558211-1
558211-1
    COMMSCOPE(康普)
558211-1 数据手册
MODULAR PLUGS, ACCESSORIES AND TOOLING 3rd Edition BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING TE CONNECTIVITY MODULAR PLUG PORTFOLIO TE Connectivity offers a vast portfolio of Modular Plugs for a wide variety of applications, performance and cable and conductor styles. Below is a brief explanation of the basics of this portfolio to assist in proper plug selection. CAT 6A, CAT 6, CAT 5E EMT and Secure Modular Plugs These modular plugs consist of a three-piece design: the modular plug body with contacts; a wire holder to manage the conductors and ensure performance and; a metal strain relief for securing the cable and if used with a shielded cable provides the shielding for the plug. These plugs can be used with shielded or unshielded cables. They are available with 3 different size strain reliefs to handle the range of cable diameters. Each performance level uses slightly different wire holders to achieve the desired performance levels. All three of these plug types utilize the 737893 or 336513 series plug boots. They utilize the ProCrimper III Hand Tool (354940-1) with the appropriate die set based on strain relief diameter. Please note that the SECURE Plugs require a unique die set to accommodate the securing key. CAT 5E, 8-Position Plug The CAT 5E Modular Plug is a two-piece design consisting of the modular plug body with contacts, and a load bar or wire holder. In this design the strain relief is built into the plug body. If the shielded option is desired, the plug comes with a factory installed wrap around shield. This plug utilizes the 569875, 569876 or 569877 series boot depending upon cable diameter. It utilizes the Pro-Installer tool with the “White” dot die set. CAT 5, 8-Position Modular Plug The CAT 5, 8-position plug is a one-piece design. This plug is available with a “standard” design which is 0.885 inches long and also a “long” design which is 0.915 inches long. The plug is also available for use with “round” cable as well as “flat oval” cable. Additionally, it is available in unshielded and shielded utilizing a wrap-around shield. This plug utilizes the same boots as the CAT 5E and the Pro-Installer tool with the “Black” dot die set. 6-Position Modular Plug The 6-position (RJ-11) modular plug is also a one-piece design and is offered in a “standard” design 0.530 inches long and also a “long” version which is 0.895 inches long. The plug is available for round as well as flat oval cable. It is available in unshielded and shielded versions. The 6-postion plug has a unique variety called “small conductor” for use with conductors with thin-wall insulation and overall diameter of 0.029 to 0.034 inches. Lastly, the 6-position plug is available with only 4 or 2 contacts installed. This plug utilizes the Pro-Installer tool with the “standard” plug using the “Blue” dot die set and the “long” using the “Violet” dot die set. 4-Position Modular Plug The 4-position (telephone handset) modular plug is a one-piece design and is 0.530 inches long and is designed for use with flat-oval cables. It is only available as unshielded. The plug utilizes the “Green” dot die set with the ProInstaller Tool. PAGE 3 Modular Plugs, Accessories and Tooling FEATURES AND BENEFITS • True mass displacement termination of jacketed cable with solid or stranded conductors • Available in all performance grades: CAT 6A, CAT 6, CAT 5E, CAT 5 and CAT 3 • Meets or exceeds EIA/TIA and ISO industry performance and specifications • Various positions, number of contacts, housing styles and packaging options available •  he most complete line of semiautomatic and manual termination capabilities and tooling – low T applied cost • Complete line of hand-held tooling available • Available for shielded and unshielded cable, round or flat oval, various cable diameters accommodated • Complete line of accessories such as boots and strain reliefs • Secure line of plugs available for secure or protected networks • Recognized by Underwriters Laboratories Inc, File # E81956 • Certified by Canadian Standards Association Certificate No LR 7189A SPECIFICATIONS Electrical Applications: 150 VAC max. at 1.5 A @ 25° C, derated to 0.2A @ 70° C Dielectric Withstanding Voltage: 1000 Volts AC between contacts 1500 Volts AC all contacts connected together with shield Insulation Resistance: 500 Megohms Mechanical Cable-to-Plug Tensile Strength: 17 lbs [76N] min. Durability: 750 mating cycles Temp. Rating: -40° C to +60° C Flame Rating: UL 94V-0 Environmental Thermal Shock: IDC-wire interface and jack-plug interface Humidity Temperature Cycling: IDC-wire interface Humidity Steady State: Jack-plug interface Mixed-Flow Gas Product Specification 108-1163 Standard 108-1163-2 High Performance BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling CAT 6/6A Shielded Slim-Line Modular Plug FEATURES • Each kit includes: (1) Modular plug assembly (1) Wire holder (1) Strain relief • Cat 6A performance achievable when used with PiMF (Pairs-in-Metal-Foil) constructed cable • Use appropriate-sized Slim-Line Modular Plug Boot (Ordered separately) Cable Type Conductor Stranded 24-26 AWG Shielded Insulation OD 0.035” to 0.043” (0.89mm to 1.09mm) Cable Diameter Package Size (500) Package Size (100) 0.201” to 0.236” (5.1mm to 6.0mm) 5-2111981-2 5-2111981-3 0.224” to 0.276” (5.7mm to 7.0mm) 5-2111984-2 5-2111984-3 CAT 6 Shielded Slim-Line Modular Plug FEATURES • Each kit includes: (1) Modular plug assembly (1) Wire holder (1) Strain relief • Use appropriate-sized Slim-Line Modular Plug Boot (Ordered separately) Cable Type Shielded or Unshielded Shielded or Unshielded Conductor Solid 23-24 AWG Stranded 24-26 AWG Insulation OD 0.035” to 0.043” (0.89mm to 1.09mm) 0.035” to 0.043” (0.89mm to 1.09mm) Cable Diameter Package Size (500) Package Size (100) 0.185” to 0.216” 4.7mm to 5.5mm 5-2111978-2 5-2111978-3 0.201” to 0.236” 5.1mm to 6.0mm 5-2111980-2 5-2111980-3 0.224” to 0.276” 5.7mm to 7.0mm 5-2111983-2 5-2111983-3 0.185” to 0.216” 4.7mm to 5.5mm 5-2111977-2 5-2111977-3 0.201” to 0.236” 5.1mm to 6.0mm 5-2111979-2 5-2111979-3 0.224” to 0.276” 5.7mm to 7.0mm 5-2111989-2 5-2111989-3 PAGE 5 Modular Plugs, Accessories and Tooling CAT 5E EMT Shielded Slim-Line Modular Plug FEATURES • Each kit includes: (1) Modular plug assembly (1) Wire holder (1) Strain relief • Use appropriate-sized Slim-Line Modular Plug Boot (Ordered separately) Cable Type Shielded Conductor Stranded 24-26 AWG Insulation OD 0.035” to 0.043” (0.89mm to 1.09mm) Cable Diameter Package Size (500) 0.185” to 0.216” 4.7mm to 5.5mm 5-2111976-2 5-2111976-3 0.201” to 0.236” 5.1mm to 6.0mm 5-2111986-2 5-2111986-3 0.224” to 0.276” 5.7mm to 7.0mm 5-2111988-2 5-2111988-3 Shielded Slim-Line Modular Plug Boot FEATURES • For use with Category 6A/6, and Cat 5e EMT modular plugs • Accepts cables with maximum diameters listed • Slim-line design support high-density applications •. Transparent boot eliminates need for colored boots to match cable jacket color • Advised to use the smallest boot size possible that will accommodate cable • Package size: 1000 pieces per box Description Slim-Line Transparent Boot Cable Diameter Package Size (100) Part Number 0.185” to 0.236” 4.7mm to 6.0 mm 2153256-1 0.224” to 0.276” 5.7mm to 7.0 mm 2153257-1 BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling CAT 5E, 8 Position Modular Plug FEATURES • In-line load bar and wrap-around shield for shielded plugs - Uses Category 5e Boots • Each Kit includes (1) Modular plug Assembly (1) Wire Holder • Use appropriate size CAT 5E modular plug boot for cable diameter ORDERING INFORMATION Part Number Description AWG Insulation O.D. Cable Jacket O.D. Conductor 100 per box 100 per box Unshielded 24 - 26 0.035" to 0.039" (0.89 mm to 0.99 mm) 0.190" to 0.220" (483 mm to 5.29 mm) Stranded 5-558530-2 5-558530-3 Solid 5-569278-2 5-569278-3 0.035" to 0.039" (0.89 mm to 0.99 mm) 0.190" to 0.220" (4.83 mm to 5.29 mm) Stranded 5-569552-2 5-569552-3 Solid 5-569550-2 5-569550-3 Shielded 24 - 26 *Note: The 336349-1 is for overmoldable boots. PAGE 7 Modular Plugs, Accessories and Tooling Modular Plug Snagless Boots for Category 5E, 5 and 3 Plugs FEATURES • For use with Category 3, 5 and 5e 8-position plugs • Three (3) boot sizes for various maximum cable diameters • 1000 boots per box ORDERING INFORMATION Color Max Cable Diameter 0.210" (5.33 mm) Max Cable Diameter 0.225 (5.71 mm) Max Cable Diameter 0.250" (6.35 mm) Black 569875-1 569876-1 569877-1 Almond 569875-2 569876-2 569877-2 Red 569875-3 569876-3 569877-3 Green 569875-4 569876-4 569877-4 Blue 569875-5 569876-5 569877-5 Yellow 569875-6 569876-6 569877-6 Orange 569875-7 569876-7 569877-7 White 569875-8 569876-8 569877-8 Violet 569875-9 569876-9 569877-9 Gray 1-569875-0 1-569876-0 1-569877-0 Slimline Modular Plug Boot ORDERING INFORMATION Description Max Cable Diameter Slimline Modular Plug Boot, Clear 0.220" (5.59 mm) Part Number 2111399-1 Modular Plug Non Snagless Boots for Category 5E, 5 and 3 Plugs ORDERING INFORMATION Color Max Cable Diameter 0.240" (6.1 mm) Black 558211-1 Almond 558211-2 Red 558211-3 Green 558211-4 Blue 558211-5 Yellow 558211-6 Orange 558211-7 White 558211-8 Violet 558211-9 BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling External Strain Reliefs For Modular Plugs FEATURES • Metal strain relief that positively engages plug housing • PRO-CRIMPER Tool and Die Set reference will be noted in tooling section • For use with 8-position Category 3, 5 and 5e Modular Plugs only • RoHS compliant ORDERING INFORMATION Description Part Number Not for use with Modular Plug Boots 558527-1 For use with Modular Plug Boots 558527-3 Category 5 and 3, 8-Position Modular Plugs • Each Kit includes (1) Modular plug Assembly • Packaged either 500 or 100 to bag • Use appropriate size modular plug boot for cable diameter 8-Position 8-Position Shielded 8-Position Round, Standard Flat, Standard Round, Standard ORDERING INFORMATION Shielding Cable Type Cable Jacket O.D. Conductor type AWG Insulation O.D. Body Type 0.210 " (5.33 mm) max. Stranded 26-28 0.029 " to 0.039 " (0.74 mm to 0.99 mm) Standard 0.200" (5.08 mm) Solid 24-26 0.029 " to 0.039 " (0.74 mm to 0.99 mm) Long Stranded 26-28 Solid 24-26 Stranded 26-28 0.029 " to 0.039 " (0.74 mm to 0.99 mm) Standard Solid 24-26 0.029 " to 0.039 " (0.74 mm to 0.99 mm) Standard Stranded 26-28 0.029 " to 0.039 " (0.74 mm to 0.99 mm) Standard Round Unshielded Flat Oval Round 0.100" x 0.350" (2.54 mm x 8.89 mm) max. 0.200" (5.08 mm) Shielded Flat Oval 0.110" x 0.355" (2.79 mm x 9.02 mm) max. 0.035" to 0.039" (0.89 mm to 0.99 mm) 0.035" to 0.039" (0.89 mm to 0.99 mm) Long Standard Quantity Per Box Part Number 100* 5-554169-3 500 5-554169-2 100* 5-557315-3 500 5-557315-2 100* 5-554739-3 500 5-554739-2 100* 5-554720-3 500 5-554720-2 100 5-569532-3 500 5-569532-2 100 5-569530-3 500 5-569530-2 100 5-569542-3 500 5-569542-2 PAGE 9 Modular Plugs, Accessories and Tooling Small-conductor Category 5 and 3, 8-Position Modular Plugs Small conductor plugs are for 0.029' to 0.034" (0.74 to 0.86 mm) insulated conductors. ORDERING INFORMATION Shielding Unshielded Cable Type Cable Jacket OD Conductor Type Round 0.158" (4.0 mm) Stranded Flat Oval Round 0.100"x 0.350" (2.54 mm x 8.89 mm) Stranded 0.158" (4.0 mm) Solid AWG Body Type 26-28 Standard 26-28 Standard 26-28 Standard Qty Part Number 100 5-557961-3 500 5-557961-2 100 5-557973-3 500 5-557973-2 100 5-557972-3 500 5-557972-2 Keyed Category 5 and 3, 8-Position Modular Plugs Small key on side of plug to interface with slot in jack. ORDERING INFORMATION Shielding Cable Type Cable Jacket OD Conductor Type AWG Body Type Qty Unshielded Round 0.158" (4.0 mm) Stranded 26-28 Standard 100 5-554170-3 Shielded Round 0.158" (4.0 mm) Stranded 26-28 Standard 100 5-569533-3 BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Part Number Modular Plugs, Accessories and Tooling 6-Position Modular Plugs 6-Position, Round, Standard ORDERING INFORMATION Positions Cable Type Shielding Cable Jacket O.D 0.180" (4.58 mm) Conductor Type 6-Position, Round, Long AWG Insulation O.D. Body Type 26-28 0.035" (0.89 mm) max Standard 26-28 0.029" to 0.039" (0.74 mm to 0.99 mm) max Long Stranded Round 0.195" (4.96 mm) Solid 24-26 0.039" (0.99 mm) Standard 0.195" (4.96 mm) Solid 24-26 0.039" (0.99 mm) Long Stranded 26-28 0.029" to 0.039" (0.74 mm to 0.99 mm) Standard Solid 24-26 0.035" to 0.039" (0.89 mm to 0.99 mm) Standard Unshielded 6 Flat Oval 0.090" x 0.260" (2.29 mm x 6.61 mm) Flat Oval 0.110" x 0.270" (2.79 mm x 6.85 mm) Stranded 26-28 0.029" to 0.039" (0.74 mm to 0.99 mm) Long Round 0.180" (4.58 mm) Stranded 26-28 0.029" to 0.039" (0.74 mm to 0.99 mm) Long Shielded 6-Position, Flat, Standard Quantity Per Box Part Number 100 5-554710-3 500 5-554710-2 100 5-555177-3 500 5-555177-2 100 5-569032-3 500 5-569032-2 100 5-555426-3 500 5-555426-2 100 5-641337-3 500 5-641337-2 100 5-555042-3 500 5-555042-2 100 5-555174-3 500 5-555174-2 100 5-555175-3 500 5-555175-2 Small-conductor 6-Position Modular Plugs Small Conductor plugs are for 0.029' to 0.034" (0.74 to 0.86 mm) insulated conductors. ORDERING INFORMATION Shielding Cable Type Cable Jacket O.D Conductor Type AWG Body Type Flat Oval 0.090" x 0.260" (2.29 mm x 6.61 mm) Stranded 26-28 Standard Flat Oval 0.090" x 0.260" (2.29 mm x 6.61 mm) Solid 24-26 Standard Round 0.180" (4.58 mm) Solid 24-26 Standard Unshielded Shielded Qty Part Number 100 5-557971-3 500 5-557971-2 100 5-557970-3 500 5-557970-2 100 5-1368336-3 500 5-1368336-2 PAGE 11 Modular Plugs, Accessories and Tooling 6-Position/4 or 2 Contacts Modular Plugs ORDERING INFORMATION Number of Contacts 4 Cable Type Flat Oval Cable Jacket O.D 0.090" x 0.260" (2.29 mm x 6.61 mm) Conductor Type AWG Body Type Stranded 26-28 Standard Solid 24-26 Standard Stranded Small Conductor* 26-28 Standard Solid Small Conductor* 2 Flat Oval 0.090" x 0.260" (2.29 mm x 6.61 mm) Stranded 26-28 26-28 Standard Standard Qty Part Number 100 5-641335-3 500 5-641335-2 100 5-556384-3 500 5-556384-2 100 5-557967-3 500 5-557967-2 100 5-557965-3 500 5-557965-2 100 5-641333-3 500 5-641333-2 Note: Small Conductor plugs are for 0.029' to 0.034" (0.74 to 0.86 mm) insulated conductors. 4-Position Modular Plug ORDERING INFORMATION Cable Type Cable Jacket O.D Flat Oval 0.090" x 0.260" (2.29 mm x 6.61 mm) Conductor Type AWG Body Type Stranded 26-28 Standard Solid 24-26 Standard Qty Part Number 100 5-641334-3 1000 5-641334-2 1000 5-556200-2 Qty Part Number 100 5-557963-3 500 5-557963-2 10-position Modular Plugs ORDERING INFORMATION Cable Type Cable Jacket O.D Conductor Type AWG Body Type Round Unshielded 0.021" (5.34 mm) Stranded 24-28 Standard BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling RJ45 SECURE Category 6 Modular Plugs FEATURES • Six color-coded keyed designs limit improper connections in segregated networks • Gray (universal key) available for use in testing • RJ45 SECURE plugs only mate with RJ45 SECURE jacks of the same color • See CAT 6/6A modular plug boots for matching color boots • 5 - 6 mm plug terminated with Pro-Crimper III hand-tool 354940-1 and die set 1976200-2 or combination tool/die set 1976200-1 • 6 - 7 mm plug terminated with Pro-Crimper III hand-tool 354940-1 and die set 1976200-4 or combination tool/die set 1976200-3 ORDERING INFORMATION Conductor Type Standard Solid Cable O.D. Qty Per Box Red Yellow Green Blue Violet Orange Gray (Universally Keyed) 5-6 mm 100 5-1479802-3 5-1479804-3 5-1479806-3 5-1479808-3 5-1499675-3 5-1499677-3 5-1499679-3 6-7 mm 100 5-1499549-3 5-1499551-3 5-1499553-3 5-1499555-3 5-1499557-3 5-1499559-3 5-1499561-3 5-6 mm 100 5-1479803-3 5-1479805-3 5-1479807-3 5-1479809-3 5-1499676-3 5-1499678-3 5-1499680-3 6-7 mm 100 5-1499550-3 5-1499552-3 5-1499554-3 5-1499556-3 5-1499558-3 5-1499560-3 5-1499562-3 PAGE 13 Modular Plugs, Accessories and Tooling Base Terminator: 1320840-1 (115 Vac, 60 Mhz) ModPlug Dual Terminator Fast Facts • Pneumatically powered, foot pedal actuated • Terminate two connectors at the same time • Programmable tester — Check forshorts and opens as product is terminated. Program tester for individual positions or crossovers. • Terminate up to 200 dual-ended cables/hr • Interchangeable die sets — Easy changeover die sets for your particular product. Die sets have been designed to terminate all TE modular plug products • Steel die sets for long life • Fully adjustable, primary strain relief, secondary strain relief and contact height • Lightweight (36 lbs) design makes the press easy to move within work center • Rental and purchase options available • Compact size — 8" x 8" x 101/2" tall • 1-year limited warranty • TECHNICAL REQUIREMENTS: • Air pressure — 80 - 100 psi • Air supply hose — 3/16 dia. with 1/8 NPT fitting TE plugs are UL approved when terminated using this tool and the procedures outlined in CM 409-10010 and IS 408-9743 CAT 5E, 5 and 3 (4, 6, 8 and 10 Position) Teminating Modules* Modular Plug Style Performance Rating Terminating Module 4 Position Plug CAT 3 856196-3 6 Position Plug (Standard Body) CAT 3 856196-1 6 Position Plug (Long Body) CAT 3 856196-4 10 Position Plug CAT 3, CAT 5 856196-6 8 Position Plug (Standard or Long Body) CAT 3, CAT 5 856196-2 8-Position Plug CAT 5E 1-856196-1 *B  ase Terminator 1320840-1 required. See Instruction Sheet 408-9743 for more information. CAT 5E EMT, CAT 6, CAT 6A and Secure Plug Terminating Modules* Cable Diameter (Strain Relief) Range Terminating Module 0.185" to 0.216" / 4.7mm to 5.5mm 791804-4 0.201" to 0.236' / 5.1mm to 6.0mm 791804-1* 0.224" to 0.276" / 5.7mm to 7.0mm 791804-3 * Base Terminator 1320840-1 required. Note: M  odular Plug 336349 requires teminating module 791804-2. See Instruction Sheet 408-8734 for more information. BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling Base Terminator: 354711-1 ModPlug Single Terminator Fast Facts • Terminate up to 250 connectors/hr • Interchangeable steel die sets terminate all TE plugs • Compact, low cost pneumaticallydesigned bench unit • Independent adjustments for insertion, primary strain relief, and secondary strain relief depths • Weighs only 13 lbs • Compact size — 31/2" x 83/4" x 51/8" tall • CE approved • TE plugs are UL approved when terminated using this tool and the procedures outlined in IS 408-9919 • Technical requirements: Air pressure — 80 - 100 psi Air supply hose — 1/8 I.D. with 1/8 NPT fitting ORDERING INFORMATION Modular Plug Style Performance Rating Terminating Module (Only)* Terminator with Terminating Module** 4 Position Plug (Standard Body) CAT 3 354714-3 354711-4 6 Position Plug (Standard Body) CAT 3 354714-1 354711-2 6 Position Plug (Long Body) CAT 3 354714-4 354711-5 10 Position Plug CAT 3, CAT 5 354714-5 354711-6 8 Position Plug (Standard or Long Body) CAT 3, CAT 5 354714-2 354711-3 8-Position Plug CAT 5E 354714-7 354711-8 *B  ase Terminator (354711-1) required if purchasing terminating modules only. With tooling included. See Instruction Sheet 408-9919 for additional information. PAGE 15 Modular Plugs, Accessories and Tooling Category 6A, 6 and CAT 5E EMT Modular Plugs FEATURES • Ratchet control provides complete termination cycle • Die set and tool crimps both the strain relief and the modular contacts at the same time • Interchangeable die sets accommodate all plug sizes • Sold with or without die. Dies can be purchased separately ORDERING INFORMATION Cable (Strain Relief) Diameter 0.185" to 0.216" 4.7mm to 5.5mm 0.201" to 0.236" 5.1mm to 6.0mm 0.224" to 0.276" 5.7mm to 7.0mm Die Set Only 790163-8 790163-2 790163-6 Tool With Die* 790163-7 790163-1 790163-5 Hand Held Tool Only 354940-1 * Includes 2119000-1 JacKnack Tool. JacKnack Tool FEATURES • Cable Jacket Stripper • Cable Filler Sheer • Untwist Wire Pairs – Controls Degree of Untwist and Quick • JacKnack Clamp – holds untwisted pair until ready for insertion. • Wire Placement Tool • Lightweight Design • Ergonomic Design – Finger loop used to actuate tool • Convenient - Finger loop allows the user keep the tool on their finger ORDERING INFORMATION Description Part Number Instruction Sheet JacKnack Tool 2119000-1 408-10326 BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling Pro-Installer's Modular Plug Hand Tool FEATURES • Ratchet control provides complete termination cycle • Sold with and without die sets • Interchangeable die sets accommodate all plug sizes Die set to modular plug cross-reference shown Hand Tool Without Die: 2-231652-0 Plug Style CAT 5E 8-Position Cat 5 and 3 8-Position 6-Position Long Body 6-Position Standard Body 4-Position DOT Color White Black Violet Blue Green Die Only P/N 1-853400-0 853400-1 853400-7 853400-8 853400-3 Hand Tool with Die 3-231652-0* 2-231652-1* 2-231652-7 2-231652-8 2-231652-3 PAGE 17 Modular Plugs, Accessories and Tooling Pro-Installer's Modular Plug Hand Tool Kits and Accessories FEATURES • Each kit contains carrying case, blade replacement kit, screw driver, and items as listed • Modular plug to die set cross reference listed as shown Included Components JacKnack Tool Hand Tool Dot Color CAT 5E 8-Position Die Set 8-Position Die Set 6-Position Standard 4-Position Die Set White Black Blue Green Description 2119000-1 2-231652-0 1-853400-0 853400-1 853400-8 853400-3 Part Number Pro-Installer's X X X X X X 1-231666-5 Mod Plug X X - X X X 1-231666-1 X X - X X - 1-231666-0 Hand Tool Kits Carrying Case, Blade Replacement Kit, JacKnack and Screw Driver ONLY 231666-9 Replacement Blade Kit (5 Cutters and 5 sets of Strip Blades) 231662-5 Cutter Blade 856727-1 See Instruction Sheet 408-9767 for more information. BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING Modular Plugs, Accessories and Tooling PAGE 19 te.com TE Connectivity, TE connectivity (logo) and Every Connection Counts are trademarks. All other logos, products and/or company names referred to herein might be trademarks of their respective owners. The information given herein, including drawings, illustrations and schematics which are intended for illustration purposes only, is believed to be reliable. However, TE Connectivity makes no warranties as to its accuracy or completeness and disclaims any liability in connection with its use. TE Connectivity‘s obligations shall only be as set forth in TE Connectivity‘s Standard Terms and Conditions of Sale for this product and in no case will TE Connectivity be liable for any incidental, indirect or consequential damages arising out of the sale, resale, use or misuse of the product. Users of TE Connectivity products should make their own evaluation to determine the suitability of each such product for the specific application. © 2015 TE Connectivity Ltd. family of companies. All Rights Reserved. 318178.5AE  03/15   Revision BROADBAND NETWORK SOLUTIONS /// MODULAR PLUGS, ACCESSORIES AND TOOLING CATALOG Contact us P.O. Box 1101 Minneapolis, Minnesota USA 55440-1101 Tel: 1-800-366-3891 x73000 1-952-917-3000 Fax: 1-952-917-3237 www.te.com/bns
558211-1 价格&库存
很抱歉,暂时无法提供与“558211-1”相匹配的价格&库存,您可以联系我们找货
