637W/638W SERIES
Waterproof HD D-Sub Connectors: Straight
Features:
High density waterproof D-Sub
0.090”(2.29mm) contact spacing x 0.078”(1.98mm) row spacing
Plug and receptacle in 15, 26 or 44 contact sizes
Pin and socket contact mating design with straight P.C. tail or solder cup termination
Plug shell indents provide grounding and additional mating retention
Mounting options for panel mount or connector mating include threaded inserts or threaded
standoffs
D-shaped connector mating outline provides polarization
Degree of protection: IP67 as per IEC60529
Specifications:
Insulator Material
PBT Thermoplastic with 30% Glass Filled, UL 94V-0 Rated, Black color
Contact Material
Pins and Sockets: Copper Alloy
Contact Plating
Gold Plating over Nickel underplating
Shell Material
Nickel Plated Steel
Epoxy Sealant
Epoxy
O-Ring
Silicone
Current Rating
3 amps Per Contact
Contact Resistance
10 Milliohms maximum
Dielectric Withstanding Voltage
5000 megaohms minimum
Insulation Resistance
1000 V AC rms at Sea Level
Operating Temperature
-25°C To +85°C
Ordering Code:
638-W15-221-012
SERIES:
PLUG . . . . 637
RECEPTACLE . . . . 638
EDAC CODE:
WATERPROOF . . . . W
NO. OF CONTACTS:
15 CONTACT PINS . . . . 15
26 CONTACT PINS . . . . 26
44 CONTACT PINS . . . . 44
CONTACT PLATING:
GOLD FLASH OVER NICKEL . . . . 2
15µ" GOLD OVER NICKEL . . . . 3
30µ" GOLD OVER NICKEL . . . . 6
www.edac.net
MOUNTING OPTION:
2 . . . . #4-40 UNC THREADED HOLE
NOTE:ALL CONNECTORS ARE SHIPPED WITH
#4-40 UNC HEXAGON SCREWS
(Packed Separately)
SHELL OPTIONS:
1 . . . . NICKEL PLATED
INSULATOR COLOR:
0 . . . . BLACK
CONTACT CODE:
21 . . . . PC TAIL
22 . . . . SOLDER CUP TERMINATION
customerservice@edac.net
很抱歉,暂时无法提供与“638-W44-621-012”相匹配的价格&库存,您可以联系我们找货
