5664THCDB3V
5664THCDB3V
    APEM(埃斐)
    APEM - 5664THCDB3V - TOGGLE SWITCH, 4PDT, 4A, 30VDC, SOLDER
5664THCDB3V 数据手册
05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page21 5000 series Toggle switches Distinctive features UG1410A THE WIDEST RANGE IN MINIATURE SWITCHES A ❑ 17 actuators including toggles, paddle levers and locking levers in different lengths. ❑ Various contact materials for low and high currents. ❑ 8 functions including maintained and momentary versions. ❑ 1 to 4 pole configurations. ❑ 12 terminal types including 9 for PC board mounting. Other types include quick-connect and wire-wrap. ❑ 6 bushing styles from 6 (.236) plain to 11,9 (15/32) threaded. ❑ 3 types of finish including military black. ❑ 3 approvals (UL - CSA - CECC). ❑ 4 types of sealing for terminal or front panel requirements. ❑ Numerous accessories available for actuator and bushing options. The company reserves the right to change specifications without notice. APEM www.apem.com A-21 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page22 5000 series Toggle switches Overview 5 Number of poles SERIES A 3 4 5 6 Terminals Single pole Double pole Three pole Four pole Solder lugs or straight PC depending on model Solder lugs with Ø 11,9 (15/32) bushing (5600 switches) Wire wrap (for 5200 switches only) Right angle, horizontal mounting (5200 - 5400 switches) Right angle, vertical mounting (5200 - 5400 switches) Blank M MIWR W WW Terminals and bushing 0 1 2 3 4 5 6 7 9 Straight PC terminals, 5,08 (.200) terminal spacing, with Ø 6,35 (1/4) threaded bushing Straight PC or quick-connect terminals, 4,70 (.185) terminal spacing, with Ø 6 (.236) threaded bushing. Straight PC terminals, 4,70 (.185) terminal spacing, right angle, quick-connect or wire wrap terminals, with 6,35 (1/4) threaded bushing Straight PC terminals, 4 (.157) terminal spacing, with Ø 6 (.236) threaded bushing Straight PC terminals, 4 (.157) terminal spacing or right angle terminals , with Ø 6,35 (1/4) threaded bushing Solder lug terminals, with Ø 6 (.236) threaded bushing. Solder lug terminals, with Ø 6,35 (1/4) or Ø 11,9 (15/32) threaded bushing. Solder lug terminals, with Ø 6,35 (1/4) flatted bushing. Straight PC or quick-connect terminals, with Ø 6,35 (1/4) flatted bushing, 4,70 (.185) terminal spacing. Y Y4 Y6 Y7 Z ] ] Bracket mounting (5200 switches) ] ] Quick connect (5200 - 5100 - 5900 switches) Connections for function 4 Momentary for function 4 TH Standard CT Reversed See wiring diagrams end of catalogue. . For functions 4, 4-1R, 4-2R (leave blank for all other functions). 1R ON ON MOM 2R MOM ON MOM Electrical functions 6 9 7 8 2 ON ON OFF MOM OFF ON OFF ON - ON ON MOM MOM MOM 4 ON ON ON ON ON MOM ▲ MOM ON MOM ▲ Leave blank for other functions. Function 4 Must not have blank in "connections" box. . ▲ Must not have blank in "momentary" box. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches with threaded bushing - model structure of switches with plain bushing - options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. A-22 www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page23 5000 series Toggle switches Overview Finish Fluorescent tip Blank Nickel plated G Black finish on bushing, actuator and hardware. Contact materials A AD CD Silver Silver, gold plated Brass, gold plated For peak currents, see X814, under Special Options. Special options Blank None -038 White fluorescent tip to lever Blank No special requirement X408 Front panel sealing by two O-rings X404 Horizontal right angle with reduced overall dimensions Other : specific bushing height, PC terminal length, finish, ratings, etc... See following pages. Available with matt black finish (G) only. Sealing Blank No sealing except where standard B Epoxy sealed terminals K Front panel sealing by one O-ring and sealing washer Sealing AAAby two O-rings, see X408 under "Special options". threaded bushing Blank (std) 10,5 (.413) -2 16 (.629) -7 -8 (flat) 21,3 (.838) -9 (flat) 11,4 (.448) -12 (flat) 6,3 (.248) -16 5,5 (.216) -17 7 (.275) -21 (+ U640) 21,3 (.838) insulated -22 21,3 (.838) -23 14 (.551) Blank (large) 17,5 (.688) -25 16,30 (.642) -27 (large) 11,7 (.460) Caps U270 U1710 Length 11 (.433) 7,3 (.287) Paddles U240N U290N U390N 12,4 (.488) 20 (.787) 21,5 (.846) Approvals Levers Length with Caps and paddles plain bushing 13,5 (.531) 19 (.748) 6,6 (.259) 8,5 (.334) 10 (.393) - UL CSA CECC Availability : Consult factory for details of approved models. For VDE, refer to 55000. - -4N 9 (.354) 12 (.472) 4N for use with paddle actuators only. Locking levers -1V 1 locked position -2V 2 locked positions -3V 3 locked positions Other, consult factory. For models with Ø 6,35 (1/4) bushing. Sealing boots are available. They are presented in section H. Mounting accessories : standard hardware supplied with all models with Ø 6,35 (1/4) or Ø 6 (.236) threaded bushing : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware available are presented in section I. Packaging unit : 25 pieces or 50 pieces depending on models. APEM www.apem.com A-23 A 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page24 5000 series Toggle switches Specifications ELECTRICAL SPECIFICATIONS • Current/voltage rating with resistive load : Contact A Maximum Minimum Level* Silver (A) 4A 30VDC 50mA 10VDC III and IV Silver, gold plated (AD) 4A 30VDC Gold plating withstands up to 100mA 30VDC 10mA 50mV 10µA 5V I to IV Brass, gold plated (CD) 0,4 VA at 20VAC or DC 10mA 50mV 10µA 5V I and II • For inductive, lamp or capacitive load, consult factory. • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals 1.500 Vrms 50 Hz min. between poles 1.500 Vrms 50 Hz min. between terminals and frame • Contact bounce : 2 ms max. • Electrical life at full load : 50.000 cycles for single and double pole 40.000 cycles for 3 pole 30.000 cycles for 4 pole • Low level or mechanical life : 100.000 cycles * For details, see Technical Information, end of catalogue. MATERIALS • Case : diallylphthalate (DAP) or high temperature plastic material (UL94-V0) • Actuator : brass, nickel plated • Paddles : UL94HB polyamide • Lever caps : vinyl • Bushing : brass, nickel plated • Housing : stainless steel or steel tin plated • Contacts A : silver AD : silver, gold plated CD : brass, gold plated X814 : for peak currrents, see “Special options”. • Terminal seal : epoxy GENERAL SPECIFICATIONS • Torque : 1,25 Nm (.922 Ft.lb) max. applied to nut • Panel thickness : 2,5 mm (.098) with 2 nuts - 4 mm (.157) with 1 nut • Operating temperature : -40°C to +85°C AGENCY APPROVALS/PREFERENTIAL LIST CECC 96201-007 3A 250VAC, 6A 125VAC For VDE, refer to 55000 series. NATO Availability : consult factory for details of approved models. Marking : to order switches marked UL, CSA or CECC, complete appropriate box of ordering format. The preferential list does not appear on the switches. A-24 www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page25 5000 series Toggle switches - solder lug terminals Threaded bushing Ø 6,35 (1/4) : 5600 • 1, 2, 3 and 4 pole configurations 3.70 (.145) 1.90 (.074) ➞ Keyway 1 2 3 1.10 (.043) 1.80 (.070) MODEL STRUCTURE Shown with standard lever ➞ Keyway 10.50 (.413) 8.00 (.314) 1.80 (.070) Ø6.35-40UNS (1/4-40UNS) ➞ Keyway APEM ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 9 1 7 2 8 www.apem.com I 13.10 (.516) 3.70 (.145) 0.50 (.019) 3 1.00 (.039) II 24˚ I 1-2 4-5 7-8 4.70 (.185) 5656 5659 5657 5658 5652 II Ø3.00 (.118 DIA) III 2-3 5-6 8-9 4.75 (.187) Ø3.00 (.118 DIA) 4.70 (.185) 5646 ON ON 10.50 8.00 (.413) (.314) 5649 ON OFF ON 5647 MOM OFF MOM 5648 ON OFF MOM Ø6.35-40UNS 5642 ON - MOM (1/4-40UNS) 5644* ON ON ON 5644 1R* ON ON MOM 5644 2R* MOM ON MOM * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. Three pole 13.20 (.519) II III III 10.50 (.413) Ø6.35-40UNS (1/4-40UNS) 8.00 (.314) 16.50 (.649) 13.20 (.519) 4 12.00 (.472) 4.75 (.187) 1 I 5 3.70 (.145) 0.50 (.019) 6 2 12.00 (.472) 0.80 (.031) 3 1.00 (.039) 1.80 (.070) I 1-2 4-5 0.80 (.031) II 24˚ III 2-3 5-6 0.80 (.031) III ➞ Keyway Double pole 7.00 (.275) 3.70 (.145) 13.20 (.519) II 2 1 12.00 (.472) 0.50 (.019) I 3 ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 1.00 (.039) 1.80 (.070) I 1-2 Ø3.00 (.118 DIA) 5636 5639 5637 5638 5632 II 24˚ III 2-3 4.70 (.185) Single pole A-25 A 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page26 5000 series Toggle switches - solder lug terminals Threaded bushing Ø 6,35 (1/4) : 5600 III 10.50 (.413) Ø6.35-40UNS (1/4-40UNS) 8.00 (.314) 13.20 (.519) 0.50 (.019) II 21.20 (.834) 1.80 (.070) ON ON MOM MOM MOM ON MOM MOM I 3.70 (.145) 24˚ 7 10 11 13.10 (.516) 0.80 (.031) OFF OFF OFF ON ON ON 12 8 Ø3.00 (.118 DIA) ON ON MOM ON ON ON ON MOM 5666 5669 5667 5668 5662 5664* 5664 1R* 5664 2R* A 9 4.70 (.185) III II I 2-3 1-2 5-6 4-5 8-9 7-8 11-12 10-11 1.00 (.039) 4.75 (.187) ➞ Keyway Four pole *Function 4 : DP in 4P case - specify CT or TH connections, see end of catalogue. Ø6.50 (.255 DIA) Ø2.20 (.086 DIA) 5.20 (.204) Standard A-26 Ø6.50 (.255 DIA) 1.10 (.043) PANEL CUT-OUT Ø6.50 (.255 DIA) 2.70 (.106) With K sealing option 2.70 (.106) With X408 sealing option www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page27 5000 series Toggle switches - solder lug terminals 5700 models • Flatted bushing Ø 6,35 mm (1/4) • 1, 2, 3 and 4 pole configurations A Diagram as per 5600 model MODEL STRUCTURE For model structure numbers, refer to 5600 models and replace 6 with 7. PANEL CUT-OUT Ø6.50 (.255 DIA) 2.70 (.106) Standard or with K sealing option 5500 models • Threaded bushing Ø 6 mm x 0.75 SI (.236 x 0.75 IS) • 1, 2, 3 and 4 pole configurations Diagram as per 5600 model MODEL STRUCTURE For model structure numbers, refer to 5600 models and replace 6 with 5. PANEL CUT-OUT Ø2.20 (.086 DIA) Ø6.20 (.244 DIA) 6.20 (.244) Standard APEM www.apem.com Ø6.20 (.244 DIA) 2.55 (.100) With X408 sealing option A-27 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page28 5000 series Toggle switches - solder lug terminals Threaded bushing Ø 11,9 (15/32) : 5600M • 1, 2, 3 and 4 pole configurations • Supplied with 2 hex nuts and 1 locking ring • Panel thickness up to 6 mm (.236) 3.70 (.145) 1.90 (.074) ➞ Keyway 1 A 2 1.10 (.043) 1.80 (.070) 3 MODEL STRUCTURE Shown with standard lever 11.00 (.433) 2 0.50 (.019) I 3 3.70 (.145) II III 17.50 (.688) 11.90 (.468) 0.80 (.031) 1 1.80 (.070) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 7.00 (.275) 24˚ I 1-2 Ø5.00 (.196 DIA) 5636M 5639M 5637M 5638M 5632M II 13.20 (.519) III 2-3 4.70 (.185) ➞ Single pole Keyway Ø11.9-32UNS (15/32-32UNS) ON ON MOM MOM MOM ON MOM MOM 6 1 4 I 5 II 24˚ 2 0.50 (.019) 3 3.70 (.145) III 17.50 (.688) 11.90 (.468) 0.80 (.031) 4.75 (.187) OFF OFF OFF ON ON ON 11.00 (.433) 12.00 (.472) 1.80 (.070) ON ON MOM ON ON ON ON MOM I 1-2 4-5 Ø5.00 (.196 DIA) 5646M 5649M 5647M 5648M 5642M 5644M* 5644M 1R* 5644M 2R* II 4.70 (.185) III 2-3 5-6 13.20 (.519) ➞ Keyway Double pole Ø11.9-32UNS (15/32-32UNS) * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. 7 8 0.50 (.019) 1 2 I II III 17.50 (.688) 11.90 (.468) 4.75 (.187) 9 3.70 (.145) 0.80 (.031) 3 12.10 (.476) 1.80 (.070) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 16.50 (.649) 24˚ I 1-2 4-5 7-8 Ø5.00 (.196 DIA) 5656M 5659M 5657M 5658M 5652M II 4.70 (.185) III 2-3 5-6 8-9 13.20 (.519) ➞ Keyway Three pole Ø11.9-32UNS (15/32-32UNS) A-28 www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page29 5000 series Toggle switches - solder lug terminals Threaded bushing Ø 11,9 (15/32) : 5600M II III 17.50 (.688) 11.90 (.468) 4.75 (.187) ON ON MOM MOM MOM ON MOM MOM 0.50 (.019) 10 11 0.80 (.031) 1 2 I 3.70 (.145) 24˚ 12 12.10 (.476) 1.80 (.070) OFF OFF OFF ON ON ON 3 4.70 (.185) ON ON MOM ON ON ON ON MOM 5666M 5669M 5667M 5668M 5662M 5664M* 5664M 1R* 5664M 2R* 21.20 (.834) Ø5.00 (.196 DIA) III II I 2-3 1-2 5-6 4-5 8-9 7-8 11-12 10-11 13.20 (.519) ➞ Keyway Four pole Ø11.9-32UNS (15/32-32UNS) *Function 4 : DP in 4P case - specify CT or TH connections, see end of catalogue. PANEL CUT-OUT Ø12.50 (.492 DIA) Ø12.50 (.492 DIA) 1.70 (.066) Ø3.50 (.137 DIA) 9.60 (.377) Standard 5.10 (.200) With K sealing option OTHER : M bushing can be combined with other types such as : 5200, Z, MIWR... Consult factory. APEM www.apem.com A-29 A 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page30 5000 series Toggle switches - straight PC terminals Threaded bushing Ø 6,35 (1/4) : 5200 1 A 2 Other terminal lengths presented under "Special options". Also available with plain bushing, see "Special options" X371 3 4.00 (.157) For new projects, we recommend switches with support bracket (option Y) which holds the switch securely on the PCB. 5.30 (.208) • Terminal spacing 4,7 mm (.185) • 1, 2, 3 and 4 pole configurations • Epoxy sealed terminals standard ➞ Keyway 1.10 (.043) MODEL STRUCTURE Shown with standard lever I 2 II 1 III 10.50 (.413) 8.00 (.314) 7.00 (.275) 13.20 (.519) 0.50 (.019) 3 4.70 (.185) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 4.00 (.157) Ø6.35-40UNS (1/4-40UNS) Ø1.60 (.063 DIA) 1.10 (.043) I 1-2 Ø3.00 (.118 DIA) 5236 B 5239 B 5237 B 5238 B 5232 B II 13.30 (.523) 24° III 2-3 1.00 (.039) 0.80 (.031) ➞ Single pole Keyway 4.70 (.185) Epoxy 4 III 10.50 8.00 Ø3.00 (.118 DIA) (.413) (.314) 5246 B ON ON 5249 B ON OFF ON 5247 B MOM OFF MOM Ø6.35-40UNS 5248 B ON OFF MOM (1/4-40UNS) 5242 B ON - MOM 5244 B* ON ON ON 5244 1R B* ON ON MOM 5244 2R B* MOM ON MOM *Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. Ø1.60 (.063 DIA) 4.70 (.185) Epoxy ➞ Keyway I 8 II 1 7 III Ø6.35-40UNS (1/4-40UNS) 8.00 (.314) 0.80 (.031) 10.50 (.413) Epoxy www.apem.com 4.75 (.187) 9 2 16.50 (.649) 13.20 (.519) 0.50 (.019) 3 4.75 (.187) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 4.00 (.157) 24° I 1-2 4-5 7-8 14.40 (.567) 1.10 (.043) 5256 B 5259 B 5257 B 5258 B 5252 B II 4.70 (.185) III 2-3 5-6 8-9 1.00 (.039) Ø3.00 (.118 DIA) Three pole A-30 13.20 (.519) II 1 0.50 (.019) I 5 12.00 (.472) 0.80 (.031) 6 2 4.75 (.187) 3 4.00 (.157) 1.10 (.043) I 1-2 4-5 13.30 (.523) 24° II 4.70 (.185) III 2-3 5-6 1.00 (.039) 4.75 (.187) ➞ Keyway Double pole Ø1.60 (.063 DIA) 4.70 (.185) APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page31 5000 series Toggle switches - straight PC terminals Threaded bushing Ø 6,35 (1/4) : 5200 - 5000 ➞ Keyway III ON ON MOM MOM MOM ON MOM MOM 13.20 (.519) 10 0.50 (.019) II 7 10.50 (.413) 8.00 (.314) 0.80 (.031) I 11 21.20 (.834) Ø1.60 (.063 DIA) 1.10 (.043) Ø6.35-40UNS (1/4-40UNS) A 4.75 (.187) 4.75 (.187) OFF OFF OFF ON ON ON 12 8 Ø3.00 (.118 DIA) ON ON MOM ON ON ON ON MOM 5266 B 5269 B 5267 B 5268 B 5262 B 5264 B* 5264 1R B* 5264 2R B* 9 4.00 (.157) 14.40 (.567) 1.00 (.039) 24° III II I 2-3 1-2 5-6 4-5 8-9 7-8 11-12 10-11 4.70 (.185) Four pole 4.70 (.185) Epoxy *Function 4 : DP in 4P case - specify CT ot TH connections, see end of catalogue. PANEL CUT-OUT 5200 - 5000 - 5400 Ø6.50 (.255 DIA) Ø2.20 (.086 DIA) 1.10 (.043) Ø6.50 (.255 DIA) 2.70 (.106) 5.20 (.204) Standard With K sealing option 5000 models 4.35 (.171) 5.50 (.216) • Terminal spacing 5,08 mm (.200) • Epoxy sealed terminals standard • 1 and 2 pole configurations 0.60 (.023) Diagram as per 5200 model MODEL STRUCTURE Shown with standard lever II I 1-2 4-5 III II 24˚ I Ø3.00 (.118 DIA) Ø6.35-40UNS (1/4-40UNS) Ø1.10 (.043 DIA) 4.35 (.171) APEM www.apem.com 5.08 (.200) 1.00 (.039) 13.10 (.515) 8.00 (.314) Single pole Double pole 5036 5046 ON ON 5039 5049 ON OFF ON 5037 5047 MOM OFF MOM EPOXY 5038 5048 ON OFF MOM 0.60 1 0.60 2 3 (.023) (.023) 5.08 5032 5042 ON - MOM (.200) 5044* ON ON ON 12.00 13.20 (.472) (.519) 5044 1R* ON ON MOM 5044 2R* MOM ON MOM *Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. 0.60 (.023) 7.00 (.275) 5.08 (.200) III 2-3 5-6 ➞ Keyway 10.50 (.413) Terminal spacing 5,08 (.200) - single and double pole 5.08 (.200) A-31 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page32 5000 series Toggle switches - straight PC terminals 5400 models • Threaded bushing Ø 6,35 mm (1/4) • Terminal spacing 4 mm (.157) • 1, 2, 3 and 4 pole configurations A Diagram, as per 5200 model MODEL STRUCTURE For model structure numbers, refer to 5200 models and replace 2 with 4. Panel cut-out, see 5200. 5900 models ➞ Flat • Flatted bushing Ø 6,35 mm (1/4) • Terminal spacing 4,7 mm (.185) • 1, 2, 3 and 4 pole configurations 1 2 3 MODEL STRUCTURE For model structure numbers, refer to 5200 models and replace 2 with 9. PANEL CUT-OUT Ø6.50 (.255 DIA) 2.70 (.106) Standard or with K sealing option A-32 www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page33 5000 series Toggle switches - straight PC terminals 5100 models • Threaded bushing Ø 6 mm x 0.75 SI (.236 x 0.75 IS) • Terminal spacing 4,7 mm (.185) • 1, 2, 3 and 4 pole configurations A Diagram, as per 5200 model MODEL STRUCTURE For model structure numbers, refer to 5200 models and replace 2 with 1. Panel cut-out, see below. 5300 models • Threaded bushing Ø 6 mm x 0.75 SI (.236 x 0.75 IS) • Terminal spacing 4 mm (.157) • 1, 2, 3 and 4 pole configurations Diagram, as per 5200 model MODEL STRUCTURE For model structure numbers, refer to 5200 models and replace 2 with 3. PANEL CUT-OUT 5100 - 5300 Ø6.20 (.244 DIA) Ø2.20 (.086 DIA) 6.20 (.244) Standard APEM www.apem.com Ø6.20 (.244 DIA) 2.55 (.100) With X408 sealing option A-33 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page34 5000 series Toggle switches - quick-connect terminals Threaded bushing Ø 6,35 (1/4) : 5200Z • Terminal spacing 4,7 mm (.185) • Epoxy sealed terminals standard • 1and 2 pole configurations 1 A 2 5.30 (.208) 6.50 (.255) ➞ Keyway 1.57 (.061) 3 MODEL STRUCTURE Shown with standard lever 13.10 (.515) I 1-2 I 1-2 4-5 13.10 (.515) 1.00 (.039) I ON ON MOM MOM MOM ON MOM MOM III 13.20 (.519) 2 24˚ OFF OFF OFF ON ON ON Ø3.00 (.118 DIA) ON ON MOM ON ON ON ON MOM 12.00 (.472) 3 II 5246Z 5249Z 5247Z 5248Z 5242Z 5244Z* 5244Z 1R* 5244Z 2R* 5.30 (.208) 13.20 (.519) II 10.50 (.413) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) EPOXY 4.75 (.187) III 2-3 5-6 1 Ø6.35-40UNS (1/4-40UNS) ➞ Keyway Double pole EPOXY 0.78 (.030) 8.00 (.314) 1.57 (.061) Ø3.00 (.118 DIA) 10.50 (.413) 4.70 (.185) III 2 24˚ 3 II ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 7.00 (.275) 4.70 (.185) I 5236Z 5239Z 5237Z 5238Z 5232Z 5.30 (.208) 1.00 (.039) 1 II 0.78 (.030) III 2-3 1.57 (.061) ➞ Single pole Keyway *Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. Ø6.50 (.255 DIA) Ø2.20 (.086 DIA) 5.20 (.204) Standard A-34 Ø6.50 (.255 DIA) 1.10 (.043) PANEL CUT-OUT Ø6.50 (.255 DIA) 2.70 (.106) With K sealing option 2.70 (.106) With X408 sealing option www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page35 5000 series Toggle switches - quick-connect terminals 5900Z models • Flatted bushing Ø 6,35 mm (1/4) • Terminal spacing 4,7 mm (.185) • Epoxy sealed terminals standard • 1and 2 pole configurations A Diagram, as per 5900 model MODEL STRUCTURE For model structure numbers, refer to 5200Z models and replace 2 with 9. PANEL CUT-OUT Ø6.50 (.255 DIA) 2.70 (.106) Standard or with K sealing option 5100Z models • Threaded bushing Ø 6 mm x 0.75 SI (.236 x 0.75 IS) • Terminal spacing 4,7 mm (.185) • Epoxy sealed terminals standard • 1and 2 pole configurations Diagram, as per 5200 model MODEL STRUCTURE For model structure numbers, refer to 5200Z models and replace 2 with 1. PANEL CUT-OUT Ø2.20 (.086 DIA) Ø6.20 (.244 DIA) 6.20 (.244) Standard APEM www.apem.com A-35 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page36 5000 series Toggle switches - wire-wrap terminals Threaded bushing Ø 6,35 (1/4) : 5200MIWR 1 A 2 16.90 (.665) 18.00 (.708) • Terminal spacing 5,08 mm (.200) • Epoxy sealed terminals standard • 1and 2 pole configurations • Can also be used as extended PCB terminals ➞ Keyway 3 0.60 (.023) MODEL STRUCTURE Shown with standard lever I 1-2 1.00 (.039) I III 10.50 (.413) 8.00 (.314) EPOXY Ø6.35-40UNS (1/4-40UNS) Ø1.10 (.043 DIA) 5.08 (.200) 0.60 (.023) Ø3.00 (.118 DIA) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 2 24˚ 3 II 5236MIWR 5239MIWR 5237MIWR 5238MIWR 5232MIWR 7.00 (.275) 13.20 (.519) II 16.90 (.665) 5.08 (.200) III 2-3 13.10 (.515) 0.60 1 (.023) ➞ Terminal spacing 5,08 (.200) - single pole Keyway I OFF OFF OFF ON ON ON ON ON MOM MOM MOM ON MOM MOM 3 II 2 III 10.50 (.413) Ø3.00 (.118 DIA) ON ON MOM ON ON ON ON MOM 5246MIWR 5249MIWR 5247MIWR 5248MIWR 5242MIWR 5244 MIWR* 5244 1R MIWR* 5244 2R MIWR* 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) 12.00 (.472) EPOXY 13.20 (.519) 1.00 (.039) 16.90 (.665) Ø1.10 (.043 DIA) 5.08 (.200) 5.08 (.200) 13.10 (.515) 0.60 1 (.023) I 1-2 4-5 0.60 (.023) II 24˚ III 2-3 5-6 5.08 (.200) ➞ Keyway Terminal spacing 5,08 (.200) - double pole *Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. Ø6.50 (.255 DIA) Ø2.20 (.086 DIA) 5.20 (.204) Standard A-36 Ø6.50 (.255 DIA) 1.10 (.043) PANEL CUT-OUT Ø6.50 (.255 DIA) 2.70 (.106) With K sealing option 2.70 (.106) With X408 sealing option www.apem.com APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page37 5000 series Toggle switches - plain bushing Right angle terminals - horizontal : 5200W • Terminal spacing 4,7 mm (.185) • 1, 2 and 3 pole configurations Special switch 5200WX404 with reduced overall dimensions is presented under "Special options". A MODEL STRUCTURE Ø6.25 (.246 DIA) 4 OFF OFF OFF ON ON ON 6 ON ON MOM MOM MOM ON MOM MOM 6.00 11.00 (.236) (.433) III II 24˚ 2 I 3 1.00 (.039) 12.00 (.472) 5.08 (.200) 1.10 (.043) Ø3.00 (.118 DIA) ON ON MOM ON ON ON ON MOM 1 Ø6.25 (.246 DIA) 5246W 5249W 5247W 5248W 5242W 5244W* 5244W 1R* 5244W 2R* 13.50 (.531) 3.70 (.145) 7.40 (.291) 12.70 (.500) 3.81 (.150) 3.81 12.70 (.150) (.500) I 1-2 4-5 (.519) 13.20 II 4.70 (.185) III 2-3 5-6 Ø1.60 (.062 DIA) 4.70 (.185) 0.80 (.031) Double pole 12.70 (.500) 1.10 (.043) 12.70 (.500) 7.40 (.291) 5.08 (.200) 5.08 (.200) I II 24˚ 1.00 (.039) 3 13.20 (.519) III 2 7.00 (.275) 0.50 (.019) 1 6.00 11.00 (.236) (.433) 0.80 (.031) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 13.50 (.531) 3.70 (.145) I 1-2 Ø3.00 (.118 DIA) 5236W 5239W 5237W 5238W 5232W II 4.70 (.185) III 2-3 (.019) 0.50 Single pole 5.08 (.200) Shown with standard lever Ø1.60 (.062 DIA) (.185) 4.70 APEM II 24˚ I www.apem.com 1.10 (.043) 7.20 (.283) 14.35 (.564) 3.81 (.150) 5.08 (.196) 1.00 (.039) 6 III 13.20 (.519) 5 16.60 (.653) 0.50 (.019) 9 4 12.5 (.492) 3.81 14.35 (.150) (.564) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 7 6.00 (.236) 0.80 (.031) I 1-2 4-5 7-8 13.50 (.531) Ø6.25 (.246 DIA) 5256W 5259W 5257W 5258W 5252W II 4.70 (.185) III 2-3 5-6 8-9 3.70 (.145) Ø3.00 (.118 DIA) Three pole 5.08 (.200) *Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. Ø1.60 (.062 DIA) (.185) 4.70 A-37 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page38 5000 series Toggle switches - plain bushing Right angle terminals - horizontal : 5400W A SP 16.60 (.653) 8.30 (.326) 5200W 12.00 (.472) 6.00 (.236) 3.50 (.137) 7.00 (.275) PCB MOUNTING FOR DP 3P 5400W models • Terminal spacing 4 mm (.157) • 1and 2 pole configurations Diagram, as per 5200W model MODEL STRUCTURE PC LAYOUT 5.08 (.200) Ø1.60 (.062 DIA) 4.00 (.157) SP A-38 www.apem.com 3.81 12.70 (.150) (.500) 5.08 (.200) 12.70 (.500) For model structure numbers, refer to 5200W single and double pole and replace 2 with 4. Ø1.60 (.062 DIA) DP 4.00 (.157) APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page39 5000 series Toggle switches - plain bushing Right angle terminals - vertical : 5200WW • Pin spacing 3,81 mm (.150) • 1, 2, 3 and 4 pole configurations A MODEL STRUCTURE Shown with standard lever I 3 1.00 (.039) II 24˚ 2 III 1 5.65 (.222) 5.08 (.200) 0.80 (.301) 12.70 (.500) Three pole ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 3 9 I 1 7 III 2 1.00 (.039) 5.08 (.200) www.apem.com 1.10 (.043) 13.10 (.515) 6.00 (.236) 12.50 (.492) 12.70 (.500) 13.20 (.519) 3.00 (.118) 4.75 (.187) 3.81 (.150) 3.81 (.150) Ø1.60 (.062 DIA) 5.08 (.200) 16.50 (.649) II 24˚ 8 Ø3.00 (.118 DIA) * and ** : see notes next page. APEM I 1-2 4-5 7-8 Ø6.25 (.246 DIA) 5256WW 5259WW 5257WW 5258WW** 5252WW** II 12.70 (.500) 13.20 (.519) III 2-3 5-6 8-9 5.65 (.222) 5.08 (.200) 4.75 (.187) 1.00 (.039) 0.80 (.301) 12.70 (.500) III II 24˚ 7.20 (.283) 12.70 (.500) 3.81 (.150) 4.75 (.187) Ø1.60 (.062 DIA) 3.00 (.118) 4 3.81 (.150) 1 5 12.70 (.500) I 12.00 (.472) 0.80 (.031) ON ON MOM MOM MOM ON MOM MOM 6 2 5.08 (.200) 6.00 11.00 (.236) (.433) 1.10 (.043) OFF OFF OFF ON ON ON 3 13.50 (.531) Ø3.00 (.118 DIA) ON ON MOM ON ON ON ON MOM I 1-2 4-5 Ø6.25 (.246 DIA) 5246WW 5249WW 5247WW 5248WW** 5242WW** 5244WW* 5244WW 1R* 5244WW 2R* II Ø1.60 (.062 DIA) 1.10 (.043) Ø3.00 (.118 DIA) Double pole III 2-3 5-6 3.81 (.150) 3.81 (.150) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 7.00 (.275) 13.20 (.519) I 1-2 Ø6.25 (.246 DIA) 5236WW 5239WW 5237WW 5238WW** 5232WW** II 6.00 11.00 (.236) (.433) 4.75 (.187) III 2-3 13.50 (.531) 3.00 (.118) Single pole 5.08 (.200) A-39 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page40 5000 series Toggle switches - plain bushing Right angle terminals - vertical : 5200WW - 5400WW 7 10 III 21.20 (.834) 13.20 (.519) II 24˚ 12.70 (.500) 3.81 (.150) 5.08 (.200) 4.75 (.187) 3.81 (.150) 4.75 (.187) 7.20 (.283) 3.00 (.118) 1.00 (.039) ON ON MOM MOM MOM ON MOM MOM 12.50 (.492) Ø1.60 (.062 DIA) 5.08 (.200) 12.70 (.500) I 11 Ø3.00 (.118 DIA) OFF OFF OFF ON ON ON 12 8 Ø6.25 (.246 DIA) ON ON MOM ON ON ON ON MOM 5266WW 5269WW 5267WW 5268WW** 5262WW** 5264WW* 5264WW 1R* 5264WW 2R* A 9 6.00 (.236) 1.10 (.043) III II I 2-3 1-2 5-6 4-5 8-9 7-8 11-12 10-11 13.10 (.515) 0.80 (.031) Four pole * Function 4 : SP in DP case, DP in 4P case - specify CT or TH connections, see end of catalogue. ** Functions 2 and 8 : reversed connection available, consult factory. 7.00 (.275) 12.00 (.472) SP DP 16.50 (.649) 21.20 (.834) 3P 4P 13.20 (.519) 6.60 (.259) PCB MOUNTING 5400WW models • Pin spacing 2,54 mm (.100) • 1, 2, 3 and 4 pole configurations Diagram as per 5200WW model MODEL STRUCTURE 12.70 (.500) 2.54 (.100) Ø1.60 (.062 DIA) 12.70 (.500) 2.54 (.100) 12.70 (.500) A-40 Ø1.60 (.062 DIA) Ø1.60 (.062 DIA) 12.70 (.500) Ø1.60 (.062 DIA) 5.08 (.200) 5.08 (.200) 5.08 (.200) 5.08 (.200) SP DP 3P 4P www.apem.com 2.54 (.100) PC LAYOUT 2.54 (.100) For model structure numbers, refer to 5200WW models and replace 2 with 4. APEM 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page41 5000 series Toggle switches - plain bushing 8.50 (.334) 1.10 (.043) • Epoxy sealed terminals standard • 1and 2 pole configurations 9.80 (0.385) 4.00 (.157) Brackets reduce mechanical stress on solder joints and increase resistance to vibrations. Bracket material : tin plated steel. 5.30 (.208) Straight PC terminals - bracket mounting : 5200Y 1.10 (.043) Y - Y6 Y4 - Y7 MODEL STRUCTURE Shown with standard lever Short bracket - width 15,75 (.620) - single pole : 5230Y III 15.75 (.620) II 24˚ 1.17 (.046) 0.40 (.015) I 3.18 (.125) EPOXY 7.00 (.275) Ø6.25 (.246 DIA) Ø3.00 (.118 DIA) 3.18 (.125) 1 2 15.75 (.620) 3 15.75 (.620) 3 4.70 (.185) 2 0.40 (.015) 12.00 (.472) 1.17 (.046) 4.70 (.185) ON ON MOM MOM MOM ON MOM MOM 8.20 (.322) 1 13.10 (.515) OFF OFF OFF ON ON ON EPOXY Ø1.60 (.062 DIA) 3.18 (.125) 5.60 (.220) 3.18 (.125) 13.00 (.511) ON ON MOM ON ON ON ON MOM I 1-2 4-5 4.70 (.185) 5246Y B 5249Y B 5247Y B 5248Y B 5242Y B 5244Y B* 5244Y 1R B* 5244Y 2R B* II Ø3.00 (.118 DIA) 13.50 (.531) Short bracket - width 15,75 (.620) - double pole : 5240Y III 2-3 5-6 Ø6.25 (.246 DIA) I 6.00 (.236) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM II 24˚ 4.75 (.187) Ø1.60 (.062 DIA) 15.75 (.620) III I 1-2 4.10 (.161) 5236Y B 5239Y B 5237Y B 5238Y B 5232Y B II 13.00 (.511) III 2-3 * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. APEM www.apem.com A-41 A 05-Serie 5000-A-structure_05-Serie 5000-A-structure 30/10/14 14:58 Page42 5000 series Toggle switches - plain bushing Straight PC terminals - bracket mounting : 5200Y4 - Y6 - Y7 III II 24˚ I 4.70 (.185) 12.00 (.472) ON ON MOM MOM MOM ON MOM MOM Ø3.00 (.118 DIA) Ø1.60 (.062 DIA) 2 3 0.40 (.015) 19.05 (.750) II 24˚ I 6.35 (.250) 12.00 (.472) 6.35 (.250) 15.75 (.620) 19.05 (.750) 4.75 (.187) 6.35 (.250) Ø6.25 (.246 DIA) Ø3.00 (.118 DIA) Ø1.60 (.062 DIA) 1 2 3 0.40 (.015) 19.05 (.750) 6.35 (.250) 12.00 (.472) 4.75 (.187) 19.05 (.750) 13.10 (.515) EPOXY 6.35 (.250) 19.05 (.750) 1 III 1.27 (.050) 6.35 (.250) Ø6.25 (.246 DIA) 6.35 (.250) 19.05 (.750) OFF OFF OFF ON ON ON 8.20 (.322) I 1-2 4-5 16.00 (.629) ON ON MOM ON ON ON ON MOM II 6.35 (.250) EPOXY 1.27 (.050) 4.75 (.187) 15.75 (.620) 4.70 (.185) 13.10 (.515) 15.75 (.620) 3.18 (.125) Ø1.60 (.062 DIA) 4.70 (.185) ON ON MOM MOM MOM ON MOM MOM 5.20 (.204) III 2-3 5-6 Double pole 5246Y7 B 5249Y7 B 5247Y7 B 5248Y7 B 5242Y7 B 5244Y7 B* 5244Y7 1R B* 5244Y7 2R B* 3 0.40 (.015) 2 13.10 (.515) OFF OFF OFF ON ON ON Tall bracket - width 19,05 (.750) : 5200Y7 Single pole 5236Y7 B 5239Y7 B 5237Y7 B 5238Y7 B 5232Y7 B 1 6.00 (.236) ON ON MOM ON ON ON ON MOM 13.00 (.511) Double pole 5246Y6 B 5249Y6 B 5247Y6 B 5248Y6 B 5242Y6 B 5244Y6 B* 5244Y6 1R B* 5244Y6 2R B* EPOXY 8.20 (.322) I 1-2 4-5 4.70 (.185) Single pole 5236Y6 B 5239Y6 B 5237Y6 B 5238Y6 B 5232Y6 B II 1.17 (.046) 3.18 (.125) 3.18 (.125) 3.18 (.125) Short bracket - width 19,05 (.750) : 5200Y6 III 2-3 5-6 Ø6.25 (.246 DIA) Ø3.00 (.118 DIA) 4.70 (.185) ON ON MOM MOM MOM ON MOM MOM I 4.70 (.185) OFF OFF OFF ON ON ON II 24˚ 6.00 (.236) ON ON MOM ON ON ON ON MOM III 6.00 (.236) A Double pole 5246Y4 B 5249Y4 B 5247Y4 B 5248Y4 B 5242Y4 B 5244Y4 B* 5244Y4 1R B* 5244Y4 2R B* 8.20 (.322) I 1-2 4-5 16.00 (.629) Single pole 5236Y4 B 5239Y4 B 5237Y4 B 5238Y4 B 5232Y4 B II 5.20 (.204) III 2-3 5-6 4.70 (.185) Tall bracket - width 15,75 (.620) : 5200Y4 * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. A-42 www.apem.com APEM 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page43 5000 series Toggle switches UG1410A CONTACT MATERIALS Silver Silver, gold plated Brass, gold plated A AD CD A Special contacts for peak currents : see X814, under “Special Options”. FINISH Blank G Nickel plated Black finish on bushing, actuator and hardware SEALING Blank • For 5000 - 5200Z and 5200MIWR models : epoxy sealed terminals standard • Other models : no sealing required B Epoxy sealed terminals K Front panel sealing by one O-ring and sealing washer. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. Available on models with Ø 6,35 (1/4) or 11,9 (15/32) threaded bushing only. Not available with levers 8, 9, 12, 22, 23. Combined sealings KB ➀ O-ring ➁ Sealing washer K with Ø 6,35 (1/4) keyway bushing K with Ø 6,35 (1/4) flatted bushing K with Ø 11,9 (15/32) keyway bushing 1 4 Maxi (.157 MAX) 3 Maxi (.118 MAX) 1 2 Includes washer U360 Includes washer U5141 2 Includes washer U60 Sealing by two O-rings, see X408 under "Special options". APEM www.apem.com A-43 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page44 5000 series Toggle switches FLUORESCENT TIP Blank None -038 White fluorescent tip. Becomes luminous when submitted to ultraviolet rays. A Standard lever Locking lever Available with matt black finish (option G) only. -19 Same dimensions as standard actuator below. Consult factory for levers available with this option. ACTUATORS Dash compulsory before lever code. Levers for threaded bushing models Ø 6,35 (1/4) or Ø 6 (.236) Ø3.00 (.118) 9.00 (.354) 1.00 (.039) Blank Standard -2 -4N For use with paddles only Ø5.00 (.196 DIA) Ø4.20 (.165 DIA) 11.40 (.448) 21.30 (.838) Ø5.00 (.196 DIA) 6.30 (.248) 9.00 (.354) 10.50 (.413) 16.00 (.629) Ø3.00 (.118 DIA) -8 Not available with sealing options K or X408 -9 Not available with sealing options K or X408 -12 Not available with sealing options K or X408 16.40 (.645) Ø2.80 (.110 DIA) 5.50 (.216) 7.00 (.275) Ø2.70 (.354 DIA) 21.30 (.838) Ø3.30 (.129) DIA) -16 A-44 -17 www.apem.com -21 (+U640) U640 to be placed in last box of ordering format. Replace 0 by colour code. APEM 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page45 5000 series Toggle switches ACTUATORS (continued) Ø3.30 (.129 DIA) ø3.30 (.129 DIA) 16.30 (.642) 14.00 (.551) 21.30 (.838) Ø3.30 (.129 DIA) A -22 -23 -25 Not available with sealing options K or X408 Not available with sealing options K or X408 Not available with sealing options K or X408 Levers for threaded bushing models Ø 11,9 (15/32) : 5600M Ø5.00 (.196 DIA) 11.90 (.468) 11.90 (.468) 11.70 (.460) 17.50 (.688) Ø5.00 (.196 DIA) Blank -27 Standard Locking levers 15.10 (.594) 14.75 (.580) Ø6.35-40UNS (1/4-40UNS) -1V -2V -3V 1 locked position (function 6) 2 locked positions (function 6) 3 locked positions (functions 9 and 4) 9.00 (.354) 9.00 (.354) 14.85 (.584) Ø6.35-40UNS (1/4-40UNS) ➞ Keyway 9.00 (.354) Ø6.35-40UNS (1/4-40UNS) Ø5.20 (.204 DIA) ➞ Keyway ➞ Keyway Consult factory for other locking lever options. Available with Ø 6,35 mm (1/4) threaded bushing models only. For plain bushing models, see X386 or X916 under “Special options” on the following pages. APEM www.apem.com A-45 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page46 5000 series Toggle switches ACTUATORS (continued) For plain bushing models : W - WW and Y Ø3.00 (.118 DIA) 12.00 (.472) 1.00 (.039) -4N For use with paddles only -2 Blank Standard Ø2.60 (.102 DIA) 8.50 (.334) 6.70 (.263) -7 -16 -17 Actuator colours Ø3.30 (.129 DIA) Replace "0" by number 16.40 (.645) 24.30 (.956) Ø2.80 (.110 DIA) Ø2.70 (.106 DIA) 10.00 (.393) 6.00 (.236) 13.50 (.531) A 19.00 (.748) Ø3.00 (.118 DIA) 1 1/4 2 3 4 5 6 7 7/1 9 -21 (+U640) U640 to be placed in last box of ordering format. Replace 0 by colour code. blue dark blue black green grey yellow red ivory white orange LEVER LENGTH With bracket or mounting plate lever length will be reduced by 0,4 mm (.015) as a rule. Please refer to switch technical drawings in "Model Structure" pages for details. A-46 www.apem.com APEM 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page47 5000 series Toggle switches SPECIAL OPTIONS No special requirement X408 Front panel sealing by two O-rings. Flatted bushing for precise orientation. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. Includes sealed terminals (option B). Available only on models with threaded bushing except 5600M. Not available with levers 8, 9, 12, 22, 23. A ➀ O-rings 7.30 (.287) 8.50 (.334) 7.40 (.291) 12.70 (.500) Standard W III 7.40 (.291) 6 3 4.70 (.185) ø1.60 (.062 DIA) 3.81 12.70 (.150) (.500) 12.70 (.500) 5.08 (.196) ø2.67 (.105) 12.70 (.500) II 24° Double pole 5246W X404 ON ON 5249W X404 ON OFF ON 5247W X404 MOM OFF MOM 3 2 1 5248W X404 ON OFF MOM 7.00 0.50 (.275) (.019) 0.80 5242W X404 ON - MOM (.031) 5244W X404* ON ON ON 4.70 12.00 (.185) (.472) 5244W1R X404* ON ON MOM 5244W2R X404* MOM ON MOM * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. 7.40 (.291) Single pole 5236W X404 5239W X404 5237W X404 5238W X404 5232W X404 I ø6.25 (.246 DIA) 12.70 (.500) I 1-2 4-5 3.81 (.150) II 12.70 (.500) Option WX404 11.00 7.20 7.30 (.433) (.283) (.287) III 2-3 5-6 7.40 (.291) 3.50 (.137) Horizontal right angle with reduced overall dimensions (shown with lever -16) 3.50 (.137) X404 1 3 mini - 5 Maxi (.118 MIN. - .196 MAX.) Blank 5.08 (.196) 4.70 (.185) -17 -21 (+U640)* -22 8.10 (.318) 13.20 (.519) 15.80 (.622) 23.10 (.909) -8 -9 -12 Note : levers -8, -9 and -12 not available with function 2 (ON-MOM) 8.80 (.346) 7.30 (.287) -16 23.10 (.909) 10.80 (.425) -4N (for paddles) 16.40 (.645) -2 23.10 (.909) -13 1.00 (.039) 7.20 (.283) 12.30 (.484) 17.80 (.700) Levers lenghts for WX404 (also available with X445 option ) -23 * U640 to be placed in last box of ordering format. Replace 0 by colour code. Insulating caps and paddles for X404 : Insulating cap U1710 available with lever style 16. Paddles U240N, U290N and U390N available with lever style 4N. See details on next pages. APEM www.apem.com A-47 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page48 5000 series Toggle switches (continued) With options X372, X386, X442 and X445, the lever lengths indicated on previous pages will be modified. Threaded bushing Ø 6,35 (1/4). Height 7 mm (.274). 6.00 (.236) 1.00 (.039) A X371 X445 Plain bushing. Height 7,2 mm (.283) - for W, WW and Y models. Available with the same levers, insulating cap and paddles as X404.` X601 Silver plated brass contacts. Current/voltage rating for an electrical life of 20.000 cycles : 0,5A 30VDC. Minimum quantity : 5.000 pieces per model and shipment. X681 Satin chrome actuator X814 Switches for peak currents 1.00 (.039) Threaded bushing Ø 6,35 mm (1/4) - Height 9,9 mm (.389). X386 Ø6.35-40UNS (1/4-40UNS X442 Ø6.25 (.246 DIA) 1.00 (.039) X442 X372 Ø6.35-40UNS (1/4-40UNS 9.00 (.354) Threaded bushing Ø 6,35 mm (1/4) to replace plain bushing on models W - WW and Y. 7.20 (.283) X386 1.00 (.039) X372 Ø6.35-40UNS (1/4-40UNS Ø6.25 (.246 DIA) 0.30 (.011) Plain bushing Ø 6,25 mm (.246) (instead of standard threaded bushing). 7.00 (.275) X371 9.90 (.389) SPECIAL OPTIONS X445 Peak current up to 120A (1 ms) 60VDC - single/double pole ON Double pole 5646A X814 ON - ON X902 Plain bushing Ø 6,25 mm (.246) - Height 9 mm (.354) (not available with K sealing option). X916 Locking lever on model with plain bushing. • Contacts : silver/nickel alloy (AgNi) • Max. current/voltage rating : 2/120A (1 ms) 60VDC - 10.000 cycles • Further specifications and dimensions : see 5600 series. • General information on peak currents : see end of catalogue. Ø6.25 (.246 DIA) 1.00 (.039) - 14.75 (.580) ON 9.00 (.354) Single pole 5636A X814 X916 A-48 www.apem.com APEM 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page49 5000 series Toggle switches AGENCY APPROVALS UL CSA CECC All standard models, except 5200MIWR Standard models 5600 - 5200 A Availability : consult factory for details of approved combinations or options. Marking : to order switches marked UL, CSA or CECC, complete above box with desired approvals, in this order & without space (ex. : ULCSACECC). Blank : no agency approval required. VDE (with UL & CSA) Refer to 55000 series on the following pages. Preferential lists : see specifications. INSULATING CAPS AND PADDLES + U... Insulating caps 13.50 (.531) 11.00 (.433) Cap colours Ø3.5 (.137 DIA) 7.30 (.287) U270 For standard lever & threaded bushing only U1040 For standard lever & plain bushing only 1 1/4 2 3 4 5 6 7/1 9 blue dark blue black green grey yellow red white orange Ø3.5 (.137 DIA) U1710 For lever 17 and threaded bushing For lever 7 and plain bushing APEM Ø3.5 (.137 DIA) Replace last "0" by number Insulating caps are not available in ivory colour. www.apem.com A-49 06-Serie 5000-A-options_06-Serie 5000-A-options 30/10/14 15:09 Page50 5000 series Toggle switches INSULATED CAPS AND PADDLES (continued) Paddles For use with lever 4N only. Shown with standard threaded bushing. Order separately. 9.00 (.354) Ø6.35-40UNS (1/4-40UNS) Ø6.35-40UNS (1/4-40UNS) U290N U240N 2.00 (.078) 11.00 (.433) Ø6.35-40UNS (1/4-40UNS) 14.00 (.551) 21.55 (.848) 18.00 (.708) Replace last "0" by number 1 1/4 2 3 4 5 6 7 7/1 9 blue dark blue black green grey yellow red ivory white orange 9.00 (.354) 21.40 (.842) 6.00 (.236) Paddle colours 21.55 (.848) 6.00 (.236) 11.00 (.433) 9.00 (.354) 14.15 (.557) 12.60 (.496) 5.30 (.208) 20.00 (.787) 6.60 (.259) 2.25 (.088) A 2.00 (.078) U390N A-50 www.apem.com APEM
5664THCDB3V 价格&库存
很抱歉,暂时无法提供与“5664THCDB3V”相匹配的价格&库存,您可以联系我们找货
