AV031003C900
AV031003C900
    APEM(埃斐)
    SWITCH PUSH SPST-NO 2A 48V
AV031003C900 数据手册
PANEL SWITCHES 0 25 V -A 1 71 1 V- AV series SW Security pushbutton switches suitable for 250 VAC • approved according to EN 61058-1 DISTINCTIVE FEATURES Mains switches approved to EN61058-1 Ø 16 (.629), 19 (.748) and 22 mm (.866) Latching Three terminal types ENVIRONMENTAL SPECIFICATIONS • Optional front panel sealing : IP65 according to IEC 60529 • Operating temperature : -30 °C to +70 °C(-22 °F to +158 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 1 A 250 VAC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 2,000 Vrms 50 Hz min. between terminals 500 Vrms 50 Hz between terminals and frame • Electrical life : 10,000 cycles at 1 A 250 VAC GENERAL SPECIFICATIONS • Torque : 5 Nm min. - 14 Nm max. applied to nut • Panel thickness : Ø 16 : 1 (.039) to 6 mm (.236) max. Ø 19 and Ø 22 : 1 (.039) to 9 mm (.354) max. • Low level or mechanical life : 200,000 cycles • Hand soldering : 300 °C (572 °F), 4 sec. max. MATERIALS • Case : PA4-6, UL94-V0 • Contacts : silver (A) • Bushing & actuator : see following pages APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 PANEL SWITCHES AV series Security pushbutton switches suitable for 250 VAC • approved according to EN 61058-1 AGENCY APPROVAL EN61058-1 1A 250 VAC All models marked ELECTRICAL FUNCTIONS ON OFF PANEL MOUNTING CAVDTF1SFCT • Panel cut-out : Ø 16.2 mm (.755) Ø 19.2 mm (.755) or Ø 22.2 mm (.874) 2 Security pushbutton switches suitable for 250 VAC • approved according to EN 61058-1 BUILD YOUR PART NUMBER BASIC PART NUMBER AV SERIES ACTUATOR TYPES 06 Ø 16 (.629), flat 09 FUNCTION MODEL 100 1 CONTACTS A TERMINALS 2 Solder Ø 19 (.748), flat 4 PC 03 Ø 22 (.866), flat 8 Quick-connect 16 Ø 16 (.629), curved 19 Ø 19 (.748), curved 02 Ø 22 (.866), curved OFF-ON Silver OPTIONS BUSHING/ACTUATOR MATERIALS 00 (std) Nickel plated brass / Nickel plated brass 10 Nickel plated brass / Stainless steel 40 Stainless steel / Stainless steel SEALING Blank K No sealing Sealed to IP65 ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of website. 3 PANEL SWITCHES AV series Security pushbutton switches suitable for 250 VAC • approved according to EN 61058-1 Hex nut 19 (.748) across flats Ø 16 (.629) - FLAT OR CURVED ACTUATOR SOLDER LUG TERMINALS 3.40 (.133) 3.00 (.118) 2.30 (.090) OFF 3.45 (.135) ON 4.00 (.157) 2.00 (.078) Ø 19 (.748) - FLAT OR CURVED ACTUATOR SOLDER LUG TERMINALS 9.00 (.354) 15.20 (.598) CAV06DTF1 3.45 (.135) 2.00 (.078) 13.50 (.531) 4.00 10.70 (.157) (.421) ON AV191001A2 1.40 (.055) Curved actuator Ø15.00 (.590DIA) OFF Ø22.00 (.866DIA) ON 2.80 (.110) 2.30 (.090) CAVDT1-250 OFF EPOXY Hex nut 22 (.866) across flats Ø19.00x1.00 SI (.748DIAx1.00 IS) Flat actuator AV091001A2 2.30 (.090) Ø15.00 (.590DIA) Ø22.00 (.866DIA) 1.50 (.059) Product shown in OFF position. 1.40 (.055) AV161001A2 Ø19.00x1.00 SI (.748DIAx1.00 IS) 1.40 (.055) Curved actuator Ø12.00 (.472DIA) ON Ø18.00 (.708DIA) OFF Ø18.00 (.708DIA) AV061001A2 Ø12.00 (.472DIA) Flat actuator Ø16.00X1.00 SI (.629DIAX1.00 IS) 3.00 (.118) 13.50 (.531) 2.80 (.110) 10.70 (.421) CAVDT1-250 Product shown in OFF position. Hex nut 25 (.984) across flats Ø 22 (.866) - FLAT OR CURVED ACTUATOR SOLDER LUG TERMINALS Ø22.00x1.00 SI (.866DIAx1.00 IS) 4.00 (.157) 2.00 (.078) 3.45 (.135) 2.30 (.090) OFF ON OFF ON AV021001A2 1.40 (.055) Curved actuator Ø15.00 (.590DIA) AV031001A2 Ø25.00 (.984DIA) Flat actuator Ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) 3.45 (.135) 12.60 (.496) 4.00 11.60 (.157) (.456) CAVDT2-250 Ø25.00 (.984DIA) Product shown in OFF position. 2.80 (.110) 2.30 (.090) QUICK-CONNECT TERMINALS 1.10 (.043) 5.08 (.200) EPOXY 0.50 1.10 (.019) (.043) 1.20 (.047) 0.50 (.019) 2.80 (.047) Replace 2 with 4 at the end of the model numbers shown above. CAV16COPC 4 CAV16COPC 8.00 (.314) CAVDT2-250 EPOXY EPOXY 1.20 (.047) 2.80 (.110) 11.60 (.456) 2.40 (.094) 5.08 (.200) 8.00 (.314) 0.50 (.019) EPOXY 12.60 (.496) 2.40 (.094) 0.50 (.019) 3.50 (.137) 1.40 (.055) Ø15.00 (.590DIA) STRAIGHT PC TERMINALS 3.50 (.137) PANEL SWITCHES AV series 2.80 (.047) Replace 2 with 8 at the end of the model numbers shown above. CAV16COSO CAV16COSO Security pushbutton switches suitable for 250 VAC • approved according to EN 61058-1 BUSHING/ACTUATOR MATERIALS BASIC P/N CODE BUSHING ACTUATOR 00 (std) Nickel plated brass Nickel plated brass 10 Nickel plated brass Stainless steel 40 Stainless steel Stainless steel SEALING BASIC P/N Blank No sealing K Front panel sealing to IP65 OPTION K 1 2 - elastomeric membrane - external gasket CAVNONFET 5 PANEL SWITCHES AV series
AV031003C900 价格&库存
很抱歉,暂时无法提供与“AV031003C900”相匹配的价格&库存,您可以联系我们找货
AV031003C900
