AV series
New!
Security pushbutton switches Ø 19 mm (.748)
Momentary (NC/NO)
ORDER FORMAT
AV
19
L
P
SERIES
Bushing
diameter
Bushing/act.
config.
Actuator
shape
P Flat
C
C
C
40
9
Act./bushing
material
40 Stainless
steel
Combined NC/NO
SPECIFICATIONS
Terminals
00 PC
04 Wire
leads
MATERIALS
• Max. current/voltage rating with resistive load :
2A 12VDC, 200.000 cycles - 1A 24VDC, 200.000 cycles
3A 125Vca - 0,2A 60VDC - 6.000 cycles
• Initial contact resistance : 100 mΩ max.
• Insulation resistance: 100 MΩ min. at 500VDC
• Dielectric strength : 500 Vrms 50 Hz min.
• Torque : 5 Nm min.- 14 Nm max. applied to nut
• Panel thickness : 1 (.039) to 6 mm (.236) max.
• Operating temperature : -20°C to +55°C
• Mechanical life : 1.000.000 cycles
• Front panel sealing : IP65
• Hand soldering : 300°C, 3 seconds max.
• Packaging unit : models with straight PC terminals : 20 pieces
Models with wire lead terminals : individual bags
BASIC MODEL
Microswitch
type
• Contacts : silver
• Bushing and actuator : stainless
steel
CUT-OUT
• Panel cut-out : Ø 19,2 mm
(.755)
• Min. pitch for matrix mounting :
30 mm x 30 mm (1.181x1.181)
The common terminal is indicated by the letter C on the drawing.
Flat actuator - straight PC terminals
Hex nut 22 (.866) across flats
➞ O-Ring
5.08
5.08
(.200) (.200)
2.00
(.078)
C
Ø19.00x1.00 SI
(.748DIAx1.00 IS)
Ø15.00
(.590DIA)
5.80
(.228)
AV19LP40900
Ø22.00
(.866DIA)
C
C
13.50
(.531)
Flat actuator - wire lead terminals
9.30
(.366)
2.90
(.114)
➞ O-Ring
500±10mm
(19.68±.393)
2.00
(.078)
Ø15.00
(.590DIA)
AV19LP40904
Ø22.00
(.866DIA)
C
13.50
(.531)
Wire length : 500 mm
APEM
9.30
(.366)
Ø19.00x1.00 SI
(.748DIAx1.00 IS)
In the upper position (ON), the closed circuit is through the red wires.
In the lower position (MOM), the closed circuit is through the blue wires.
www.apem.com
B-101
B
很抱歉,暂时无法提供与“AV19LP40904”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+373.80942
- 10+364.07131
- 50+351.37463
- 100+343.34937
- 250+337.06092
- 国内价格 香港价格
- 20+1048.5201820+135.17448
