621-015-668-530
621-015-668-530
    621 SERIES RIGHT ANGLE D-SUB PLU
621-015-668-530 数据手册
621/622 SERIES D-Sub Connectors: Right Angle, 0.318” (8.08mm) Footprint Features: • • • • • • • • • Two contact rows with 0.318”(8.08mm) footprint, right angle bend 0.109”(2.77mm) contact spacing X 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, 25, or 37 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include threaded hole, two and four prong boardlock for superior retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Ferrite Specs 20dB MIN @30 MHz, 30dB MIN @50 MHz, and 50dB MIN @100 MHz Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 621-025-260-013 SERIES: 621: PLUG (PIN) 622: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 60 - .318" FOOTPRINT CONTACT 68 - .318" FOOTPRINT WITH FERRITE FILTER www.edac.net FLANGE MOUNTING OPTIONS FLANGE MOUNTING OPTIONS: 0 - #4-40 THREADED FIXED STANDOFF 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE 6 - M3 THREADED STANDOFF BOARD MOUNTING FEATURE: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 3 - TWO PRONG BOARDLOCKS 4 - FOUR PRONG BOARDLOCKS 5 - #4-40 THREADED HOLE INSULATOR MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR customerservice@edac.net 621/622 SERIES D-Sub Connectors: Right Angle, 0.318” (8.08mm) Footprint B 8.08 Ø1.10 2-Ø3.20 9.50 2.77±0.13 2.84 #4-40UNC/M3 12.55±0.38 8.36±0.13 2.84 PLUG A B C 2.77±0.13 1.385 P.C.B EDGE RECEPTACLE 6.00±0.25 8.08±0.25 2.84±0.25 9.50±0.25 12.40±0.25 RECOMMENDED P.C.B LAYOUT (FOR PLUG AND RECEPTACLE) 3.18±0.38 A B C 2.77±0.13 NUMBER OF CONTACTS www.edac.net A±0.38mm B±0.25mm 5.80±0.25 8.08±0.25 2.84±0.25 9.50±0.25 12.40±0.25 12.55±0.38 7.90±0.13 2.84 #4-40UNC/M3 3.18±0.38 C±0.13mm C±0.13mm PLUG RECEPTACLE Inch (mm) Inch (mm) Inch (mm) 9 1.213 (30.81) .984 (24.99) .667 (16.92) .643 (16.33) 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.511 (38.38) 37 2.729 (69.32) 2.500 (63.50) 2.182 (55.42) 2.159 (54.84) Inch (mm) customerservice@edac.net
621-015-668-530
物料型号:621/622 系列 器件简介:D-Sub 连接器,直角,0.318英寸(8.08mm)足迹,两排接触点,0.318英寸(8.08mm)足迹,0.109英寸(2.77mm)接触点间距 x 0.112英寸(2.84mm)行间距。 引脚分配:插头和插座接触点设计,带有P.C.尾部端接。 参数特性:包括绝缘材料、接触材料、接触镀层、铁氧体规格、壳体材料、电流额定值、接触电阻、介质耐电压、绝缘电阻、工作温度、插入力和拔出力等详细规格。 功能详解:金属壳体提供EMI/RFI屏蔽,插头壳体凹槽提供接地和额外的配对保持力。 应用信息:设计基于MIL-C-24038、EIA RS-232和RS-449的要求。 封装信息:包括法兰安装选项、D形连接器配对轮廓提供极化等。
621-015-668-530 价格&库存
很抱歉,暂时无法提供与“621-015-668-530”相匹配的价格&库存,您可以联系我们找货
  • 200+31.34519200+4.02436
