317 SERIES
Card Edge Connector 0.156” (3.96mm) Pitch
Features:
0.156” (3.96mm) contact spacing x 0.200” (5.08mm) row spacing
Accepts 0.062” (1.57mm) nominal thickness P.C. board
High profile insulator body, 0.720” (18.29mm)
Contact termination 0.045” (1.14mm) square wire wrap
Single or dual row configurations
Large variety of mounting options
Accepts between contact and in-contact polarizing keys
Pre-assembled card guides are available
RoHS Compliant
Specifications:
Insulator Material
UL 94V-0 Diallyl Phthalate, Green Color
Contact Material
Copper Alloy
Contact Plating
Gold Plating with Nickel underplating all over
Current Rating
5 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1800 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-65°C to +125°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge
Mounting Options:
Description:
01
No Mounting Lug
02
Ø.144" (Ø3.66mm) Mounting Holes
03
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
04
Ø.156" (Ø3.96mm) Mounting Holes
07
M3-0.5 Metric Threaded Inserts
Contact Rows
08
#4-40 Unified Threaded Inserts
Mounting Options
78
Example Part Number:
317-072-542-808
Series
Total Number of Contacts
Contact Code
In-Line Card Guides
Series:
317
Total Number of Contacts:
Contact Rows:
006, 007, . . . . 043
Single Row
012, 014, . . . . 086
IN-CONTACT
POLARIZING KEY
P/N 321-240-328
Dual Row
Contact Code:
Tail Description:
542
Wire Hole
541
Wire Wrap
Tail Size:
IN-CONTACT
POLARIZING KEY
P/N 334-240-318
Tail Length “G”:
Single Row Contacts - Read One Side of Daughter Board
.045 Square (1.14 Square)
.750(19.05)
Single Row Contacts - Read Both Sides of Daughter Board
.750(19.05)
Dual Row Contacts - Read Both Sides of Daughter Board
540
Wire Wrap
.750(19.05)
542
Wire Wrap
.750(19.05)
543
Wire Wrap
.900(22.86)
Contact Rows:
Description:
6
Single Row
8
Dual Row
www.edac.net
Ordering Code Notes:
1) All connector sizes up to 43 contacts single row / 86 contacts dual row are
available upon request.
2) For details of the mounting options refer to next pages.
customerservice@edac.net
317 SERIES
A
DUAL ROW CONTACTS
CODES 540 & 543
B
CODE 542
C
.370 (9.40)
CARD SLOT
D
.240 (6.10)
POINT OF
CONTACT
.500
(12.70)
.240 (6.10)
POINT OF
CONTACT
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.250 (6.35)
.720
(18.29)
SINGLE ROW CONTACTS
CODE 541
G
.163
(4.14)
.445
(11.30)
CODE 542
.100 (2.54)
.156 (3.96)
ROW A
SIDE OF
CONNECTOR
BACK UP SPRINGS
LOCATED IN POSITIONS
B2, B5, B8, B11, ... B41
ROW A
SIDE OF
CONNECTOR
14
15
13
12
10
11
8
9
7
5
6
3
4
1
A
.200 (5.08)
2
B
E
.156 (3.96) DIA
HOLES REF
+.000
D MINUS .012 (0.30) ) -.015 (0.38)
.530 (13.46)
.390 (9.91)
.140 (3.56)
.125 (3.18)
.055 (1.40)
CUT OUT FOR IN-CONTACT CUT OUT FOR BETWEEN CONTACT
POLARIZING KEY
POLARIZING KEY
B
RECOMMENDED DAUGHTER BOARD
CONNECTOR MOUNTING PATTERN
PANEL MOUNT CUT OUT
NUMBER OF CONTACTS
"A"
"B"
"C"
"D"
"E"
Single
Double
Inch
mm
Inch
mm
Inch
mm
Inch
mm
Inch
mm
6
12
1.830
46.48
1.539
39.09
1.220
30.99
1.100
27.94
0.780
19.81
10
62.33
2.163
54.94
1.844
46.84
1.724
43.79
1.404
35.66
15
30
3.234
82.14
2.943
74.75
2.624
66.65
2.504
63.60
2.184
55.47
18
36
3.702
94.03
3.411
86.64
3.092
78.54
2.972
75.49
2.652
67.36
22
44
4.326
109.88
4.035
102.49
3.716
94.39
3.596
91.34
3.276
83.21
25
50
4.794
121.77
4.503
114.38
4.184
106.27
4.064
103.23
3.744
95.10
28
56
5.262
133.65
4.971
126.26
4.652
118.16
4.532
115.11
4.212
106.98
30
60
5.574
141.58
5.283
134.19
4.964
126.09
4.844
123.04
4.524
114.91
36
72
6.510
165.35
6.219
157.96
5.900
149.86
5.780
146.81
5.460
138.68
43
86
7.602
193.09
7.311
185.70
6.992
177.60
6.872
174.55
6.552
166.42
www.edac.net
317 SERIES
0.12 [2.95] I.D.
Floating Eyelets
0.25 [6.35] Dia.
.144 (3.66) Dia.
Through Hole
Code x01
Code x02
0.010 [0.25]
Radial Float
Code x03
0.01 [0.13]
Vertical Float
0.33 [8.33]
0.11 [2.79]
.156 (3.96) Dia.
Through Hole
M5-0.5 Metric
Insert
#4-40 UNC
Threaded Insert
1.71 [43.48]
0.25 [6.35]
Code x04
www.edac.net
Code x07
Code x08
Code x78
很抱歉,暂时无法提供与“317-078-540-808”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+1040.2494825+134.74869
