AV19LB407
AV19LB407
    APEM(埃斐)
    APEM - AV19LB407 - VANDAL RESISTANT SW, SPDT, 5A, 250VAC
AV19LB407 数据手册
AV series V -A SW PANEL SWITCHES PL L 19 1 71 1 B- Security pushbutton switches • Ø 19 mm • momentary NC/NO DISTINCTIVE FEATURES Momentary NC/NO Long life Sealed to IP65 and IP69K ENVIRONMENTAL SPECIFICATIONS • Front panel sealing : IP65 and IP69K according to IEC 60529 • Operating temperature : -20 °C to +85 °C (-4 °F to +185 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 5 A 250 VAC - 5 A 125 VAC - 6.000 cycles 5 A 15 VDC - 3 A 30 VDC - 50,000 cycles • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1,000 mΩ min. at 500 VDC • Dielectric strength : 2,000 Vrms 50 Hz min. between terminals and frame GENERAL SPECIFICATIONS • Torque : 5 Nm min. - 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 9 mm (.354) max. • Low level or mechanical life : 1,000,000 cycles MATERIALS • Case : PA 6/6 • Contacts : silver • Bushing : stainless steel (std) ELECTRICAL FUNCTIONS • Actuator : stainless steel (std) APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. MOUNTING Combined NC/NO • Panel cut-out : Ø 19.2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) The company reserves the right to change specifications without notice. 3 1 2 4 CAV19LPFCT 1 Security pushbutton switches • Ø 19 mm • momentary NC/NO BUILD YOUR PART NUMBER BASIC PART NUMBER AV SERIES L BUSHING DIAMETER 19 BUSHING/ACTUATOR CONFIGURATION ACTUATOR STYLE 19 (.748) P Flat B Curved CONTACTS/TERMINALS 7 Silver contact, solder lug terminals BUSHING/ACTUATOR MATERIALS 40 (std) Stainless steel / Stainless steel 00 Nickel plated brass / Nickel plated brass 20 Chrome plated brass / Chrome plated brass ABOUT THIS SERIES Mounting accessories: standard hardware supplied : 1 hex nut and 1 O-ring. Standard and special hardware is presented in the "Hardware" section of website. Hex nut 22 (.866) across flats O-RING SOLDER LUG TERMINALS 3 1 2 Ø15.00 (.590) Ø22.00 (.866DIA) Curved actuator Ø15.00 (.590) AV19LP407 4 Flat actuator 0.50 (.019) Ø19.00X1.00 SI (.748DIAX1.00 IS) 1.50 (.059) 2.00 (.078) 3.60 (.141) Ø22.00 (.866DIA) PANEL SWITCHES AV series AV19LB407 13.10 (.515) 2 12.60 (.496) 3.60 (.141) 2.00 (.078)
AV19LB407 价格&库存
很抱歉,暂时无法提供与“AV19LB407”相匹配的价格&库存,您可以联系我们找货
