IB and IS series
Sealed pushbutton switches - bushing Ø 12 mm - momentary
Distinctive features and specifications
UG1410-A-R1
❑ Snap-in and threaded bushing models
❑ Compact, light in weight
• Behind-panel depth of 13 mm (.512) only
• 50 % reduction in weight compared to metallic models
❑ Tactile feedback
❑ Sealed to IP67 (IS series) or IP54 (IB series)
B1
ENVIRONMENTAL SPECIFICATIONS
MATERIALS
• Front panel sealing according to IEC 60529 : IP67 (IS) or IP54 (IB)
• Shock resistance : 100 g according to IEC 512-4, test 6c
• Vibration resistance : 10-500 Hz - 10 g according to IEC 512-4, test 6d
• Salt spray : IEC 512-6, test 11f
• Operating temperature : -40°C to +85°C
• Case : thermoplastic UL94-V0
• Actuator : polyamide 6/6
• Bushing/bezel : polyamide 6/6
• Contacts : silver, gold plated
• Terminal seal : epoxy
ELECTRICAL SPECIFICATIONS
AGENCY APPROVAL
• Max. current/voltage rating with resistive load :
400mA 32VAC - 100mA 48VDC
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1 GΩ min. at 500VDC
• Dielectric strength : 1.000 Vrms
• Electrical life at full load : 500.000 cycles
2A 125VAC/250VAC
File E83438
Availability : consult factory for
details of approved models.
Marking : to order switches marked
UL, complete approrpiate box of
ordering format.
GENERAL SPECIFICATIONS
• Panel thickness :
- IB series : 0,8 mm (.031) min. - 1,8 mm ( .071) max.
- IS series : 1,5 mm (.059) min. - 4 mm (.157) max.
• Total travel : 1,7 mm (.066) +/- 0,3 mm
• Typical operating force : 4N +/- 3N
• Low level or mechanical life : 1.000.000 cycles
• Torque (applied to nut) : 1 Nm max. with metal nut U166
1,5 Nm max. with plastic nut U4248
• Soldering : 300°C max. for 3 seconds
itch:
m sw s.
o
t
s
u
f c e serie
ple o
h
Exame end of t
se
Panel mounting : see next pages.
The company reserves the right to change specifications without notice.
APEM
www.apem.com
B1-25
IB and IS series
Overview
SERIES
IB Snap-in
IS Threaded
bushing
Actuator shapes
R
P
Round, curved
Round, flat
3
Electrical function
Terminals
Normally open
(NO)
S Solder lug
P Straight PC
Z1 Quick-connect
2,8 x 0,5 mm
Contacts
AD Silver, gold
plated
B1
Actuator colours
1
B
2
3
4
5
6
7/1
8
9
A
Blue
Dark blue
Black
Green
Grey
Yellow
Red
White
Bright chrome
Orange
Satin chrome
Bezel finish
00
08
10
Black (std)
Bright chrome
(IS only)
White
Satin chrome
(IS only)
Option
104
High actuator
Approval
UL
Consult factory for
detail of approved
models.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches and options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
A sealing boot is available to protect the switches against frost and sand. It is presented after the IA series and in section H.
Mounting accessories : Standard hardware supplied : 1 flat seal (IB series)
1 metal hex nut 14 mm (.551) across flats, part number U166, and 1 flat seal (IS series).
Plastic nut 17 mm (.669) across flats, thickness 4 mm (.157) available on request. Part number U4248.
Packaging unit : 50 pieces
B1-26
www.apem.com
APEM
IB and IS series
• Ten actuator colours
• Curved or flat actuator
• Antirotation bushing
Solder lug S
Quick-connect Z1
3.40
(.133)
1.00
(.039)
1.50
(.059)
1.20
(.047)
1.20
(.047)
2.80
(.110)
2.80
(.110)
Function 3 (NO)
MODEL
STRUCTURE
8.40
(.330)
2.40
(.094)
Straight P
CISCOS-A
CISCOSP
ECH: 0.9
ECH: 0.9
Actuator marking available on IBP and
ISP models (symbol 10 mm max.). On request.
5-05-03
Snap-in mounting - solder lug terminals
5-05-03
CISCOSZ-A
Ø17.50
(.688DIA)
Normally open
1.20
(.047)
Flat actuator
IBP3SAD
5.00
(.196)
Normally open
DESSIN ECH 0.9
5-05-03
3.20
(.125)
13.00
(.511)
Curved actuator
IBR3SAD
2.00
(.078)
Ø12.00
(.472DIA)
0.50
(.019)
2.80
(.110)
EPOXY
5.08
(.200)
Also available with straight PC : IB•3PAD or quick-connect terminals : IB•3Z1AD
Panel thickness : 1,5 mm to 4 mm
Flat
Mounting by threaded bushing - solder lug terminals ➞
Ø17.50
(.688DIA)
5.60
(.220)
Normally open
1.20
(.047)
Flat actuator
ISP3SAD
5.00
(.196)
Normally open
13.00
(.511)
Curved actuator
ISR3SAD
2.00
(.078)
Ø12.00
(.472DIA)
3.20
(.125)
0.50
(.019)
5.08
(.200)
2.80
(.110)
EPOXY
Ø12.00x0.75SI
(.472DIAx0.75IS)
Also available with straight PC : IS•3PAD or quick-connect terminals : IS•3Z1AD
ACTUATOR COLOURS
Actuator marking available on IBP and ISP models (symbol 10 mm max.). On request.
1 : blue - B : dark blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7/1 : white - 8 : bright chrome
9 : orange - A : satin chrome
BUSHING AND BEZEL FINISH
00 : Black (standard)
08 : Bright chrome (IS series only)
10 : White
20 : Satin chrome (IS series only)
APEM
B1
Panel thickness : 0,8 mm to 1,8 mm
Flat
www.apem.com
B1-27
IB and IS series
Ø12.00
(.472DIA)
4.70
(.185)
Ø12.00
(.472DIA)
ACTUATOR OPTION
4.70
(.185)
104 : High actuator
IBR
IBP
APPROVAL
UL
Availability : consult factory for details of approved models.
Marking : to order switches marked UL, complete above box with ”UL”.
IB SERIES MOUNTING
Panel cut-out
18.00
(.709)
1.80 MAXI.
(.071MAX.)
12.90
(.507)
Matrix mounting
0.80 MINI.
(.031MIN.)
18.00
(.709)
18.00
(.709)
Ø13.60
(.535DIA)
IS SERIES MOUNTING
Matrix mounting
12.90
(.507)
1
Ø13.60
(.535DIA)
➀ Flat seal
20.00
(.787)
20.00
(.787)
20.00
(.787)
Panel cut-out
1.50min-4Max
(.059MIN.-.157MAX.)
B1
Ø13.50
(.531DIA)
Example of custom switch
• Painted bushing and actuator, soft feel
• Flying leads (55 mm) + connector
• Overmolded rear part
ISR3FADB22X1248-01
B1-28
www.apem.com
APEM
很抱歉,暂时无法提供与“IBR3SADB00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+139.64956
- 10+135.46320
- 50+131.26642
- 100+128.55882
- 250+126.09074
