series
Specifications
RELIABILITY
- RUN-IN TEST
Upon request, each individual switch can be submitted to a low level run-in
test of 50 or 250 cycles to ensure suitability for special applications requiring
a very high level of reliability (military, space,etc.).
AGENCY APPROVALS
2A 125VAC/250VAC
CECC 96401-001
Designed to MIL specifications
B2
Availability :
UL : all models with silver or gold plated silver contacts
CECC : consult factory for details of approved models.
Marking : to order switches marked UL or CECC, complete appropriate box
of ordering format.
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
Sealing boots are available to protect the switches against dust and water. They are presented in section H.
Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and
1 lockwasher.
Standard and special hardware available are presented in section I.
Packaging unit : 50 pieces.
APEM
www.apem.com
B2-45
10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page46
13000 series
Overview
13
Terminals and bushing
SERIES
2
4
B2
Straight PC terminals,
bushing Ø 6,35 (1/4)
Solder lugs, bushing Ø 6,35
(1/4) or 11,9 (15/32)
Right angle terminals,
Contact materials
A
AD2
CD
No of poles
3
4
Single pole
Double pole
Electrical function
5
ON
Finish
Silver
Silver, gold plated
(2 micron gold)
Brass, gold plated
Terminals
MOM
Blank Solder lugs or straight PC
depending on model
W
Right angle, horizontal
mounting
Caps
Special options
Blank Bright chrome finish
G
Black finish on
bushing, plunger and
hardware
Blank
X640
X768
No special
requirement
Reinforced sealing
by three O-rings
Bushing Ø 11,9
(15/32) + front
panel sealing
(double pole only)
U900
U1140
U1720
U480
U630
U2430
U2020
Ø 5 (.196)
Ø 8 (.314)
Ø 9,4 (.370)
Ø 10 (.393) std
Ø 15 (.590)
Square, height
4 (.157)
Square, height
6 (.236)
For models with Ø 4
(.157) plunger only.
Plungers
Sealing
Blank Standard for Ø 6,35
(1/4) bushing
-4
-9
4 mm (.157) long, for
Ø 11,9 (15/32)
bushing (X768)
9 mm (.354) long, for
Ø 11,9 (15/32)
bushing (X768)
Blank Epoxy sealed
terminals standard
K
Front panel sealing by
one O-ring and
sealing washer
Reinforced sealing, see X640
under "Special options".
Approvals
UL
CECC
Availability :
Consult factory for
details of approved
models.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- options in the same order as in above chart
B2-46
www.apem.com
APEM
10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page47
13000 series
Solder lug terminals : 13400 - Straight PC terminals : 13200
• Threaded bushing Ø 6,35 mm (1/4)
• Epoxy sealed terminals standard
1.20
(.047)
1 2 3
1.00
(.039)
9.50
(.374)
5.00
(.196)
1.70
(.066)
➞ Keyway
2.50
(.098)
MODEL
STRUCTURE
B2
➞ Keyway
ON
MOM
Ø6.35-40UNS
(1/4-40UNS)
MOM
1
EPOXY
4.00
(.157)
2.50
(.098)
2
3
13.40
(.527)
ON
6.00
(.236)
1-2
14.00
(.551)
0.50
(.019)
5.00
(.196)
Double pole
13445
1-3
Ø4.00
(.157 DIA)
0.70
(.027)
Single pole
13435
8.00
(.314)
6.30
(.248)
6.00
(.236)
Double pole
13245
ON
MOM
EPOXY
1.00
(.039)
4.00
(.157)
1
2
0.50
(.019)
3
4.00
(.157)
Ø6.35-40UNS
(1/4-40UNS)
6.00
(.236)
6.00
(.236)
4.00
(.157)
MOM
Ø1.6
(.062 DIA)
13.40
(.527)
ON
14.00
(.551)
0.70
(.027)
1-2
Ø4.00
(.157 DIA)
9.50
(.374)
1-3
Single pole
13235
6.30
(.248)
8.00
(.314)
6.00
(.236)
➞ Keyway
PANEL CUT-OUT
13400 - 13200
Ø2.20
(.086 DIA)
5.20
(.204)
2.70
(.106)
Standard
APEM
Ø6.50
(.255 DIA)
Ø6.50
(.255 DIA)
1.10
(.043)
Ø6.50
(.255 DIA)
With K
sealing option
2.70
(.106)
With X640
sealing option
www.apem.com
B2-47
10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page48
13000 series
Right angle terminals : 13400W
1-2
MOM
Ø4.00
(.157 DIA)
Ø1.6
(.062 DIA)
4.40
(.173) EPOXY
2
3
13.40
(.527)
1
0.70
(.027)
5.90
(.232)
2.60
(.102)
9.27
(.364)
1.00
(.039)
4.00
(.157)
5.08
(.200)
9.27
(.364)
0.40
(.015)
1-3
ON
13435W
6.00
(.236)
8.00
(.314)
Ø6.35-40UNS
(1/4-40UNS)
➞ Keyway
Right angle terminals - single pole
4.00
(.157)
4.00
(.157)
0.50
(.019)
14.20
(.559)
B2
Panel cut-out, see previous page.
CONTACT MATERIALS
A
AD2
CD
Silver
Silver, gold plated (2 micron gold)
Brass, gold plated
PLUNGER
Dash compulsory before plunger code.
Blank
Standard plunger for Ø 6,35 (1/4) bushing
-4
4 mm (.157) long plunger for Ø 11,9 (15/32) bushing (X768 option)
-9
9 mm (.354) long plunger for Ø 11,9 (15/32) bushing (X768 option)
B2-48
www.apem.com
APEM
10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page49
13000 series
FINISH
Blank
G
Black finish on bushing, actuator and hardware
SEALING
1
2
Reinforced sealing : see X640 under "Special options".
Ø11.80
(.464 DIA)
Ø5.80
(.228 DIA)
➀ O-ring
Ø6.40
(.251 DIA)
Front panel sealing by one O-ring and sealing washer. Protects the
switch against water and dust.
Panel seal withstands 1 bar pressure and remains sealed even when
switch is operated.
2.00 Maxi
(.078 MAX)
K
Ø10.60
(.417 DIA)
2.30
(.090)
B2
➁ Sealing washer
X640
Front panel sealing by three O-rings. Flatted bush for precise orientation.
Protects the switch against water and dust.
Panel seal withstands 1 bar pressure and remains sealed even when switch
is operated.
4.00 Maxi
(.157 MAX)
SPECIAL OPTIONS
Available on models with Ø 6,35 (1/4) bushing only.
X935
APEM
➀ O-rings
C-ring on plunger for positive stop
www.apem.com
X640
1
B2-49
10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page50
13000 series
X768
Sealed switch with Ø 11,9 (15/32) flatted bushing. Chrome plated actuator. Solder lug terminals,
double pole. Contact and finish options available.
Security cap for this model : see section I.
ON
MOM
3
2
1
EPOXY
6.00
(.236)
0.50
(.019)
9.00
(.354)
With long plunger
13445 -9 X768
7.50
(.295)
MOM
Ø12.00
(.472 DIA)
1.50
(.059)
ON
Ø11.9 32UNS
(.468-32UNS)
1-2
Ø8.00
(.314 DIA)
5.00
(.196)
B2
1-3
With short plunger
13445 -4 X768
Ø8.00
(.314 DIA)
14.20
(.559)
4.00
(.157)
➞ Flat
4.00
(.157)
Short (-4)
2.50
(.098)
5.10
(.200)
Long (-9)
AGENCY APPROVALS
UL
CECC
CECC 96401-001
Availability :
Marking : to order switches marked UL or CECC, please complete above box with desired approval.
Blank : no agency approval required.
B2-50
www.apem.com
APEM
10-Serie 13000-A_13-Serie 13000-A 31/10/14 09:05 Page51
13000 series
CAPS
+ U...
Ø8.00
(.314)
U900
U1140
3.00
(.118)
U1720
B2
Ø15.00
(.590 DIA)
For models with Ø 6,35 (1/4)
bushing only.
Cap colours
3.00
(.118)
3.00
(.118)
10.00
(.393)
7.50
(.295)
Ø10.00
(.393)
U480
Standard
Replace last
"0" by number
U630
11.50x11.50
(.452 SQ)
4.00
(.157)
3.00
(.196)
6.00
(.236)
5.00
(.195)
1
1/4
2
3
4
5
6
7
7/1
9
11.50x11.50
(.452 SQ)
U2020
Square
6.35
(.250)
Ø9.40
(.370)
6.35
(.250)
3.00
(.118)
4.00
(.157)
3.30
(.129)
Ø5.00
(.196)
U2430
Square
blue
dark blue
black
green
grey
yellow
red
ivory
white
orange
DRESS NUTS
Chrome plated
For models with Ø 6,35 (1/4) bushing only.
Ø13.50
(.531 DIA)
U1636
For cap U1140
8.00
(.314)
Ø6.35-40UNS
(1/4-40UNS)
U840
For cap U480
Ø6.35-40UNS
(1/4-40UNS)
U825
For cap U630
5.80
(.228)
Ø15.50
(.610 DIA)
8.00
(.314)
Ø10.50
(.413 DIA)
6.20
(.244)
8.20
(.322)
Ø8.20
(.322 DIA)
Ø18.50
(.728 DIA)
5.80
(.228)
Ø12.70
(.500 DIA)
Ø6.35-40UNS
(1/4-40UNS)
Dress nuts are to be ordered separately.
APEM
www.apem.com
B2-51
