AV9612F1020840K
AV9612F1020840K
    APEM(埃斐)
    APEM - AV9612F1020840K - Vandal Resistant Switch, AV Series, 19.2 mm, SPST-NO, SPST-NC, Momentary, R...
AV9612F1020840K 数据手册
AV series Security pushbutton switches Ø 19 mm (.748) New! With illuminated ring - momentary (NC/NO) ORDER FORMAT 2 AV 9 SERIES Bushing dia. 19 mm 0 1 2 4 LED colour 0 : no LED - 1 : blue - V : green 5 : yellow - 6 : red - 7 : white - 9 : amber NC/NO LED resistor No resistor supplied 12VDC resistor 24VDC resistor 48VDC resistor SPECIFICATIONS Terminals 2 Solder / quick-connect F Flying leads C Cable MATERIALS • Travel : 2 mm ± 0,3 mm (.003) • Max. current/voltage rating with resistive load : 1A 30VDC • LED voltage : 12VDC, 24VDC or 48VDC (If not supplied by APEM, a resistor must be series-connected by the user)** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 10 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 1.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 250.000 cycles at full load • Operating force : 5N ± 2N • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Mechanical life : 1.000.000 cycles • Operating temperature : -20°C to +55°C • Hand soldering : 350°C, 5 seconds max. • Packaging unit : flying lead/cable models : 1 piece - other models : 40 pieces • Case : polyamide, glass filled • Contacts : silver • Bushing : see next page • Actuator : see next page • Elastomeric membrane : silicone • LED B CUT-OUT • Panel cut-out : Ø 19,2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) To order a product, select a basic model below and add the desired LED colour and voltage. Then select the desired options on next page. ** Resistor value = supply voltage - LED forward voltage LED forward current Hex nut 22 (.866) across flats Flat actuator - solder lug terminals 2.20 (.086) NC 3.00 (.118) - Ø22.00 (.866DIA) + 2.80x0.50 (.110x.019) NO Illuminated (select LED colour above) * AV9•022 Non-illuminated AV90022 Contacts 2 Silver Ø19.00x1.00 SI (.748DIAx1.00 IS) CAV3-9FCT ECHELLE 1 Options : see next page. NC NO 11.60 (.456) 22.00 (.866) 12.10 (.476) 8.30 (.326) * No LED resistor supplied on this model. Hex nut 22 (.866) across flats CAV9DT-1 Flat actuator - flying lead terminals ECHELLE 1 Illuminated (select LED colour & resistor above) AV9••2F Non-illuminated AV9002F 3.00 (.118) Ø15.00 (.590DIA) Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø22.00 (.866DIA) 2.20 (.086) 11.60 (.456) 12.10 (.476) Ø12.00 (.472DIA) 200 (7.874) CAV9DT-2 APEM www.apem.com ECHELLE 1 B-139 AV series Security pushbutton switches Ø 19 mm (.748) New! With illuminated ring - momentary (NC/NO) Hex nut 22 (.866) across flats Flat actuator - cable terminals 2.20 (.086) 3.00 (.118) Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø22.00 (.866DIA) Illuminated (select colour & resistor) AV9••2C Non-illuminated AV9002C 11.60 (.456) 12.10 (.476) 200 (7.874) B After selecting basic model No., fill in last 5 boxes with desired options. Flying lead protection Flying lead/ cable length Ring colour Bushing / plunger mat. CAV9DT-3 Sealing ECHELLE 1 BASIC MODEL FLYING LEAD PROTECTION No protection and/or no flying leads Heat-shrink sleeves Tube + epoxy 0 1 2 FLYING LEAD/CABLE LENGTH No flying leads / no cable Length 20 cm (standard) Length in centimeters 000 020 XXX RING COLOURS BUSHING/PLUNGER MATERIALS CODE COLOUR CODE BUSHING ACTUATOR 00 40 4A 4B Brass, nickel plated Stainless steel 303 Stainless steel 304 Stainless steel 316 Brass, nickel plated Stainless steel 303 Stainless steel 304 Stainless steel 316 1 2 3 4 5 Blue Black * Green Grey * Yellow CODE COLOUR 6 7 8 9 Red Opal white (std) Translucent Orange Other : on request. * non-illuminated only SEALING Blank No sealing 2 1 CAV3ET K 1 (IP67) Front panelECHELLE sealing B-140 ➀ internal membrane ➁ external gasket www.apem.com APEM
AV9612F1020840K 价格&库存
很抱歉,暂时无法提供与“AV9612F1020840K”相匹配的价格&库存,您可以联系我们找货
