8646ADGB6X923+U3631
8646ADGB6X923+U3631
    APEM(埃斐)
    8646ADGB6X923+U3631
8646ADGB6X923+U3631 数据手册
07-Serie 8000-A_11-Serie 8000-A 31/10/14 09:08 Page28 8000 series Momentary or alternate action pushbutton switches Distinctive features and specifications UG1410A ❑ Bushing Ø 6,35 (1/4) and Ø 11,9 (15/32) ❑ UL approved B2 ELECTRICAL SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : - silver contacts : 4A 30VDC - gold plated contacts : 0,4VA max. 20VAC or DC • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 30.000 cycles at full load GENERAL SPECIFICATIONS • Torque : 1,25 Nm (.922 Ft.lb) max. applied to nut • Total travel : 2,70 mm (.106) • Operating temperature : -40°C to +85°C • Case : diallylphthalate (DAP) • Actuator : brass, nickel plated • Bushing : brass, nickel plated • Housing : stainless steel • Contacts A : silver AD : silver, gold plated CD : brass, gold plated • Terminal seal : epoxy AGENCY APPROVAL 3A 250VAC, 6A 125VAC Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete appropriate box of ordering format. The company reserves the right to change specifications without notice. B2-28 www.apem.com APEM 07-Serie 8000-A_11-Serie 8000-A 04/11/14 14:39 Page29 8000 series Momentary or alternate action pushbutton switches Overview 8 SERIES Terminals and bushings 4 6 Straight PC or right angle terminals Solder lug terminals Number of poles 3 4 Electrical functions Single pole Double pole 2 6 ON ON - MOM ON All models with Ø 6,35 (1/4) or Ø 11,9 (15/32) threaded bushing. Terminals Blank W Solder lugs or straight PC depending on model Right angle B2 Order separately. Contact materials A Silver AD Silver, gold plated CD Brass, gold plated Sealing Special options Blank No sealing B Epoxy sealed terminals K Front panel sealing by O-ring and sealing washer X718 Bushing Ø 11,9 (15/32) X934 Flatted bushing Ø 11,9 (15/32) + front panel sealing Caps U900 U1140 U1720 U480 U630 U2430 Other, see following pages. U2020 Plungers For bushing Ø 6,35 (1/4) Blank Height 6,3 (.248) -9 Height 8,8 (.346) For bushing Ø 11,9 (15/32) Blank Height 8,6 (.338) -6 Height 7 (.275) Ø 5 (.196) Ø 8 (.314) Ø 9,4 (.370) Ø 10 (.393) Standard Ø 15 (.590) Square Height 4 (.157) Square Height 6 (.236) Approval UL Availability : Consult factory for details of approved models. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Sealing boots are available to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware available are presented in section I. Packaging unit : 50 pieces, except 8000W (25 pieces). APEM www.apem.com B2-29 07-Serie 8000-A_11-Serie 8000-A 31/10/14 09:08 Page30 8000 series Momentary or alternate action pushbutton switches Threaded bushing Ø 6,35 (1/4) 1 2 3 Funct. 6 (ON-ON) 2 3 1 2 Funct. 2 (ON-MOM) 4.00 (.157) 1.10 (.043) 1.80 (.070) 3 1.10 (.043) MODEL STRUCTURE Shown with standard plunger ➞ Keyway MOM ON 2-3 5-6 1-2 4-5 ON ON MOM ON 4.75 (.187) 0.80 (.031) 1 2 3 0.50 (.019) 4.00 (.157) 12.00 (.472) ➞ Keyway Right angle terminals - horizontal : 8400W B2-30 MOM ON www.apem.com 4.00 (.157) 5.08 (.196) 12.00 (.472) 3.70 (.145) 0.80 (.031) 4.00 (.157) 3 2 1 0.50 (.019) Ø1.60 (.062 DIA) 4.00 (.157) 8.60 (.338) ON ON Ø4.00 (.157 DIA) 11.00 (.433) 1-2 4-5 0.40 (.015) 2-3 5-6 4.75 (.187) Ø10.00 (.393 DIA) 8.60 (.338) MOM ON 1.10 (.043) Double pole 8442W 8446W ON ON 12.70 (.500) Single pole 8432W 8436W 1-2 1.10 (.043) 7.00 (.275) 13.20 (.519) 7.00 (.275) 6.30 (.248) Ø6.35-40UNS (1/4-40UNS) 2-3 Ø1.60 (.062 DIA) 4.00 (.157) ON ON Ø4.00 (.157 DIA) 19.50 (.767) 1-2 Ø10.00 (.393 DIA) 13.20 (.519) 7.20 (.283) 2-3 7.00 (.275) 7.20 (.283) Double pole 8442 8446 Ø6.35-40UNS (1/4-40UNS) 4.00 (.157) Straight PC terminals : 8400 Single pole 8432 8436 4.00 (.157) 12.00 (.472) 1.80 (.070) 12.70 (.500) MOM ON 1 2 3 0.50 (.019) 0.80 (.031) 12.00 (.472) 3.70 (.145) 3.81 12.70 (.150) (.500) ON ON 4.75 (.187) 12.70 (.500) 1-2 4-5 18.20 (.716) 2-3 5-6 3.70 (.145) MOM ON 7.20 (.283) ON ON Ø4.00 (.157 DIA) 7.00 (.275) 1-2 6.30 (.248) Double pole 8642 8646 2-3 Ø10.00 (.393 DIA) 13.20 (.519) 7.00 (.275) Single pole 8632 8636 Ø6.35-40UNS (1/4-40UNS) 6.30 (.248) ➞ Solder lug terminals : 8600 Keyway 3.81 (.150) B2 1 5.30 (.208) 3.70 (.145) 1.90 (.074) • Solder lug, straight PC or right angle terminals • 1 and 2 pole configurations • Button returns in upper position after actuation. ➞ Keyway 5.08 (.200) Ø1.60 (.062 DIA) 4.00 (.157) APEM 07-Serie 8000-A_11-Serie 8000-A 31/10/14 09:08 Page31 8000 series Momentary or alternate action pushbutton switches PANEL CUT-OUT Ø2.20 (.086 DIA) 5.20 (.204) Standard Ø6.50 (.255 DIA) 2.70 (.106) 1.10 (.043) Ø6.50 (.255 DIA) With K sealing option B2 CONTACT MATERIALS A AD CD Silver Silver, gold plated Brass, gold plated B Epoxy sealed terminals K Front panel sealing by one O-ring and sealing washer. Protects the switch against water and dust. Panel seal withstands 1 bar pressure. KB Combined sealings Ø10.60 (.417 DIA) 1 Ø11.80 (.464 DIA) 2 Sealing boot : see section H. 5.80 (.228) Ø6.40 (.251 DIA) No sealing 2Maxi (.078 Max) Blank 2.30 (.090) SEALING ➀ O-ring ➁ Sealing washer APEM www.apem.com B2-31 07-Serie 8000-A_11-Serie 8000-A 31/10/14 09:08 Page32 8000 series Momentary or alternate action pushbutton switches PLUNGERS For Ø 6,35 (1/4) bushing Ø4.00 (.157 DIA) Ø4.00 (.157 DIA) 14.20 (.559) 7.00 (.275) Blank Standard -9 For Ø 11,9 (15/32) bushing (X718 models) Ø11.90-32UNS (15/32-32UNS) Ø6.40 (.251DIA) Ø4.00 (.157 DIA) 12.00 (.472) 7.00 (.275) 8.50 (.334) Ø11.90-32UNS (15/32-32UNS) 12.00 (.472) -6 Blank SPECIAL OPTIONS X601 Silver plated brass contacts Current/voltage rating for an electrical life of 20.000 cycles : 0,5A 30VDC. Minimum quantity : 5.000 pieces per model and shipment. ➞ Keyway or flat X748 Ø11.90-32UNS (15/32-32UNS) Ø12.50 (.492 DIA) Ø3.50 (.137 DIA) 9.60 (.377) 1 2 3 5.10 (.200) X718 Snap-in mounting. Consult factory Panel cut-out 15 x 12,5 (.59 x .492) Ø6.40 (.251) 7.00 (.275) www.apem.com 2 3 8 Maxi (.314 MAX) 1.50 (.059) 1 B2-32 Ø12.00 (.472 DIA) 10.50 (.413) Flatted bushing Ø 11,9 (15/32) + sealing by two O-rings (for plunger -6 only). Epoxy sealed terminals. Ø11.90-32UNS (15/32-32UNS) 12.50 (.492) X934 Ø12.00 (.472 DIA) 1.70 (.066) Ø4.00 (.157) 8.60 (.338) Bushing Ø 11,9 (15/32) For all basic models (solder lug straight PC or right angle terminals) Available with plungers 13 and 6. K sealing option available. 12.00 (.472) X718 11.00 (.433) B2 7.00 (.275) 14.20 (.559) 8.80 (.346) 6.30 (.248) Dash compulsory before plunger code. Ø6.35-40UNS (1/4-40UNS) Ø6.35-40UNS (1/4-40UNS) EPOXY 5.10 (.200) X934 APEM 07-Serie 8000-A_11-Serie 8000-A 31/10/14 09:08 Page33 8000 series Momentary or alternate action pushbutton switches APPROVAL UL Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete above box with ”UL”. CAPS Order separately. The caps below are for Ø 4 mm plungers (standard and -9), except U2600. Ø15.00 (.590 DIA) Cap colours Replace last "0" by number 10.00 (.393) U630 1 1/4 2 3 4 blue dark blue black green grey 11.50x11.50 (.452 SQ) U2430 Square 6.00 (.236) Ø13.00 (.511 DIA) 6.00 (.236) 5.00 (.195) 4.00 (.157) 11.50x11.50 (.452 SQ) 5 yellow 6 red 7 ivory 7/1 white 9 orange U2020 Square 3.00 (.118) U480 Standard 3.00 (.118) 3.00 (.118) 7.50 (.295) Ø10.00 (.393) 6.35 (.250) U1720 3.00 (.118) 6.35 (.250) 3.00 (.118) 4.00 (.157) 3.30 (.129) U1140 3.00 (.196) Ø9.40 (.370) Ø8.00 (.314) Ø5.00 (.196) U900 B2 U2600 For large plunger -6 only. DRESS NUTS Chrome plated. Order separately. U1636 For cap U1140 APEM 8.00 (.314) 8.00 (.314) Ø6.35-40UNS (1/4-40UNS) Ø10.50 (.413 DIA) 5.80 (.228) Ø15.50 (.610 DIA) 6.20 (.244) 8.20 (.322) Ø8.20 (.322 DIA) Ø13.50 (.531 DIA) Ø18.50 (.728 DIA) 5.80 (.228) Ø12.70 (.500 DIA) Ø6.35-40UNS (1/4-40UNS) Ø6.35-40UNS (1/4-40UNS) U825 U840 For cap U630 For cap U480 www.apem.com B2-33
8646ADGB6X923+U3631 价格&库存
很抱歉,暂时无法提供与“8646ADGB6X923+U3631”相匹配的价格&库存,您可以联系我们找货
