TOLERANCE
UNLESS OTHERWISE
SPECIFIED
.X
.XX
.XXX
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
1
ORIGINAL
±0.25
±0.13
±0.05
39.15
25.25
8.36
12.60
33.30
6.10
10°
11.00
NOTES:
MATERIAL:
HOUSING: THERMOPLASTIC POLYESTER, UL94V-0
SHELL: STEEL, Sn or Ni PLATED
CONTACT: COPPER ALLOY SEE ORDERING GUIDE FOR PLATING
OPERATING TEMPERATURE: -55 C ~ 125 C
SIGNAL CONTACT CURRENT RATING: 5A PER CONTACT
SIGNAL CONTACT RESISTANCE: 10mΩ MAX.
INSULATOR RESISTANCE: 5000MΩ min.
DIELECTRIC
WITHSTANDING VOLTAGE: 1000V AC rms
627 COMBO ASSEMBLY
SW REFERENCE NO.:
COMBINATION D-SUB
C.B
DRAWN:
DATE:
DATE:
CHECKED:
COMPLIANT
THIS SERIES FULLY CONFORMS TO
EDAC INC
THE EUROPEAN UNION DIRECTIVES
TORONTO, ONTARIO
CANADA
2011/65/EU FOR RoHS COMPLIANCY.
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
SCALE:
JAN. 01/2019
(IN C.A.D. 1:1)
SHEET
1
OF
4
DRAWING NUMBER:
627-3W3-624-3N1
ISSUE
PART NUMBER:
627-3W3-624-3N1
1
TOLERANCE
UNLESS OTHERWISE
SPECIFIED
.X
.XX
.XXX
ISSUE NUMBER
±0.25
±0.13
±0.05
SW REFERENCE NO.:
COMBINATION D-SUB
C.B
DRAWN:
CHECKED:
COMPLIANT
EDAC INC
TORONTO, ONTARIO
CANADA
1
ORIGINAL
SCALE:
N.T.S
627 COMBO ASSEMBLY
DATE:
JAN. 01/2019
DATE:
SHEET
2
OF
6
DRAWING NUMBER:
627-3W3-624-3N1
ISSUE
PART NUMBER:
627-3W3-624-3N1
1
TOLERANCE
UNLESS OTHERWISE
SPECIFIED
.X
.XX
.XXX
CURRENT RATING /
10A / 2.2
20A / 3.3
30A / 3.7
40A / 4.2
ISSUE NUMBER
±0.25
±0.13
±0.05
A
SW REFERENCE NO.:
COMBINATION D-SUB
C.B
DRAWN:
CHECKED:
COMPLIANT
EDAC INC
TORONTO, ONTARIO
CANADA
1
ORIGINAL
SCALE:
N.T.S
627 COMBO ASSEMBLY
DATE:
JAN. 01/2019
DATE:
SHEET
3
OF
4
DRAWING NUMBER:
627-3W3-624-3N1
ISSUE
PART NUMBER:
627-3W3-624-3N1
1
TOLERANCE
UNLESS OTHERWISE
SPECIFIED
.X
.XX
.XXX
ISSUE NUMBER
±0.25
±0.13
±0.05
SW REFERENCE NO.:
COMBINATION D-SUB
C.B
DRAWN:
CHECKED:
COMPLIANT
EDAC INC
TORONTO, ONTARIO
CANADA
1
ORIGINAL
SCALE:
N.T.S
627 COMBO ASSEMBLY
DATE:
JAN. 01/2019
DATE:
SHEET
4
OF
4
DRAWING NUMBER:
627-3W3-624-3N1
ISSUE
PART NUMBER:
627-3W3-624-3N1
1
很抱歉,暂时无法提供与“627-3W3-624-3N1”相匹配的价格&库存,您可以联系我们找货
