634-M26-363-BN3
634-M26-363-BN3
    634M SERIES RIGHT ANGLE D-SUB RE
634-M26-363-BN3 数据手册
633M/634M SERIES Machined D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint Features: • • • • • • • • High density three contact rows with 0.350”(8.89mm) footprint, right angle bend with machined contacts 0.090”(2.29mm) contact spacing, 0.078”(1.98mm) row spacing Plug and receptacle in 15, 26, 44 or 62 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Grounding features include brackets and four prong boardlock for exceptional retention to P.C. board Mounting options for panel mount or connector mating include through hole, threaded inserts and threaded standoffs D-shaped connector mating outline provides polarization Specifications: Insulator Material PA9T, UL 94V-0, Color: Black or White (PA6T, UL 94V-0 for 62 Contacts) Contact Material Copper Alloy Contact Plating Gold Plating over Nickel All Over Shell Material Nickel Plated Steel Current Rating 5 amps Contact Resistance 10 Milliohms maximum Dielectric Withstanding Voltage 5000 megaohms minimum Insulation Resistance 1000 V AC rms at Sea Level Operating Temperature -55°C To +125°C Ordering Code: 634-M15-263-BN1 SERIES: 633: PLUG (PIN) 634: RECEPTACLE (SOCKET) MACHINED CONTACTS NO. OF CONTACTS: 15 - 15 CONTACTS 26 - 26 CONTACTS 44 - 44 CONTACTS 62 - 62 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 63 - STANDARD CONTACT TAIL LENGTH(3.50 ±0.40) www.edac.net MOUNTING & GROUNDING OPTIONS: 1 - Ø3.05 THRU HOLE 2 - 4-40 UNC INSERT 3 - 4-40 UNC INSERT + STABILIZER PCB + 4 PRONG BOARD LOCK 4 - 4-40 UNC INSERT + STABILIZER PCB + Ø3.20 DIA HOLE 5 - 4-40 UNC STANDOFF + STABILIZER PCB + 4 PRONG BOARD LOCK 6 - 4-40 UNC STANDOFF + STABILIZER PCB + Ø3.20 DIA HOLE SHELL PLATING CODE: N - NICKEL T - TIN MATERIAL CODE: B - BLACK W - WHITE customerservice@edac.net 633M/634M SERIES Machined D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint MOUNTING & GROUNDING OPTIONS CODE - 1 CODE - 2 CODE - 3 THRU HOLE 4-40 UNC INSERT 4-40 UNC INSERT+PCB + BOARDLOCK #4-40 UNC 11.43 15.10 #4-40 UNC Ø 3.05 2.70 3.30 6.25 CODE- 6 4-40 UNC INSERT+PCB + THRU HOLE 4-40 UNC STANDOFF+PCB + BOARDLOCK 4-40 UNC STANDOFF+PCB + THRU HOLE #4-40 UNC 6.25 Ø3 PLUG RECEPTACLE A A B B 11.00±0.30 C 5.80 8.89 10° Ø0.65 E 3.10±0.40 D E 3.10±0.40 D Ø0.65 10.70±0.30 C 6.10 8.89 10° 11.43 11.43 13.97 13.97 0.80 0.80 Ø3 .05 6.25 .2 0 3.30 Ø3 .2 0 6.25 #4-40 UNC 11.43 15.10 11.43 15.10 15.10 11.43 #4-40 UNC 6.00 CODE - 5 6.00 CODE - 4 No. of pos. A B C D E No. of pos. A B C D E 15 30.80 25.00 16.90 12.50 8.30 15 30.80 25.00 16.30 12.50 7.90 26 39.20 33.30 25.25 12.50 8.30 26 39.20 33.30 24.60 12.50 7.90 44 53.05 47.05 38.95 12.50 8.30 44 53.05 47.05 38.40 12.50 7.90 62 69.40 63.50 55.40 12.50 8.30 62 69.40 63.50 54.80 12.50 7.90 www.edac.net customerservice@edac.net 633M/634M SERIES Machined D-Sub Connectors: Right Angle, High Density, 0.350” (8.89mm) Footprint PCB LAYOUT FOR PLUG PCB LAYOUT FOR RECEPTACLE 15 Pos 25.00 25.00 12.50 2.29 PCB EDGE PCB EDGE 26 Pos 26 Pos 33.30 33.30 16.65 2.29 8.59 2.29 44 Pos 44 Pos 47.05 47.05 23.53 2.29 16.60 16.60 .10 Ø1 .20 Ø3 11.43 11.43 Ø 0 3.2 2.54 .10 Ø1 2.54 16.60 8.89 2.54 16.60 8.89 2.29 PCB EDGE PCB EDGE 62 Pos 62 Pos 63.50 63.50 31.75 PCB EDGE .20 Ø3 8.89 2.41 2.54 .10 Ø1 11.43 23.50 8.89 23.50 2.54 31.75 23.50 23.50 .10 Ø1 .20 Ø3 11.43 2.54 23.53 2.54 .20 Ø3 PCB EDGE PCB EDGE 2.54 .10 Ø1 9.73 11.43 11.43 .20 Ø3 2.54 2.54 .10 Ø1 9.73 8.89 2.54 9.73 8.89 2.54 16.65 www.edac.net .20 Ø3 11.43 2.29 .10 Ø1 5.15 5.15 8.89 11.43 .20 Ø3 2.54 .10 Ø1 2.54 2.54 5.15 5.15 8.89 2.54 12.50 2.41 PCB EDGE customerservice@edac.net
634-M26-363-BN3
物料型号:633M/634M系列
器件简介:这些是直角、高密度的D-Sub连接器,具有0.350英寸(8.89mm)的尺寸,有15、26、44或62个接触点。
引脚分配:提供了不同接触点数量的引脚分配表。
参数特性: - 绝缘体材料:PA9T, PA6T - 接触材料:铜合金 - 接触镀层:金镀层覆盖镍 - 外壳材料:镀镍钢 - 电流额定值:5安培 - 接触电阻:最大10毫欧姆 - 介质耐压:至少5000兆欧姆 - 绝缘电阻:在海平面上1000V交流有效值 - 工作温度:-55°C至+125°C
功能详解:包括金属外壳提供EMI/RFI屏蔽,插头外壳提供接地和额外的配对保持力。
应用信息:适用于需要高密度连接的应用。
封装信息:提供了多种安装和接地选项,包括通孔、螺纹嵌件和螺纹立杆。
订购代码示例:634-M15-263-BN1
634-M26-363-BN3 价格&库存
很抱歉,暂时无法提供与“634-M26-363-BN3”相匹配的价格&库存,您可以联系我们找货
634-M26-363-BN3
  • 300+109.73373300+14.23786
