630-009-640-532
630-009-640-532
    弯插
    630 SERIES RIGHT ANGLE D-SUB REC
630-009-640-532 数据手册
629/630 SERIES D-Sub Connectors: Right Angle, 0.406” (10.30mm) Footprint Features: • • • • • • • • • Two contact rows with 0.406”(10.30mm) footprint, right angle bend 0.109”(2.77mm) contact spacing X 0.100”(2.54mm) row spacing Plug and receptacle in 9, 15, 25, or 37 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include two and three prong boardlock for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 629-025-240-033 SERIES: 629: PLUG (PIN) 630: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 025 - 25 CONTACTS 015 - 15 CONTACTS 037 - 37 CONTACTS FLANGE MOUNTING OPTIONS FLANGE MOUNTING OPTIONS: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING BOARD MOUNTING FEATURE: 1 - Ø.120"(Ø3.05MM) THROUGH HOLE 3 - TWO PRONG BOARDLOCKS 4 - THREE PRONG BOARDLOCKS CONTACT CODE: 40 - .406" FOOTPRINT POWER CONTACT MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR www.edac.net customerservice@edac.net 629/630 SERIES D-Sub Connectors: Right Angle, 0.406” (10.30mm) Footprint PLUG 629 SERIES A B C 2.77 2 9 3 10 4 11 2.84 5 12 7 6 14 13 8 15 15 1.10 1.385 2-Ø3.20 11.62 1 B 2.77 10.20 12.55±0.38 8.36±0.13 2.84 SEE FLANGE MOUNTING OPTIONS P.C.B EDGE 1.385 RECOMMENDED P.C.B LAYOUT 6.00±0.25 10.20±0.25 2.84 11.62±0.25 14.60±0.25 (FOR PLUG AND RECEPTACLE) 6.275±0.25 3.18±0.38 R ECEPTACLE 630 SER IES A B C 2.77 12.55±0.38 7.90±0.13 2.84 SEE FLANGE MOUNTING OPTIONS 8 7 15 6 14 5 13 4 12 3 11 2 10 1 9 5.80±0.25 10.20±0.25 2.84 11.62±0.25 14.60±0.25 1.385 www.edac.net A±0.38 B±0.25 6.275±0.25 3.18±0.38 C±0.13 PLUG NUMBER OF CONTACTS Inch (mm) Inch (mm) Inch (mm) 9 1.213 (30.81) .984 (24.99) .666 (16.92) 15 1.543 (39.19) 1.312 (33.32) .994 25 2.088 (53.04) 1.852 (47.04) 1.534 37 2.729 (69.32) 2.500 (63.50) 2.182 C±0.13 RECEPTACLE Inch (mm) .643 (16.33) (25.25) .971 (24.66) (38.96) 1.511 (38.38) (55.42) 2.159 (54.84) customerservice@edac.net
630-009-640-532
物料型号:629/630系列
器件简介:这些是直角D-Sub连接器,具有0.406英寸(10.30mm)的尺寸,适用于9、15、25或37个接触点。
引脚分配:两排接触点,间距为0.109英寸(2.77mm),行间距为0.100英寸(2.54mm)。
参数特性: - 绝缘体材料:热塑性聚酯,UL 94V-0,耐化学腐蚀,颜色为黑色。 - 接触材料:插头(针)和插座(孔)均为铜合金。 - 接触镀层:选择性金层(详见订购代码),尾端镀锡。 - 外壳材料:镀镍钢。 - 电流额定值:3安培。 - 接触电阻:最大25毫欧姆。 - 绝缘电阻:最小5000兆欧姆。 - 耐电压:1000V交流有效值。 - 工作温度:-55°C至+85°C(高温型可达+125°C)。 - 插入力:每个接触位置最大16盎司(4.45牛顿)。 - 拔出力:每个接触位置最小0.28牛顿。
功能详解:金属外壳提供EMI/RFI屏蔽,插头外壳的凹槽提供接地和额外的配对保持力。
应用信息:设计基于MIL-C-24038、EIA RS-232和RS-449的要求。
封装信息:包括板锁和法兰安装选项,适用于面板安装或连接器配对。
订购代码示例:629-025-240-033,包括法兰安装选项和接触点数量。
630-009-640-532 价格&库存
很抱歉,暂时无法提供与“630-009-640-532”相匹配的价格&库存,您可以联系我们找货
  • 1000+18.081711000+2.34668
