AV series
-A
SW
PANEL SWITCHES
VE
O
22
9
V1
RM
9
70
-1
Tactile security pushbutton switches with
overmolded actuator • Ø 19 or 22 mm
DISTINCTIVE FEATURES
Tactile feedback
Illuminated or non-illuminated
Momentary (NO)
Overmolded marking available
ENVIRONMENTAL SPECIFICATIONS
• Front panel sealing : IP67 or IP69K according to IEC 60529
• Operating temperature : -30 °C to +70 °C (-22 °F to +158 °F)
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load : 50 mA 24 VDC
• LED voltage and consumption : 2-color LED : 2 V (3 V max.) 20 mA
Other colors : 2 V (3 V max.) 10 mA
(a resistor must be series-connected by the user)**
• Initial contact resistance : 100 mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500 VDC
• Dielectric strength : 500 Vrms 50 Hz min. between terminals
2,000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 1,000,000 cycles at full load
** Resistor value = supply voltage - LED forward voltage
LED forward current
GENERAL SPECIFICATIONS
• Travel : 0.7 mm (.027) ± 0.1 mm (.003)
• Operating force : 7 N ± 2N - Sealing option K will increase
the operating force.
• Torque : 5 Nm min.- 14 Nm max. applied to nut
• Panel thickness : 1 (.039) to 6 mm (.236) max.
• Hand soldering : 270 °C (518 °F), 3 sec. max.
The company reserves the right to change specifications without notice.
1
PANEL SWITCHES
AV series
Tactile security pushbutton switches with overmolded actuator •
Ø 19 or 22 mm
MATERIALS
• Case : PBT UL94-V0
• Terminals : brass, gold plated
• Contacts : gold plated dome
• Bushing : see following pages
• Actuator : stainless steel, with thermoplastic overmolding
• LED
ELECTRICAL FUNCTIONS
Function 3 (NO)
MOUNTING
• Panel cut-out : Ø 19.2 mm (.755), or Ø 22.2 mm (.874)
• Min. pitch for matrix mounting :
30 mm x 30 mm (1.181x1.181)
2
Ø 19 or 22 mm
BUILD YOUR PART NUMBER
BASIC PART NUMBER
AV
SERIES
BUSHING DIAMETERS
CONTACTS
ILLUMINATION
9
19 (.748)
S0
No
3
22 (.866)
SL
Illuminated
D
TERMINALS
Gold plated
dome
2
Solder
9
Screw
4
Quick-connect
OPTIONS
BUSHING MATERIALS
(std)
Nickel plated
brass
2
Chrome plated
brass
4
LED COLORS
OVERMOLDING COLORS
SEALING
1
Blue
1
Blue
5
Yellow
2
Black*
2
Red/green
6
Red
3
Green
3**
Green
7
White
Stainless steel
4
Grey*
V**
9
Amber
5
Gold plated brass
5
Yellow
Green, high
intensity
6
Chrome plated
brass, satin
6
Red
7
Chrome plated
brass, black
7
White
8
Translucent
9
Orange
* non-illuminated only
Blank
K
No sealing
Sealed to IP67
or IP69K
** To order a green LED for actuator
style 002, always use code V.
Other actuator styles can be ordered
with LED code 3 or V.
ACTUATOR STYLES
002
Illuminated ring
006
Validation
009
Standby
010
Cancel
011
Power
Other styles : see website.
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of
website.
3
PANEL SWITCHES
AV series
Ø 19 or 22 mm
Hex nut 22 (.866) across flats
BUSHING Ø 19 (.748) - FLAT ACTUATOR
SOLDER LUG TERMINALS
2.00
(.078)
4.00
(.157)
2.00
(.078)
1.90
(.074)
Ø15.00
(.590DIA)
Ø22.00
(.866DIA)
Ø15.00
(.590DIA)
Ø22.00
(.866DIA)
AV9SLD2
1.10
(.043)
Illuminated
4.15
(.163)
Non-illuminated
AV9S0D2
4.30
(.169)
9.80
(.385)
SCREW TERMINALS
2.00
(.078)
4.00
(.157)
2.00
(.078)
9.00
CAV9SDTL-1
(.354)
Ø15.00
(.590DIA)
Ø22.00
(.866DIA)
Ø15.00
(.590DIA)
AV9SLD9
Ø22.00
(.866DIA)
Illuminated
Non-illuminated
AV9S0D9
CAV9SDTL-3
Hex nut
25 (.984) across flats
BUSHING Ø 22 (.866) - FLAT ACTUATOR
2.00
(.078)
4.00
(.157)
2.00
(.078)
1.90
(.074)
Ø15.00
(.590DIA)
Ø25.00
(.984DIA)
Ø15.00
(.590DIA)
Ø25.00
(.984DIA)
1.10
(.043)
Illuminated
AV3SLD2
4.30
(.169)
9.80
(.385)
EPOXY
4.15
(.163)
Non-illuminated
AV3S0D2
4.80
(.188)
9.30
(.366)
CAV3SDTL-1
Hex nut 25 (.984) across flats
SCREW TERMINALS
ECHELLE 1
2.00
(.078)
4.00
(.157)
2.00
(.078)
9.00
(.354)
Ø15.00
(.590DIA)
Non-illuminated
Ø25.00
(.984DIA)
AV3SLD9
Ø15.00
(.590DIA)
Illuminated
Ø25.00
(.984DIA)
PANEL SWITCHES
AV series
AV3S0D9
9.30
(.366)
4
4.80
(.188)
Ø 19 or 22 mm
BUSHING MATERIALS
BASIC P/N
0 (std)
2
4
5
6
7
Nickel plated brass
Chrome plated brass
Stainless steel
Gold plated brass
Chrome plated brass, satin
Chrome plated brass, black
OVERMOLDING COLORS
BASIC P/N
1
2
3
4
5
6
7
8
9
Blue
Black*
Green
Grey*
Yellow
Red
White
Translucent
Orange
LED COLORS
BASIC P/N
Blank
1
2
3**
V**
5
6
7
9
No LED
Blue
Red / green
Green
Green, high intensity
Yellow
Red
White
Amber
** To order a green LED for actuator style 002, always use code V.
Other actuator styles can be ordered with LED code 3 or V.
ACTUATOR STYLES
BASIC P/N
The ring and symbols are obtained by photochemical engraving of a stainless steel insert.
The insert is then overmolded in the desired color.
The following actuator styles are available. For other types, consult factory.
001
Illuminated
ring and disc
002
Illuminated
ring
003
Arrow
004
Loudspeaker
OFF
005
Opening
006
Validation
008
Closing
009
Standby
010
Cancel
011
Power
CAV9SBS
ECHELLE 1
5
PANEL SWITCHES
AV series
PANEL SWITCHES
AV series
Ø 19 or 22 mm
SEALING
BASIC P/N
Blank No sealing
K
Front panel sealing to IP67 or IP69K
OPTION K - FRONT PANEL SEALING IP67
2
1
- internal membrane
- external gasket
CAV9SETA
OPTION K - FRONT PANEL SEALING IP69K
CAV9SET69K
ECHELLE1
6
很抱歉,暂时无法提供与“AV9SLD2011001K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 16+849.1382416+110.34768
