FPAR3D1432B1X
FPAR3D1432B1X
    APEM(埃斐)
    APEM - FPAR3D1432B1X - Industrial Pushbutton Switch, FP, 24.2 mm, SPST-NO, Momentary, Round, Green
FPAR3D1432B1X 数据手册
FP series Fully illuminated pushbutton switches - momentary or latching Distinctive features and specifications ❑ Suited for integrated designs ❑ Large but lightweight ❑ Pad printed or laser etched symbols ❑ Full actuator or symbol illumination, adaptable to design requirements Pad printing Laser Non-illuminated Illuminated ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 200mA 12VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. • Electrical life at full load : 300.000 cycles GENERAL SPECIFICATIONS MATERIALS • Case : stanyl PA46 • Actuator : PA12 • Bushing/ bezel : PA66 • Contacts : silver, gold plated (code 4) • Multi-wire lead AWG22 • Terminal seal : epoxy or termelt overmolding • Panel thickness : 1(.039) to 18 mm (.708) max. • Total travel : 2,8 mm ± 0,5 mm • Typical operating force : 8N ± 2N • Mechanical life : 1 million cycles • Torque : 3 Nm max. applied to nut • Operating temperature : -40°C to +75°C Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. Tolerance : The general tolerance for dimensions in this brochure is ± 0,3 (.012). Dimensions, specifications and data shown in this brochure are subject to change without notice. 2 www.apem.com APEM FP series Fully illuminated pushbutton switches - momentary or latching Overview FP SERIES P R Model A Actuator Electrical function Round, flat Round, curved 1 3 Threaded bushing, dia. 24 mm Terminals OFF - ON Normally open (NO) Solder lugs Straight cable Right angle cable, length 300 mm 1 2 3 LED control and No of poles A B C D Contact mat. 4 Silver, gold plated Silver on request. Actuator colour 1 2 3 4 5 6 7 9 A B Blue Black Green Grey Yellow Red White/natural Orange Maroon Black lacquered Bezel colour 1 2 3 4 5 6 7 Blue Black Green Grey Yellow Red White/natural Non-illuminated, 1 pole Non-illuminated, 2 poles Independent, 1 pole Independent, 2 poles LED colour X A B C D E F G Non-illum. Blue Green Red Yellow White Red/green Red/blue Symbols LED resistor 0 1 2 3 No resistor supplied 12V resistor 24V resistor 48V resistor See end of series Marking X 1 2 No marking Pad printing Laser ABOUT THIS SERIES On the following pages, you will find successively : model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : 1 hex nut and 1 O-Ring Packaging unit : solder lug versions : 20 pieces - cable versions : 1 piece APEM www.apem.com 3 FP series Fully illuminated pushbutton switches - momentary or latching Mounting by Ø 24 mm threaded bushing • Three terminal types • Curved or flat actuator To order a product, replace • with one of the codes selected under “LED control and number of poles” on next page, then add he desired options. MODEL STRUCTURE Solder lug terminals LATCHING Curved actuator FPAR1•1 Flat actuator FPAP1•1 OFF - OFF ON ON MOMENTARY (NO) Curved actuator FPAR3•1 Flat actuator FPAP3•1 Straight cable terminals LATCHING Curved actuator FPAR1•2 Flat actuator FPAP1•2 OFF - OFF ON ON MOMENTARY (NO) Curved actuator FPAR3•2 Flat actuator FPAP3•2 Right angle cable terminals LATCHING Curved actuator FPAR1•3 Flat actuator FPAP1•3 OFF OFF - ON ON MOMENTARY (NO) Curved actuator FPAR3•3 Flat actuator FPAP3•3 4 www.apem.com APEM FP series Fully illuminated pushbutton switches - momentary or latching Options LED CONTROL AND NUMBER OF POLES Complete the model numbers on previous pages with one of the following codes. Function 1 (latching) Function 3 (momentary) Function 1 (latching) Non-illuminated one pole Independent one pole A C Non-illuminated two poles Independent two poles B D Function 3 (momentary) CONTACT MATERIALS 4 Silver, gold plated Silver : on request. ACTUATOR COLOUR 1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7 : white/natural 9 : orange - A : maroon - B : black, lacquered BEZEL COLOUR 1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow 6 : red - 7 : white/natural - 8 : bright chrome LED COLOUR X : non-illuminated A : blue - B : green - C : red - D : yellow - E : white - F : red/green - G : red/blue APEM www.apem.com 5 FP series Fully illuminated pushbutton switches - momentary or latching Options LED RESISTOR 0 1 2 3 No resistor supplied 12V resistor 24V resistor 48V resistor MARKING X 1 2 No marking Pad printing Laser SYMBOLS XX No symbol Available symbols See following pages. Marking colour White marking for illuminated actuators (laser etching) and non-illuminated black actuators (pad printing). Black marking for non-illuminated colour actuators (pad printing). Other : on request. Marking area The symbol will be included in the hatched area. 6 www.apem.com APEM FP series Fully illuminated pushbutton switches - momentary or latching Symbols Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the description). Contact us for symbols not featured in the following tables. Legend scale : Depending on space available on the product (see “Symbols” section). CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION 32 Emergency first aid vehicle (2565) Rear ventilator 33 Load tipping (1557) 18 Heating (0637) 34 Loading light (2457) - 19 Door opening 35 Tractor, rear-ward (1667) 04 - 20 Windshield demister/defroster (0635) 36 Combine, direction of movement (1678) 05 - 21 Windshield wiper (0086) 37 Use no forks (2406) 06 - 22 Windshield washer (0088) 38 Transmission (1166) 07 Stop 23 Ventilator fan (0089) 39 Working spot light (1145) 08 Motion 24 Side mirror defroster 40 Engine (0640) 09 Up motion 25 Restarting pump 41 Horn (0244) 10 Down motion 26 Front fog lights (0633) 42 Lock (1656) 11 Hot 27 Rear fog lights (0634) 43 Taxi sign light (2551) 12 Cold 28 Propulsion system trim 44 Working light (1204) 13 Hazard warning (0085) 29 Beacon (1141) 45 Working light symmetric (1204) 14 Traveller lighting 30 Anchor 46 - 15 Driver lighting (1421 31 Electric motor (0011) 47 - - 16 01 - 17 02 - 03 XX APEM None Revolving light www.apem.com 7 FP series Fully illuminated pushbutton switches - momentary or latching Symbols Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the description). Contact us for symbols not featured in the following tables. Legend scale : Depending on space available on the product (see “Symbols” section). CODE 8 SYMBOL DESCRIPTION CODE 48 All wheel drive 49 SYMBOL DESCRIPTION CODE 64 Indicator 80 Front windshield heating Differential lock (1662) 65 Brake release 81 Aus 50 - 66 Baggage room left door 82 Radiator fan 51 - 67 Baggage room right door 83 Remove retarder 52 - 68 Power blinds 84 Restricted speed 53 - 69 Engine idle control 85 Preheater 54 Rear window wiper (0097) 70 Cruise res/set 86 ABS detection 55 Rear window washer (0099) 71 Driver windows up/down 87 ECAS detection 56 Lower load (2223) 72 Middle door opening 88 Engine stop 57 Cab lock (1560) 73 Front door opening 89 Cruise res/cancel 58 Extraction 74 Lighting in baggage room 90 ECAS reset 59 Pumping in 75 Cruise on/off 91 Driver windows heating 60 Rear PTO (1572) 76 TV 92 Cruise set 61 Front PTO 77 Pump 93 Air bag up/down 62 Rockshaft down 78 Toilet 94 Read lighting 63 Rockshaft up 79 Toilet decontamination 95 Lighting main switch www.apem.com SYMBOL DESCRIPTION APEM FP series Fully illuminated pushbutton switches - momentary or latching Symbols Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the description). Contact us for symbols not featured in the following tables. Legend scale : Depending on space available on the product (see “Symbols” section). CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION Heating using water AD - AV - 97 Low beam AE - AW - 98 Position lights AF - AY - 99 Diesel acceleration AG Battery charging condition (0247) AZ - A1 Manual mode AH Turn signals (0084) B1 - A2 Clockwise cabin rotation AJ High beam (0082) B2 - A3 Anticlockwise cabin rotation AK Differential lock, bogie (2600) B3 - A4 - AL Brushing with a rotating brush (0070) A5 - AM Differential lock, transfer case 4x4 (2475) A6 Parking brake AN Loader bucket, float (1441) A7 - AP Loader bucket (1437) A8 - AQ Rear window washer & wiper (0098) A9 - AR Header Header drive (1579) AA - AS Excavator/backhoe boom side shift (2091) AB - AT Chemical water treatment (1851) AC - AU Grapple skidder, single funct° boom (1762) APEM www.apem.com FP1105-A. 96 9
FPAR3D1432B1X 价格&库存
很抱歉,暂时无法提供与“FPAR3D1432B1X”相匹配的价格&库存,您可以联系我们找货
FPAR3D1432B1X
  • 1+335.27349
  • 5+325.22414
  • 10+315.14354
  • 25+308.25999
  • 50+301.90755
库存:40
