630W3W3-140-4NC
630W3W3-140-4NC
    CONN D-SUB RCPT 3POS R/A SLDR
630W3W3-140-4NC 数据手册
629WC/630WC SERIES Waterproof D-Sub Connectors: Power Combo, Right Angle Features: • • • • • • • • Signal, along with power contacts within one connector Space saving on the PCB and I/O designs Available in various pin out configurations Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Mounting options include threaded hole with #4-40UNC or M3, with or without boardlocks D-shaped connector mating outline provides polarization IP Rating: IP67 Specifications: Power Only Insulator Material PBT+30% GF, UL 94V-0, Color: Black Contact Material Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel Shell Material and Plating Steel with Ni or Tin Plating Sealing compound Epoxy O-ring Material Silicone Current Rating (Power Contacts) 10 amps, 20 amps, 30 amps, 40 amps Current Rating (Signal Contacts) Combination 5 amps Voltage Rating 125 V Contact Resistance (Power Contacts) 1 Milliohms maximum Contact Resistance (Signal Contacts) 10 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -25°C To +85°C Mating Cycle 500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating IP Rating IP67 Ordering Code: 629W2W2-240-1N2 SERIES: 629: PLUG (PIN) 630: RECEPTACLE (SOCKET) MOUNTING OPTIONS: 2 - #4-40 UNC THREADED RIVET 3 - #4-40 UNC THREADED RIVET WITH BRACKET & BOARDLOCKS 4 - #4-40 UNC THREADED RIVET WITH BRACKET A - M3 THREADED RIVET B - M3 THREADED RIVET WITH BRACKET & BOARDLOCKS C - M3 THREADED RIVET WITH BRACKET CONNECTOR TYPE: W - WATERPROOF LAYOUT: POWER ONLY COMBINATION SIZE 9 CONTACT SHELL 2W2 2WK2 5W1 SIZE 15 CONTACT SHELL 3W3 3WK3 7W2 11W1 SIZE 25 CONTACT SHELL 5W5 9W4 13W3 17W2 21W1 8W8 2WK2 TOTAL NO.OF POWER CONTACT TOTAL NO.OF CONTACT MALE FEMALE COMBINATION CONTACT PLATING THICKNESS: 2 - GOLD FLASH PLATING 1 - 5 MICROINCHES OF GOLD PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING TAIL TYPE: 40 - PC TAIL www.edac.net SHELL PLATING: N - NICKEL T - TIN CURRENT RATING: 1 - 10A 2 - 20A 3 - 30A 4 - 40A customerservice@edac.net 629WC/630WC SERIES Waterproof D-Sub Connectors: Power Combo, Right Angle R/A PCB Power Contacts: Mounting Options: #4-40 UNC THREADED RIVIT CODE: 2 M3 THREADED RIVIT CODE: A www.edac.net #4-40 UNC THREADED RIVIT WITH BRACKET & BOARDLOCKS #4-40 UNC THREADED RIVIT WITH BRACKET CODE: 3 CODE: 4 M3 THREADED RIVIT WITH BRACKET & BOARDLOCKS CODE: B M3 THREADED RIVIT WITH BRACKET CODE: C customerservice@edac.net 629WC/630WC SERIES Waterproof D-Sub Connectors: Power Combo, Right Angle WATERPROOF POWER COMBO D-SUB 25.00 6.72 2W2/2WK2 5W1 33.30 13.70 2.54 5W5 47.05 47.05 ØD 0 .1 Ø1 30.47 2.54 2.77 6.45 10.25 8.12 2.54 6.45 8.12 30 3. 10.25 33.24 Ø 30 3. ØD Ø 19.39 6.45 10.25 8.12 2.77 13W3 9W4 27.70 2.77 Ø1 .10 2.54 6.45 8.12 ØD 30 3. 5.54 4.16 Ø 30 3. 2.77 7.79 2.54 47.14 29.05 14.51 ØD Ø 10.25 8.38 6.86 10.25 8.12 6.45 10.25 8.12 30 3. D 6.74 7.79 30 3. 14.48 14.48 ØD Ø Ø 30 3. .10 Ø1 Ø 16.62 Ø 47.05 47.05 SHELL SIZE 3(B) 5.54 33.30 19.39 2.77 D 7W2 3W3/3WK3 11W1 21W1 17W2 www.edac.net Ø .30 Ø3 8.12 10.25 10.25 6.45 ØD Ø3 .30 SHELL SIZE 2(A) 2.77 10.25 6.85 6.85 6.45 33.30 Current Rating D(mm) 10.25 8.30 ØD 6.45 8.12 10.25 30 3. Ø3 .30 .10 Ø1 Ø 11.04 2.54 25.00 8.12 SHELL SIZE 1(E) RIGHT ANGLE PCB SOLDER LAYOUT 10A 2.2 20A 3.3 30A 3.7 40A 4.2 customerservice@edac.net
630W3W3-140-4NC
物料型号:629WC/630WC系列
器件简介:这些连接器是防水D-Sub连接器,具有直角设计,可同时传输信号和电源接触,节省PCB和I/O设计空间。
引脚分配:提供多种引脚配置,包括9、15、25接触点的壳体大小。
参数特性: - 绝缘体材料:PBT+30% GF, UL 94V-0, 颜色:黑色 - 接触材料:铜合金 - 接触镀层:选择性金(见订购代码) - 壳体材料和镀层:钢,镀镍或锡 - 密封剂:环氧树脂 - O型圈材料:硅胶 - 电流额定值:电源接触点有10A、20A、30A、40A选项;信号接触点为5A - 电压额定值:125V - 接触电阻:电源接触点最大1毫欧姆,信号接触点最大10毫欧姆 - 绝缘电阻:最小5000兆欧姆 - 耐电压:1000V AC rms在海平面 - 工作温度:-25°C至+85°C - 插拔寿命:30微英寸金镀层500次,金闪镀层50次 - IP等级:IP67
功能详解:金属壳体提供EMI/RFI屏蔽,插头壳体凹槽提供接地和额外的配对保持力。D形连接器配合轮廓提供极性。
应用信息:适用于需要防水和直角设计的电源和信号传输场合。
封装信息:提供带螺纹孔的安装选项,包括#4-40UNC或M3,带或不带板锁。
订购代码示例:629W2W2-240-1N2,其中包含系列编号、安装选项、连接器类型、布局、壳体大小、壳体镀层、接触点总数、接触点镀层厚度、电流额定值和尾部类型。
630W3W3-140-4NC 价格&库存
很抱歉,暂时无法提供与“630W3W3-140-4NC”相匹配的价格&库存,您可以联系我们找货
630W3W3-140-4NC
  • 200+179.27841200+23.22283
