New
H SERIES SNAP-IN ROCKER SWITCHES
FEATURES
Higher power load ratings.
Single and double pole models with smooth action and tactile response.
Bezels, actuators & lenses available in a wide range of colors.
Unique double rocker design with integral illumination.
.248" (6.3mm) solder lug/quick-connect terminals.
Choice of 125 or 250 volt neon indicator lamp.
Illuminated and non-illuminated models.
SPECIFICATIONS
Contact ratings:
Electrical life:
Mechanical life:
Maximum working temperature:
16 amps (resistive) at 250VAC, 4 amps inductive at 250VAC
10,000 operations min. at full load
100,000 operations
+85°C
MATERIALS
Contacts:
Terminals:
Armature:
Actuator:
Body:
Bezel:
Lens:
90% silver, 10% cadmium
Silver plated brass
Silver plated copper
Polycarbonate or ABS
Polyester
Polycarbonate
Polycarbonate
SINGLE
POLE
MODEL NO.
DOUBLE
POLE
MODEL NO.
CIRCUIT
H11CG1R1
H12CG1R1
H21CG1R1
H22CG1R1
ON-OFF
ON-ON
Above models have silk chrome
actuator, gun metal bezel, red lens
and 125V neon lamp with resistor
wired in series (see wiring diagrams).
See order guide for other models.
B54
APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE
B
New
'BUILD YOUR OWN SWITCH' ORDER GUIDE
Fill in boxes with selections shown for complete model number.
Allowable options are shown below each respective box.
Note 'NONE' indicates box may be left empty.
Series Number
of poles
Electrical
function
Actuator
color
Bezel
color
Terminal
type
B
Lens
color
Lamp
voltage
1
H
1
2
Single
Double
1 ON/OFF
2 ON/ON
Other functions
on request
A White
B Black
C Chrome
G Gun Metal
Other colors
on request
A White
Solder lug/
Quick-connect
B Black
G Gun Metal
NONE
A Amber
G Green
R Red
Illuminated
switches only.
NONE
1 125V
2 250V
Illuminated
switches only.
Example of completely specified
model number:
H11BB1R1
WIRING DIAGRAMS
Illuminated single pole
Non-illuminated single pole
Illuminated double pole
Non-illuminated double pole
PANEL CUT-OUT & MINIMUM RECOMMENDED SPACING FOR ADJACENT SWITCHES
B55
很抱歉,暂时无法提供与“H21CG1”相匹配的价格&库存,您可以联系我们找货
