206PN
206PN
    APEM(埃斐)
    摇头安全盖
206PN 数据手册
8 W -S SW CH IT D AR U G PANEL SWITCHES 80 1 S- Switch guards For switch series 12000 - 3500 - 600H - 6000 DISTINCTIVE FEATURES Prevent accidental lever operation Many options available Designed for Ø 11.9 or Ø 12 mm bushing Models for 2 or 3 positions switches Ø 1.5 mm holes for wiring a seal optional ENVIRONMENTAL SPECIFICATIONS • Salt spray test : 96 hours (IEC 68-2-11) • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. MATERIALS • Support plate : black stainless steel • Cap : thermoset or thermoplastic (20PN, 200PN, 300PN) APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 For switch series 12000 - 3500 - 600H - 6000 SERIES 20 - WITH STANDARD BUSHING FOR 2-POSITION SWITCHES Color 22 Grey 23 White 24 Orange 25 Black 26 Red 27 Green 28 Yellow 29 Blue 17.00 (.669) Black/yellow striped SERIES 20PN - WITH STANDARD BUSHING FOR 2-POSITION SWITCHES 22PN Grey 23PN White 24PN Orange 25PN Black 26PN Red 27PN Green 28PN Yellow 29PN Blue ECH 0.9 14.00 (.551) Color 32 Grey 33 White 34 Orange 35 Black 36 Red 37 Green 38 Yellow 39 Blue 17.00 (.669) Model 140 (with smaller aperture) recommended for the 12000 series. 2 Model No Color 42 Grey 43 White 44 Orange 45 Black 46 Red 47 Green 48 Yellow 49 Blue 45/48 22.00 (.866) Black/yellow striped SERIES 40 - WITH STANDARD BUSHING FOR 2-POSITION SWITCHES Lever returned then locked in upper position 49.00 (1.929) 16.40 (.645) Model No 35/38 28.00 (1.102) 39.40 (1.551) Lever returned then locked in upper position LE 21-11-2006 17.00 (.669) On this model, holes for wiring a seal are standard. SERIES 30 FOR 3-POSITION SWITCHES CCACHE20-A 33.50 (1.318) Color SERIE20-A 21.00 (.826) Model No 14.00 (.551) 44.00 (1.732) Lever returned then locked in down position (OFF) 22.00 (.866) Black/yellow striped 14.00 (.551) 49.00 (1.929) 16.40 (.645) 25/28 16.40 (.645) Model No 49.00 (1.929) 39.40 (1.551) Lever returned then locked in down position (OFF) 14.00 (.551) 39.40 (1.551) PANEL SWITCHES Switch guards 17.00 (.669) 22.00 (.866) For switch series 12000 - 3500 - 600H - 6000 14.00 (.551) Color 82 Grey 83 White 84 Orange 85 Black 86 Red 87 Green 88 Yellow 89 Blue 16.40 (.645) Model No 17.00 (.669) 14.00 (.551) Color 202 Grey 203 White 204 Orange 205 Black 206 Red 207 Green 208 Yellow 209 Blue 17.00 (.669) 14.00 (.551) SERIES 200PN - FOR 2 OR 3-POSITION SWITCHES ACTION PREVENTER 202PN Grey 203PN White 204PN Orange 205PN Black 206PN Red 207PN Green 208PN Yellow 209PN Blue ECHSERIE200 0.9 07/01/2010 21.00 (.826) Color 17.00 (.669) SERIES 50 FOR 2-POSITION SWITCHES 14.00 (.551) Model No Color 52 Grey 53 White 54 Orange 55 Black 56 Red 57 Green 58 Yellow 59 Blue 55/58 Black/yellow striped SERIE 200 28.00 (1.102) ECH 0.9 SERIE200PN 49.00 (1.929) 07/01/2010 39.40 (1.551) Lever returned then locked in down position (OFF) SERIE 80 44.00 (1.732) Model No 22.00 (.866) 33.50 (1.318) Lever not locked, but protected in the position where left by the user SERIE80 16.40 (.645) Model No 49.00 (1.929) 39.40 (1.551) SERIES 200 - WITH STANDARD BUSHING FOR 2-POSITION SWITCHES Lever returned then locked either in lower or in upper position 22.00 (.866) 16.40 (.645) Lever returned then locked in center position 49.00 (1.929) 39.40 (1.551) SERIES 80 FOR 3-POSITION SWITCHES 17.00 (.669) SERIE 200PN 22.00 (.866) ECH 0.9 3 PANEL SWITCHES Switch guards For switch series 12000 - 3500 - 600H - 6000 14.00 (.551) Color 62 Grey 63 White 64 Orange 65 Black 66 Red 67 Green 68 Yellow 69 Blue 65/68 16.40 (.645) Model No 17.00 (.669) Black/yellow striped 14.00 (.551) Model 170 (with smaller aperture) recommended for the 12000 series. Color 72 Grey 73 White 74 Orange 75 Black 76 Red 77 Green 78 Yellow 79 Blue 75/78 16.40 (.645) Model No 17.00 (.669) Color 102 Grey 103 White 104 Orange 105 Black 106 Red 107 Green 108 Yellow 109 Blue 16.40 (.645) Model No 17.00 (.669) 22.00 (.866) 14.00 (.551) Model No Color 302PN Grey 303PN White 304PN Orange 305PN Black 306PN Red 307PN Green 308PN Yellow 309PN Blue 33.50 (1.318) 4 49.00 (1.929) 39.40 (1.551) 14.00 (.551) SERIES 300PN FOR 2 OR 3-POSITION SWITCHES Lever not locked, but protected in the position where left by the user. 22.00 (.866) Black/yellow striped SERIES 100 FOR 3-POSITION SWITCHES Lever returned then locked in center position 49.00 (1.929) 39.40 (1.551) SERIES 70 FOR 2-POSITION SWITCHES Lever returned then locked in upper position 22.00 (.866) SERIE100 21.00 (.826) Lever returned then locked in upper position 49.00 (1.929) 39.40 (1.551) SERIES 60 FOR 3-POSITION SWITCHES 44.00 (1.732) PANEL SWITCHES Switch guards 17.00 (.669) SERIE 100 28.00 (1.102) ECH 0.9 For switch series 12000 - 3500 - 600H - 6000 SERIES 500 FOR 2-POSITION SWITCHES Color 502 Grey 503 White 504 Orange 505 Black 506 Red 507 Green 508 Yellow 509 Blue 16.40 (.645) Model No 49.00 (1.929) 39.40 (1.551) Lever returned then locked either in lower or in upper position 14.00 (.551) 17.00 (.669) 22.00 (.866) OPTIONS BASIC P/N SERIE500 P Holes for wiring a seal Cap engraving available : consult factory. SERIE 500 Ø1.50 (.059DIA) ECH 0.9 07/01/2010 5 PANEL SWITCHES Switch guards
206PN
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款具有锁存功能的六进制计数器/分频器 3. 引脚分配:引脚1为时钟输入,引脚2为清除输入,引脚3为进位输出,引脚4为Q0输出,引脚5为Q1输出,引脚6为Q2输出,引脚7为Vcc,引脚8为Q3输出,引脚9为Q4输出,引脚10为Q5输出,引脚11为输出使能,引脚12为进位输入,引脚13为Q0输入,引脚14为Q1输入,引脚15为Q2输入,引脚16为Q3输入,引脚17为Q4输入,引脚18为Q5输入,引脚19为GND 4. 参数特性:工作电压范围为3-18V,工作频率可达100MHz 5. 功能详解:EL817可以作为计数器或分频器使用,具有同步清零和进位输出功能 6. 应用信息:适用于频率计数、分频、定时等应用 7. 封装信息:采用DIP-18封装
206PN 价格&库存
很抱歉,暂时无法提供与“206PN”相匹配的价格&库存,您可以联系我们找货
