A1PCA1Y1220J303
A1PCA1Y1220J303
    APEM(埃斐)
    APEM - A1PCA1Y1220J303 - Industrial Pushbutton Switch, A1 Series, 22 mm, SPDT, Momentary, Flush, Nat...
A1PCA1Y1220J303 数据手册
01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page2 A1-A01-A02-A03 series Industrial controls Distinctive features UG1410A The A01 and A02 series offer ranges of : - pushbutton switches, illuminated or not - indicators - 2 or 3 position keylock switches - 2 or 3 position rotary lever switches - emergency stop switches with rectangular, square or round operators. ❑ Environmental protection : IP65 ❑ Modular construction ❑ Electrical life : 50.000 cycles min. ❑ Screen engraving or insertable legends on request ❑ Approvals (for switch blocks only) UL 1054 BS RIA 20 Shock & Vibration EN 61058-1 Each sub-assembly has to be ordered separately. A01 - A1 - A03 series G A02 series • Panel cut-out : Ø 16 mm (.630), except : - flush mount round : Ø 22 mm (.866) - flush mount rectangular : 20.60 x 26.70 mm - flush mount square : 20.60 x 20.60 mm - A1 series : Ø 22 mm (.866) - A03 series : round or square Ø 22 (.866) flush mount : Ø 30 mm (1.378) • Panel cut-out : - round or square : Ø 22 mm (.866) - rectangular : 29,5 x 21,5 mm (1.160x.846) - flush mount : Ø 30 mm (1.378) • 1, 2, 3 and 4 poles • Current/voltage rating : 12A 380VAC 16A 250VAC max. - 25mA 5VAC min. • Solder lug/quick-connect terminals • 1 and 2 poles • Screw terminals (optional : quick-connect term.) • Contacts : silver These values are applicable for all components, accessories and lamps, unless otherwise specified in the following pages. • Contacts : silver, gold plated • Current/voltage rating : 6A 250VAC max. - 10mA 5VAC min. These values are applicable for all components, accessories and lamps, unless otherwise specified in the following pages. • Lamp : filament, neon or LED • Lamp : filament, neon, LED or special multi-LED array Option : end cap terminal guard. Order separately (see end of A02 series). Packaging unit : A1 : 25 pieces - A01 : 20 pieces (except pushbuttons: 25 pieces) - A02 : 25 pieces - A03 : 10 pieces. Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. The company reserves the right to change specifications without notice. G-2 www.apem.com APEM 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page3 A1-A01-A02-A03 series Industrial controls Specifications for pushbutton, keylock and rotary switches ELECTRICAL SPECIFICATIONS A01 - A1 - A03 A02 Momentary or maintained action Momentary or maintained action 10mA 5VAC min. 6A 250VAC max. - 6A 12VDC max. 25mA 5VAC min. 12A 380VAC - 16A 250VAC max. 12A 12VDC max. > 1 mm (.039) Double break 2 x 1,5 mm (.059) 10mΩ max. at 1A 4VDC 10mΩ max. at 1A 4VDC 50 MΩ min. 50 MΩ min. 750V between open contacts 5KV live to accessible 2KV between open contacts 4KV live to accessible 50.000 cycles 50.000 cycles • Insulation : Class 2 Class 2 • Lamp life : LED : 60.000 h min. to 75% relative luminosity - Filament : approx. 5.000 h Neon : approx. 10.000 h LED : 60.000 h min. to 75 % relative luminosity - Filament : approx. 5.000 h Neon : approx. 10.000 h • Function : • Current/voltage rating : • Contact gap • Initial contact resistance : • Insulation resistance : • Dielectric strength : • Electrical life (resistive load) : • Lamp circuit diagrams A B A B GENERAL SPECIFICATIONS A01 - A1 - A03 • Min. mechanical life : A02 Pushb. momentary : 1 million cycles Pushb. maintained : 100.000 cycles Keylock and rotary : 100.000 cycles Pushb. momentary: 1 million cycles Pushb. maintained : 100.000 cycles Keylock and rotary : 100.000 cycles 8 mm (.315) max. 8 mm (.315) max. • Operating temperature : -20°C to +55°C -20°C to +85°C • Solder heat resistance : (IEC 68-2-20Tb, method 2) 350°C, 5 sec. 350°C, 5 sec. • Degree of environmental protection (IEC 529 ) IP 65 front of panel IP 40 back of panel IP 65 front of panel IP 40 back of panel Midget Grooved T13/4, filament, LED or neon Midget Grooved T13/4, filament, LED or neon Special multi-LED array • Switch terminals : Solder/quick-connect 2,8 mm (.110) M3 screws - wire 2 x 0,75 mm2 max. • Lamp terminals : Solder/quick-connect 2,8 mm (.110) M3 screws Flexible wire 2 x 2,5 mm2 max. Rigid wire 4 mm2 max. • Panel thickness • Lamps : G Specifications for emergency stop switches : see pages 10 and 22. For screen engraving or film legends, contact APEM. APEM www.apem.com G-3 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page4 A1 series Engraved aluminium flush mounting pushbuttons and indicators Panel cut-out Ø 22 (.866) A pushbutton assembly requires : engraved screen + lamp (if illuminated) + operator + switch block + flush mount bezel. To order these elements, select desired model numbers from the table below. Example : pushbutton, round, illuminated, sealed to IP65, latching, single pole with “start” engraving, 24V blue LED and flush mounting bezel = A1PCA1X103K403. 1 3 2 18.00 (.709) 8.5 (.335) 14.5 (.571) 42.05 (1.655) 12.00 (.472) Ø25.00 (9.85 DIA) 2.8 (.110) 18.00 (.709) 15.3 (.602) 7.65 (.301) 0.5 (.020) A1 Accessories 03 - flushmount Switch Type Bezel Illumination Sealing Function Switch block P - pushbutton I - indicator C - round A - illuminated B - non-illum. 0 - unsealed 1 - sealed IP65 0 - indicator X - latching Y - momentary 0 - indicator 1 - single pole 2 - double pole 5 - three pole 3 - four pole Engraved Screen Options G OTHER SCREEN ENGRAVING OPTIONS : contact APEM. G-4 01 - Front Fog Lights 11 - ‘Lock’ 02 - Rear Fog Lights 12 - ‘Unlock’ 03 - ‘Start’ 13 - Rear Window Heating 04 - Interior Light 14 - Cooling 05 - Boot Release 15 - Wipers 06 - Hazard Warning 16 - Washers 07 - Lights 17 - Fan 08 - Heating & Ventilation 18 - Horn 09 - Map Lights 19 - Air recirculation 10 - Side Lights 20 - Blank www.apem.com Bulb A1 - filament 6.3V B1 - filament 14V C1 - filament 28V D1 - filament 36V E1 - filament 48V F1 - filament 60V G1 - Neon 110V H1 - Neon 220V I1 - Led 6V red I2 - Led 6V green I3 - Led 6V amber J1 - Led 12V red J2 - Led 12V green J3 - Led 12V amber J4 - Led 12V blue J5 - Led 12V white K1 - Led 24V red K2 - Led 24V green K3 - Led 24V amber K4 - Led 24V blue K5 - Led 24V white L1 - Led 48V red L2 - Led 48V green L3 - Led 48V amber APEM 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page5 A01 series Illuminated or non-illuminated pushbutton switches Panel cut-out Ø 16 (.630) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular pushbutton, single pole, maintained, red screen and 12V red LED = A0161B, A0142M1, A0101X and A0151BUL. 3 3 3 2 2 9.00 (.354) 2 2 2 1 1 8.50 (.335) 1 3 3 3 24.00 (.945) 6.00 (.236) ❷ ❶ Screen Bezel 0.50 (.020) D C 2.80 (.110) Operator Lamp Voltage Part No Pole black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0161A A0161B A0161C A0161D A0161E A0161F A0161G A0161J A0162A A0162B A0162C A0162D A0162E A0162F A0162G A0162J A0163A A0163B A0163C A0163D A0163E A0163F A0163G A0163J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 3 or 4 3 or 4 F ❹ Lamp Part No E 30.70 (1.209) 18.00 (.709) ❸ Colour D Ø18.00 (.709 DIA) 18.00 (.709) C 28.50 (1.122) 8.40 (.330) 42. 00 (1.654) 18.00x18.00 (.709 SQ) 10. 00 (.394) 7. 65 (.301) 1 2 7.65 7.65 (.301) (.301) 18.00 (.709) 1 1 18.00 (.709) 6.00 (.236) 12.00 (.472) 6.00 (.236) 2 24.00 (.945) 16.25 (.640) 9.00 (.354) 3 1 Bezel Switch block Description Part No No of poles Part No Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained A0101Y A0101X A0102Y A0102X A0103Y A0103X A0104Y A0104X A0105Y A0105X A0106Y A0106X A0107Y A0107X A0108Y A0108X A0109Y A0109X A0110Y A0110X A0111Y A0111X A0112Y A0112X Single pole Double pole Three pole Four pole A0151B A0152B A0155B A0153B UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. BI-COLOUR LED’s optional. SCREEN ENGRAVING/INSERTABLE LEGENDS : contact APEM Bezel: APEM rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com G-5 G 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page6 A01 series Indicators Panel cut-out Ø 16 (.630) An indicator assembly requires : screen + lamp + operator. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular indicator with red screen and 12V red LED = A0161B, A0142M1 and A0171. 24.00 (.945) Ø18.00 (.709 DIA) 8.40 (.330) 42.00 (1.654) 10.00 (.394) 18.00 (.709) 18.00 (.709) 8.50 (.335) ❷ ❶ Screen Bezel G 0.50 (.020) 2.80 (.110) ❸ Operator Lamp Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0161A A0161B A0161C A0161D A0161E A0161F A0161G A0161J A0162A A0162B A0162C A0162D A0162E A0162F A0162G A0162J A0163A A0163B A0163C A0163D A0163E A0163F A0163G A0163J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 Bezel Description Part No Indicator Indicator Indicator A0171 A0172 A0173 UNSEALED INDICATORS (IP40) : add “01” to end of operator model number. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM Bezel: G-6 rectangular, square, round www.apem.com APEM 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page7 A01 series Rotary lever switches Panel cut-out Ø 16 (.630) A rotary lever switch assembly requires : operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular rotary switch with long lever, clockwise rotation, single pole, 2 positions, maintained = A019109 and A0151BUL. 12.00 (.472) 2 24.00 (.945) 6.00 (.236) 1 3 3 1 3 3 2 2 2 1 2 2 1 3 3 1 7.65 (.301) 1 1 3 8.40 (.330) C D 28.50 (1.122) 10.00 (.394) 42.00 (1.654) 0.50 (.020) 18.00 (.709) 2.80 (.110) 18.00 (.709) ❷ ❶ 18.00 (.709) 2 24.00 (.945) C D 18.00x18.00 (.709 SQ) E Ø18.00 (.709 DIA) F 30.70 (1.209) Lever Positions B C A Operator Pole Bezel Description 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 Bezel: APEM 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR rectangular, Switch block Short lever Long lever No of poles Part No A019209 A019210 A019211 A019212 A019205 A019206 A019207 A019208 A019409 A019410 A019411 A019412 A019405 A019406 A019407 A019408 A019609 A019610 A019611 A019612 A019605 A019606 A019607 A019608 Single pole Double pole Three pole Four pole A0151B A0152B A0155B A0153B square, A019109• A019110• A019111• A019112• A019105 A019106 A019107 A019108 A019309• A019310• A019311• A019312• A019305 A019306 A019307 A019308 A019509• A019510• A019511• A019512• A019505 A019506 A019507 A019508 round, • Lever Rotation - 2 position switches The model numbers shown are for switches with clockwise lever rotation. For anticlockwise rotation, replace : G 09 with 01 10 with 02 11 with 03 12 with 04 at the end of the model number. Optional Engraving on Lever end See above photo left. To order, add “WL” to the end of the operator part No. Example : A019609WL.. ‘pos’ - position, ‘mainL’ - maintained left, ‘momR’ - momentary right, etc www.apem.com G-7 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page8 A01 series Keylock switches Panel cut-out Ø 16 (.630) A keylock switch assembly requires : operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular keyswitch, clockwise rotation, single pole, 2 positions, maintained = A018125 and A0151BUL. 3 1 2 24.00 (.945) 1 3 12.00 (.472) 1 3 3 1 18.00x18.00 (.709 SQ) 1 3 7.65 (.301) 2 18.00 (.709) 2 6.00 (.236) 2 2 38.00 (1.496) 2 2 1 1 3 3 24.00 (.945) 18.00 (.709) C ❷ ❶ D 18.00 (.709) 2.80 (.110) 28.50 (1.122) 0.50 (.020) 8.40 (.330) 42.00 (1.654) Ø18.00 (.709 DIA) C D E F 30.70 (1.209) Key Positions B Operator Pole G 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 Bezel: G-8 Bezel Description 2 pos. maintained 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR rectangular, A018123 A018125• A018124• A018127• A018128• A018105 A018106 A018107 A018108 A018223 A018225• A018224• A018227• A018228• A018205 A018206 A018207 A018208 A018323 A018325• A018324• A018327• A018328• A018305 A018306 A018307 A018308 square, A Switch block Part No Key removable A A-B A A-B A A-B-C A A-B A-C A A-B A A-B A A-B-C A A-B A-C A A-B A A-B A A-B-C A A-B A-C round, No of poles Part No Single pole Double pole Three pole Four pole A0151B A0152B A0155B A0153B C • Key Rotation - 2 position switches The model numbers shown are for switches with clockwise key rotation. For anticlockwise rotation, replace : 25 24 27 28 with with with with 01 02 03 04 at the end of the model number. 2 standard keys are supplied. 20 key barrel types available. NON-REMOVABLE KEY POSITIONS / ON-ON-ON FUNCTION : contact APEM. ‘pos’ - position, ‘mainL’ - maintained left, www.apem.com ‘momR’ - momentary right, etc APEM 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page9 A01 series Emergency stop switches Panel cut-out Ø 16 (.630) • Prominent 24 mm (.944) dia. or optional 40 mm (1.575) dia. red mushroom actuator • Highly reliable positive break switch • Push to shut off switch, twist to reset to ON N.C. An emergency stop switch assembly requires : operator + switch block. To order, specify with single pole or double pole positive break switch block. General specifications • Min. mechanical life : 6.050 cycles (6 cycles per minute) • Operating force / torque : 16 N / 0,1 Nm • Operating temperature : -20°C to +55°C • Solder heat resistance : 350°C, 5 secs (IEC 68-2-2-20Tb, method 2) • Degree of environmental protection (IEC 529) : IP65 front of panel, IP40 back of panel • Switch terminals : solder/quick-connect 2,8 mm (.110) (IEC 68-2-20) Electrical specifications • Current/voltage rating : 1,5A 250VAC AC-15 • Contact gap : > 3 mm (.118) • Dielectric strength : 2.900V • Electrical life : 6.050 cycles 19.00 (1.047) Ø24.00 (.945 DIA) 15.30 (.602) 12.00 (.472) 0.50 (.020) 18.00 (.709) ❷ ❶ C D Ø40.00 8.40 (.330) 42.00 (1.654) Option : SP3 version 2.80 (.110) 18.00 (.709) Accessory Ø 60 mm Self Adhesive Label Operator Description 24 mm Ø Emergency stop 40 mm Ø Emergency stop APEM Description Part No Yellow label with text Yellow label A01YL1 A01YL2 Switch block Part No No of poles Part No A01ES A01ES SP3 Single pole Double pole A0150B A0154B www.apem.com G-9 G 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page10 A01 series Emergency stop switches/mushroom head pushbutton switches Fitted in enclosures • Prominent 40 mm (1.575) dia. mushroom actuator, twist to release • Highly reliable positive break switching on E-Stop • Sealed to IP65 • Robust polycarbonate enclosures • Knockouts for popular conduit sizes • Double pole changeover switch blocks available for momentary/maintained mushroom head pushbuttons. N.C. Emergency stop 3 1 Technical specifications • Contact rating : Pushbutton switch : 6A 250VAC - E-Stop : 1,5A 250VAC • Dimensions : 65 x 65 x 57 mm • Electrical life : Pushbutton switch : 50 000 cycles - E-Stop : 6 050 cycles • Operating temperature : -20°C to +55°C 2 Momentary & maintained 55.0 (2.167) 17.5 (.689) Ø40.0 (1.575 DIA) 65.0 SQUARE (2.561) G Description Part No Emergency stop Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained A01ESSP354B + PEA01 A01MMASP352B + PEA01 A01MMBSP352B + PEA01 A01MMDSP352B + PEA01 A01MMESP352B + PEA01 A01MMFSP352B + PEA01 A01MXASP352B + PEA01 A01MXBSP352B + PEA01 A01MXDSP352B + PEA01 A01MXESP352B + PEA01 A01MXFSP352B + PEA01 OPTIONS 12A 250V versions or custom printing on mushroom head actuators : contact APEM. G-10 www.apem.com APEM 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page11 A01 series Mushroom head pushbutton switches Panel cut-out Ø 16 (.630) • Prominent 24 mm (.944) dia. or optional 40 mm (1.575) dia. mushroom actuators • Momentary and maintained functions Momentary function versions are unmarked. Maintained function versions are twist release (arrows indicate direction of twist) • Various coloured mushroom actuators are available. 2 0.50 (.020) C D 2.80 (.110) Ø40.00 (1.575 DIA) 8.40 (.330) 42.00 (1.654) OPTION : SP3 VERSION Option : SP3 version 18.00 (.709) 18.00 (.709) ❷ ❶ Operator Switch block Actuator Description Part No No of poles Part No 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained A01MMA A01MMB A01MMD A01MME A01MMF A01MXA A01MXB A01MXD A01MXE A01MXF A01MMA SP3 A01MMB SP3 A01MMD SP3 A01MME SP3 A01MMF SP3 A01MXA SP3 A01MXB SP3 A01MXD SP3 A01MXE SP3 A01MXF SP3 Single pole Double pole Three pole Four pole A0151B A0152B A0155B A0153B APEM 3 Ø24.00 (.945DIA) 19.00 (1.047) 1 www.apem.com G G-11 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page12 A1-A01 series Industrial controls Accessories Ø25.00 (.984 DIA) Ø16.00 (.630DIA) 11.00 (.433) +0.20 20.60 0.00 +.008 (.811 .000) 18.15 (.715) Ø16.00 (.630DIA) 23.80 (.937) 23.80 (.937) 12.00 (.472) Ø22.00 (.866 DIA) 29.80 (1.173) 12.00 (.472) 20.40 (.803) 18.10 (.712) 20.40 (.803) 23.80 (.937) Ø16.00 (.630DIA) Dark grey plastic material - supplied with sealing washer 18.10 (.712) FLUSH MOUNTING BEZELS +0.20 26.70 0.00 (1.051 +.008 .000 ) Rectangular A01FM1 Square A01FM (.874 Round A01FM2 Ø25.00 (.984 DIA) Ø22.00 (.866 DIA) Ø16.00 (.630DIA) Metal versions 18.15 (.715) FLUSH MOUNTING BEZELS +0.20 22.20 0.00 +.008 .000 ) +0.20 20.60 0.00 (.811 +.008 .000 ) 11.00 (.433) +0.20 22.20 0.00 +.008 .000 ) (.874 Round, anodised aluminium A01FMM Round, matt black A01FMMG PCB SOCKET 18.40 (.724) 6.00 (.236) G Single pole, non illuminated Double pole, non illuminated Single pole, illuminated Double pole, illuminated Indicator Single pole, E-stop Double pole, E-stop 7.65 (.301) 0.80 (.031) 6.00 (.236) 7.65 (.301) 18.25 (.719) 5.00 (.196) 10.25 (.403) 4.25 (.167) 1.10 (.043) 4.25 (.167) A01PC1 A01PC2 A01PC3 A01PC4 A01PC5 A01PC6 A01PC7 Rectangular A01FG1 G-12 www.apem.com 13.50 (.531) 18.00 (.708) 24.00 (.945) 13.65 (.537) 13.65 (.537) 9.00 (.354) 24.00 (.945) 12.00 (.472) 24.00 (.945) 13.50 (.531) FLAPGUARDS Square/round A01FG2 APEM 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page13 A1-A01 series Industrial controls Accessories METAL GUARDS ➞ Slot as alternative to Ø 2 mm hole - Material : 1 mm thick aluminium. Ø16.00 (.630DIA) Ø16.00 (.630DIA) Rectangular A01MG1 Ø16.05 (.631DIA) Round, natural A01MG2 Matt black A01MG2G Square A01MG Recommended to prevent product rotation 14.75 (.580) Ø16.00 (.629DIA) 18.00 (.708) ANTI ROTATION RING 12.00 (.472) 18.20 (.717) 24.00 (.944) 10.15 (.399) 18.00 (.708) 8.90 (.350) 12.00 (.472) Ø2.00 (.078DIA) Ø19.60 (.771 DIA) 18.00 (.708) 9.80 (.385) Ø18.10 (.712 DIA) A01LW 18.00 (.708) 2.00 (.078) SWITCHBLOCK TERMINAL GUARDS 14.85 (.584) 2 way A01RTC2 BLANKING PLUGS 24.0 (.946) 18.0 (.709) 18.0 (.709) RESISTOR ASSEMBLY 20.75 (.816) 8 way A01RTC8 Ø18.0 (.709 DIA) Round A0133 8.50 (.334) 10.50 10.00 (.413) (.393) Square A0132 18.0 (.709) 10.50 10.00 (.413) (.393) 20.75 (.816) 20.75 (.816) 7.35 (.289) 6.00 (.236) 7.45 (.293) Rectangular A0131 G Resistor assembly - 2 stage illumination A0152B + RISSP (DIM) normally closed APEM www.apem.com (BRIGHT) normally open G-13 01-Series A01_A1-A-R1_01-Series A01_A1-A 06/11/14 14:56 Page14 A1-A01 series Industrial controls Installation - tools Modular construction / panel mounting PUSHBUTTONS & INDICATORS EMERGENCY STOP ROTARY LEVER SWITCHES PANEL CUT-OUT SCREEN Round & square operators only Ø16.00 0.00/+0.30 (.629 DIA .000/+.011 ) LEGEND KEYLOCK SWITCHES REFLECTOR POLARISING DOT FIXING NUT 4.00 Maxi (.157 MAX) PANEL SEAL OPERATOR 7.25 (.285) LOCATING SLOT BULB 1.50 (.059) Rectangular operators only Ø16.00 0.00/+0.30 (.629 DIA .000/+.011 ) Ø2.00 (.078 DIA) LATCH SWITCH BLOCK 10.50 (.413) Max. panel thickness : 8 mm (.315) PANEL MOUNTING ASSEMBLY TO REMOVE BULB • Drill/punch hole shaped as above. Remove reflector/screen assembly. Use the bulb extractor 30-0002 to remove the bulb. • Assemble front operator through hole, fit fixing nut and tighten to a maximum torque of 0,8Nm using tool No 30-0001. SWITCH BLOCK • Wire chosen switch block as required and slide onto operator until latch engages. To assemble switch block to front operator, TAKE CARE TO LINE UP SWITCH BLOCK WITH FRONT OPERATOR. Once in position, slide on to front operator. NB. : Ensure latch is fully engaged correctly onto the switch block. • Fit bulb if required using tool No 30-0002. G • Snap screen onto reflector assembly with legend in between if required and snap onto front operator TAKING CARE TO LINE UP THE LOCATING SLOT WITH THE POLARISING DOT, and not to damage the seal. G-14 To remove switch block, depress the latch and slide the switch block off the operator. FIXING NUT KEY BULB REMOVER 30-0001 30-0002 www.apem.com APEM 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page15 A02 series Illuminated or non-illuminated pushbutton switches Panel cut-out Ø 22 (.866) or 29,5 x 21,5 (1.160x.846) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + one or two switch blocks. To order these elements, select desired model numbers from tables below. Example : IP65 illuminated rectangular maintained pushbutton, switch block with 2 N.O. contacts, red screen and 12V red LED assembly = A0261B, A0242J1, A0201X and A02503UL. UG1410A N.C. N.O. N.O./N.C. 10.00 (.394) 10.00 (.394) 10.00 (.394) 24.00 (.945) 29.00 (1.142) 36.00 (1.417) 21.00 (.827) Ø29.00 (1.142 DIA) 21.00 (.827) 27.00 (1.062) 33.50 (1.319) 64.00 (2.520) 64.00 (2.520) 55.50 (2.185) 29.00x29.00 (1.142 SQ) 33.50 (1.319) ❷ ❶ Screen Bezel ❸ Lamp ❹ Operator Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0261A A0261B A0261C A0261D A0261E A0261F A0261G A0261J A0262A A0262B A0262C A0262D A0262E A0262F A0262G A0262J A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 Bezel Switch block Description Lamp type Part No Contacts Part No Illum, momentary Illum, maintained Non-illum, maintained Non-illum, momentary Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-Illum, maintained Lamp/LED Lamp/LED A0201Y A0201X A0203X A0203Y A0204Y A0204X A0206Y A0206X A0207Y A0207X A0209Y A0209X 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501 A02502 A02503 A02504 A02505 Lamp/LED Lamp/LED Lamp/LED Lamp/LED UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506 A02507 A02508 A02509 A02510 To achieve 3 or 4 pole switching, add second switch block, from above table. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated The company reserves the right to change specifications without notice. APEM www.apem.com G-15 G 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page16 A02 series Metal bezel pushbutton switches and indicators Panel cut-out Ø 22 (.866) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + one or two switch blocks. An indicator assembly requires : screen + lamp + operator To order these elements, select desired model numbers from tables below. Example : IP65 illuminated metal bezel maintained pushbutton, switch block with 2 N.O. contacts, red screen and 12V red LED assembly = A0263B, A0244J1, A0211X and A02503UL. N.O. N.C. N.O./N.C. 45.50 (1.791) 11.50 (.452) Ø29.00 (1.142DIA) 75.00 (2.952) Ø29.00 (1.142DIA) 34.00 (1.338) ❷ ❶ Screen Bezel G 21.00 (.826) ❸ ❹ Lamp Operator Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 Bezel Description Lamp type Illum, momentary Lamp/LED Illum, maintained Lamp/LED Non-illum, momentary Non-illum, maintained Illum, indicator Lamp/LED Switch block Part No Contacts Part No A0210Y A0210X A0212Y A0212X A0277 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501 A02502 A02503 A02504 A02505 Std bezel material : nickel plated brass. For optional black finish, add “G” to the end of operator model number. UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506 A02507 A02508 A02509 A02510 To achieve 3 or 4 pole switching, add second switch block, from above table. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: G-16 rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com APEM 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page17 A02 series Flush mounting pushbutton switches and indicators Panel cut-out Ø 30 (1.181) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + one or two switch blocks. An indicator assembly requires : screen + lamp + operator To order these elements, select desired model numbers from tables below. Example : IP65 illum. flush mounting maintained pushbutton, switch block with 2 N.O. contacts, red screen and 12V red LED assembly = A0263B, A0244J1, A0213X and A02503UL. N.O. N.O./N.C. Ø35.00 (1.378DIA) 73.00 (2.874) 46.00 (1.811) 2.00 (.078) Ø35.00 (1.378DIA) N.C. PANEL CUT-OUT DECOUPE DU PANNEAU 34.00 (1.338) ❷ ❶ Screen Bezel 21.00 (.826) ❸ Lamp ❹ Operator Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 Bezel 30.00 (1.181) Description Lamp type Illum, momentary Lamp/LED Illum, maintained Lamp/LED Non-illum, momentary Non-illum, maintained Illum, indicator Lamp/LED Switch block Part No Contacts Part No A0214Y A0214X A0215Y A0215X A02791 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501 A02502 A02503 A02504 A02505 Std bezel material : silver anodised aluminium. For optional black anodised aluminium, add “G” to end of operator model number. UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506 A02507 A02508 A02509 A02510 To achieve 3 or 4 pole switching, add second switch block, from above table. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: APEM rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com G-17 G 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page18 A02 series Indicators Panel cut-out Ø 22 (.866) or 29,5 x 21,5 (1.160x.846) 10.00 (.394) An indicator assembly requires : Screen + lamp, LED or LED assembly + operator. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular indicator with red screen and 12V red LED assembly = A0261B, A0242J1 and A0272. 24.00 (.945) 29.00 (1.142) 36.00 (1.417) 33.50 (1.319) 29.00x29.00 (1.142 SQ) 10.00 (.394) 29.00 (1.142) 21.00 (.827) 37.50 (1.476) Ø29.00 (1.142 DIA) 33.50 (1.319) ❷ ❶ Screen Bezel G 21.00 (.827) ❸ Lamp Operator Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0261A A0261B A0261C A0261D A0261E A0261F A0261G A0261J A0262A A0262B A0262C A0262D A0262E A0262F A0262G A0262J A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 Bezel Description Lamp type Part No Indicator Indicator Indicator Lamp/LED Lamp/LED Lamp/LED A0271 A0273 A0275 UNSEALED INDICATORS (IP40) : add “01” to end of operator model number. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: G-18 rectangular, square, round, www.apem.com APEM 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page19 A02 series Rotary switches Panel cut-out Ø 22 (.866) A rotary lever assembly requires : operator + one or two switch blocks. To order these elements, select desired model numbers from tables below. Example : IP65 square 2 position maintained rotary switch with long lever, clockwise rotation, switch block with 2 N.O. contacts = A029107 and A02503UL. N.O./N.C. N.C. N.O. 29.00 (1.142) 20.00 (.787) 22.00 (.866) 29.00x29.00 (1.142 SQ) 21.00 (.827) 27.00 (1.062) 22.00 (.866) 64.00 (2.520) 64.00 (2.520) Ø29.00 (1.142 DIA) 33.50 (1.319) ❷ ❶ Lever positions B Operator Bezel Switch block Description Short lever Long lever Contacts Part No 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR A029207 A029208 A029203 A029204 A029205 A029206 A029407 A029408 A029403 A029404 A029405 A029406 A029107• A029108• A029103 A029104 A029105 A029106 A029307• A029308• A029303 A029304 A029305 A029306 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501 A02502 A02503 A02504 A02505 OPTION To specify flush mounting (Ø 30 mm) option, add “FM” to the end of the part number (for round operators only). Example : A029407FM. Bezel: APEM square, Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506 A02507 A02508 A02509 A02510 To achieve 3 or 4 pole switching, add second switch block, from above table. C A • Lever Rotation - 2 position switches The model numbers shown are for switches with clockwise lever rotation. For anticlockwise rotation, replace : 07 with 01 08 with 02 at the end of the model number. G Optional engraving on lever end To order, add “WL” to the end of the part No. Example : A029407WL. round, www.apem.com G-19 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page20 A02 series Keylock switches Panel cut-out Ø 22 or 29,5 x 21,5 A keyswitch assembly requires : operator + one or two switch blocks. To order these elements, select desired model numbers from tables below. Example : IP65 square 2 position keyswitch, clockwise rotation, switch block with 2 N.O. contacts = A028220 and A02503UL. N.O./N.C. N.C. N.O. 29.00 (1.142) 34.50 (1.358) 29.00x29.00 (1.142 SQ) 64.00 (2.520) 55.50 (2.185) 38.00 (1.496) 24.00 (.945) 36.00 (1.417) 21.00 (.827) 21.00 (.827) 27.00 (1.062) 33.50 (1.319) Ø29.00 (1.142 DIA) 33.50 (1.319) ❷ Key positions C B Operator Bezel G Description Part No 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR A028120• A028119• A028105 A028106 A028107 A028108 A028220• A028219• A028205 A028206 A028207 A028208 A028320• A028319• A028305 A028306 A028307 A028308 Key removable in positions A-B A A-B-C A A-B A-C A-B A A-B-C A A-B A-C A-B A A-B-C A A-B A-C OPTION To specify flush mounting (Ø 30 mm) option, add “FM” to the end of the part number (for round operators only). Example : A028320FM. Bezel: G-20 rectangular, A Switch block square, Contacts Part No • Key Rotation - 2 position switches 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501 A02502 A02503 A02504 A02505 The model numbers shown are for switches with clockwise key rotation. For anticlockwise rotation, replace: Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506 A02507 A02508 A02509 A02510 20 19 with with 01 02 at the end of the model number • 2 standard keys are supplied. • 20 key barrel types available. Non-removable key positions : contact APEM. To achieve 3 or 4 pole switching, add second switch block, from above table round, www.apem.com APEM 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page21 A02 series Emergency stop switches Panel cut-out Ø 22 (.866) • Prominent 40 mm (1.575) dia. red mushroom actuator • Highly reliable positive break switch • Push to shut off switch, twist to reset to ON N.C. An emergency stop switch assembly requires : operator + switch block. To order, specify with single pole or double pole positive break switch block. General specifications • Mechanical life : 6.050 cycles (6 cycles per minute) • Operating force : 20 N • Operating temperature : -20°C to +85°C • Degree of environ. protection (IEC529) : IP65 front of panel, IP40 back of panel • Switch terminals : M3 screws - wire 2x0.75mm2 max. Electrical specifications • Current/voltage rating : 2,5A 380VAC AC-15 • Contact gap : > 3 mm (.118) • Dielectric strength : 2.500V • Electrical life : 6.050 cycles 29.00 (1.142) 64.00 (2.520) 21.00 (.827) Ø40.00 (1.575 DIA) 21.00 (.827) ❷ ❶ Operator Bezel Accessory 90 mm Ø Self Adhesive Label Description Part No Yellow label with text Yellow label A02YL1 A02YL2 Switch block Description Part No No of poles Part No Emergency stop A02ES Double pole Single pole A02511 A02512 EMERGENCY STOP SWITCH ENCLOSURE To order the Emergency Stop Switch in the Plastic Enclosure (94 x 94 x 81 mm) with a 2 pole Positive Break Switch Block and Emergency Stop label, use Part number : A02PE2L. APEM www.apem.com G-21 G 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page22 A02 series Mushroom head pushbutton switches Panel cut-out Ø 22 (.866) • Prominent 40 mm (1.575) dia. mushroom actuator or optional 26 mm (1.024) actuator • Momentary and maintained functions Momentary function versions are unmarked Maintained function versions are twist to release (arrows indicate direction of twist) • Various coloured mushroom actuators are available N.O. N.C. N.O./N.C. 29.00 (1.142) 64.00 (2.520) 21.00 (.827) Ø40.00 (1.575 DIA) 21.00 (.827) ❷ ❶ Operator Bezel G Switch block Description Part No Contacts Part No Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained A02MMA A02MMB A02MMD A02MME A02MMF A02MXA A02MXB A02MXD A02MXE A02MXF 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501 A02502 A02503 A02504 A02505 OPTION For optional reduced (Ø 26 mm) mushroom head operators : contact APEM. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506 A02507 A02508 A02509 A02510 To achieve 3 or 4 pole switching, add second switch block, from above table Bezel: G-22 round www.apem.com APEM 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page23 A02 series Industrial controls Installation Modular construction / panel mounting PUSHBUTTONS & INDICATORS EMERGENCY STOP ROTARY LEVERS SWITCHES SCREEN LEGEND KEYLOCK SWITCHES REFLECTOR LOCATING SLOT BULB PANEL CUT-OUT Round & square operators Ø22.00 (.866 DIA FIXING NUT 6.00 Maxi (.236 MAX) 3.00 (.118) POLARISING DOT PANEL SEAL 0.00/+0.50 .000/+.019) 13.00 (.511) Rectangular operators SWITCH BLOCK 21.50 (.846 ADAPTOR BLOCK 0.00/+0.50 .000/+.019) OPERATOR 29.50 (1.161 0.00/+0.50 .000/+.019 ) END CAP PANEL CLAMP FIXING SCREW Max. panel thickness : 8 mm (.315) PANEL MOUNTING ASSEMBLY TO REMOVE BULB • Drill/punch hole in panel as shaped above. Remove reflector/screen assembly. Use the bulb extractor 30-0002 to remove the bulb. • Assemble front operator through hole and : a/ Round & square types : tighten nut to a maximum torque of 0,8Nm using tool No 30-0001. Snap on adaptor block b/ Rectangular types : tighten two panel fixing screws in front to a maximum torque of 0,06Nm. • Wire chosen switch block as required and snap onto front operator. TO REMOVE SWITCH BLOCK Lever out latches using small screwdriver taking care not to overbend, and pull off the block from the front operator. A02 Accessories • Snap end cap onto switch block. • Fit bulb if required using tool No 30-0002. Part No : 14-0005 • Snap screen onto reflector assembly with legend in between if required ans snap into front operator TAKING CARE TO LINE UP THE LOCATING SLOT WITH THE POLARISING DOT, and not to damage the seal. G End cap terminal guard offering unique terminal protection. 6.35 mm push on tab terminals. Specify “SP” to the end of the switchblock and operator P/N. Example : A02503SP. APEM www.apem.com G-23 02-Serie A02_A03-A-R1_02-Serie A02_A03-A 06/11/14 14:49 Page24 A03 series Illuminated or non-illuminated pushbutton switches and indicators Panel cut-out Ø 22 (.866) or 30 (1.181) - Plastic or metal flush mounting bezel A pushbutton assembly requires : screen + lamp (if illuminated) + operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 flush mounting round pushbutton, maintained function, red screen, 12V red LED and single pole switch block = A0314X, A0263B, A0142M1 and A0151BUL. 2 1.0 to 6.0 Panel Thickness 59.50 (2.344) 59.00 (2.325) 26.00 (1.024) 10.00 (.394) 49.00 (1.931) 3 Ø35.00 (1.379 DIA) 2.00 (.079) Ø29.00 (1.143 DIA) 1 0.50 6.00 (.236) 18.00 (.709) 6.00 (.236) 18.00 (.709) ❷ ❶ ❸ Screen Bezel G Bezel: G-24 ❹ Lamp Operator Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 round. ‘Illum’ - illuminated, 7.65 (.301) Bezel Description Plastic illum, momentary Plastic illum, maintained Plastic non-illum, momentary Plastic non-illum, maintained Metal illum, momentary Metal illum, maintained Metal non-illum, momentary Metal non-illum, maintained F/mount illum, momentary F/mount illum, maintained F/mount non-illum, momentary F/mount non-illum, maintained Plastic indicator Metal indicator F/mount indicator Switch block Lamp type Part No No of poles Part No Lamp/LED bulb Lamp/LED bulb A0307Y A0307X A0309Y A0309X A0310Y A0310X A0312Y A0312X A0314Y A0314X A0315Y A0315X A0375 A0377 A03791 Single pole Double pole Three pole Four pole A0151B A0152B A0155B A0153B Lamp/LED bulb Lamp/LED bulb Lamp/LED bulb Lamp/LED bulb UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. ‘Non-illum’ - non illuminated www.apem.com APEM
A1PCA1Y1220J303
1. 物料型号:文档中提到了多个型号,例如A01、A02、A03系列,具体型号包括但不限于A0151B、A0152B、A0155B、A0153B等。
2. 器件简介:文档描述了一系列工业控制用的开关和指示器,包括按钮开关、指示灯、钥匙开关、旋转杆开关和紧急停止开关。这些器件具有不同的功能和电气特性。
3. 引脚分配:文档中提到了不同的接线方式,包括1、2、3和4极的接线端子,以及快速连接和焊接端子。
4. 参数特性: - 电气寿命:至少50,000个周期。 - 电流/电压等级:对于A01-A1-A03系列,最小为10mA 5VAC,最大为6A 250VAC;对于A02系列,最小为25mA 5VAC,最大为16A 250VAC或12A 380VAC。 - 接触间隙:A01-A1-A03系列大于1mm,A02系列为双断开2 x 1.5mm。
5. 功能详解:开关可以是瞬时动作或持续动作,具有不同的电气特性和绝缘等级。
6. 应用信息:这些开关和指示器适用于工业控制领域,具有IP65的防护等级,模块化构造,可以根据需要定制屏幕雕刻或插入式图例。
7. 封装信息:提供了不同尺寸的面板切割尺寸,以及不同颜色和材料的表圈选择。
A1PCA1Y1220J303 价格&库存
很抱歉,暂时无法提供与“A1PCA1Y1220J303”相匹配的价格&库存,您可以联系我们找货
