322 SERIES
Card Edge Connectors 0.156” (3.96mm) Pitch
Features:
0.156” (3.96mm) contact spacing x 0.200” (5.08mm) row spacing
Accepts 0.062” (1.57mm) nominal thickness P.C. board
Low profile insulator body, 0.473” (12.01mm) with card guides
Contact termination options include P.C. tail, wire hole, wire wrap, 90 degree and extender board bends
Single or dual row configurations
Variety of mounting options
Accepts between contact and in-contact polarizing keys
RoHS Compliant
Specifications:
Insulator Material
Grey polycarbonate, Glass reinforced
Contact Material
Copper Alloy
Contact Plating
Gold plating on mating area, Tin plating on tails with nickel underplating all over
Current Rating
5 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1800 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-40°C to +105°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge
EXAMPLE PART NUMBER
322-044-500-258
Series
Contact Code:
Tail Description:
Tail Size:
Tail Length “G”:
Single Row Contacts - Read One Side of Daughter Board
505
Wire Hole
.087 x . 013 (2.21 x 0.33)
.282 (7.16)
Contact Code
525
P.C. Tail
.046 x .013 (1.17 x 0.33)
.213 (5.41)
Contact Rows
527
P.C. Tail
.358 (9.09)
Mounting Options
531
P.C. Tail
.023 x .013 (0.58 x 0.33)
.213 (5.41)
545
Wire Wrap
.708 (17.98)
Series:
547
Wire Wrap
.520 (13.21)
322
558
90 DEGREE BEND (CODE 545 CONTACTS)
559
90 DEGREE BEND (CODE 527 CONTACTS)
501
Wire Hole
.089 x .014 (2.29 x 0.36)
.213 (5.41)
Total Number of Contacts
Total Number of Contacts:
Contact Rows:
022
Single Row
044
Dual Row
Contact Rows:
Insulator Material:
Description:
521
P.C. Tail
.046 x .014 (1.17 x 0.36)
.213 (5.41)
1
Grey Polycarbonate
Single Row
541
Wire Wrap
.495 (12.57)
2
Grey Polycarbonate
Double Row
553
90 DEGREE BEND (CODE 521 CONTACTS)
Mounting Options:
Description:
554
90 DEGREE BEND (CODE 501 CONTACTS)
54
Ø.156” (Ø3.96mm) x .300” (7.62mm) Deep Holes
557
90 DEGREE BEND (CODE 541 CONTACTS)
57
M3-0.5 Metric Threaded Inserts
58
#4-40 Unified Threaded Inserts
500
Wire Hole
.087 x .013 (2.21 x 0.33)
.282 (7.16)
520
P.C. Tail
.213 (5.41)
522
P.C. Tail
.358 (9.09)
524
P.C. Tail
.213 (5.41)
540
Wire Wrap
.708 (17.98)
542
Wire Wrap
.520 (13.21)
555
.062 EXTENDER BOARD BEND (CODE 500 CONTACTS)
556
.062 EXTENDER BOARD BEND (CODE 520 CONTACTS)
558
90 DEGREE BEND (CODE 522 AND 540 CONTACTS)
559
560
.062 EXTENDER BOARD BEND (CODE 522 CONTACTS)
www.edac.net
Single Row Contacts - Read Both Sides of Daughter Board
Dual Row Contacts - Read Both Sides of Daughter Board
customerservice@edac.net
322 SERIES
4.875 (123.83)
4.530 (115.06)
DUAL ROW CONTACTS
4.306 (109.37)
.325 (8.26)
CARD SLOT
.343 (8.71)
CARD SLOT ACCEPTS
.054 (1.37) TO .070 (1.78)
THICK P.C. BOARDS
.100 (2.54)
POINT OF
CONTACT
CODE 54 MOUNTING - .156 (3.96) DIA X .300 (7.62) DEEP HOLES
CODE 57 MOUNTING - M3-0.5 METRIC THREADED INSERTS
CODE 58 MOUNTING - #4-40 UNC THREADED INSERTS
3.000
(76.20)
SINGLE ROW CONTACTS
READ ONE SIDE
OF DAUGHTER BOARD
3.610 (91.69)
.062
(1.57)
.325 (8.26)
CARD SLOT
.100 (2.54)
POINT OF
CONTACT
.473
(12.01)
SINGLE ROW CONTACTS
.048 (1.22) X .125 (3.18)
WIRE HOLE
G
READ BOTH SIDES
OF DAUGHTER BOARD
.156 (3.96)
.325 (8.26)
CARD SLOT
3.276 (83.21)
4.030 (102.36)
www.edac.net
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
A
B
C
D
E
F
H
J
K
L
M
N
P
R
S
T
U
V
W
X
Y
Z
.180 (4.57)
POINT OF
CONTACT
很抱歉,暂时无法提供与“322-044-559-258”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+272.4586025+35.42713
