08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page34
9000 series
Momentary pushbutton switches
Distinctive features and specifications
❑ Two case lengths
❑ Three electrical functions
❑ Sealing options
❑ Model X1146 with Ø 16 (.630) bushing
B2
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contact (A) : 1A 30VDC
- gold plated contacts (CD) : 100mA 30VDC
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
1.000 Vrms 50 Hz min. between terminals
1.500 Vrms 50 Hz min. between terminals and frame
• Electrical life : 250.000 cycles
MATERIALS
• Case : thermoplastique UL94-V0
• Actuator : polyamide, glass
filled
• Bushing : brass, nickel plated
• Contacts :
A : silver
CD : brass, gold plated
• Terminal seal : epoxy
B2-34
GENERAL SPECIFICATIONS
• Total travel :
9600-9400-9400Y
9600N-9400N
Functions 3 and 5
Function 2
Function 3
1,3 mm
2 mm
0,9 mm
• Torque : 1,25 Nm (.922 Ft.lb) max. applied to nut
• Operating temperature : -30°C to +65°C
www.apem.com
APEM
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page35
9000 series
Overview
9
Number of poles
SERIES
3
Single pole
Electrical functions
2
3
5
Normally closed (NC)
Normally open (NO)
Combined (NC/NO)
Terminals, case and bushing
B2
Case length 11,2 (.440)
All models have Ø 6,35 (1/4) threaded bushing.
4
Straight PC terminals
6
Solder lug terminals
4..Y
Straight PC terminals, bracket mounting
Case length 8,5 (.334)
4..N
6..N
6..NZ1 Quick-connect terminals
Contact materials
A
CD
Silver
Brass, gold
plated
Sealing
B
KB
Epoxy sealed
terminals (standard)
Front panel sealing
by two O-rings - not
available with 9400Y.
Special options
X1146
X601
Bushing Ø 16 (.630)
Special contact, lower rating
Caps
U900
U1140
U1720
U480
U630
U2430
U2020
Ø 5 (.196)
Ø 8 (.314)
Ø 9,4 (.370)
Ø 10 (.393) standard
Ø 15 (.590)
Square - Height 4 (.157)
Square - Height 6 (.236)
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- their options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Sealing boots are available to protect the switches against dust and water. They are presented in section H.
Mounting accessories : standard hardware supplied with all switches : 2 hex nuts 8 mm (.314) across flats and 1 lockwasher.
Standard and special hardware available are presented in section I.
Packaging unit : 50 pieces, except for 9400Y (25 pieces)
APEM
www.apem.com
B2-35
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page36
9000 series
9600 - 9400 - 9400Y
• Single pole
• Solder lug or straight PC terminals
• Epoxy sealed terminals
9600Z1
1.20
(.047)
2.80
(.110)
4.55
(.179)
5.20
(.204)
1.50
(.059)
1.20
(.047)
Function 5
(combined)
1.00
(.039)
2.00
(.078)
MODEL
STRUCTURE
Solder lug terminals - case length 11,2 (.440) : 9600
6.00
(.236)
Ø4.00
(.157 DIA)
9635B
Combined function
Ø6.35-40UNS
(1/4-40UNS)
Ø10.00
(.393 DIA)
11.20
(.440)
Normally Closed
7.00
(.275)
9632B
Ø9.00
(.354 DIA)
NO
EPOXY
NO
NC
0.40
(.015)
5.20
(.204)
2.00
(.078)
5.08
(.200)
For Normally Open (function 3), see next page.
Straight PC terminals - case length 11,2 (.440) : 9400
9433B
Normally Open
9435B
Combined function
EPOXY
11.85
(.466)
Ø10.00
(.393 DIA)
NO
4.55
(.179)
0.40
(.015)
5.08
(.200)
Ø4.00
(.157 DIA)
5.08
(.200)
Ø6.35-40UNS
(1/4-40UNS)
6.60
(.259)
5.08
(.200)
6.00
(.236)
5.08
(.200)
NO
NC
1.00
(.039)
9435YB
Normally Open
Combined function
3.18
(.125)
13.00
(.511)
Ø10.00
(.393 DIA)
0.40
(.015)
1.17
(.046)
3.18
(.125)
8.20
(.322)
The bracket is not fastened to the switch.
B2-36
F2
www.apem.com
EPOXY
Ø1.60
(.062 DIA)
NO
NO
NC
0.40
(.015)
5.08
(.200)
15.75
(.620)
5.08
(.200)
9433YB
Normally Closed
4.10
(.161)
9432YB
Ø1.60
(.062 DIA)
Ø9.00
(.354 DIA)
15.75
(.620)
Normally Closed
15.75
(.620)
9432B
Bracket mounting - case length 11,2 (.440) : 9400Y
5.08
(.200)
Ø6.35-40UNS
(1/4-40UNS)
5.08
(.200)
6.00
(.236)
Ø4.00
(.157 DIA)
7.00
(.275)
B2
Function 3
(NO)
9400
5.20
(.204)
2.40
(.094)
8.70
(.342)
Function 2
(NC)
9600
3.18
(.125)
F5
APEM
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page37
9000 series
9600N - 9400N
Solder lug terminals - case length 8,5 (.334) : 9600N
6.00
(.236)
Ø4.00
(.157 DIA)
Normally Open
8.50
(.334)
Ø9.50
(.374 DIA)
7.00
(.275)
EPOXY
5.00
(.196)
0.40
(.015)
5.08
(.200)
1.50
(.059)
9633NB
Ø6.35-40UNS
(1/4-40UNS)
2.00
(.078)
Ø8.50
(.334 DIA)
B2
Also available with quick-connect terminals 2,8 x 0,5 mm : 9633NZ1
Straight PC terminals - case length 8,5 (.334) : 9400N
6.00
(.236)
Ø4.00
(.157 DIA)
Ø9.50
(.374 DIA)
10.00
(.393)
Normally Open
7.00
(.275)
Ø1.60
(.062 DIA)
EPOXY
3.50
(.137)
5.08
(.200)
1.00
(.039)
5.08
(.200)
0.40
(.015)
1.50
(.059)
9433NB
Ø6.35-40UNS
(1/4-40UNS)
Ø8.50
(.334 DIA)
PANEL CUT-OUT
Ø6.50
(.255 DIA)
2.00
(.078)
Panel cut-out : Ø 16,2 (.637)
Max. current/voltage rating. : 1A 30VDC
Epoxy sealed terminals. Options of the following pages not applicable.
APEM
3.00
(.118)
19.00
(.748)
Ø16.00x1.00SI
(.629DIAx1.00IS)
www.apem.com
0.40
(.015)
5.08
(.200)
5.20
(.204)
Gold plated silver contacts
9633ADX1146
Normally open
7.40
(.291)
Normally open
Ø18.00
(.708DIA)
3.30
(.129)
Ø12.00
(.472DIA)
9.50
(.374)
Silver contacts
9633AX1146
1.50
(.059)
Bushing Ø 16 (.630) - metal button : 9633•X1146
Hex nut 19 (.748) across flats
B2-37
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page38
9000 series
CONTACT MATERIALS
A
CD
Silver
Brass, gold plated
Special contact, lower rating : see X601 under "Special options".
SEALING
B
Epoxy sealed terminals (standard)
KB
Combined sealings
Epoxy sealed terminals + front panel sealing by two O-rings.
Protects the switch against water and dust.
Panel seal withstands 0,1 bar pressure.
5.50 Maxi
(.216 MAX)
B2
1
Option KB not available on 9400Y model.
K
➀ O-rings
Sealing boots : see section H.
SPECIAL OPTIONS
X601
Silver plated brass contacts
Current/voltage rating for an electrical life of 20.000 cycles : 0,5A 30VDC.
Minimum quantity : 5.000 pieces per model and shipment.
X1146
Model with dia. 16 (.630) bushing and metal plunger
See previous page.
B2-38
www.apem.com
APEM
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page39
9000 series
CAPS
+ U...
U1140
B2
U1720
Ø15.00
(.590 DIA)
Ø10.00
(.393)
Replace last
"0" by number
1
1/4
2
3
4
5
6
7
7/1
9
3.00
(.118)
3.00
(.118)
10.00
(.393)
7.50
(.295)
Cap colours
U480
Standard
U630
5.00
(.195)
4.00
(.157)
U2430
Square
blue
dark blue
black
green
grey
yellow
red
ivory
white
orange
6.00
(.236)
11.50x11.50
(.452 SQ)
11.50x11.50
(.452 SQ)
3.00
(.196)
6.35
(.250)
3.00
(.118)
6.35
(.250)
3.00
(.118)
4.00
(.157)
3.30
(.129)
U900
Ø9.40
(.370)
Ø8.00
(.314)
Ø5.00
(.196)
U2020
Square
DRESS NUTS
Ø18.50
(.728 DIA)
Ø8.20
(.322 DIA)
Ø10.50
(.413 DIA)
Ø15.50
(.610 DIA)
APEM
8.00
(.314)
8.00
(.314)
8.20
(.322)
U1636
Ø6.35-40UNS
(1/4-40UNS)
Ø6.35-40UNS
(1/4-40UNS)
Ø6.35-40UNS
(1/4-40UNS)
For cap U1140
5.80
(.228)
Ø13.50
(.531 DIA)
6.20
(.244)
Ø12.70
(.500 DIA)
5.80
(.228)
Chrome plated. Order separately.
U825
U840
For cap U480
For cap U630
www.apem.com
B2-39
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page40
9000 series
Alternate action or momentary pushbutton switches
❑ Bushing Ø 6,35 (1/4) and 11,9 (15/32)
❑ Two electrical functions
B2
• Max. current/voltage rating with resistive load and electrical life :
- silver contacts (A) : 1A 28VDC - 250.000 cycles
3A 28VDC - 10.000 cycles
- gold plated contacts (CD) : 0,4VA 20V max. AC or DC
• Initial contact resistance : 10 mΩ max. at 0,1A 3VDC
• Insulation resistance : 10.000 MΩ min.
MATERIALS
• Case : diallylphthalate
• Actuator : nylon
black for series 9630M
white for series 9631
• Contacts :
A : silver
B2-40
• Operating temperature : -30°C to +85°C
• Travels : see table below.
MODELS
9631
9633M
Total travel
3,48 (.137)
2,79 (.110)
Pre-travel
0,66 (.026)
Over travel
2,69 (.106)
0,51 (.020)
www.apem.com
APEM
08-Serie 9400-9600-A_11-Serie 9400-9600-A 21/11/12 15:02 Page41
9000 series
• Single pole
• Solder lug terminals
Function 3
(NO)
2.55
(.100)
Function 1
OFF
ON
1.00
(.040)
5.60
(.220)
2.05
(.080)
1.25
(.050)
B2
Bushing Ø 6,35 (1/4) - Alternate action - tactile feedback
Silver contacts
9631AB
ON
OFF
5.35
(.210)
6.35
(.250)
ON
Ø4.05
(.160 DIA)
Ø9.40
(.370 DIA)
16.25
(.640)
Gold plated contacts
9631CDB
Ø6.35-40UNS
(1/4-40UNS)
OFF
EPOXY
5.60
(.220)
0.40
(.015)
5.30
(.209)
Standard hardware : 1 conic nut and 1 lockwasher
Bushing Ø 11,9 (15/32) - front or rear mounting - NO
A
Ø8.40
(.330 DIA)
Normally open
9.25
(.365)
9633MCDB
16.65
(.655)
Ø11.90-32UNS
(15/32-32UNS)
Ø9.40
(.370 DIA)
MODEL
A
9633M
6.35 (.250)
EPOXY
5.60
(.220)
0.40
(.015)
5.30
(.209)
Standard hardware : 2 hex nuts 14 mm (.551) across flats and 1 lockwasher
APEM
www.apem.com
B2-41
很抱歉,暂时无法提供与“9633NCD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.34022
- 50+50.02808
- 100+47.66414
- 250+46.31034
- 500+45.27937
