5632A9
5632A9
    APEM(埃斐)
    APEM - 5632A9 - Toggle Switch, On-(On), SPDT, Non Illuminated, 5000 Series, Panel Mount, 6 A
5632A9 数据手册
PANEL SWITCHES 0 -5 SW 05 18 00 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing DISTINCTIVE FEATURES 17 actuators including toggles, paddle levers and locking levers in different lengths. Various contact materials for low and high currents. 8 functions including maintained and momentary versions. 1 to 4 pole configurations. 12 terminal types including 9 for PC board mounting. Other types include quick-connect and wire-wrap. Several bushing styles. 3 types of finish including military black. 3 approvals (UL - CSA - CECC). 4 types of sealing for terminal or front panel requirements. Numerous accessories available. The company reserves the right to change specifications without notice. 1 PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing MATERIALS ELECTRICAL SPECIFICATIONS • Current/voltage rating with resistive load : Contact Maximum Minimum Level* Silver (A) 4 A 30 VDC 50 mA 10 VDC III and IV Silver, gold plated (AD) 4 A 30 VDC Gold plating withstands up to 100 mA 30 VDC 10 mA 50 mV 10 µA 5 V I to IV Brass, gold plated (CD) 0.4 VA at 20 VAC or DC 10 mA 50 mV 10 µA 5 V I and II *For details, see Technical Information on website. • For inductive, lamp or capacitive load, consult factory. • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals 1,500 Vrms 50 Hz min. between poles 1,500 Vrms 50 Hz min. between terminals and frame • Contact bounce : 2 ms max. • Electrical life at full load : 50,000 cycles for single and double pole 40,000 cycles for 3 pole 30,000 cycles for 4 pole • Low level or mechanical life : 100,000 cycles GENERAL SPECIFICATIONS • Torque : 1.25 Nm (.922 Ft.lb) max. applied to nut • Panel thickness : 2.5 mm (.098) with 2 nuts - 4 mm (.157) with 1 nut • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) AGENCY APPROVALS CECC 96201-007 3 A 250 VAC, 6 A 125 VAC For VDE, refer to 55000 series. NATO Availability : consult factory for details of approved models. Marking : to order switches marked UL, CSA or CECC, complete appropriate box of ordering format. The preferential list does not appear on the switches. 2 • Case : diallylphthalate (DAP) or high temperature plastic material (UL94-V0) • Actuator : brass, nickel plated • Paddles : UL94HB polyamide • Lever caps : vinyl • Bushing : brass, nickel plated • Housing : stainless steel or steel tin plated • Contacts A : silver AD : silver, gold plated CD : brass, gold plated X814 : for peak currrents, see "Special options". • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing Solder lugs Straight PC Straight PC 8.50 (.334) 8.50 (.334) 1.10 1.10 (.043)(.043) 9.80 (0.385) 1.57 (.061) 4.00 (.157) 5.30 (.208) 5.30 (.208) 5.30 (.208) 6.50 (.255) 0.60 (.023) 1.10 (.043) 4.00 (.157) 9.80 (0.385) 1.10 (.043) 4.35 (.171) 5.50 (.216) 8.50 (.334) 1.80 (.070) 9.80 (0.385) 1.10 (.043) 4.00 (.157) 5.30 (.208) 3.70 (.145) 1.90 (.074) TERMINALS 1.10 1.10 (.043)(.043) Quick-connect Straight PC bracket mounting ELECTRICAL FUNCTION KEYWAY 1 2 3 PANEL CUT-OUT Ø2.20 (.086 DIA) Ø6.50 (.255 DIA) Ø6.50 (.255 DIA) 1.10 (.043) Ø6.50 (.255 DIA) 2.70 (.106) 5.20 (.204) 2.70 (.106) With K sealing option Standard With X408 sealing option PCB MOUNTING FOR RIGHT ANGLE TERMINAL MODELS SP 16.60 (.653) 8.30 (.326) DP SP 7.00 (.275) 12.00 (.472) SP SP DP DP 3P DP 3P 16.50 (.649) 21.20 (.834) 3P 3P 4P 13.20 (.519) VERTICAL WW 6.60 (.259) 12.00 (.472) 6.00 (.236) 3.50 (.137) 7.00 (.275) HORIZONTAL W 4P 3 PANEL SWITCHES 5000 series PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing BUILD YOUR PART NUMBER BASIC PART NUMBER 5 3 Single pole 4 Double pole 5 Three pole 6 Four pole TERMINALS AND BUSHINGS MOMENTARY FOR FUNCTION 4 Blank Solder lugs or straight PC depending on model W Right angle, horizontal mounting (5200 - 5400 switches) WW Right angle, vertical mounting (5200 - 5400 switches) Y• Bracket mounting (5200 switches) Z Quick-connect (5200 5900 switches) ELECTRICAL FUNCTIONS Straight PC terminals, 5.08 (.200) terminal spacing 6 ON - ON TH Standard 9 ON OFF ON CT Reversed 2 Straight PC terminals, 4.70 (.185) terminal spacing, right angle or quick-connect 7 MOM OFF MOM 8 ON OFF MOM 4 Straight PC terminals, 4 (.157) terminal spacing or right angle terminals 2 ON - MOM 6 4 Solder lug terminals ON ON MOM 7 Solder lug terminals, with flatted bushing 9 Straight PC or quickconnect terminals, with flatted bushing, 4.70 (.185) terminal spacing ON ON ON ON MOM MOM Function 4 Must not have blank in «connections» box. Must not have blank in «momentary» box. 1R ON ON MOM 2R MOM ON MOM CONNECTIONS FOR FUNCTION 4 0 Bushing Ø 6 (.236) x 0.75 IS also available as standard. 4 TERMINALS NUMBER OF POLES SERIES For functions 4, 4-1R, 4-2R (leave blank for all other functions). Wiring diagrams, see Technical information on website. Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing OPTIONS FINISH Blank G FLUORESCENT TIP Blank Nickel plated Black finish on bushing, actuator and hardware. -038 SPECIAL OPTIONS None X408 White fluorescent tip to lever CAPS Front panel sealing by two O-rings Other : see following pages. Available with black finish (G) only. CONTACT MATERIALS Caps Length U270 11 (.433) U1710 7.3 (.287) Silver PADDLES FOR 4N (ORDER SEPARATELY) AD Silver, gold plated U240N 12.6 (.496) CD Brass, gold plated U290N 20.00 (.787) U390N 21.4 (.842) A For peak currents, see X814, under Special Options. SEALING LEVERS Blank No sealing except where standard Length with threaded bushing plain bushing K Front panel sealing by one O-ring and sealing washer Blank (std) 10.5 (.413) 13.5 (.531) -9 (flat) 11.4 (.448) - B Epoxy sealed terminals -16 5.5 (.216) 8.5 (.334) -4N 9 (.354) 12 (.472) Sealing by two O-rings, see X408 under «Special options». 4N for use with paddle actuators only. LOCKING LEVERS -1V 1 locked position -2V 2 locked positions -3V 3 locked positions AGENCY APPROVALS UL, CSA, CECC For VDE, refer to 55000 series. Other levers and locking levers, see following pages. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Sealing boots are available. See "Sealing Boots" section of website. Mounting accessories : standard hardware supplied with all models with Ø 6.35 (1/4) or Ø 6 (.236) threaded bushing : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware is presented in the “Hardware“ section of website. 5 PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm OFF MOM ON OFF MOM 5632 ON - MOM OFF ON 5647 MOM OFF MOM 5648 ON OFF MOM 5642 ON - MOM 5644* ON ON ON 5644 1R* ON ON MOM 5644 2R* MOM ON MOM I 5 II 1 4 III 10.50 (.413) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) 1.80 (.070) ON 12.00 (.472) 24˚ 5649 6 2 4.70 (.185) - 3 Ø3.00 (.118 DIA) 5646 I 1-2 4-5 ON 3.70 (.145) 12.00 (.472) 0.50 (.019) 1.00 (.039) II * Function 4 : SP in DP case - specify CT or TH connections. KEYWAY 5652 ON - MOM Ø6.35-40UNS (1/4-40UNS) KEYWAY 5669 ON OFF ON 5667 MOM OFF MOM 5668 ON OFF MOM 5662 ON - MOM - 5664* ON ON ON 5664 1R* ON ON MOM 5664 2R* MOM ON MOM 13.10 (.516) 3.70 (.145) 0.50 (.019) 5666 1.00 (.039) 9 12 I 8 11 II 7 10 III 24˚ I 1-2 4-5 7-8 10-11 ON 4.70 (.185) II III 2-3 5-6 8-9 11-12 ON 8.00 (.314) 10.50 (.413) Ø6.35-40UNS (1/4-40UNS) 8.00 (.314) 13.20 (.519) MOM 10.50 (.413) 4.75 (.187) OFF III 21.20 (.834) 13.20 (.519) ON 7 4.75 (.187) 5658 II 1 1.80 (.070) MOM I 8 0.80 (.031) ON OFF 9 2 16.50 (.649) 1.80 (.070) OFF MOM 3.70 (.145) 24˚ ON 5657 3 4.70 (.185) 5659 - I 1-2 4-5 7-8 ON Ø3.00 (.118 DIA) II 5656 III 2-3 5-6 8-9 ON 13.10 (.516) 0.50 (.019) 1.00 (.039) 0.80 (.031) SOLDER LUG TERMINALS THREE POLE SOLDER LUG TERMINALS FOUR POLE Ø6.35-40UNS (1/4-40UNS) KEYWAY III 2-3 5-6 ON 13.20 (.519) MOM 5638 8.00 (.314) 13.20 (.519) 5637 10.50 (.413) 4.75 (.187) ON III 0.80 (.031) OFF II 1 1.80 (.070) ON I 2 0.80 (.031) 5639 7.00 (.275) 3.70 (.145) 24˚ - 3 4.70 (.185) 5636 I 1-2 ON Ø3.00 (.118 DIA) II 12.00 (.472) 0.50 (.019) 1.00 (.039) III 2-3 ON SOLDER LUG TERMINALS DOUBLE POLE Shown with standard lever KEYWAY SOLDER LUG TERMINALS SINGLE POLE Ø3.00 (.118 DIA) PANEL SWITCHES 5000 series * Function 4 : DP in 4P case - specify CT or TH connections. All models above also available with flatted bushing : 5700 or with dia. 6 mm x 0.75 SI (.236 x 0.75 IS) : 5500. 6 Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing - 5239 B ON OFF ON 5237 B MOM OFF MOM 5238 B ON OFF MOM 5232 B ON - MOM I 2 II 1 III 10.50 (.413) Ø3.00 (.118 DIA) 4.70 (.185) ON 3 13.20 (.519) ON 0.50 (.019) 5236 B 7.00 (.275) 8.00 (.314) 0.80 (.031) I 1-2 4.00 (.157) Ø6.35-40UNS (1/4-40UNS) Ø1.60 (.063 DIA) 1.10 (.043) II 13.30 (.523) 1.00 (.039) 24 III 2-3 Shown with standard lever KEYWAY STRAIGHT PC TERMINALS - SPACING 4.7 (.185) SINGLE POLE 4.70 (.185) Epoxy MOM 5248 B ON OFF MOM 5242 B ON - MOM 5244 B* ON ON ON 5244 1R B* ON ON MOM 5244 2R B* MOM ON MOM 4 III 13.20 (.519) OFF II 1 10.50 (.413) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) Ø1.60 (.063 DIA) 4.75 (.187) MOM 0.50 (.019) 5247 B I 5 0.80 (.031) ON 12.00 (.472) 4.75 (.187) OFF 6 2 1.10 (.043) ON 4.00 (.157) 24 5249 B 3 4.70 (.185) - 1-2 4-5 ON 13.30 (.523) 1.00 (.039) Ø3.00 (.118 DIA) 5246 B 2-3 5-6 ON C52DT1-A KEYWAY STRAIGHT PC TERMINALS - SPACING 4.7 (.185) DOUBLE POLE II I III 4.70 (.185) Epoxy * Function 4 : SP in DP case - specify CT or TH connections. ON OFF MOM 5252 B ON - MOM III 13.20 (.519) 5258 B 7 10.50 (.413) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) 4.75 (.187) MOM II 1 4.75 (.187) OFF 0.50 (.019) MOM I 8 16.50 (.649) 0.80 (.031) ON 5257 B 9 2 1.10 (.043) OFF 4.00 (.157) 24 ON 3 4.70 (.185) 5259 B - I 1-2 4-5 7-8 ON 14.40 (.567) 1.00 (.039) Ø3.00 (.118 DIA) II 5256 B III 2-3 5-6 8-9 ON C52DT2-A KEYWAY STRAIGHT PC TERMINALS - SPACING 4.7 (.185) THREE POLE Ø1.60 (.063 DIA) 4.70 (.185) Epoxy C52DT3-A KEYWAY OFF MOM 5268 B ON OFF MOM 5262 B ON - MOM 5264 B* ON ON ON 5264 1R B* ON ON MOM 5264 2R B* MOM ON MOM 10 III 10.50 (.413) 8.00 (.314) 13.20 (.519) MOM II 7 Ø6.35-40UNS (1/4-40UNS) Ø1.60 (.063 DIA) 4.75 (.187) 5267 B I 11 21.20 (.834) 4.75 (.187) ON 0.50 (.019) OFF 4.00 (.157) 0.80 (.031) ON 14.40 (.567) 24 5269 B - 12 8 4.70 (.185) 5266 B 9 Ø3.00 (.118 DIA) 1-2 4-5 7-8 10-11 ON 2-3 5-6 8-9 11-12 ON 1.00 (.039) 1.10 (.043) STRAIGHT PC TERMINALS - SPACING 4.7 (.185) FOUR POLE II I III Epoxy 4.70 (.185) * Function 4 : SP in DP case - specify CT or TH connections. All models above : Epoxy sealed terminals standard (B). All models above also available with flatted bushing : 5900 or with terminal spacing 4 mm (.157) : 5400. C52DT4-A 7 PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing KEYWAY III I Ø3.00 (.118 DIA) I 1-2 4-5 ON ON OFF ON 5047 B MOM OFF MOM 5038 B 5048 B ON OFF MOM 5032 B 5042 B ON - MOM 5044* B ON ON ON 5044 1R* B ON ON MOM 5044 2R* B MOM ON MOM 12.00 (.472) 5.08 (.200) 13.20 (.519) 0.60 (.023) 7.00 (.275) 5.08 (.200) 13.10 (.515) 5.30 (.208) MOM 5238Z B ON OFF MOM 5232Z B ON - MOM 13.20 (.519) OFF 3 MOM 2 5237Z B III 10.50 (.413) 8.00 (.314) 1 ON 0.78 (.030) OFF II 24˚ ON I Ø3.00 (.118 DIA) II 7.00 (.275) 4.70 (.185) 1.00 (.039) - 5239Z B 3 KEYWAY I 1-2 ON 5236Z B 2 * Function 4 : SP in DP case - specify CT or TH connections. QUICK-CONNECT TERMINALS SINGLE POLE III 2-3 ON 0.60 1 (.023) EPOXY Ø6.35-40UNS (1/4-40UNS) 1.57 (.061) Epoxy sealed terminals standard (B). EPOXY 0.60 (.023) 5.08 (.200) 5049 B 5037 B Ø1.10 (.043 DIA) 5.08 (.200) 5039 B - 13.10 (.515) 5046 B 4.35 (.171) Double pole 1.00 (.039) Single pole Ø6.35-40UNS (1/4-40UNS) 10.50 (.413) II III 2-3 5-6 ON 5036 B II 24˚ 8.00 (.314) STRAIGHT PC TERMINALS SPACING 5.08 (.200) Single and double pole models also available with flatted bushing : 5900Z. Epoxy sealed terminals standard (B). KEYWAY ON OFF MOM 5242Z B ON - MOM 5244Z* B ON ON ON 5244Z 1R* B ON ON MOM 5244Z 2R* B MOM ON MOM Epoxy sealed terminals standard (B). 10.50 (.413) 8.00 (.314) EPOXY Ø6.35-40UNS (1/4-40UNS) * Function 4 : SP in DP case - specify CT or TH connections. KEYWAY - ON 5239W ON OFF ON 5237W MOM OFF MOM 5238W ON OFF MOM 5232W ON - MOM Also available with terminal spacing 4 mm (.157) instead of 4.7 (.185) : 5400W. 5.08 (.200) 1.00 (.039) ON I 5.08 (.200) 1.10 (.043) 7.40 (.291) 12.70 (.500) 12.70 (.500) 5236W II 24˚ 3 7.00 (.275) 0.80 (.031) I 1-2 Ø3.00 (.118 DIA) II III 2 Ø6.25 (.246 DIA) III 2-3 1 6.00 11.00 (.236) (.433) 13.20 (.519) 13.50 (.531) 3.70 (.145) 0.50 (.019) RIGHT ANGLE TERMINALS - HORIZONTAL SINGLE POLE 8 13.20 (.519) 5248Z B III 4.75 (.187) MOM 4.70 (.185) OFF 3 MOM II 2 5247Z B I 12.00 (.472) 1 ON 1.00 (.039) 0.78 (.030) OFF 5249Z B 5.30 (.208) 1.57 (.061) ON 5246Z B II 13.10 (.515) 24˚ - I 1-2 4-5 ON 2-3 5-6 ON Ø3.00 (.118 DIA) QUICK-CONNECT TERMINALS DOUBLE POLE III 4.70 (.185) PANEL SWITCHES 5000 series Ø1.60 (.062 DIA) 4.70 (.185) Miniature toggle switches • plain bushing Shown with standard lever ON ON MOM 5244W 2R* MOM ON MOM Also available with terminal spacing 4 mm (.157) instead of 4.7 (.185) : 5400W. RIGHT ANGLE TERMINALS - HORIZONTAL THREE POLE 7.40 (.291) ON 5257W MOM OFF MOM 5258W ON OFF MOM 5252W ON - MOM 7 III 1.00 (.039) 7.20 (.283) ON OFF MOM 5232WW** ON - MOM RIGHT ANGLE TERMINALS - VERTICAL II III DOUBLE POLE I 1-2 4-5 ON 5246WW 2-3 5-6 ON - 5249WW ON OFF ON 5247WW MOM OFF MOM 5248WW** ON OFF MOM 5242WW** 5244WW* 5244WW 1R* ON ON ON ON ON MOM ON MOM 5244WW 2R* MOM ON MOM 0.80 (.301) 5.65 (.222) 5.08 (.200) 12.70 (.500) 3.81 (.150) Ø1.60 (.062 DIA) 3.81 (.150) 5238WW** III 13.50 (.531) 3 6 I 2 5 II 24˚ 1 4 III 1.00 (.039) 12.00 (.472) 6.00 11.00 (.236) (.433) 0.80 (.301) 5.65 (.222) 5.08 (.200) 5.08 (.200) 12.70 (.500) 3.81 (.150) 4.75 (.187) 3.81 (.150) MOM 1 1.10 (.043) ON OFF II 24˚ 7.00 (.275) Ø3.00 (.118 DIA) OFF MOM I 2 5.08 (.200) 6.00 11.00 (.236) (.433) Ø3.00 (.118 DIA) ON 5237WW 1.00 (.039) 3 Ø6.25 (.246 DIA) 5239WW 5.08 (.200) Ø1.60 (.062 DIA) Ø6.25 (.246 DIA) 5236WW - I 1-2 ON 3.81 (.150) 4.75 (.187) 13.50 (.531) II 12.70 (.500) 5.08 (.200) RIGHT ANGLE TERMINALS - VERTICAL SINGLE POLE III 2-3 ON 1.00 (.039) 13.20 (.519) OFF II 24˚ 1 16.50 (.649) 3.81 (.150) ON I 8 12.50 (.492) 1.10 (.043) - 5259W 9 2 6.00 (.236) Ø3.00 (.118 DIA) 5256W I 1-2 4-5 7-8 ON 3 Ø6.25 (.246 DIA) II (.185) 4.70 3.81 (.150) * Function 4 : SP in DP case - specify CT or TH connections. 13.10 (.515) III 2-3 5-6 8-9 ON 12.70 (.500) 3.00 (.118) ON ON 12.70 (.500) ON Ø1.60 (.062 DIA) 13.20 (.519) 5244W* 5244W 1R* 1.10 (.043) 3.00 (.118) MOM 12.70 (.500) - 13.20 (.519) ON 3.00 (.118) 5242W 5.08 (.200) Vertical right angle models above : * Function 4 : SP in DP case, DP in 4P case - specify CT or TH connections. ** Functions 2 and 8 : reversed connection available, consult factory. Also available with pin spacing 2.54 mm (.100) instead of 3.81 mm (.150) : 5400WW Ø1.60 (.062 DIA) 12.70 (.500) MOM 3.81 12.70 (.150) (.500) MOM OFF (.519) 13.20 OFF ON 4.75 (.187) MOM 5248W I 4.75 (.187) 5247W (.019) 0.50 ON II 24˚ 3 0.80 (.031) OFF III 2 6 12.00 (.472) 0.80 (.031) ON 1 1.10 (.043) 5249W 4 6.00 11.00 (.236) (.433) Ø3.00 (.118 DIA) - 13.50 (.531) Ø6.25 (.246 DIA) 5246W 2-3 5-6 ON I 1-2 4-5 ON 3.70 (.145) 4.70 (.185) RIGHT ANGLE TERMINALS - HORIZONTAL DOUBLE POLE II III 5.08 (.200) 9 PANEL SWITCHES 5000 series Miniature toggle switches • plain bushing Shown with standard lever ON - MOM OFF ON MOM OFF MOM 5268WW** ON OFF MOM 5262WW** 5264WW* 5264WW 1R* ON ON ON ON ON MOM ON MOM 5264WW 2R* MOM ON MOM Vertical right angle models above also available with terminal spacing 2.54 mm (.100) instead of 3.81 mm (.150) : 5400WW. II 24˚ 7 10 III 1.00 (.039) 7.20 (.283) MOM 5238Y B ON OFF MOM 5232Y B ON - MOM II 24˚ I Ø6.25 (.246 DIA) Ø3.00 (.118 DIA) Ø1.60 (.062 DIA) EPOXY 3.18 (.125) 4.70 (.185) ON OFF 5.08 (.200) 13.50 (.531) OFF MOM 4.75 (.187) 5.60 (.220) ON 5237Y B 5.08 (.200) 3.18 (.125) 13.00 (.511) 5239Y B - I 1-2 ON 4.10 (.161) 5236Y B 3.81 (.150) Ø1.60 (.062 DIA) III II 12.70 (.500) * Function 4 : SP in DP case, DP in 4P case - specify CT or TH connections. SHORT BRACKET - WIDTH 15.75 (.620) SINGLE POLE III 2-3 ON 21.20 (.834) 4.75 (.187) ON 5267WW I 11 12.50 (.492) Ø3.00 (.118 DIA) 5269WW 12 8 Ø6.25 (.246 DIA) 5266WW 9 6.00 (.236) 5.08 (.200) 13.20 (.519) 13.10 (.515) I 1-2 4-5 7-8 10-11 ON 2-3 5-6 8-9 11-12 ON - 13.20 (.519) Ø1.60 (.062 DIA) ** Functions 2 and 8 : reversed connection available, consult factory. RIGHT ANGLE TERMINALS - VERTICAL II III FOUR POLE 3.00 (.118) 4.75 (.187) 3.81 (.150) 5252WW** 3.81 (.150) 12.70 (.500) MOM MOM 12.70 (.500) 3.00 (.118) OFF OFF 7.20 (.283) 5.08 (.200) 3.81 (.150) MOM ON III 1.00 (.039) 1.10 (.043) 5257WW 5258WW** 7 12.70 (.500) ON II 24˚ 1 1 2 3 1.17 (.046) 0.40 (.015) 15.75 (.620) 15.75 (.620) OFF I 8 16.50 (.649) 4.75 (.187) ON 9 2 1.10 (.043) 5259WW 3 12.50 (.492) Ø3.00 (.118 DIA) - I 1-2 4-5 7-8 ON Ø6.25 (.246 DIA) II 5256WW III 2-3 5-6 8-9 ON 6.00 (.236) 0.80 (.031) 13.10 (.515) 0.80 (.031) RIGHT ANGLE TERMINALS - VERTICAL THREE POLE 7.00 (.275) Epoxy sealed terminals standard (B). OFF ON 5247Y B MOM OFF MOM 5248Y B ON OFF MOM 5242Y B ON - MOM 5244Y B* ON ON ON 5244Y 1R B* ON ON MOM 5244Y 2R B* MOM ON MOM Epoxy sealed terminals standard (B). 10 Ø6.25 (.246 DIA) Ø3.00 (.118 DIA) 3.18 (.125) EPOXY 3.18 (.125) 1 2 15.75 (.620) 3 0.40 (.015) 1.17 (.046) 12.00 (.472) 4.75 (.187) *Function 4 : SP in DP case - specify CT or TH connections. Ø1.60 (.062 DIA) 15.75 (.620) ON I 4.70 (.185) 5249Y B II 24˚ 13.10 (.515) - I 1-2 4-5 ON III 6.00 (.236) 5246Y B 2-3 5-6 ON 8.20 (.322) 13.00 (.511) SHORT BRACKET - WIDTH 15.75 (.620) DOUBLE POLE II III 4.70 (.185) PANEL SWITCHES 5000 series Miniature toggle switches • plain bushing MOM OFF MOM 5248Y4 B ON OFF MOM 5232Y4 B 5242Y4 B ON - MOM 5244Y4 B* ON ON ON 5244Y4 1R B* ON ON MOM 5244Y4 2R B* MOM ON MOM EPOXY 1.17 (.046) 1 3 0.40 (.015) 2 3.18 (.125) 15.75 (.620) 3.18 (.125) 12.00 (.472) SHORT BRACKET - WIDTH 19.05 (.750) ON OFF ON 5247Y6 B MOM OFF MOM 5238Y6 B 5248Y6 B ON OFF MOM MOM 5232Y6 B 5242Y6 B ON - 5244Y6 B* ON ON ON 5244Y6 1R B* ON ON MOM 5244Y6 2R B* MOM ON MOM 5249Y7 B ON OFF ON 5237Y7 B 5247Y7 B MOM OFF MOM 5238Y7 B 5248Y7 B ON OFF MOM 5232Y7 B 5242Y7 B ON - MOM 5244Y7 B* ON ON ON 5244Y7 1R B* ON ON MOM 5244Y7 2R B* MOM ON MOM - 2 3 0.40 (.015) III II 24˚ 6.35 (.250) 12.00 (.472) 19.05 (.750) I 6.35 (.250) Ø3.00 (.118 DIA) Ø1.60 (.062 DIA) EPOXY 1.27 (.050) 6.35 (.250) 6.35 (.250) 4.75 (.187) Ø6.25 (.246 DIA) 13.10 (.515) 5246Y7 B 5239Y7 B 16.00 (.629) Double pole 1 6.35 (.250) 8.20 (.322) I 1-2 4-5 ON Single pole 5236Y7 B EPOXY 1.27 (.050) 5.20 (.204) II Ø3.00 (.118 DIA) Ø1.60 (.062 DIA) TALL BRACKET - WIDTH 19.05 (.750) III 2-3 5-6 ON 6.35 (.250) Ø6.25 (.246 DIA) 4.70 (.185) 5249Y6 B 5237Y6 B I 13.10 (.515) 5239Y6 B - II 24˚ 6.00 (.236) 5246Y6 B 5236Y6 B III 6.00 (.236) Double pole 13.00 (.511) Single pole 8.20 (.322) 4.75 (.187) 4.70 (.185) I 1-2 4-5 ON 4.70 (.185) II III 2-3 5-6 ON 15.75 (.620) 5247Y4 B 5238Y4 B Ø1.60 (.062 DIA) 15.75 (.620) 5237Y4 B 3.18 (.125) 19.05 (.750) ON 19.05 (.750) OFF 1 2 3 0.40 (.015) 19.05 (.750) 6.35 (.250) 12.00 (.472) 19.05 (.750) ON Ø3.00 (.118 DIA) 4.70 (.185) 5249Y4 B 3.18 (.125) 4.70 (.185) 5239Y4 B Ø6.25 (.246 DIA) 4.70 (.185) 5246Y4 B I 13.10 (.515) Double pole II 24˚ 6.00 (.236) Single pole 5236Y4 B 16.00 (.629) - I 1-2 4-5 ON 5.20 (.204) II III 2-3 5-6 ON III 6.35 (.250) 19.05 (.750) 8.20 (.322) 4.70 (.185) TALL BRACKET - WIDTH 15.75 (.620) 4.75 (.187) Epoxy sealed terminals standard (B). * Function 4 : SP in DP case - specify CT or TH connections. 11 PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing CONTACT MATERIALS BASIC P/N A AD CD Silver Silver, gold plated Brass, gold plated Special contacts for peak currents : see X814, under “Special Options”. FINISH BASIC P/N Blank Nickel plated G Black finish on bushing, actuator and hardware SEALING BASIC P/N Blank • For 5000 and 5200Z models : epoxy sealed terminals standard • Other models : no sealing required K Front panel sealing by one O-ring and sealing washer. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. Available on models with Ø 6.35 (1/4) threaded bushing only. Not available with levers 8, 9, 12, 22, 23. B Epoxy sealed terminals KB Combined sealings OPTION B OPTION K 1 O-ring Sealing by two O-rings, see X408 under "Special options". 3 Maxi (.118 MAX) PANEL SWITCHES 5000 series Sealing washer 2 Ø6.35K K with Ø 6.35 (1/4) keyway bushing DECOUPE PANNEAU includes washer U360 K with Ø 6.35 (1/4) flatted bushing DECOUPE PANNEAU includes washer U5141 CANON RAINURE CANON MEPLAT FLUORESCENT TIP BASIC P/N Blank None -038 White fluorescent tip. Becomes luminous when submitted to ultraviolet rays. Available with black finish (option G) only. Consult factory for levers available with this option. Same dimensions as standard actuator on next page. -19 Strandard lever 12 Locking lever Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing ACTUATORS BASIC P/N Dash compulsory before lever code. LEVERS FOR THREADED BUSHING MODELS Ø 6,35 (1/4) OR Ø 6 (.236) -2 * -4N 11.40 (.448) 9.00 (.354) 1.00 (.039) Blank Standard 21.30 (.838) Ø5.00 (.196 DIA) 16.00 (.629) 10.50 (.413) Ø3.00 (.118 DIA) 9.00 (.354) Ø5.00 (.196 DIA) Ø3.00 (.118) -8 ** -9 21.30 (.838) 16.40 (.645) Ø2.80 (.110 DIA) 7.00 (.275) Ø2.70 (.354 DIA) Ø3.30 (.129 DIA) 5.50 (.216) 6.30 (.248) Ø4.20 (.165 DIA) 21.30 (.838) Ø3.30 (.129) DIA) ** -12 ** -16 -17 ** * For use with paddles only ** Not available with sealing options K or X408 *** U640 to be placed in last box of ordering format. Replace "0" by color code (see following pages) 16.30 (.642) 14.00 (.551) ** -22 ø3.30 (.129 DIA) Ø3.30 (.129 DIA) -23 -21 (+U640) *** -25 ** LOCKING LEVERS FOR THREADED BUSHING MODELS Ø 6,35 (1/4) -1V -2V -3V 1 locked position (function 6) 2 locked position (function 6) 3 locked positions (functions 9 and 4) Ø6.35-40UNS (1/4-40UNS) -1V Ø6.35-40UNS (1/4-40UNS) 9.00 (.354) 15.10 (.594) 14.75 (.580) Ø5.20 (.204 DIA) 9.00 (.354) Ø6.35-40UNS (1/4-40UNS) 9.00 (.354) 14.85 (.584) KEYWAY -2V -3V Consult factory for other locking lever options. For plain bushing models, see X386 or X916 under “Special options” on the following pages. 13 PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing ACTUATORS (CONTINUED) BASIC P/N LEVERS FOR PLAIN BUSHING MODELS : W - WW AND Y Lever length : With bracket or mounting plate lever length will be reduced by 0.4 mm (.015) as a rule. Please refer to switch technical drawings of basic models pages for details. Ø3.00 (.118 DIA) Ø3.00 (.118 DIA) Blank Standard -2 Ø2.70 (.106 DIA) 6.70 (.263) 8.50 (.334) 19.00 (.748) 12.00 (.472) 6.00 (.236) 1.00 (.039) 13.50 (.531) Ø2.60 (.102 DIA) -4N -7 -16 Ø3.30 (.129 DIA) * U640 to be placed in last box of ordering format. For actuator colors, replace «0» by color code (see following pages) 24.30 (.956) 16.40 (.645) Ø2.80 (.110 DIA) 10.00 (.393) -17 -21 (+U640) * SPECIAL OPTIONS BASIC P/N No special requirement X408 X371 Plain bushing Ø 6.25 mm (.246) (instead of standard threaded bushing). 1.00 (.039) Ø6.35-40UNS (1/4-40UNS X372 9.00 (.354) 1.00 (.039) Threaded bushing Ø 6.35 (1/4). Height 7 mm (.274). X386 Threaded bushing Ø 6.35 mm (1/4) to replace plain bushing on models W - WW and Y. 14 X371 Ø6.35-40UNS (1/4-40UNS 7.00 (.275) X372 Ø6.25 (.246 DIA) 1 O-ring 6.00 (.236) X408 Front panel sealing by two O-rings. Flatted bushing for precise orientation. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. Includes sealed terminals (option B). Available only on models with threaded bushing. Not available with levers 8, 9, 12, 22, 23. 1.00 (.039) Blank 3 mini - 5 Maxi (.118 MIN. - .196 MAX.) PANEL SWITCHES 5000 series X386 Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing SPECIAL OPTIONS (CONTINUED) BASIC P/N X442 Threaded bushing Ø 6.35 mm (1/4) - Height 9.9 mm (.389). 9.00 (.354) X902 Plain bushing Ø 6.25 mm (.246) - Height 9 mm (.354) (not available with K sealing option). Ø6.25 (.246 DIA) 1.00 (.039) 14.75 (.580) Satin chrome actuator 1.00 (.039) 7.20 (.283) X445 X442 X814 Switches for peak currents - single and double pole. On request. X916 0.30 (.011) 9.90 (.389) X601 Silver plated brass contacts. Current/voltage rating for an electrical life of 20,000 cycles : 0.5 A 30 VDC. Minimum quantity : 5,000 pieces per model and shipment. X681 Ø6.25 (.246 DIA) Ø6.35-40UNS (1/4-40UNS X445 Plain bushing. Height 7.2 mm (.283) - for W, WW and Y models. Available with the same levers, insulating cap and paddles as X404.` X916 Locking lever on model with plain bushing. X404 Horizontal right angle (W) with reduced overall dimensions (shown with lever -16) With options X372, X386, X442 and X445, the lever lengths indicated on previous pages will be modified. OPTION X404 7.30 (.287) 12.70 (.500) Option X404 OFF ON 5237W X404 5247W X404 MOM OFF MOM 5238W X404 5248W X404 ON OFF MOM 5232W X404 5242W X404 ON - MOM 5244W X404* ON ON ON 5244W 1R X404* ON ON MOM 5244W 2R X404* MOM ON MOM - ø2.67 (.105) 7.00 (.275) 5.08 (.196) 12.70 (.500) ON III 3 2 0.50 (.019) 6 1 0.80 (.031) 4.70 (.185) 3 12.00 (.472) 4.70 (.185) ø1.60 (.062 DIA) 3.81 12.70 (.150) (.500) 5249W X404 II 24° 7.40 (.291) 5239W X404 I ø6.25 (.246 DIA) 12.70 (.500) 5236W X404 Double pole Single pole I 1-2 4-5 ON 3.81 (.150) II 5246W X404 III 2-3 5-6 ON 11.00 7.20 7.30 (.433) (.283) (.287) Standard W 7.40 (.291) 7.40 (.291) 12.70 (.500) 12.70 (.500) 7.40 (.291) 3.50 (.137) 3.50 (.137) 8.50 (.334) 5.08 (.196) 4.70 (.185) * Function 4 : SP in DP case - specify CT or TH connections 15 PANEL SWITCHES 5000 series Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing SPECIAL OPTIONS (CONTINUED) BASIC P/N -8 ** -17 -21 (+U640) *** -9 ** -12 15.80 (.622) 8.80 (.346) 7.30 (.287) -16 8.10 (.318) 13.20 (.519) 23.10 (.909) * 23.10 (.909) -4N 16.40 (.645) -2 23.10 (.909) -13 10.80 (.425) 17.80 (.700) 1.00 (.039) 12.30 (.484) OPTION X404 (CONTINUED) LEVERS LENGHTS FOR X404 (ALSO AVAILABLE WITH X445 OPTION) 7.20 (.283) PANEL SWITCHES 5000 series -22 -23 * For paddles ** Levers -8, -9 and -12 not available with function 2 (ON-MOM) *** U640 to be placed in last box of ordering format. Replace "0" with color code. Insulating caps and paddles for X404 : Insulating cap U1710 available with lever style 16. Paddles U240N, U290N and U390N available with lever style 4N. See details on next page.. AGENCY APPROVALS BASIC P/N Blank No agency approval required. UL All standard models CSA CECC Standard models 5600 - 5200 Availability : consult factory for details of approved combinations or options. Marking : to order switches marked UL, CSA or CECC, complete above box with desired approvals, in this order & without space (ex. : ULCSACECC). VDE (with UL & CSA) : Refer to 55000 series. Preferential lists : see specifications. 16 ** Miniature toggle switches • threaded bushing Ø 6.35 mm or plain bushing INSULATING CAPS 7.30 (.287) For standard lever & threaded bushing only For standard lever & plain bushing only For lever 17 and threaded bushing For lever 7 and plain bushing 11.00 (.433) U270 U1040 U1710 13.50 (.531) BASIC P/N U270 For cap colors, replace "0" with number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7/1 White 9 Orange Ø3.5 (.137 DIA) Ø3.5 (.137 DIA) Ø3.5 (.137 DIA) U1710 U1040 PADDLES For use with lever 4N only. Shown with standard threaded bushing. Order separately. 2.00 (.078) U240N U290N 14.00 (.551) Ø6.35-40UNS (1/4-40UNS) 21.55 (.848) 21.40 (.842) 18.00 (.708) 9.00 (.354) Ø6.35-40UNS (1/4-40UNS) 21.55 (.848) 6.00 (.236) 9.00 (.354) 9.00 (.354) Ø6.35-40UNS (1/4-40UNS) 11.00 (.433) 6.00 (.236) 20.00 (.787) 5.30 (.208) 6.60 (.259) 14.15 (.557) 12.60 (.496) 2.25 (.088) 2.00 (.078) 11.00 (.433) U390N For cap colors, replace "0" with number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7 Ivory 7/1 White 9 Orange 17 PANEL SWITCHES 5000 series
5632A9 价格&库存
很抱歉,暂时无法提供与“5632A9”相匹配的价格&库存,您可以联系我们找货
5632A9
  • 1+72.91769
  • 50+71.05361
  • 100+68.18981
  • 250+66.14870
  • 500+64.17007
库存:413
5632A9
    • 13+67.98771
    • 44+64.80778
    • 174+61.80921
    • 435+59.14919
    • 1303+56.65844
    库存:94
