5T25-1S0F-21-127
5T25-1S0F-21-127
    APEM(埃斐)
    APEM - 5T25-1S0F-21-127 - Joystick, 2, 5 kohm, 10 V
5T25-1S0F-21-127 数据手册
52.10 44.00 33.42 29.80 O 4 .7 5 44.00 52.10 .25 O 2 APEM APEM 5000 SERIES - POTENTIOMETER JOYSTICKS COST EFFECTIVE LOW PROFILE INSTALLATION SIMPLE INTERFACE ERGONOMIC DESIGN TWO OR THREE AXES ROHS COMPLIANT LOW CURRENT DRAIN SPECIFICALLY DESIGNED FOR KEYBOARDS www.apem.com 870044v1 5000 SERIES - POTENTIOMETER JOYSTICKS PRODUCT DESCRIPTION GENERAL DESCRIPTION The 5000 Series is a range of low profile, cost optimised potentiometer joysticks. These joysticks are designed specifically for applications such as keyboards where installed depth and cost are critical. Configurable in up to three axes, for pan, tilt and zoom control of such applications as CCTV cameras the 5000 Series is offered with a range of handles, bezels and mounting styles. MOUNTING The 5000 Series is a sub-panel mounting joystick. It is offered with two mounting options; option B allows the user to screw down from the front face of the panel, through the bezel and into the joystick. Option A has four additional screwing points on the body of the joystick, allowing the user to screw from the underside of the panel, up through the joystick and into the panel, and in so doing the screw heads are concealed. Option B is designed for use with gaiter option 1 and bezel option 2, where as option A is designed for use with bezel option 1. POTENTIOMETERS The 5000 Series is offered as standard with 5K potentiometers which have 220° tracks. With a shaft deflection angle of nominally 40°, a typical 5V supply would therefore result in a full scale nominal deflection from 2V to 3V, operating about a nominal 2.5V centre. The potentiometers used on the 5000 Series are designed for use as a variable potential divider, rather than a two pin variable resistor. Noise generated by the contact resistance of the wiper to the track dictates that for optimum performance the output signals should be fed into a load of greater than 100K. OPERATING MODE The operating mode of the joystick may be specified as either sprung to centre, or alternatively with a “ratchet” position, allowing a positive detented feel in three positions either side of centre (available on X & Y axes only). USER FLEXIBILITY The 5000 Series is designed to be as flexible as possible whilst keeping cost optimal. As standard the unit is offered without a wiring harness, allowing customers to wire the unit according to the needs of the individual application. The joystick may be factory configured with cable harnesses upon request. The 5000 Series is offered with an open square gate as standard, again allowing the customer the flexibility of determining in software how the precise control is configured. LEVERS Lever option 1 should be specified for any two axes configuration. Lever option 8 is for three axes operation. Apem offers a range of non standard lever options, including custom and lower profile options, for more details of these or any other 5000 Series enquiries please contact your local Apem representative. Note: The company reserves the right to change specifications without notice. www.apem.com 870044v1 5000 SERIES - POTENTIOMETER JOYSTICKS PRODUCT CONFIGURATION STANDARD OPTIONS The 5000 Series is available with a range of standard options, to specify your joystick, simply choose one option from each column. An example is shown below. 5 S 2 5 1 S 0 F 2 1 00 SERIES MOUNTING AXES POTS LEVER SPRING WIRED HANDLE BEZEL GAITER MODIFIER 5000 (5) Sub Mount A (S) Two (2) 5 K 220° (5) Standard (1) Ratchet (R) None (0) Conical (F) Not supplied Not supplied (0) (0) None (00) Sub Mount B (T) Three (3) For 3 Axes (8) Standard (S) 200mm (1) Tall Conical (H) Square Standard (1) Tall Slimline Circular (2) (V) (1) Third Axis (W) EXAMPLE CONFIGURATIONS TECHNICAL SPECIFICATION All parameters and dimensions shown maybe subject to specification, please refer to Apem for details. Life Cycles Lever Material Handle Material Temperature Range Maximum Voltage Weight : >1 Million Mechanical Operations : Stainless Steel : Nylon or Aluminium : -10°C to +55°C : 10V : 50 Grams Lever Travel Body Material Gaiter Material Resistance Tolerance Rated Power Potentiometer Alignment : +/-20 Degrees from Centre : ABS : Neoprene :+/-20% : 0.125W per Potentiometer : To Centre of Track (+/-50mV) www.apem.com 870044v1 5000 SERIES - POTENTIOMETER JOYSTICKS USEFUL DIMENSIONS MOUNTING OPTION A 52.10 44.00 33.40 45.50 52.10 44.00 33.40 29.50 0.75 min clearance 2.25 Ø 4 places MOUNTING OPTION B 41.50 32.20 45.50 41.50 32.20 27.50 Note: The dimensions shown are for a generic two axes 5000 Series with the F type handle. For specific dimensions of this or any other configuration please refer to Apem. www.apem.com 870044v1 5000 SERIES - POTENTIOMETER JOYSTICKS USEFUL DIMENSIONS MOUNTING OPTION A - PANEL CUT-OUT AND MOUNTING INSTALLATION MATERIAL: Nylon MOUNTING CUT-OUT 33.50 Ø5.00 x 4 33.50 44.00 44.00 The joystick is mounted from beneath the panel, with the bezel fitted onto the front face of the panel. It is recommended to use No. 2 self tapping, pan head screws, the length of which must be determined subject to the thickness of the panel. MOUNTING OPTION B - PANEL CUT-OUT AND MOUNTING INSTALLATION MATERIAL: Nylon MOUNTING CUT-OUT Ø2.50 x 4 Ø39.00 32.20 32.20 The joystick is mounted from beneath the panel. The gaiter must be passed through the panel cut-out and held in place with the mounting bezel. It is recommended to use No. 2 self tapping countersunk screws, the length of which must be determined subject to the thickness of the panel. Note: During the mounting process, great care should be taken not to damage the gaiter. All panel cut-outs should be free from sharp edges and swarf that may damage the gaiter. www.apem.com 870044v1 HANDLE SELECTION GUIDE HANDLE C The conventional choice for power chairs. 32.00 MATERIAL: Nylon MATERIAL: Phenolic FINISH: Gloss 30.00 STANDARD COLOUR: Black OTHER COLOURS: Upon request 15.50 AVAILABLE: 1000, 4000, 8000 and 9000 Series A tall cylindrical handle, with an anodised aluminium finish. Nylon MATERIAL: HANDLE D 12.70 MATERIAL: Aluminium FINISH: Anodised 35.00 STANDARD COLOUR: Black OTHER COLOURS: Not available AVAILABLE: 1000, 4000, 8000 and 9000 Series A mid-size conical handle with a modern look and feel. MATERIAL: Nylon HANDLE E 18.00 MATERIAL: Nylon FINISH: Matt 25.00 STANDARD COLOUR: Black OTHER COLOURS: Upon request 12.00 AVAILABLE: 4000, 8000 and 9000 Series The smallest conical handle for that feel of precision. MATERIAL: Nylon HANDLE F 15.00 MATERIAL: Nylon FINISH: Matt 20.00 STANDARD COLOUR: Black OTHER COLOURS: Upon request 10.00 AVAILABLE: 1000 and 5000 Series Note: The drawings above are not to scale and all dimensions shown are in millimeters. Note: Different colour variants may be subject to minimum order quantities. www.apem.com Version 2
5T25-1S0F-21-127 价格&库存
很抱歉,暂时无法提供与“5T25-1S0F-21-127”相匹配的价格&库存,您可以联系我们找货
