8642A
8642A
    APEM(埃斐)
    8642A
8642A 数据手册
PANEL SWITCHES 0 -8 SW 08 18 00 8000 series Momentary or alternate action pushbutton switches DISTINCTIVE FEATURES Momentary or alternate Bushing Ø 6.35 (1/4) and Ø 11.9 (15/32) UL approved ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts : 4 A 30 VDC - gold plated contacts : 0.4 VA max. 20 VAC or DC • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals 2,000 Vrms 50 Hz min. between terminals and frame • Electrical life : 30,000 cycles at full load GENERAL SPECIFICATIONS • Torque : 1.25 Nm (.922 Ft.lb) max. applied to nut • Total travel : 2.70 mm (.106) • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) MATERIALS • Case : diallylphthalate (DAP) • Actuator : brass, nickel plated • Bushing : brass, nickel plated • Housing : stainless steel • Contacts A : silver AD : silver, gold plated CD : brass, gold plated • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 Momentary or alternate action pushbutton switches TERMINALS 3.70 (.145) 1.90 (.074) 3 A 250 VAC, 6 A 125 VAC Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete appropriate box of ordering format. 1.80 (.070) 1.10 (.043) Solder lug PANEL CUT-OUT 5.20 (.204) Ø6.50 (.255 DIA) Ø2.20 (.086 DIA) 5.20 (.204) Ø6.50 (.255 DIA) 2.70 (.106) With K sealing option Standard ELECTRICAL FUNCTIONS KEYWAY 1 21 32 3 Funct. 6 (ON-ON) 2 2.70 (.106) 1 21 32 3 1 21 32 3 Funct. 2 (ON-MOM) 1.10 (.043) Ø6.50 (.255 DIA)Ø2.20 (.086 DIA) 1.10 (.043) Ø6.50 (.255 DIA) 4.00 (.157) AGENCY APPROVAL 5.30 (.208) PANEL SWITCHES 8000 series 1.10 (.043) Straigh PC Momentary or alternate action pushbutton switches BUILD YOUR PART NUMBER BASIC PART NUMBER 8 SERIES TERMINALS AND BUSHINGS 4 Straight PC or right angle terminals 6 Solder lug terminals NUMBER OF POLES ELECTRICAL FUNCTIONS 3 Single pole 2 ON - MOM 4 Double pole 6 ON - ON TERMINALS Solder lugs or straight PC depending on model Blank W All models with Ø 6.35 (1/4) or Ø 11.9 (15/32) threaded bushing. Right angle OPTIONS ORDER SEPARATELY. PLUNGERS CONTACT MATERIALS A For bushing Ø 6.35 (1/4) Silver AD Silver, gold plated CD Brass, gold plated Blank Height 6.3 (.248) -9 Height 8.8 (.346) For bushing Ø 11.9 (15/32) Blank -6 SEALING Blank No sealing B Epoxy sealed terminals K Front panel sealing by O-ring and sealing washer APPROVAL SPECIAL OPTIONS X718 Bushing Ø 11.9 (15/32) X934 Flatted bushing Ø 11.9 (15/32) + front panel sealing UL Consult factory for details of approved models. CAPS Height 8.6 (.338) Height 7 (.275) U900 Ø 5 (.196) U1140 Ø 8 (.314) U1720 Ø 9.4 (.370) U480 Ø 10 (.393) Standard U630 Ø 15 (.590) U2430 Square Height 4 (.157) U2020 Square Height 6 (.236) ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Sealing boots are available to protect the switches against dust and water. See "Sealing Boots" section of website. Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware available is presented in the “Hardware“ section of website. 3 PANEL SWITCHES 8000 series Momentary or alternate action pushbutton switches Shown with standard plunger KEYWAY SOLDER LUG TERMINALS : 8600 ON MOM 8646 ON ON Double pole 4 7.00 (.275) ON ON 2-3 5-6 1-2 4-5 8442 ON MOM 8446 ON ON 6.30 (.248) Ø1.60 (.062 DIA) 1 0.80 (.031) 4.75 (.187) 2 3 0.50 (.019) 4.00 (.157) 12.00 (.472) 4.00 (.157) MOM 19.50 (.767) ON 8436 Ø4.00 (.157 DIA) 7.20 (.283) 1-2 Ø10.00 (.393 DIA) 13.20 (.519) 4.00 (.157) 2-3 8432 1.10 (.043) 7.00 (.275) KEYWAY ON ON 2-3 5-6 1-2 4-5 8442W ON MOM 8446W ON ON 12.00 (.472) 3.70 (.145) 0.80 (.031) 4.00 (.157) 12.70 (.500) 3 2 1 0.50 (.019) Ø1.60 (.062 DIA) 4.00 (.157) 8.60 (.338) 8436W 7.20 (.283) MOM 11.00 (.433) ON 5.08 (.196) Ø4.00 (.157 DIA) 8.60 (.338) 8432W 12.70 (.500) 1-2 4.75 (.187) Ø10.00 (.393 DIA) 13.20 (.519) 7.00 (.275) Ø6.35-40UNS (1/4-40UNS) 2-3 1.80 (.070) 7.00 (.275) Ø6.35-40UNS (1/4-40UNS) RIGHT ANGLE TERMINALS HORIZONTAL : 8400W Single pole 4.00 (.157) 12.00 (.472) 6.30 (.248) Double pole 3 0.50 (.019) KEYWAY STRAIGHT PC TERMINALS : 8400 Single pole 2 1 0.80 (.031) 4.75 (.187) 4.00 (.157) 8642 12.00 (.472) 3.70 (.145) 5.08 (.200) 3.81 12.70 (.150) (.500) 1-2 4-5 12.70 (.500) 2-3 5-6 18.20 (.716) ON 3.70 (.145) ON 7.20 (.283) MOM 7.00 (.275) ON 8636 Ø4.00 (.157 DIA) 0.40 (.015) Double pole 1-2 1.10 (.043) Single pole 2-3 8632 Ø10.00 (.393 DIA) 13.20 (.519) 6.30 (.248) Ø6.35-40UNS (1/4-40UNS) 3.81 (.150) PANEL SWITCHES 8000 series Ø1.60 (.062 DIA) 4.00 (.157) Momentary or alternate action pushbutton switches CONTACT MATERIALS BASIC P/N A AD CD Silver Silver, gold plated Brass, gold plated SEALING Blank No sealing Ø10.60 (.417 DIA) Epoxy sealed terminals KB Combined sealings Sealing washer 1 Ø11.80 (.464 DIA) 2 Sealing boot : see "Sealing boots" section of website. Ø6.40 (.251 DIA) B O-ring 2Maxi (.078 Max) K Frontal sealing by O-ring and sealing washer. Protects the switch against water and dust. Panel seal withstands 1 bar pressure. 2.30 (.090) BASIC P/N 5.80 (.228) K B PLUNGERS BASIC P/N Dash compulsory before plunger code. FOR Ø 6.35 (1/4) BUSHING FOR Ø 11.9 (15/32) BUSHING (X718 MODELS) Ø6.35-40UNS (1/4-40UNS) Ø11.90-32UNS (15/32-32UNS) Ø6.40 (.251DIA) 7.00 (.275) Ø4.00 (.157 DIA) -9 12.00 (.472) 12.00 (.472) 7.00 (.275) 14.20 (.559) 7.00 (.275) 14.20 (.559) Blank Standard Ø11.90-32UNS (15/32-32UNS) Ø4.00 (.157 DIA) 8.50 (.334) Ø4.00 (.157 DIA) 8.80 (.346) 6.30 (.248) Ø6.35-40UNS (1/4-40UNS) Blank Standard -6 5 PANEL SWITCHES 8000 series Momentary or alternate action pushbutton switches SPECIAL OPTIONS BASIC P/N X601  Silver plated brass contacts Current/voltage rating for an electrical life of 20,000 cycles : 0.5 A 30 VDC. Minimum quantity : 5,000 pieces per model and shipment. X718 Bushing Ø 11.9 (15/32) For all basic models (solder lug, straight PC or right angle terminals) Available with plungers shown on previous page (Standard and -6) K sealing option available. X748 Snap-in mounting. Consult factory. Panel cut-out 15 x 12.5 (.59 x .492) X934 Flatted bushing Ø 11.9 (15/32) + sealing by two O-rings (for plunger -6 only). Epoxy sealed terminals. OPTION X718 KEYWAY Ø4.00 (.157) Ø12.50 (.492 DIA) Ø12.00 (.472 DIA) 1.70 (.066) Ø3.50 (.137 DIA) 11.00 (.433) 12.00 (.472) 8.60 (.338) Ø11.90-32UNS (15/32-32UNS) 9.60 (.377) 1 2 5.10 (.200) 3 OPTION X934 KEYWAY Ø6.40 (.251) Ø12.00 (.472 DIA) 1.50 (.059) 1 2 3 8 Maxi (.314 MAX) 10.50 (.413) 7.00 (.275) Ø11.90-32UNS (15/32-32UNS) 12.50 (.492) PANEL SWITCHES 8000 series 5.10 (.200) EPOXY AGENCY APPROVAL C80X934-A BASIC P/N UL C80X Page 5 Availability : consult factory for details of approved models. Le 24-09-92 Marking : to order switches marked UL, complete above box with ”UL”. ECH: 0.7 6 Momentary or alternate action pushbutton switches CAPS Order separately The caps below are for Ø 4 mm plungers (standard and -9), except U2600. Ø10.00 (.393) Ø9.40 (.370) Ø8.00 (.314) U900 U1140 3.00 (.118) 6.35 (.250) 3.00 (.118) 6.35 (.250) 3.00 (.118) 4.00 (.157) 7.50 (.295) Ø5.00 (.196) 3.30 (.129) U1720 Ø15.00 (.590 DIA) U480 Standard 11.50x11.50 (.452 SQ) 11.50x11.50 (.452 SQ) Ø13.00 (.511 DIA) U630 U2430 Square U2020 Square 3.00 (.118) 6.00 (.236) 6.00 (.236) 5.00 (.195) 4.00 (.157) 3.00 (.118) 3.00 (.196) 10.00 (.393) Cap colors Replace last "0" by number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7 Ivory 7/1 White 9 Orange U2600 For large plunger -6 only. DRESS NUTS Ø13.50 (.531 DIA) Ø8.20 (.322 DIA) Ø15.50 (.610 DIA) Ø10.50 (.413 DIA) 8.00 (.314) 8.00 (.314) 8.20 (.322) 5.80 (.228) Ø18.50 (.728 DIA) 6.20 (.244) Ø12.70 (.500 DIA) Ø6.35-40UNS (1/4-40UNS) U1636 For cap U1140 5.80 (.228) Order separately Chrome plated. Ø6.35-40UNS (1/4-40UNS) U825 For cap U630 Ø6.35-40UNS (1/4-40UNS) U840 For cap U480 7 PANEL SWITCHES 8000 series
8642A 价格&库存
很抱歉,暂时无法提供与“8642A”相匹配的价格&库存,您可以联系我们找货
8642A
    • 1+117.63471
    • 50+115.57277
    • 100+112.70896
    • 250+109.87640
    • 500+107.14797
    库存:200
    8642A
    • 5+222.093765+28.65067
    • 25+137.6278625+17.75435
    库存:40
    8642A
    • 7+133.111367+17.17171
    • 10+118.9293310+15.34219
    • 50+82.7106950+10.66989
    库存:193
    8642A
    • 1+84.091361+10.84800
    • 10+75.1566510+9.69540
    • 50+70.4265150+9.08520
    • 250+65.95916250+8.50890
    • 2500+59.564712500+7.68400
    库存:193
