325-118-500-207
325-118-500-207
    插件,P=2.54mm
    325 SERIES (.100" (2.54MM) CONTA
325-118-500-207 数据手册
325 SERIES Card Edge Connectors 0.100” (2.54mm) Pitch Features: • • • • • • • • • 0.100” (2.54mm) contact spacing x 0.300” (7.62mm) row spacing Accepts 0.125” (3.18mm) nominal thickness P.C. board Contact termination options include P.C. tail, wire hole and 0.025” (0.64mm) square wire wrap High profile insulator body 0.600” (15.24mm) Single or dual row configurations Variety of mounting options Accepts in-contact polarizing keys Automatic wire wrap positioning holes RoHS Compliant Specifications: Insulator Material UL 94V-0 Diallyl Phthalate, Green Color Contact Material Copper Alloy Contact Plating Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over Current Rating 3 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 1200 V AC rms at sea level between adjacent contacts Insulation Resistance 5000 megaohms minimum Operating Temperature -65°C to +125°C Insertion Force 16 oz (4.45 N) maximum per contact pair when tested with .135” (3.43mm) thick gauge Withdrawal Force 1 oz (0.28 N) minimum per contact pair when tested with .115” (2.92mm) thick gauge Example Part Number: 325-122-520-209 Series Total Number of Contacts Contact Code IN-CONTACT POLARIZING KEY P/N 325-240-328 Contact Rows Mounting Options Series: 325 Total Number of Contacts: Contact Rows: 005, 006, . . . . 061 Single Row 010, 012, . . . . 122 Dual Row Contact Code: Description: Contact Point: Tail Length “G”: 500 Wire Hole .050 x .025 (1.27 x 0.64) .260 (6.60) 520 P.C. Tail .025 Square (0.64 Square) .175 (4.45 540 Wire Wrap .025 Square (0.64 Square) .560 (14.22) Contact Rows: Description: 1 Single Row 2 Dual Row Mounting Options: Description: 01 No Mounting Lug 07 M3-0.5 Metric Threaded Inserts 08 #4-40 Unified Threaded Inserts 09 Ø.160” (Ø4.06mm) Mounting Holes www.edac.net Ordering Code Notes: 1) All connector sizes up to 61 contacts single row / 122 contacts dual row are available upon request. 2) For details of the mounting options, refer to next pages. customerservice@edac.net 325 SERIES Card Edge Connectors 0.100” (2.54mm) Pitch WIRE WRAP POSITIONING SLOT AND HOLE .490 (12.46) CARD SLOT ACCEPTS .115 (2.92) TO .135 (3.43) THICK P.C. BOARDS .600 (15.24) SECTION THROUGH CONTACT POSITION .297 (7.54) CARD SLOT .312 (7.92) .127 (3.23) POINT OF CONTACT .030 X .080 (0.76 X 2.03) WIRE HOLE EDAC .100 (2.54) 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 1 3 5 7 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 .300(7.62) CONTACTS FOR SINGLE ROW CONNECTORS ON EVEN NUMBERED SIDE .300 (7.62) .320 (8.13) .080 (2.03) CUT OUT FOR IN-CONTACT POLARIZING KEY +.000 MINUS .012 (0.30) -.015 (0.38) Ø.160 (4.06) REF. .100(2.54) .520 (13.21) PANEL MOUNT CUT OUT .150 (3.81) PANEL MOUNT CUT OUT .042 (1.07) +.004 (0.10)/-.000 FOR P.C. TAILS .008 (0.20) DIA "A" DIA. THROUGH HOLES THREADED INSERTS CODE X09 - THROUGH MTG. HOLES CODE X09 "A" DIA. 0.160(4.06) CODE X07 AND X08- THREADED INSERTS CODE X07 INSERT NUMBER OF CONTACTS CODE X08 M3-0.5(METRIC) "A" #4-40 UNC B C MTG. OPTION CODE x01 (NO MTG. LUGS) "B" B MTG. OPTION CODE xO9 "C" MTG. OPTION CODES x07 & xO8 (THREADED INSERTS) "D" "E" Single Double Inch mm Inch mm Inch mm Inch mm Inch mm 5 10 1.355 34.42 1.056 26.82 0.722 18.34 0.600 15.24 0.400 10.16 15 30 2.355 59.82 2.056 52.22 1.722 43.74 1.600 40.64 1.400 35.56 18 36 2.655 67.44 2.356 59.84 2.022 51.36 1.900 48.26 1.700 43.18 22 44 3.055 77.60 2.756 70.00 2.422 61.52 2.300 58.42 2.100 53.34 15 30 3.355 85.22 3.056 77.62 2.722 69.14 2.600 66.04 2.400 60.96 30 60 3.855 97.92 3.556 90.32 3.222 81.84 3.100 78.74 2.900 73.66 36 72 4.455 113.16 4.156 105.56 3.822 97.08 3.700 93.98 3.500 88.90 40 80 4.855 123.32 4.556 115.72 4.222 107.24 4.100 104.14 3.900 99.06 43 86 5.155 130.94 4.856 123.34 4.522 114.86 4.400 111.76 4.200 106.68 50 100 5.855 148.72 5.556 141.12 5.222 132.64 5.100 129.54 4.900 124.46 61 122 6.955 176.66 6.656 169.06 6.322 160.58 6.200 157.48 6.000 152.40 www.edac.net customerservice@edac.net
325-118-500-207
1. 物料型号:文档中提供了一个示例型号“325-122-520-209”,这可能代表具有特定配置的连接器。
2. 器件简介:325系列卡边连接器具有0.100英寸(2.54mm)的接触间距和0.300英寸(7.62mm)的行间距,可接受0.125英寸(3.18mm)的PCB板厚度。它们有多种安装选项,并且符合RoHS标准。
3. 引脚分配:文档列出了不同接触点数量的配置,从5到122个接触点,可以是单行或双行配置。
4. 参数特性:包括绝缘材料、接触材料、接触镀层、电流额定值、接触电阻、介电耐压、绝缘电阻、工作温度范围、插入力和拔出力等。
5. 功能详解:文档描述了连接器的多种接触终止选项,包括PCB尾、线孔和0.025英寸(0.64mm)的正方形线绕。
6. 应用信息:文档提供了订购代码注释和如何根据需求定制连接器的信息。
7. 封装信息:提供了关于极化键、接触点位置、面板安装切口和连接器安装模式的详细信息。
325-118-500-207 价格&库存
很抱歉,暂时无法提供与“325-118-500-207”相匹配的价格&库存,您可以联系我们找货
