3631NF
3631NF
    APEM(埃斐)
    插件
    钮子开关 单刀单掷 直插 28V -40℃~+85℃
3631NF 数据手册
3600NF series Sealed toggle switches for outdoor applications Distinctive features and specifications ❑ Sealing obtained by : - O-ring between lever and bushing - half-length boot and nylon washer (supplied mounted) - elastomer gasket between cover and case - molded-in terminal inserts - sealing washer U60 A ❑ Solid silver contacts ❑ UL approved ELECTRICAL SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 12A 28VDC - 6A 250VAC • Initial contact resistance : 10 mΩ max. at 1A 2VDC • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.500 Vrms 50 Hz min. between terminals 3.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 10.000 cycles at full load GENERAL SPECIFICATIONS • Case : phenolic resin • Actuator : brass, nickel plated • Bushing : brass, nickel plated • Contacts : solid silver AGENCY APPROVAL • Torque : 1,50 Nm (1.10 Ft.lb) max. applied to nut • Panel thickness : 2 mm (.079) max. with all accessories • Operating temperature : -40°C to +85°C Availability : consult factory for details or approved models. Marking : to order switches marked UL, complete last box of ordering format. ABOUT THIS SERIES Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. Mounting accessories : 1 sealing boot U1151, 1 hex nut U166, 1 nylon washer U21 and 1 sealing washer U60. See section I. Packaging unit : 25 pieces per type and colour. APEM www.apem.com A-115 3600NF series Sealed toggle switches for outdoor applications Screw terminals - solder lug/quick-connect terminals • 1 and 2 pole configurations ➞ Keyway Ø3.00x0.50 SI (.118DIAx0.50 IS) 3 2 9.20 (.362) 1 0.80 (.031) 6.35 (.25) 4.50 (.177) 9.20 (.362) A Ø3.10 (.122DIA) 6.35x0.80 (.25x.031) MODEL STRUCTURE ➞ Keyway III 2-1 II I 2-3 17.50 (.689) 1 9.20 (.362) 24.60 (.968) 9.20 (.362) 24.60 (.968) 9.20 (.362) I 2 II 5 III 3 6 Ø12.00x0.75 SI (.472DIAx0.75 IS) 21.50 (.846) ➞ Keyway III 2-1 5-4 II I 2-3 5-6 17.50 (.689) 1 4 I 30˚ OFF ON ON ON ON OFF MOM OFF MOM OFF ON 35.00 (1.378) ON ON MOM ON MOM ON ON 10.50 (.413) 90˚ 2 II 5 6.35x0.80 (.25x.031) Screw terminals - double pole 3641NF 3644NF* 3645NF 3646NF 3647NF 3648NF 3649NF 24.60 (.968) 4 30˚ ON OFF MOM ON ON ON MOM OFF MOM ON OFF MOM ON OFF ON 35.00 (1.378) 3631NF 3635NF 3636NF 3637NF 3638NF 3639NF 10.50 (.413) 90˚ 6.35x0.80 (.25x.031) Screw terminals - single pole III 3 6 Ø12.00x0.75 SI (.472DIAx0.75 IS) 21.50 (.846) * Function 4 : SP in DP case, see end of catalogue. ➞ Keyway I 2-3 ON OFF MOM ON ON ON MOM OFF MOM ON OFF MOM ON OFF ON 17.50 (.689) 10.50 (.413) 90˚ 1 4 I 2 II 5 III 3 6 Ø12.00x0.75 SI (.472DIAx0.75 IS) 6.35x0.80 (.25x.031) 3631NF/2 3635NF/2 3636NF/2 3637NF/2 3638NF/2 3639NF/2 II 35.00 (1.378) III 2-1 30˚ Solder lug/quick-connect terminals - single pole 21.50 (.846) A-116 www.apem.com APEM 3600NF series Sealed toggle switches for outdoor applications Solder lug/quick-connect terminals Solder lug and quick-connect terminals - double pole II I 2-3 5-6 17.50 (.689) 1 24.60 (.968) 9.20 (.362) 4 I 30˚ OFF ON ON ON ON OFF MOM OFF MOM OFF ON 35.00 (1.378) ON ON MOM ON MOM ON ON 3641NF/2 3644NF/2* 3645NF/2 3646NF/2 3647NF/2 3648NF/2 3649NF/2 10.50 (.413) 90˚ 2 II A 5 III 3 6 Ø12.00x0.75 SI (.472DIAx0.75 IS) 6.35x0.80 (.25x.031) III 2-1 5-4 21.50 (.846) * Function 4 : DP in 4P case, see end of catalogue. PANEL CUT-OUT Ø12.20 (.48DIA) Ø12.20 (.48DIA) Ø12.50 (.492DIA) 5.10 (.20) 9.60 (.377) Ø3.50 (.137DIA) 1.70 (.066) FINISH G Matt black finish on lever and nut of sealing boot SPECIAL LEVER X1052 30 mm (1.181) long lever AGENCY APPROVAL UL Marking : to order switches marked UL, complete above box with ”UL”. APEM www.apem.com A-117
3631NF
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离器件。
2. 器件简介:EL817是一个光隔离集成电路,用于消除电气噪声,保护电路不受外部干扰。
3. 引脚分配:EL817共有8个引脚,包括Vcc、Vo、GND、A、B、C、D、E。
4. 参数特性:工作电压范围为3.5V至15V,输入电流为5mA,输出电流为50mA。
5. 功能详解:EL817通过光隔离技术实现信号传输,提高系统稳定性和抗干扰能力。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP-8封装形式。
3631NF 价格&库存
很抱歉,暂时无法提供与“3631NF”相匹配的价格&库存,您可以联系我们找货
3631NF
  • 7+147.13541
  • 16+144.37866
  • 25+136.21724
  • 50+124.67033
  • 100+101.75788
  • 500+88.44569
  • 1000+79.92153
  • 5000+71.03464
库存:90
