6CJ1N0PR
6CJ1N0PR
    APEM(埃斐)
    APEM - 6CJ1N0PR - TACTILE SWITCH, SPST, 0.05A, 24VDC, SMD
6CJ1N0PR 数据手册
NEW SWITCH FAMILY ULTRAMEC™ ultramec TM ultramec™ 6C PANEL MOUNTED SWITCHES PCB MOUNTED SWITCHES JOYSTICKS SWITCH PANELS LED INDICATORS NEW SWITCH HIGHLY RELIABLE TACTILE SWITCH ■■ IP67 sealing ■■ 3.000.000 cycles ■■ Dimensions 8x8mm ■■ Low profile h=2,5mm ■■ Crisp sound and feel ■■ Pins for accurate positioning ■■ E xcellent for under overlay and custom caps ■■ Good when space is limited ■■ New cap 10G Ø11.5mm in 5 solid colours ■■ 6C+10G lowest solution in MEC range h=4,9mm ■■ Floating cap- easy alignment of PCB and front panel ■■ Soft actuator: no rattling from the cap when application gets shaken ultramec TM ultramec™ 6C + 10G ■■ Cap series: ■■ Round ■■ Ø11.5 mm ■■ Concave ■■ Total height: 4.9 mm ■■ Low profile h=2.5 mm ■■ Dimensions: 8 x 8 mm ■■ IP67 sealing ■■ Temp. Range: -40/+85°C ■■ Lifetime: 3,000,000 cycles ■■ Actuation force: 3.7N +/- 0.7N All dimensions in mm. Tolerances +/- 0.2 mm. 4,8 8 6 8 8 NC 10 3 1,0 1,2 0,7 4 6 9 NC 1 NC 2,5 4 NC 10 NC 2 2,5 NC 2 2x  NC 10 5 7 9 NC 9,5 3 5 7 1 3 5 7 9 3 5 7 9 NC 10,0 10,0 2 4 6 8 10 12,5 4 5 7 6 8 1 3 5 7 9 2 4 6 8 10 ■■ Tape width: 16 ■■ Pitch: 12 ■■ Reel: Ø330mm ■■ Quantity per reel: 1000 pcs ■■ MOQ: 1/2 reel 500 pcs 2 4 6 8 10 2 4 6 P2 = 2 ±0,10 8 10 Direction of tape Dot marks pin 1 P1=12±0,10 1,2,9,10 NC HOW TO ORDER Switch Mounting Poles Function Positioning pins Packaging Cap Colour code 10G 00 blue 03 grey 08 red 09 black 36 signal white + 6 C J j-bend 1 single pole NO normally open P positioning pins *optional R tape & reel Ordering example: 6CJ1NOPR + 10G09 or 6CJ1NOR Specifications subject to changes. Please see updates of products and changes of specifications on www.mec.dk 3,3 4,8 3,3 Tape & Reel 9 NC 1 NC 3 1 3 5 7 9 2,5 4,9 2,5 +0,30 W= 16 - 0,10 6 8,0 1,5 1 NC F= 7,50 ±0,10 8 NC 10 . pins r p5os o f s 7 1 hole 2 4 6 8 10 E = 1,75 ±0,10 4 3 1 3 1 5 PACKAGING 3 7 5 9 7 9 9,5 6 1,27 NC 2 13,5 2,5 1 NC 1,5 1,5 1,0 1,0 8,2 NC 2 2,5 4,8 1,0 2,5 1,5 1,5 1,0 8,0 8,2 8,2 PCB LAYOUT & CIRCUIT DIAGRAM 4 2,5 2,5 2,5 13,50 R12,5 8,0 Ø11,5 1,0 8,0 8,0 1,0 1,0 1,0 6C+10G 1,0 4,8 2,5 8,0 1,0 1,0 0,15 0,9 0,15 0,15 1,27 4,8 1,0 4,8 0,15 1,27 0,6 0,9 0,6 1,27 0,9 2,5 2,5 1,27 Switch0,6 6C 0,9 0,6 2,5 2,5 DIMENSIONS ultramec 6C TM ELECTRICAL SPECIFICATIONS TEMPERATURE RANGE Contact resistance 10MΩ Recommended resistive load 0,5-50mA 24VDC Contact bounce
6CJ1N0PR 价格&库存
很抱歉,暂时无法提供与“6CJ1N0PR”相匹配的价格&库存,您可以联系我们找货
