IBR3SAD7/1
IBR3SAD7/1
    APEM(埃斐)
    APEM - IBR3SAD7/1 - Industrial Pushbutton Switch, IB Series, 13.6 mm, SPST-NO, Momentary, Round, Whi...
IBR3SAD7/1 数据手册
IB and IS series Sealed pushbutton switches - bushing Ø 12 mm - momentary Distinctive features and specifications UG1410-A-R1 ❑ Snap-in and threaded bushing models ❑ Compact, light in weight • Behind-panel depth of 13 mm (.512) only • 50 % reduction in weight compared to metallic models ❑ Tactile feedback ❑ Sealed to IP67 (IS series) or IP54 (IB series) B1 ENVIRONMENTAL SPECIFICATIONS MATERIALS • Front panel sealing according to IEC 60529 : IP67 (IS) or IP54 (IB) • Shock resistance : 100 g according to IEC 512-4, test 6c • Vibration resistance : 10-500 Hz - 10 g according to IEC 512-4, test 6d • Salt spray : IEC 512-6, test 11f • Operating temperature : -40°C to +85°C • Case : thermoplastic UL94-V0 • Actuator : polyamide 6/6 • Bushing/bezel : polyamide 6/6 • Contacts : silver, gold plated • Terminal seal : epoxy ELECTRICAL SPECIFICATIONS AGENCY APPROVAL • Max. current/voltage rating with resistive load : 400mA 32VAC - 100mA 48VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.000 Vrms • Electrical life at full load : 500.000 cycles 2A 125VAC/250VAC File E83438 Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete approrpiate box of ordering format. GENERAL SPECIFICATIONS • Panel thickness : - IB series : 0,8 mm (.031) min. - 1,8 mm ( .071) max. - IS series : 1,5 mm (.059) min. - 4 mm (.157) max. • Total travel : 1,7 mm (.066) +/- 0,3 mm • Typical operating force : 4N +/- 3N • Low level or mechanical life : 1.000.000 cycles • Torque (applied to nut) : 1 Nm max. with metal nut U166 1,5 Nm max. with plastic nut U4248 • Soldering : 300°C max. for 3 seconds itch: m sw s. o t s u f c e serie ple o h Exame end of t se Panel mounting : see next pages. The company reserves the right to change specifications without notice. APEM www.apem.com B1-25 IB and IS series Sealed pushbutton switches - bushing Ø 12 mm - momentary Overview SERIES IB Snap-in IS Threaded bushing Actuator shapes R P Round, curved Round, flat 3 Electrical function Terminals Normally open (NO) S Solder lug P Straight PC Z1 Quick-connect 2,8 x 0,5 mm Contacts AD Silver, gold plated B1 Actuator colours 1 B 2 3 4 5 6 7/1 8 9 A Blue Dark blue Black Green Grey Yellow Red White Bright chrome Orange Satin chrome Bezel finish 00 08 10 20 Black (std) Bright chrome (IS only) White Satin chrome (IS only) Option 104 High actuator Approval UL Consult factory for detail of approved models. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. A sealing boot is available to protect the switches against frost and sand. It is presented after the IA series and in section H. Mounting accessories : Standard hardware supplied : 1 flat seal (IB series) 1 metal hex nut 14 mm (.551) across flats, part number U166, and 1 flat seal (IS series). Plastic nut 17 mm (.669) across flats, thickness 4 mm (.157) available on request. Part number U4248. Packaging unit : 50 pieces B1-26 www.apem.com APEM IB and IS series Sealed pushbutton switches - bushing Ø 12 mm - momentary • Ten actuator colours • Curved or flat actuator • Antirotation bushing Solder lug S Quick-connect Z1 3.40 (.133) 1.00 (.039) 1.50 (.059) 1.20 (.047) 1.20 (.047) 2.80 (.110) 2.80 (.110) Function 3 (NO) MODEL STRUCTURE 8.40 (.330) 2.40 (.094) Straight P CISCOS-A CISCOSP ECH: 0.9 ECH: 0.9 Actuator marking available on IBP and ISP models (symbol 10 mm max.). On request. 5-05-03 ➞ Snap-in mounting - solder lug terminals 5-05-03 CISCOSZ-A Ø17.50 (.688DIA) Normally open 1.20 (.047) Flat actuator IBP3SAD 5.00 (.196) Normally open DESSIN ECH 0.9 5-05-03 3.20 (.125) 13.00 (.511) Curved actuator IBR3SAD 2.00 (.078) Ø12.00 (.472DIA) 0.50 (.019) 2.80 (.110) EPOXY 5.08 (.200) Also available with straight PC : IB•3PAD or quick-connect terminals : IB•3Z1AD Panel thickness : 1,5 mm to 4 mm Flat Mounting by threaded bushing - solder lug terminals ➞ Ø17.50 (.688DIA) 5.60 (.220) Normally open 1.20 (.047) Flat actuator ISP3SAD 5.00 (.196) Normally open 13.00 (.511) Curved actuator ISR3SAD 2.00 (.078) Ø12.00 (.472DIA) 3.20 (.125) 0.50 (.019) 5.08 (.200) 2.80 (.110) EPOXY Ø12.00x0.75SI (.472DIAx0.75IS) Also available with straight PC : IS•3PAD or quick-connect terminals : IS•3Z1AD ACTUATOR COLOURS Actuator marking available on IBP and ISP models (symbol 10 mm max.). On request. 1 : blue - B : dark blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7/1 : white - 8 : bright chrome 9 : orange - A : satin chrome BUSHING AND BEZEL FINISH 00 : Black (standard) 08 : Bright chrome (IS series only) 10 : White 20 : Satin chrome (IS series only) APEM B1 Panel thickness : 0,8 mm to 1,8 mm Flat www.apem.com B1-27 IB and IS series Ø12.00 (.472DIA) 4.70 (.185) Ø12.00 (.472DIA) ACTUATOR OPTION 4.70 (.185) Sealed pushbutton switches - bushing Ø 12 mm - momentary 104 : High actuator IBR IBP APPROVAL UL Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete above box with ”UL”. IB SERIES MOUNTING Panel cut-out 18.00 (.709) 1.80 MAXI. (.071MAX.) 12.90 (.507) Matrix mounting 0.80 MINI. (.031MIN.) 18.00 (.709) 18.00 (.709) Ø13.60 (.535DIA) IS SERIES MOUNTING Matrix mounting 12.90 (.507) 1 Ø13.60 (.535DIA) ➀ Flat seal 20.00 (.787) 20.00 (.787) 20.00 (.787) Panel cut-out 1.50min-4Max (.059MIN.-.157MAX.) B1 Ø13.50 (.531DIA) Example of custom switch • Painted bushing and actuator, soft feel • Flying leads (55 mm) + connector • Overmolded rear part ISR3FADB22X1248-01 B1-28 www.apem.com APEM
IBR3SAD7/1 价格&库存
很抱歉,暂时无法提供与“IBR3SAD7/1”相匹配的价格&库存,您可以联系我们找货
