雅晶鑫電子
Shenzhen Yajingxin Electron Co.,Ltd
Customer
Production Name
SMD
OCSECSC4R
Customer P/N
SEAM 7.0*5.0
N/A
P/N
TFOM50M4OZKCNT2T
Revision
A
Print Date
2018-12-15
Drawn
Checked
Approved
RoHS Compliant
■Electrical Specifications
1.Model No
7050 OSC
2.Nominal Frequency
50.000MHz
3.Mode of Oscillation
3rd
4.Operating Temperature Range
-40℃ to85℃
5.Storage Temperature Range
-55℃ to +125℃
6.Frequency Stability
±50ppm
7.Power Supply Voltage
3.3V±10%
8.Input Current
10mA Max.
15mA Max.
25mA Max.
60mA Max.
9.Output Voltage
Logic High(Voh)
Logic Low(Vol)
:1.500- 32.000MHz
:32.001- 50.000MHz
:50.000- 70.000MHz
:70.001- 125.00MHz
90%Vdd Min
10%Vdd Max
10.Output Load
15pF max
CMOS Load
11.Semmetry (at 50%VDD)
40-60%Normal
12.Rise & Fall Time
8ns Max.
13.E/D or N/C.
Tri-state
14.Output Disable Time
100nsec
15.Output Enable Time(start-up time)
10msec
16.Aging
±3ppm/year
max
17.Unit Weight
p2/7
■Dimension
s
Pad
Connection
1
N.C.(INH)
■Markin
g
Line 1:
2
GND
3
OUTPUT
4
VDD
50.000
MHz
客户指定印字
Line 2:
p3/7
■Measurement Circuit
Output Wave Form
■Input Output Condition
p4/7
■Reflow Profile
■Reliability Specifications
No
Test Item
Test Methods
Device are dropped from a height of 75 cm onto 3 mm
1
DROP TEST
thickness stainless plate executing 3 times of random
drops.
2
MECHANICAL SHOCK
Device are shocked to half sine wave (1000 G) three
mutually perpendicular axes each 3 times.
3 High Temp and Humidity Test
85℃/RH 85%,
4
High temp storage test
125℃+/-2℃
5
Low temp storage test
-40℃
6
Thermal shock test
-40℃~+85℃
7
Aging test
85℃ 1000Hrs
500Hrs
500Hrs
500Hrs
DWEL 60' 100cycles
p5/7
8 Resistance
9
to
solder heat
VIBRATION
260℃
10S
Frequency range
Amplitude Sweep
Sweep Time
Test Time
10-2000 Hz
1.5 mm
20 minute
2 hours
MIL - STD - 20E Method 208C
Temperature
10
SOLDERABILITY
Material
245°C±5°C
H63A (Silver 2-3 %)
Immersion depth
0.5 mm minimum
Immersion time
3 ± 0.5 seconds
Flux
Rosin resin methyl
■Packin
g
A0:5.40±0.1
P0: 4.0±0.1
F: 7.50±0.1
B0:7.40±0.3
P : 8.0±0.1
K0:1.90±0.1
W:16.2±0.3
P2: 2.0±0.1
E1:1.75±0.1
D: phi 1.50±0.1
p6/7
■Reel Dimension
A: phi 180±1.0
E: 1.9±0.5
NOTE: 1. packgeing q’ty
B: phi 60±1.0
W: 25.5+1.0
C: phi 13.0±0.5
D: phi 12.0±1.0
1000PCS /REEL
p7/7
很抱歉,暂时无法提供与“333-028-524-207”相匹配的价格&库存,您可以联系我们找货
