379-052-555-203
    P=3.81mm
    379 SERIES (.150 (3.81MM) CONTA
379-052-555-203 数据手册
379 SERIES Card Edge Connectors 0.150” (3.81mm) Pitch Features: • • • • • • • • 0.150” (3.81mm) contact spacing x 0.200” (5.08mm) row spacing Accepts 0.062” (1.57mm) nominal thickness P.C. board High profile insulator body, 0.600” (15.24mm) Contact termination options include P.C. tail, wire wrap and extender board bends Single or dual row configurations Variety of mounting options Accepts in-contact polarizing keys RoHS Compliant Specifications: Insulator Material UL 94V-0 Thermoplastic Polyester, Black Color Contact Material Copper Alloy Contact Plating Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over Current Rating 3 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 1800 V AC rms at sea level between adjacent contacts Insulation Resistance 5000 megaohms minimum Operating Temperature -40°C to +105°C Insertion Force 16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge Withdrawal Force 1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge 379-040-520-208 Example Part Number: Series Total Number of Contacts Contact Code Contact Rows Mounting Options Series: Contact Code: Tail Description: Tail Size: Tail Length “G”: 379 520 P.C. Tail .030 x .018 (0.76 x 0.46) .175 (4.45) Total Number of Contacts: Contact Rows: 521 P.C. Tail .025 Square (0.64 Square) .150 (3.81) 006, 016, 020, 026 or 032 Single Row 523 P.C. Tail .025 Square (0.64 Square) .390 (9.91) 012, 032, 040, 052 or 064 Dual Row 524 P.C. Tail .018 Square (0.46 Square) .175 (4.45) Contact Rows: Insulator Style: 540 Wire Wrap .025 Square (0.64 Square) .560 (14.22) 1 Single Row 541 Wire Wrap .025 Square (0.64 Square) .750 (19.05) 2 Dual Row 542 Wire Wrap .025 Square (0.64 Square) .645 (16.38) Mounting Options: Description: 544 Wire Wrap .050 x .025 (1.27 x 0.64) .750 (19.05) 01 No Mounting Lug 555 EXTENDER BOARD BEND (Code 500 Contacts) 02 Ø.128” (Ø3.25mm) Mounting Holes 556 EXTENDER BOARD BEND (Code 520 Contacts) 03 Ø.116” (Ø2.95mm) I.D. Floating Eyelets 560 EXTENDER BOARD BEND (Code 523 Contacts) 04 Ø.156” (Ø3.96mm) Mounting Holes 07 M3-0.5 Metric Threaded Inserts 08 #4-40 Unified Threaded Inserts www.edac.net Ordering Code Notes: Consult with EDAC regarding 90 degree bend availability. customerservice@edac.net 379 SERIES Card Edge Connectors 0.150” (3.81mm) Pitch .250 (6.35) DIA .010 (0.25) RADIAL FLOAT A DIA THROUGH HOLES 0.328(8.33) CONNECTOR .005 (0.51) VERTICAL FLOAT CONNECTOR .116 (2.95) I.D. DIMENSION FLOATING EYELETS B DIMENSION CONNECTOR B DIMENSION MOUNTING OPTION CODES x02 AND xO4 (THROUGH MOUNTING HOLES) MOUNTING OPTION CODE x03 (FLOATING EYLETS) C MOUNTING OPTION CODE x01 (NO MOUNTING LUGS) CODE x07 M3-0.5 METRIC CODE x08 #4-40 UNC THREADED INSERTS CODE X02 AND X04- THROUGH MTG. HOLES CONNECTOR DIMENSION "A" DIA. CODE X02 CODE X04 0.128(3.25) 0.156(3.96) CODE X07 AND X08- THREADED INSERTS B CODE X07 INSERT MOUNTING OPTION CODES x07 & xO8 (THREADED INSERTS) .120 (3.05) CODE X08 M3-0.5(METRIC) #4-40 UNC .165 (4.19) .095 (2.41) A .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS CONTACT CODE 555 BEND USES WIRE HOLE CONTACTS A .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .185 (4.70) OUTSIDE TAILS CONTACT CODE 556 .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS CONTACT CODE 560 IN-CONTACT POLARIZING KEY P/N 345-240-328 CONTACT CODE www.edac.net A 555 0.245(6.22) 556 0.170(4.32) 560 0.375(9.53) B customerservice@edac.net 379 SERIES Card Edge Connectors 0.150” (3.81mm) Pitch www.edac.net customerservice@edac.net
379-052-555-203
物料型号:379系列
器件简介:0.150英寸(3.81mm)间距的卡边连接器,适用于0.062英寸(1.57mm)厚的PCB板,具有高轮廓绝缘体,多种安装选项,符合RoHS标准。
引脚分配:提供单排或双排配置,接触件数量有006, 016, 020, 026或032。
参数特性: - 绝缘体材料:UL94V-0热塑性聚酯,黑色 - 接触材料:铜合金 - 接触镀层:接触区域金镀层,尾部锡镀层,整体镍底层 - 电流额定值:3安培 - 接触电阻:最大10毫欧姆 - 介质耐电压:在相邻接触件间1800V交流有效值 - 绝缘电阻:最小5000兆欧姆 - 工作温度:-40°C至+105°C - 插入力:每对接触件最大16盎司(4.45牛顿) - 拔出力:每对接触件最小1盎司(0.28牛顿)
功能详解:该连接器设计用于高可靠性的电子设备,可接受多种接触终止选项,包括PCB尾部、线绕和扩展板弯曲。
应用信息:适用于需要高密度连接的电子设备,如计算机、通信设备等。
封装信息:提供多种尾部描述和尺寸,包括PCB尾部和线绕尾部,以及扩展板弯曲选项。
示例零件编号:379-040-520-208,具体配置包括接触件数量、接触代码、接触行和安装选项。
安装选项:包括无安装凸耳、通过安装孔、浮动眼圈和螺纹嵌件等。
订购代码说明:提供了详细的订购代码和注意事项,以确保正确选择所需配置。
379-052-555-203 价格&库存
很抱歉,暂时无法提供与“379-052-555-203”相匹配的价格&库存,您可以联系我们找货
  • 25+102.0568425+12.76498
