305-066-556-508
305-066-556-508
    305 SERIES (.156" (3.96MM) CONTA
305-066-556-508 数据手册
Mounting 0.500 Option 12.70 08-#4-40 Unified Threaded Inserts Contact Detail 556-Extender Board Bend (Code 520 Contacts) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 5.312 134.92 0.330 8.38 Card Slot 5.458 138.63 5.744 145.90 0.460 11.68 A A 305 / 315 / 355 Card Edge Connector Part Number: 305-066-556-508 See Accompanying Page for: • Mounting Options SECTION A-A 0.125 3.18 Point of Contact 6.054 153.77 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-066-556-508
物料型号:305-066-556-508
器件简介: - 305系列卡边连接器,专为电路板与卡槽连接设计。 - 此系列连接器支持多种安装选项,如统一螺纹插入件。
引脚分配: - 引脚间距为0.156英寸(3.96毫米),行间距为0.140英寸(3.56毫米)。 - 卡槽接受厚度为0.054英寸(1.37毫米)到0.070英寸(1.78毫米)的PCB板。
参数特性: - 通过孔直径为0.128英寸(3.25毫米)。 - 浮动眼孔内径为0.116英寸(2.95毫米),外径为0.250英寸(6.35毫米)。 - 浮动量为0.010英寸(0.25毫米)。
功能详解: - 提供了多种代码选项,如x01、x12、x02、x03、x04等,以适应不同的安装和应用需求。 - 包括M3-0.5公制螺纹插入件和#4-40 UNC螺纹插入件。
应用信息: - 用于电路板与卡槽的连接,确保电气连接的稳定性和可靠性。
封装信息: - 该文档是CAD生成的图纸,不得手动修改。 - 图纸和规格是EDAC INC的财产,未经书面许可,不得复制或用于制造或销售设备。
305-066-556-508 价格&库存
很抱歉,暂时无法提供与“305-066-556-508”相匹配的价格&库存,您可以联系我们找货
