05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page14
25000N series
Professional slide switches
Distinctive features and specifications
UG1410A
❑ Professional grade slide switches for PC boards
❑ Approved according to UL 1054
❑ Wave solderable
Not washable in aqueous process
❑ Available with flush, high and side actuator
❑ Various actuator lengths
ELECTRICAL SPECIFICATIONS
E
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 1A 30VDC
- gold plated brass contacts (LD) : 100mA 30VDC
• Minimum load :
- silver contacts (A) : 100mA 10V
- gold plated brass contacts (LD) : 10µA 5VDC - 10mA 50mV
• Initial contact resistance :
- silver contacts (A) : 10mΩ max.
- gold plated brass contacts (LD) : 50mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
1.000 Vrms 50 Hz min. between terminals
2.000 Vrms 50 Hz min. between poles
2.000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 10.000 cycles at full load
• Low level or mechanical life : 20.000 cycles
APPROVALS
2A 250VAC
4A 125VAC
Availability : consult factory for details of approved models.
Marking : To order switches marked UL, complete the “Options and
Approvals” box of ordering format.
MATERIALS
• Case : PBT
• Actuator : polyamide, glass
filled
• Cover : polyamide, glass filled
• Contacts
A : silver
LD : brass, gold plated
• Terminal seal : epoxy
GENERAL SPECIFICATIONS
• Operating temperature :
-40°C to +85°C
• Overall length : 14 mm (.551)
• Actuator height (outside case) :
- high : 2,80 mm (.110)
- extra high : 6 mm (.236)
- side : 2,3 mm (.090)
- long side : 6 mm (.236)
• Travel : 4 mm (.157)
The company reserves the right to change specifications without notice.
E-14
www.apem.com
APEM
05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page15
25000N series
Overview
N
25
Actuator and terminals
SERIES
1
4
3
5
Flush or high actuator,
terminal spacing
2,54 (.100)
terminal spacing
5,08 (.200)
Side actuator, terminal
spacing 2,54 (.100)
spacing 5,08 (.200)
Number of poles
3
4
Single pole
Double pole
Contact materials
A Silver
LD Gold plated brass
Electrical functions
6
9
Actuator
B
H
H6
Blank
-6
Flush
High
Extra high
Side
Long side
ON
ON
OFF
Version
N
For all models
ON
ON
Options and approvals
X601
Special contact :
lower rating
Other : see following pages.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches (including actuator options)
- contact options
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Packaging unit : single pole : 100 pieces - double pole : 50 pieces
APEM
www.apem.com
E-15
E
05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page16
25000N series
• Epoxy sealed terminals standard
• 1 and 2 pole configurations
• UL approved models : see next page.
MODEL
STRUCTURE
Double pole
25446N H
25449N H
Extra high actuator : 25000NH6
E-16
Terminal spacing
2,54 (.100)
Terminal spacing
5,08 (.200)
Single pole
25136N H6
25139N H6
Single pole
25436N H6
25439N H6
Double pole
25146N H6
25149N H6
Double pole
25446N H6
25449N H6
www.apem.com
3.00
(.118)
3.00
(.118)
0.60
(.023)
7.50
(.295)
0.60
(.023)
2.54
(.100)
Shown with 5,08 mm terminal spacing
14.10
(.555)
0.50
(.019)
5.08
(.200)
12.50
(.465)
5.08
(.200)
Double pole
25146N H
25149N H
5.08
(.200)
Ø1.10
(.043DIA)
EPOXY
0.60
(.023)
5.08
(.200)
Single pole
25436N H
25439N H
5.08
(.200)
5.08
(.200)
5.08
(.200)
14.10
(.555)
3.00
(.118)
0.50
(.019)
5.08
(.200)
12.50
(.465)
3.00
(.118)
5.08
(.200)
Single pole
25136N H
25139N H
0.60
(.023)
Ø1.10
(.043DIA)
EPOXY
0.60
(.023)
5.08
(.200)
Terminal spacing
5,08 (.200)
2.54
(.100)
EPOXY
2.80
(.110)
Terminal spacing
2,54 (.100)
7.50
(.295)
0.50
(.019)
6.00
(.236)
High actuator : 25000NH
0.60
(.023)
8.10
(.318)
Double pole
25446N B
25449N B
Ø1.10
(.043DIA)
8.10
(.318)
Double pole
25146N B
25149N B
12.50
(.465)
8.10
(.318)
Single pole
25436N B
25439N B
14.10
(.555)
3.80
(.149)
Single pole
25136N B
25139N B
7.50
(.295)
3.80
(.149)
Terminal spacing
5,08 (.200)
3.80
(.149)
E
Terminal spacing
2,54 (.100)
2.54
(.100)
Shown with 2,54 mm terminal spacing
Flush actuator : 25000NB
5.08
(.200)
5.08
(.200)
APEM
05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page17
25000N series
Double pole
25546N
25549N
0.60
(.023)
0.50
(.019)
5.08
(.200)
5.08
(.200)
Double pole
25346N -6
25349N -6
Double pole
25546N -6
25549N -6
PCB MOUNTING
6.00
(.236)
Ø1.10
(.043DIA)
8.10
(.318)
3.00
(.118)
0.60
(.023)
12.50
(.465)
0.50
(.019)
2.54
(.100)
EPOXY
2.54
(.100)
Single pole
25536N -6
25539N -6
3.00
(.118)
14.10
(.555)
0.60
(.023)
2.54
(.100)
Single pole
25336N -6
25339N -6
7.50
(.295)
4.30
(.169)
Terminal spacing
5,08 (.200)
5.08
(.200)
5.08
(.200)
E
POSITIONS AND CONNECTIONS
7.50
(.295)
2.30
(.090)
7.50
(.295)
2
6.00
(.236)
1 1
2 2
1 1
2 2
1 1
10.80
(.425)
14.10
(.555)
8.10
(.318)
0.60
(.023)
EPOXY
2.54
(.100)
3.80
(.149)
Terminal spacing
2,54 (.100)
H
Ø1.10
(.043DIA)
Long side actuator : 25000N-6
B
2.30
(.090)
2.54
(.100)
Double pole
25346N
25349N
12.50
(.465)
2.54
(.100)
Single pole
25536N
25539N
3.00
(.118)
14.10
(.555)
6.00
(.236)
Single pole
25336N
25339N
7.50
(.295)
3.80
(.149)
Terminal spacing
5,08 (.200)
1.30
(.051)
Terminal spacing
2,54 (.100)
8.10
(.318)
Side actuator : 25000N
H6
6
Function 6
Function 9
ON
ON
OFF
ON
ON
CONTACT MATERIALS
A
LD
Silver
Brass, gold plated
OPTIONS AND APPROVALS
X601
X693
X693UL
APEM
Silver plated brass contacts - Lower rating 3VA 30VDC. Min quantity : 5.000 pieces per model and shipment.
Flame retardant plastic materials
Switches approved and marked UL (silver contacts only)
www.apem.com
E-17
很抱歉,暂时无法提供与“25146NAB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+58.78646
- 40+57.72245
- 50+54.43370
- 100+29.21187
- 500+23.97646
- 1000+20.77235
- 2500+20.50634
- 5000+17.76169
