H21CG1R2
H21CG1R2
    APEM(埃斐)
    APEM - H21CG1R2 - Rocker Switch, On-Off, DPST, Illuminated, Panel Mount, Red, H
H21CG1R2 数据手册
! New H SERIES SNAP-IN ROCKER SWITCHES FEATURES ● Higher power load ratings. ● Single and double pole models with smooth action and tactile response. ● Bezels, actuators & lenses available in a wide range of colors. ● Unique double rocker design with integral illumination. ● .248" (6.3mm) solder lug/quick-connect terminals. ● Choice of 125 or 250 volt neon indicator lamp. ● Illuminated and non-illuminated models. SPECIFICATIONS Contact ratings: Electrical life: Mechanical life: Maximum working temperature: 16 amps (resistive) at 250VAC, 4 amps inductive at 250VAC 10,000 operations min. at full load 100,000 operations +85°C MATERIALS Contacts: Terminals: Armature: Actuator: Body: Bezel: Lens: 90% silver, 10% cadmium Silver plated brass Silver plated copper Polycarbonate or ABS Polyester Polycarbonate Polycarbonate SINGLE POLE MODEL NO. DOUBLE POLE MODEL NO. CIRCUIT H11CG1R1 H12CG1R1 H21CG1R1 H22CG1R1 ON-OFF ON-ON Above models have silk chrome actuator, gun metal bezel, red lens and 125V neon lamp with resistor wired in series (see wiring diagrams). See order guide for other models. B54 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE B ! New H SERIES SNAP-IN ROCKER SWITCHES 'BUILD YOUR OWN SWITCH' ORDER GUIDE SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Fill in boxes with selections shown for complete model number. Allowable options are shown below each respective box. Note 'NONE' indicates box may be left empty. Series Number of poles Electrical function Actuator color Bezel color Terminal type B Lens color Lamp voltage 1 H 1 2 Single Double 1 ON/OFF 2 ON/ON Other functions on request A White B Black C Chrome G Gun Metal Other colors on request A White Solder lug/ Quick-connect B Black G Gun Metal NONE A Amber G Green R Red Illuminated switches only. NONE 1 125V 2 250V Illuminated switches only. Example of completely specified model number: H11BB1R1 WIRING DIAGRAMS Illuminated single pole Non-illuminated single pole Illuminated double pole Non-illuminated double pole PANEL CUT-OUT & MINIMUM RECOMMENDED SPACING FOR ADJACENT SWITCHES APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com B55
H21CG1R2 价格&库存
很抱歉,暂时无法提供与“H21CG1R2”相匹配的价格&库存,您可以联系我们找货
