13445A9GX768
13445A9GX768
    APEM(埃斐)
    SWITCH PUSHBUTTON DPDT 4A 125V
13445A9GX768 数据手册
10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page44 13000 series Professional quick-break momentary pushbutton switches Distinctive features and specifications ❑ PC and panel mount models ❑ Bushing Ø 6,35 (1/4) and 11,9 (15/32) ❑ UL and CECC approved B2 ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A-AD2) : 4A 30VDC - gold plated contacts (CD) : 100mA 30V • Minimum load (AD2-CD contacts) : 10mA 50mV, 10µA 5V min. • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between poles and between terminals and frame • Contact bounce : 2 ms max. • Electrical life : Contacts Max. current/voltage rating Number of cycles A 4A 30VDC 50.000 AD2 4A 30VDC (gold plating : 100mA 30VDC max.) 20.000 CD 100mA 30VDC 50.000 Low level or mechanical life MATERIALS 150.000 GENERAL SPECIFICATIONS • Case : diallylphthalate (DAP) • Actuator : brass, nickel plated • Bushing : brass, nickel plated • Housing : brass, nickel plated • Contacts : A : silver AD2 : silver, gold plated (2 micron gold) CD : brass, gold plated • Terminal seal : epoxy • Torque : 1,25 Nm (.922 Ft.lb) max. applied to nut • Standard panel thickness : 2 mm (.078 ) max. • Total travel : 2 mm (.078) • Operating temperature : -40°C to +85°C Note : AD2 contacts can be used for high level applications.In this case, the gold layer is considered only as a protection against oxidation during storage. B2-44 www.apem.com APEM 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page45 13000 series Professional quick-break momentary pushbutton switches Specifications RELIABILITY - RUN-IN TEST Upon request, each individual switch can be submitted to a low level run-in test of 50 or 250 cycles to ensure suitability for special applications requiring a very high level of reliability (military, space,etc.). AGENCY APPROVALS 2A 125VAC/250VAC CECC 96401-001 Designed to MIL specifications B2 Availability : UL : all models with silver or gold plated silver contacts CECC : consult factory for details of approved models. Marking : to order switches marked UL or CECC, complete appropriate box of ordering format. Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Sealing boots are available to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware available are presented in section I. Packaging unit : 50 pieces. APEM www.apem.com B2-45 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page46 13000 series Professional quick-break momentary pushbutton switches Overview 13 Terminals and bushing SERIES 2 4 B2 Straight PC terminals, bushing Ø 6,35 (1/4) Solder lugs, bushing Ø 6,35 (1/4) or 11,9 (15/32) Right angle terminals, bushing Ø 6,35 (1/4) Contact materials A AD2 CD No of poles 3 4 Single pole Double pole Electrical function 5 ON Finish Blank Solder lugs or straight PC depending on model W Right angle, horizontal mounting MOM Caps Special options Blank Bright chrome finish G Black finish on bushing, plunger and hardware Silver Silver, gold plated (2 micron gold) Brass, gold plated - Terminals Blank X640 X768 No special requirement Reinforced sealing by three O-rings Bushing Ø 11,9 (15/32) + front panel sealing (double pole only) U900 U1140 U1720 U480 U630 U2430 U2020 Ø 5 (.196) Ø 8 (.314) Ø 9,4 (.370) Ø 10 (.393) std Ø 15 (.590) Square, height 4 (.157) Square, height 6 (.236) For models with Ø 4 (.157) plunger only. Plungers Sealing Blank Standard for Ø 6,35 (1/4) bushing -4 -9 4 mm (.157) long, for Ø 11,9 (15/32) bushing (X768) 9 mm (.354) long, for Ø 11,9 (15/32) bushing (X768) Blank Epoxy sealed terminals standard K Front panel sealing by one O-ring and sealing washer Reinforced sealing, see X640 under "Special options". Approvals UL CECC Availability : Consult factory for details of approved models. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as in above chart B2-46 www.apem.com APEM 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page47 13000 series Professional quick-break momentary pushbutton switches Solder lug terminals : 13400 - Straight PC terminals : 13200 • Threaded bushing Ø 6,35 mm (1/4) • Epoxy sealed terminals standard 1.20 (.047) 1 2 3 9.50 (.374) 5.00 (.196) 1.70 (.066) ➞ Keyway 2.50 (.098) 1.00 (.039) MODEL STRUCTURE B2 MOM ON 1 MOM EPOXY 2 3 13.40 (.527) ON 14.00 (.551) 4.00 (.157) 2.50 (.098) 5.00 (.196) 1-2 0.70 (.027) Double pole 13445 1-3 6.30 (.248) Single pole 13435 6.00 (.236) Ø4.00 (.157 DIA) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) ➞ Keyway Solder lug terminals : 13400 0.50 (.019) 6.00 (.236) 1-3 14.00 (.551) 4.00 (.157) Ø4.00 (.157 DIA) 6.00 (.236) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) ➞ Keyway Straight PC terminals : 13200 1-2 Single pole 13235 ON MOM Double pole 13245 ON MOM 2 3 13.40 (.527) 1 0.70 (.027) 6.30 (.248) Ø1.6 (.062 DIA) 6.00 (.236) EPOXY 0.50 (.019) 6.00 (.236) 4.00 (.157) 4.00 (.157) 9.50 (.374) 1.00 (.039) PANEL CUT-OUT 13400 - 13200 Ø2.20 (.086 DIA) 5.20 (.204) 2.70 (.106) Standard APEM Ø6.50 (.255 DIA) Ø6.50 (.255 DIA) 1.10 (.043) Ø6.50 (.255 DIA) With K sealing option 2.70 (.106) With X640 sealing option www.apem.com B2-47 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page48 13000 series Professional quick-break momentary pushbutton switches Right angle terminals : 13400W 1-2 MOM Ø4.00 (.157 DIA) Ø1.6 (.062 DIA) 4.40 (.173) EPOXY 2 3 13.40 (.527) 1 0.70 (.027) 5.90 (.232) 2.60 (.102) 9.27 (.364) 1.00 (.039) 4.00 (.157) 5.08 (.200) 9.27 (.364) 0.40 (.015) 1-3 ON 13435W 6.00 (.236) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) ➞ Keyway Right angle terminals - single pole 4.00 (.157) 4.00 (.157) 0.50 (.019) 14.20 (.559) B2 Panel cut-out, see previous page. CONTACT MATERIALS A AD2 CD Silver Silver, gold plated (2 micron gold) Brass, gold plated PLUNGER Dash compulsory before plunger code. Blank Standard plunger for Ø 6,35 (1/4) bushing -4 4 mm (.157) long plunger for Ø 11,9 (15/32) bushing (X768 option) -9 9 mm (.354) long plunger for Ø 11,9 (15/32) bushing (X768 option) B2-48 www.apem.com APEM 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page49 13000 series Professional quick-break momentary pushbutton switches FINISH Blank Bright chrome finish G Black finish on bushing, actuator and hardware SEALING Ø10.60 (.417 DIA) Front panel sealing by one O-ring and sealing washer. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. Reinforced sealing : see X640 under "Special options". 1 2.00 Maxi (.078 MAX) Ø11.80 (.464 DIA) 2 Ø5.80 (.228 DIA) ➀ O-ring ➁ Sealing washer Ø6.40 (.251 DIA) K 2.30 (.090) B2 X640 Front panel sealing by three O-rings. Flatted bush for precise orientation. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. 4.00 Maxi (.157 MAX) SPECIAL OPTIONS Available on models with Ø 6,35 (1/4) bushing only. X935 APEM ➀ O-rings C-ring on plunger for positive stop www.apem.com X640 1 B2-49 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page50 13000 series Professional quick-break momentary pushbutton switches X768 Sealed switch with Ø 11,9 (15/32) flatted bushing. Chrome plated actuator. Solder lug terminals, double pole. Contact and finish options available. Security cap for this model : see section I. ➞ Flat ON MOM 3 2 1 9.00 (.354) With long plunger 13445 -9 X768 7.50 (.295) MOM Ø12.00 (.472 DIA) 1.50 (.059) ON Ø11.9 32UNS (.468-32UNS) 1-2 EPOXY 6.00 (.236) 5.00 (.196) B2 1-3 With short plunger 13445 -4 X768 Ø8.00 (.314 DIA) 14.20 (.559) 4.00 (.157) Ø8.00 (.314 DIA) 4.00 (.157) 2.50 (.098) 5.10 (.200) 0.50 (.019) Short (-4) Long (-9) AGENCY APPROVALS UL CECC CECC 96401-001 Availability : UL : all models with silver or gold plated silver contacts CECC : consult factory for details of approved models. Marking : to order switches marked UL or CECC, please complete above box with desired approval. Blank : no agency approval required. B2-50 www.apem.com APEM 10-Serie 13000-A_13-Serie 13000-A 21/11/12 14:59 Page51 13000 series Professional quick-break momentary pushbutton switches CAPS + U... Ø8.00 (.314) U900 3.00 (.118) 6.35 (.250) Ø9.40 (.370) 6.35 (.250) 3.00 (.118) 4.00 (.157) 3.30 (.129) Ø5.00 (.196) U1140 U1720 B2 Ø15.00 (.590 DIA) Ø10.00 (.393) Cap colours 3.00 (.118) 3.00 (.118) 10.00 (.393) 7.50 (.295) For models with Ø 6,35 (1/4) bushing only. U480 Standard Replace last "0" by number U630 11.50x11.50 (.452 SQ) U2020 Square 4.00 (.157) 3.00 (.196) 11.50x11.50 (.452 SQ) 6.00 (.236) 5.00 (.195) 1 1/4 2 3 4 5 6 7 7/1 9 U2430 Square blue dark blue black green grey yellow red ivory white orange DRESS NUTS Chrome plated U1636 For cap U1140 Ø18.50 (.728 DIA) Ø10.50 (.413 DIA) Ø15.50 (.610 DIA) 5.80 (.228) Ø13.50 (.531 DIA) Ø6.35-40UNS (1/4-40UNS) 8.00 (.314) 8.00 (.314) 8.20 (.322) Ø8.20 (.322 DIA) 6.20 (.244) Ø12.70 (.500 DIA) 5.80 (.228) For models with Ø 6,35 (1/4) bushing only. Ø6.35-40UNS (1/4-40UNS) Ø6.35-40UNS (1/4-40UNS) U840 For cap U480 U825 For cap U630 Dress nuts are to be ordered separately. APEM www.apem.com B2-51
13445A9GX768 价格&库存
很抱歉,暂时无法提供与“13445A9GX768”相匹配的价格&库存,您可以联系我们找货
