627WC/628WC SERIES
Waterproof D-Sub Connectors: Power Combo, Vertical
Features:
Signal, along with power or coaxial contacts within one connector
Space saving on the PCB and I/O designs
Available in various pin out configurations
Pin and socket contact mating design with P.C. tail and solder cup termination
Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating
retention
Mounting options for panel mount or connector mating include through hole, threaded hole and
threaded standoffs
D-shaped connector mating outline provides polarization
Specifications:
Power Only
Insulator Material
PBT+30% GF, UL 94V-0, Color: Black
Contact Material
Copper Alloy
Contact Plating
Selective Gold (See Ordering Code) over Nickel
Shell Material and Plating
Steel with Ni or Tin Plating
Sealing compound
Epoxy
O-ring Material
Silicone
Current Rating (Power Contacts)
10 amps, 20 amps, 30 amps, 40 amps
Current Rating (Signal Contacts)
Combination
5 amps
Voltage Rating
125 V
Contact Resistance
(Power Contacts)
1 Milliohms maximum
Contact Resistance
(Signal Contacts)
10 Milliohms maximum
Insulation Resistance
5000 megaohms minimum
Dielectric Withstanding Voltage
1000 V AC rms at Sea Level
Operating Temperature
-25°C To +85°C
Mating Cycle
500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating
IP Rating
IP67
Ordering Code:
627W2W2-222-1N2
SERIES:
627: PLUG (PIN)
628: RECEPTACLE (SOCKET)
MOUNTING OPTIONS:
2 - #4-40 UNC THREADED HOLE
5 - #4-40 UNC THREADED HOLE WITH BOARDLOCKS
A - M3 THREADED HOLE
D - M3 THREADED HOLE WITH BOARDLOCKS
CONNECTOR TYPE:
W - WATERPROOF
LAYOUT:
POWER ONLY
COMBINATION
2W2
2WK2
5W1
SIZE 15 CONTACT SHELL
3W3
3WK3
7W2
11W1
SIZE 25 CONTACT SHELL
5W5
9W4
13W3 17W2 21W1
SIZE 9 CONTACT SHELL
8W8
TOTAL NO.OF POWER
TOTAL NO.OF CONTACT
2WK2
MALE FEMALE COMBINATION
CONTACT PLATING THICKNESS:
2 - GOLD FLASH PLATING
1 - 5 MICROINCHES OF GOLD PLATING
3 - 15 MICROINCHES OF GOLD PLATING
6 - 30 MICROINCHES OF GOLD PLATING
TAIL TYPE:
22 - SOLDER CUP
24 - PC TAIL
www.edac.net
SHELL PLATING:
N - NICKEL
T - TIN
CURRENT RATING:
1 - 10A
2 - 20A
3 - 30A
4 - 40A
customerservice@edac.net
627WC/628WC SERIES
Layout:
SHELL SIZE LAYOUT
1(E)
2(A)
3WK3(FEMALE)
3(B)
3WK3(MALE)
5W1
2W2
2WK2(FEMALE)
2WK2(MALE)
3W3
7W2
11W1
9W4
5W5
13W3
21W1
17W2
Straight PCB Power Contacts:
STRAIGHT PCB SOLDER POWER CONTACTS
MALE
FEMALE
17.10
16.90
5.30
ØA
Ø3.6
CURRENT RATING
10A
20A
30A
40A
www.edac.net
5.30
ØA
Ø5.50
Ø5.50
DIMENSION (mm) ØA
1.7
2.8
3.2
3.75
627WC/628WC SERIES
Current Rating:
D(mm):
www.edac.net
10A
2.2
20A
3.3
30A
3.7
40A
4.2
627WC/628WC SERIES
Power Combo D-Sub Connectors: Vertical
Solder Cup Power Contacts:
SOLDER CUP POWER CONTACTS
MALE
FEMALE
21.80
21.80
10.20
10.20
ØA ØB
Ø3.60
CURRENT RATING
10A
20A
30A
40A
ØA ØB
Ø5.50
DIMENSION (mm) ØA
1.7
2.7
3.5
4.6
Ø5.50
DIMENSION (mm) ØB
2.5
3.6
4.4
5.5
Mouting options:
CODE: 2
M3 THREADED HOLE
CODE: A
www.edac.net
WITH BOARDLOCKS
CODE: 5
M3 THREADED HOLE
WITH BOARDLOCKS
CODE: D
很抱歉,暂时无法提供与“627W2W2-324-4ND”相匹配的价格&库存,您可以联系我们找货
