A1 SERIES
ENGRAVED ALUMINIUM FLUSH MOUNTING PUSHBUTTON SWITCHES & INDICATORS
Panel cut-out Ø22
A pushbutton assembly requires:
Engraved screen + lamp (if illuminated) + operator + switch block + flush mount bezel
To order these elements, select desired model numbers from the table below.
Example: Pushbutton, round, illuminated, sealed to IP 65, latching, single pole with
‘start’ engraving, 24V blue LED and flush mounting bezel. A1PCA1X103K403.
3
1
2
14.5
(.571)
42.05
(1.655)
12.00
(.472)
7.65
Ø25.00
(9.85 DIA)
8.5
(.335)
(.301)
15.3
(.602)
18.00
(.709)
(.709)
2.8
(.110)
0.5
(.020)
18.00
A1
Accessories
03 - flushmount
Switch Type
Bezel
Illumination
Sealing
Function
Switch Block
Bulb
P - pushbutton
I - indicator
C - round
A - illuminated
B - non-illum.
0 - unsealed
1 - sealed IP65
0 - indicator
X - latching
Y - momentary
01253-
A1 - filament 6.3v
B1 - filament 14v
C1 - filament 28v
D1 - filament 36v
E1 - filament 48v
F1 - filament 60v
G1 - Neon 110v
H1 - Neon 220v
I1 - Led 6v red
I2 - Led 6v green
I3 - Led 6v amber
J1 - Led 12v red
J2 - Led 12v green
J3 - Led 12v amber
J4 - Led 12v blue
J5 - Led 12v white
K1 - Led 24v red
K2 - Led 24v green
K3 - Led 24v amber
K4 - Led 24v blue
K5 - Led 24v white
L1 - Led 48v red
L2 - Led 48v green
L3 - Led 48v amber
indicator
single pole
double pole
three pole
four pole
Engraved Screen Options
For other screen engraving options
contact APEM Components.
Max. panel thickness 8mm.
01 - Front Fog Lights
11 - ‘Lock’
02 - Rear Fog Lights
12 - ‘Unlock’
03 - ‘Start’
13 - Rear Window Heating
04 - Interior Light
14 - Cooling
05 - Boot Release
15 - Wipers
06 - Hazard Warning
16 - Washers
07 - Lights
17 - Fan
08 - Heating and Ventilation
18 - Horn
09 - Map Lights
19 - Air recirculation
10 - Side Lights
20 - Blank
www.apem.com
A1/A3 Series Datasheet
PRELIMINARY DATA SHEET
Voltage
8
R
Sealing
Voltage
Electrical Specification
General Specification
www.apem.com
很抱歉,暂时无法提供与“A1PCA1X220J103”相匹配的价格&库存,您可以联系我们找货
