104350003
104350003
    APEM(埃斐)
104350003 数据手册
09-Serie 10400-A_13-Serie 10400-A 04/11/14 14:46 Page42 10400 series Professional pushbutton switches - threaded bushing Ø 10 (.393) Distinctive features and specifications UG1410A ❑ CECC approved B2 ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 3A 24VDC • Minimum load : 100µA 10mV • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Veff. 50 Hz min. between terminals of the same pole 2.000 Veff. 50 Hz min. between terminals and frame 2.000 Veff. 50 Hz min. between terminals of adjacent poles • Electrical life : 50.000 cycles APPROVAL MATERIALS • Case : diallylphthalate (DAP) • Actuator : brass, chrome plated • Bushing : brass, nickel plated • Housing : brass, nickel plated • Contacts : - silver - gold plated silver • Terminal seal : epoxy GENERAL SPECIFICATIONS CECC 96401-001 Availability : consult factory for details of approved models. • Torque : 1,50 Nm (1.106 Ft.lb) max. applied to nut • Operating temperature : -40°C to +85°C • Max. panel thickness : 3,5 mm (.138) Marking : to order switches marked CECC, add “CECC” to model number. ABOUT THIS SERIES Complete part numbers are shown on the following page. Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Sealing boots are available to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied with all models : 1 knurled nut, 1 hex nut, 1 locking ring and 1 lockwasher. They are presented in section I. Packaging unit : 25 pieces. The company reserves the right to change specifications without notice. B2-42 www.apem.com APEM 09-Serie 10400-A_13-Serie 10400-A 31/10/14 09:06 Page43 10400 series 2 3 1 1 Single pole 3 1.70 (.066) • Solder lug terminals • 1 and 2 pole configurations • Available with matt black finish : consult factory for model number ➞ Keyway 1.20 (.047) 2 Double pole 5.00 (.196) Professional pushbutton switches - threaded bushing Ø 10 (.393) 2.50 (.098) MODEL STRUCTURE B2 ➞ Keyway 8.00 (.314) ON Gold plated silver contacts 104350108 - 3 MOM 2 5.00 (.196) 11.00 (.433) Ø10.00 X 0.75 SI (.393 DIA X 0.75 IS) MOM 2.50 (.098) ➞ Keyway ON - MOM Gold plated silver contacts 104450108 ON - MOM 3 1 A B 5 4.00 (.157) 2 12.70 5.00 (.500) (.196) 6 4 5.00 (.196) 11.00 (.433) Ø10.00 X 0.75 SI (.393 DIA X 0.75 IS) EPOXY Ø14.00 (.551 DIA) 2.50 (.098) Ø6.40 (.251 DIA) Silver contacts 104450003 14.00 (.551) 1 3 2 B 2-3 5-6 0.50 (.019) A 2-1 5-4 14.00 (.551) Double pole Ø14.00 (.551 DIA) EPOXY Ø6.40 (.251 DIA) ON - 14.00 (.551) Silver contacts 104350003 A B 4.00 (.157) 1 12.70 5.00 (.500) (.196) 6.00 (.236) B 1-3 2 3 1 A 1-2 0.50 (.019) Single pole + U... Cap colours Replace last "0" by number 3.00 (.118) 6.00 (.236) Ø13.00 (.511 DIA) Ø10.20 (.401 DIA) 6.20 (.244) PANEL CUT-OUT CAP 1 1/4 2 3 4 blue dark blue black green grey 5 yellow 6 red 7 ivory 7/1 white 9 orange 2.20 (.086) U2600 APEM www.apem.com B2-43
104350003 价格&库存
很抱歉,暂时无法提供与“104350003”相匹配的价格&库存,您可以联系我们找货
    • 1+331.93434
    • 50+326.12501
    • 100+317.95601
    • 250+309.51152
    • 500+302.31274
    库存:18
